audi a4 2004 non starter
raf0468
C?ID=120244
Hi all have a friend who disconected car battery terminal thinking it would reset airbag light, but after re-conect car would turn but not fire..
i took a scan , engine speed sensor no signal fault shows, would this stop car from starting..?
scan as followed..
Monday,19,September,2016,18:11:18:29062
VCDS Version: 16.8.0.1 (x64)
Data version: 20160801 DS254
VIN: WAUZZZ8H24K020737   License Plate: A4 CAB RED
Mileage: 184630km-114723mi   Repair Order:
Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
          67 69 75 76 77
VIN: WAUZZZ8H24K020737   Mileage: 184630km-114723miles
Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
   Part No SW: 8E0 909 518 AL    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT         0003
   Coding: 0011584
   Shop #: WSC 00672 785 00200
   VCID: 7AFE7E4B36AEDF92EC-5120
16706 - Engine Speed Sensor (G28)
            P0322 - 004 - No Signal
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E0 910 155 K    HW: 01J 927 156 JK
   Component: V30 01J 1.8l5VT RdW 3220
   Revision: 00000007    Serial number: 00000001210588
   Coding: 0000001
   Shop #: WSC 04940 001 00001
   VCID: 2D548517B760B82A39-513C
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04499
   Shop #: WSC 00672
   VCID: 65C43D37FF10406A31-5120
            35-00 -  -
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1323
   Coding: 00100
   Shop #: WSC 00672
   VCID: 60CA2C23E0322542C2-5120
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 00001
   Shop #: WSC 00672
   VCID: 3564AD770F30F0EA41-4AE6
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 B
   Component: Airbag 8.4EC        2015
   Coding: 0011104
   VCID: 397CA1477328148AA5-513C
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01011
   Shop #: WSC 00672
   VCID: 4380C3AF51E45E5AFF-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8H0 920 950 G
   Component: KOMBI+WEGFAHRS. RB4 D22
   Coding: 00401
   Shop #: WSC 00586
   VCID: 306A9C63F052D5C212-5120
   WAUZZZ8H24K020737     AUZ6Z0D0009531
01039 - Coolant Temperature Sensor (G2)
            30-00 - Open or Short to Plus
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8H0 951 178
   Component: Innenraumueberw.   0411
   Coding: 00001
   VCID: 6FE85F1F2DEC8A3A4B-5120
01350 - Alarm via Theft Warning System; Rear
            43-00 - Closed
01839 - Transceiver Module 1 for Interior Monitoring (G303)
01349 - Alarm via Theft Warning System; Front
            43-00 - Closed
01838 - Transceiver Module 2 for Interior Monitoring (G305)
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8H0 959 433 F
   Component: Komfortgerát T3B    3220
   Coding: 06795
   Shop #: WSC 00672
   VCID: 3778A77F153C02FA53-4B00
   Subsystem 1 - Part No: 8H2959802
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8H2959801
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
10 Faults Found:
            49-00 - No Communications
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -  -
            37-10 - Faulty - Intermittent
            37-00 - Faulty
   Part No: 8E0 035 186 M
   Component: concert II  GRO    0001
   Coding: 13001
   Shop #: WSC 00672
   VCID: 316C9967FB58DCCA1D-4B00
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            36-00 - Open Circuit
End-------------------------(Elapsed Time: 05:38)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
If no signal from G28, engine will not start.
Gone But Not Forgotten
Clear DTC and log the RPM ref during cranking in VCDS.
Sometimes after a battery is disconnected, it creates this code and stops the ECU from starting in this controller series 8E0.
Recoding the ECU may also net a solution.
If no RPM signal is seen replace the G28 after verifying the wiring and existing sensor with a meter.
If the signal is present and wiring is good.......... change the engine controller J220.
raf0468
C?ID=120244
thanks for response.. i cleared code several times , but as i turn key engine cranks the fault code re-appears..
ive looked in measuring blocks when cranking engine speed is 0
hes going to go and get speed sensor checked first..
thanks..
raf0468
C?ID=120244
a little update..
new sensor fitted by garage , they say car ran for ten minutes but was running rough and stalled and never fired up again.
i was asked by my friend to have another look with vcds , speed sensor now working signal was present,engine was turning very lazy.
garage have advised him need to check timing ,compression, etc..
my friend cant believe his luck by disconnecting battery terminal its gone to this.
MartinsX
Riga, Latvia
C?ID=268515
Charge battery first.
Autoscan after replaced G28?
