Mk7 GSW disabling DRL
nacg8or
The Windy City
C?ID=106971
I am trying to disable the DRLs but unlike my Mk5 Rabbit where there was a bit you could uncheck in the 09-Cent. Elect. controller, I don't see that here. Is there any way of doing it on the new Mk7s?
I also noticed, when looking through the 17-Instruments controller that Byte 4, Bit 7 is checked (AWD installed) and this is not a awd car. Is there a reason that would be checked?
nacg8or: Hello. Yes, as you have already observed, the lighting stuff on a mk7 is managed very differently to your mk5!. In your mk7, these facilities are still controlled by the 09-Cent. Elect. module (this forum tends to use the term BCM for this controller), but instead of using the Byte/Bits in the coding string, the swiches have been embedded into the module's adaptation channels. In fact, if you look at the admaps for the control modules on your mk7, you will be impressed by the total number of adaption channels that the car has - it's about 3,500 in my modestly equipped mk7!
So, back to your question. If you just want to disable the DLRs (incidentally, you should check that doing this is legal in your local area before making the alteration), then try the following:
1. Select 09 - Central Elect control module
2. Select Security Access - 16 from the "Open Controller" screen
3. Enter the magic number 31347 and return to the "Open Controller" screen
4. Select Adaptation - 10 from the "Open Controller" screen
5. Enter ENG115833 into the search box and from the pull-down button select IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag
6. Change setting to not active (see picture below),
PS: The tweak instructions above will permanently remove DRLs. Another, perhaps more elegant method of doing something similar is to enable a DRL switch on the MENU screen that allows the driver to choose which mode to use (i.e. DRL-on, of DRL-off). If you prefer this alternative, then see the instructions HERE
nacg8or
The Windy City
C?ID=106971
Thanks for the info Don. I also looked at the multi function display and noticed you couldn't control DRLs from there either but if there is a way of adding it to the menu, that is great. I did look briefly at the adaptation channels and you need several hours to go through all that. Lol. I will take a look at your suggestions tomorrow and see how that goes.
As far as my post regarding the fog light installation from the other thread, my car is definitely not equipped with a BCM that supports front fog lights. I saw that indicated in the Central Electrics controller, and that is unfortunate. It is odd that you can enable the rear fog light if you have tail lights that have it but you need an upgraded BCM to run front fog lights.
nacg8or: hm............. how did you deduce that the BCM can't accommodate front fog lights? Can you post-up an autoscan please?
nacg8or
The Windy City
C?ID=106971
I was trying to post a snapshot image of the module for the front fogs not being supported but can't seem to get it to work. At any rate, Byte 7 in the 09 module has no bit 3 check box and the text reads "Front fog lights are NOT supported by this Contol Module".
That said, here is the auto scan.
Sunday,18,September,2016,10:10:12:27338
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
Workshop Code: 444 12345 054321
VIN: 3VWA17AU0HM505098   License Plate:
Mileage: 471km-292mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWA17AU0HM505098   Mileage: 471km-292miles
Address 01: Engine (J623-CXBA)       Labels: None
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 091100122424002F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001003
   ROD: N/A
   VCID: 44A99EAACFF11562CA-8010
No ASAM data for: "EV_ECM18TFS0208V0906264K" (VW37)
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 51656000000540
   Coding: 04FA6AA1242009714077020981CB2920562490024081943400430050C00203
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 75CF336ED4ABFCEA8D-8020
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 B    HW: 5GM 907 426 B
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 02020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X.rod
   VCID: 47B389A6FEC73E7A2F-8012
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 T    HW: 5Q0 937 087 T
   Revision: --------    Serial number: 8658190716012T
   Coding: 000008424041804169E44000000407001000000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 4CB9B68AE7A1DD2202-8018
   Component: WWS    160804  043 0581
   Serial number:         160807202350
   Serial number: 003GCR056C61
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000005H1GFE
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 001 606 16
   Serial number: 357000000000B6A44C1K
   Subsystem 3 - Part No SW: -----------    HW: 480 001 606 16
   Serial number: 3580000000019B19FB1V
   Subsystem 4 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 3510002C320FC4C3015.
   Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3520002AD21160C1309R
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 16
   Serial number: 3550002AD20EDB6500BE
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 16
   Serial number: 3560002AD209E9E1B07K
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160713400290
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3A55E052BD355392A0-806E
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BB41102A180CF0502086A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 266D2422598DC772F4-8072
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2265
   Revision: --------    Serial number: 18061610800990
   Coding: 0101000830085900FB000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07025
   ROD: EV_GatewConti.rod
   VCID: 7BDB2556F28FAA9AFB-802E
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160000950270106196
   Coding: 30FFFF
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 150716060501QX
   Coding: 003003200000020000000000
   VCID: 41A797BED0E3004AE1-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000013355359
   Coding: 011000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0102
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: 45AF83AEC4CB2C6ADD-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 120716060506KM
   VCID: 40A192BADBE90942EE-8014
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000013085791
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730200FF00000051220001001808009F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D7FDB0E7C7BF42A35-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW00TZA
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43AB9DB6CAFF125AF3-8016
End-------------------------(Elapsed Time: 02:26)--------------------------
In addition, I'm getting a "No ROD file found" message for
EV_ECM18TFS0208V0906264K 001003 (VW 37). I just updated VCDS to the latest version this morning.
Nic
Brand new 2017 model car..... ;)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We will likely publish an update shortly and I've made some additions so that most modules will be covered with that new data version. :) Thanks for reporting this, your feedback is much appreciated.
nacg8or
The Windy City
C?ID=106971
You're welcome. I appreciate all the help you guys provide.
Sebatian: guten Morgen. A question please - why does the second setting descriptor in my picture (post #2) incorrectly identify "daytime running lights" when this setting applies low-beams as DRLs?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please double check that with VCDS 16.8.2 or newer once it's out and let us know...
nacg8or
The Windy City
C?ID=106971
This worked perfectly. My DRLs are disabled but can activate them any time from the multi function display.
I've made a few other changes from info found elsewhere namely the ability to open and close windows via the key fob. I'm still trying to see if I can get the passenger mirror to dip when going in reverse. I'm not sure if this varies between AT and MT cars because the tweaks I've made didn't work but I'll have to check again. Another tweak I need to work on is the hatch pop via the fob. I'm not sure why VW removed the button inside the car to pop the hatch either.
^^^^^ nacg8or: I'm pleased that the tweak was successful- well done.
There are lots of examples on different forums for how to implement the mirror reverse tweak, so I've no doubt that you will easily find these instructions. Just a word of caution though regarding this tweak - it stands to reason that in order for this function to work correctly, the car needs to remember the position of the mirror in the forward direction (so that it returns where it started). The mechanism that the mk7 uses to do this is the inclusion of a memory module in the mirror system. NOT ALL MK7S HAVE THIS MEMORY MODULE! What I understand happens when the memory module isn't installed and the mirror dip tweak is implemented is that it either doesn't work at all, or if it does work, the return position of the mirror isn't correct (i.e. the passenger-side mirror returns to different poitions when the car moves forward).
So, before you implement the tweak, I suggest that you go to the Advanced Measuring Values area for the passenger door control module (@ address hex52) and then tick the boxes shown in the picture below. If the memory module is installed, you should see the values shown on the right-side of the picture (note: the X/Y coordinates might differ - but they shouldn't be "255". However, the last two "Actual" entries must be the same as shown)
nacg8or
The Windy City
C?ID=106971
Thanks for the info Don. I guess this tweak isn't going to work because this
[/URL][/IMG]
Oh well
Nic
