;SW:8K5-907-551-G HW:4G0-907-551-A --- Engine
;Component:3.0l V6 TFSIH07 0006, Coding:1A250034052600060000
;EV_ECM30TFS0218K5907551G,001006,EV_ECM30TFS0218K5907551G.rod
;Tuesday,11,September,2018,18:40:52:29015
; Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: BA3731BE3D2E4E94A9-80EE
Group,Description,Actual
IDE00019,Voltage terminal 30,14.015, V
IDE00021,Engine speed,698, /min
IDE00025,Coolant temperature,97, °C
IDE00078,Time since engine start,1658, s
IDE00083,Throttle valve position (absolute),11.4, %
IDE00084,Absolute load value,29, %
IDE00085,Normed load value,8.6, %
IDE00086,Accelerator position,15, %
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00167,Exhaust temperature 1 bank 1,451.1, °C
IDE00168,Exhaust temperature 1 bank 2,449.2, °C
IDE00190-ENG103225,Charge air pressure specified value-MAP_SP,307.79, hPa
IDE00349,Throttle valve position: normed,2, %
IDE00400-ENG100810,Intake manifold Runner Control (IMRC): activation-LV_PORT_DEAC,00000001 ,
IDE00401-ENG111851,Intake manifold Runner Control (IMRC): acknowledgment-FAC_PORT_DEAC[0],0.99998,
IDE00402-ENG100810,Intake manifold runner control 2: activation-LV_PORT_DEAC,00000001 ,
IDE00403-ENG111852,Intake manifold runner control 2: acknowledgment-FAC_PORT_DEAC[1],0.99998,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown,
IDE00474,Ambient air pressure,97, kPa
IDE00495,Calculated oil temperature,84,
IDE00496,Activation of oil pressure switch valve,Low pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside air temperature,31, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.999 Lambda / -0.008 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.795, V
IDE00565,Current of oxygen sensor bank 2 sensor 1 (broadband sensor),0.994 Lambda / -0.035 mA,
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.795, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.001, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing memory,19119, km
IDE00588,Fuel tank fill level,40.0, %
IDE00589,Fuel pressure,3570, kPa rel
IDE00592,Oxygen sensor control status,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,9.0, Degrees
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 / B2S1 B2S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,0.8, %
IDE00598,Long term adaptation of mixture formation bank 2,0.8, %
IDE00601,Monitoring status since erasing memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,-3.1, %
IDE00605,Short term adaptation of mixture formation bank 2,-3.9, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE01266-ENG104168,Coolant shut-off valve-STATE_VLV_HEAT_TM,3,
IDE01369-ENG103168,Intake manifold runner control (IMRC): offset closed-V_PORT_1_OFS,0.000, V
IDE01371-ENG103327,Intake manifold runner control (IMRC) 2: offset closed-V_PORT_2_OFS,0.010, V
IDE01650,Throttle valve position 2,11, %
IDE01680-ENG99798,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-STATE_EOL_CPS,2,
IDE01880,Accelerator position 2,15, %
IDE01986-ENG99224,Contact for tank leak test-LV_DIAG_SMT_SWI_AV_NVLD,00000001 ,
IDE02119,Long term adaptation of oxygen sensor control: bank 1,-5.5, %
IDE03189-MAS00106,Number of prevented stop processes (statistics)-Year,2000,
IDE03189-MAS00107,Number of prevented stop processes (statistics)-Month,0,
IDE03189-MAS00108,Number of prevented stop processes (statistics)-Day,0,
IDE03189-MAS00109,Number of prevented stop processes (statistics)-Hours,0,
IDE03189-MAS00110,Number of prevented stop processes (statistics)-Minutes,0,
IDE03189-MAS00111,Number of prevented stop processes (statistics)-Seconds,0,
IDE03189-ENG99013,Number of prevented stop processes (statistics)-Ambient air density,0,
IDE03189-ENG28432,Number of prevented stop processes (statistics)-Bremsunterdruck km Stand,0, km
IDE03189-ENG28396,Number of prevented stop processes (statistics)-Bremsunterdruck Zähler,0,
IDE03189-ENG28317,Number of prevented stop processes (statistics)-Gemischadaption km Stand,0, km
IDE03189-ENG28438,Number of prevented stop processes (statistics)-Gemischadaption Zähler,0,
IDE03189-ENG102773,Number of prevented stop processes (statistics)-Low brake pressure,1,
IDE03189-ENG102617,Number of prevented stop processes (statistics)-Mixture adaptation,4,
IDE03189-ENG98900,Number of prevented stop processes (statistics)-Poor start detection,3,
IDE03189-ENG102190,Number of prevented stop processes (statistics)-Regeneration operation,5,
IDE03189-ENG28313,Number of prevented stop processes (statistics)-Regenerationsbetrieb km Stand,0, km
IDE03189-ENG28320,Number of prevented stop processes (statistics)-Regenerationsbetrieb Zähler,0,
IDE03189-ENG28486,Number of prevented stop processes (statistics)-Schlechtstarterkennung km Stand,0, km
IDE03189-ENG28389,Number of prevented stop processes (statistics)-Schlechtstarterkennung Zähler,0,
IDE03189-ENG98917,Number of prevented stop processes (statistics)-Sporadic function restriction,2,
IDE03189-ENG28277,Number of prevented stop processes (statistics)-Sporadische Funktionsverhinderung km Stand,0, km
IDE03189-ENG28378,Number of prevented stop processes (statistics)-Sporadische Funktionsverhinderung Zähler,0,
IDE03189-ENG28363,Number of prevented stop processes (statistics)-Umgebungsluftdichte km Stand,0, km
IDE03189-ENG28444,Number of prevented stop processes (statistics)-Umgebungsluftdichte Zähler,0,
IDE03190-MAS00106,Number of requested start processes (statistics)-Year,2000,
IDE03190-MAS00107,Number of requested start processes (statistics)-Month,0,
IDE03190-MAS00108,Number of requested start processes (statistics)-Day,0,
IDE03190-MAS00109,Number of requested start processes (statistics)-Hours,0,
IDE03190-MAS00110,Number of requested start processes (statistics)-Minutes,0,
IDE03190-MAS00111,Number of requested start processes (statistics)-Seconds,0,
IDE03190-ENG28432,Number of requested start processes (statistics)-Bremsunterdruck km Stand,0, km
IDE03190-ENG28396,Number of requested start processes (statistics)-Bremsunterdruck Zähler,0,
IDE03190-ENG102773,Number of requested start processes (statistics)-Low brake pressure,2,
IDE03190-ENG102966,Number of requested start processes (statistics)-Motortemperatur zu groß,1,
IDE03190-ENG28347,Number of requested start processes (statistics)-Motortemperatur zu groß-km Stand,0, km
IDE03190-ENG28268,Number of requested start processes (statistics)-Motortemperatur zu groß-Zähler,0,
IDE03190-ENG101832,Number of requested start processes (statistics)-Motortemperatur zu klein,0,
IDE03190-ENG28293,Number of requested start processes (statistics)-Motortemperatur zu klein-km Stand,0, km
IDE03190-ENG28308,Number of requested start processes (statistics)-Motortemperatur zu klein-Zähler,0,
IDE03190-ENG09305,Number of requested start processes (statistics)-SCR,4,
IDE03190-ENG29827,Number of requested start processes (statistics)-SCR-km Stand,0, km
IDE03190-ENG29826,Number of requested start processes (statistics)-SCR-Zähler,0,
IDE03190-ENG28366,Number of requested start processes (statistics)-Wegfahrsperre fordert Wiederholstart,3,
IDE03190-ENG28384,Number of requested start processes (statistics)-Wegfahrsperre km Stand,0, km
IDE03190-ENG28475,Number of requested start processes (statistics)-Wegfahrsperre Zähler,0,
IDE03582-ENG102532,Temperature sensor for engine temperature management-TCYLH_OUT_TM,102.8, °C
IDE03583-ENG103498,Engine shut-down overrides-Binary 8 Bit,00000000 ,
IDE03584-ENG103498,Engine starting requirements-Binary 8 Bit,00000000 ,
IDE03585-ENG100821,System status for the start/stop function master-STATE_STST_MNG_SYS,0,
IDE03586-ENG99620,Starting requirements for active participants-Binary 16 Bit,00000000 00000000 ,
IDE03587-ENG99620,Stop overrides for active participants-Binary 16 Bit,00000000 00000000 ,
IDE03588-ENG99620,System malfunctions for active participants start/stop-Binary 16 Bit,00000000 00000000 ,
IDE03589-ENG103498,Error status for start-stop related sensors-Binary 8 Bit,00000100 ,
IDE03816-ENG125310,Exhaust flap bank 1-LV_EF[0],00000000 ,
IDE04000,Intake air temperature sensor,IAT 11:52, °C
IDE04001,Turbocharger intake pressure sensor,TCA_PRESS: 29, kPa
IDE04002,Charge press. ctrl.,BP_A act:30 kPa / BP_B act:30 kPa,
IDE04003,Charge air temperature sensor,B1S1:55 °C / B2S1:55 °C,
IDE04083,Coolant temperatures, 1:97 °C / 2:103 °C,
IDE04324,Long term adaptation of oxygen sensor control: bank 2,-2.3, %
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04491-ENG99395,Temp sensor for fuel tank leakage diagnosis-TAM_SMT_NVLD,30.00, °C
IDE04637-ENG100681,Engine temperature management actuator-PWM_CWP_MAIN_TM,99.8, %
IDE04638-ENG103447,Transmission coolant valve-LV_VLV_GB_HEAT_OPEN_TM,00000000 ,
IDE04814-ENG103396,Transmission oil cooler valve-LV_VLV_GB_COOL_OPEN_TM,00000000 ,
IDE05749-ENG103225,Charge air pressure 2: specified value-MAP_SP,305.88, hPa
IDE06386-ENG112967,Oil level: static measurement-LOIL_STAT,22.4375, mm
IDE06387-ENG101747,Oil level: last valid dynamic value-LOIL_DYN,13.5000, mm
IDE06388-ENG112972,Oil level: condition for static measurement fulfilled-LV_LOIL_STAT_VLD,00000000 ,
IDE06389-ENG103837,Oil level: maximum value-LOIL_MAX_SRV_INTL,19.0625, mm
IDE06390-ENG102184,Oil level: minimum value-LOIL_MIN_SRV_INTL,13.0000, mm
IDE06391-ENG103698,Oil temperature sensor 2-Oil temperature,85, °C
IDE06392-ENG112991,Oil temperature sensor 2: raw value-TOIL_SRV_INTL_RAW,85, °C
IDE06393-ENG102180,Oil level: dynamic average value-LOIL_DYN_TMP,0.0000, mm
IDE06567-ENG122706,Start-stop function deactivation frequency counter-Strt_Stop_Stc_ct_Deac_Strt_Stop_Swt_VW,0,
IDE06568-ENG122707,Stop prevention by driver frequency counter-Strt_Stop_Stc_ct_Stop_Not_Req_VW,0,
IDE06569-ENG121095,Vehicle stopped frequency counter-CTR_STST_STC_ENG_VEH_STOP,0,
IDE06610-ENG121096,Vehicle standstill with stop frequency counter-CTR_STST_STC_VEH_STOP,0,
ENG102981,AC compressor: speed increase,00000000 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103226,Accelerator pedal sender 1: voltage ratio,0.757, V
ENG103029,Accelerator pedal sender 2: voltage ratio,0.381, V
ENG103042,Accelerator pedal sender: learned end stop,0.000, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,0.09579,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG103654,Activation: throttle valve positioner,-13.934, %
ENG101818,Actual fuel rail pressure,35698.3, hPa
ENG103323,Additional water pump,00000000 ,
ENG101828,Air mass,10.84375, kg/h
ENG100339,Air mass integral: actual,5.44, kg
ENG99216,Air mass integral: specified,7.03, kg
ENG104264,Alternator load,450, W
ENG99319,Ambient pressure,975.61, hPa
ENG103910,Ambient temperature,27.00, °C
ENG101830,AMP_ENVD,976.4219, hPa
ENG101473,AR_RED_AD_ADD_MMV,-0.0268, cm²
ENG102979,AR_RED_AD_FAC,0.000, %
ENG98377,As,CCP on PT,
ENG103165,Battery voltage,14.015625, V
ENG100763,Brake Light Switch,00000000 ,
ENG103466,Brake test switch,00000000 ,
ENG103031,Camshaft adjustment: inlet phase: bank 1,-0.750, °
ENG99898,Camshaft adjustment: inlet phase: bank 2,0.375, °
ENG99173,Camshaft adjustment: inlet: bank 1/2: specified,127.875, °
ENG100104,Camshaft adjustment: inlet: bank 1: actual,0.000, °
ENG102242,Camshaft adjustment: inlet: bank 1: duty cycle,0.000, %
ENG100701,Camshaft adjustment: inlet: bank 2: actual,0.375, °
ENG101781,Camshaft adjustment: inlet: bank 2: duty cycle,0.000, %
ENG101975,CAN messages: status for ,0.000, s
ENG99096,CAN messages: status for AC,0, s
ENG103515,CAN messages: status for ,0.000, s
ENG103345,CAN messages: status for airbag,0.0, s
ENG99384,CAN messages: status for battery energy management,0.0, s
ENG101540,CAN messages: status for dash panel insert,0.0, s
ENG100217,CAN messages: status for electronic ignition lock,0, s
ENG103239,CAN messages: status for electronic parking brake,0.000, s
ENG104136,CAN messages: status for gateway,0, s
ENG101579,CAN messages: status for gearbox,0.000, s
ENG100306,CAN messages: status for steering column module,0, s
ENG99220,CAN messages: status for trailer recognition,0, s
ENG103849,Cat. ageing: bank 1: actual,0.01563,
ENG101785,Cat. temperature: bank 1,450.0375, °C
ENG100075,Cat. temperature: bank 2,447.9750, °C
ENG101837,Cause of irreversible brake cut-in disable,0,
ENG103793,Cause of irreversible disable (),0,
ENG101960,Cause of reversible brake cut-in disable,0,
ENG102021,Cause of reversible disable (),393232,
ENG103399, shut-off criterion: switch position,0,
ENG100798, shut-off criterion: switch position,00000001 ,
ENG99361, shut-off criterion: switch position,00000000 ,
ENG100479,Charge air cooling water pump: actual duty cycle,50.000000, %
ENG102583,Charge air cooling water pump: result,OK,
ENG99256,Charge air cooling water pump: specified duty cycle,88.000, %
ENG102333,Charge air cooling water pump: status,00000000 00000101 ,
ENG103690,Charge pressure control: charge press.before throttle valve,292.20, hPa
ENG125285,CL_MMV_ENVD,0.000,
ENG125284,Co_TE_t_Hd_Sp_Fil_Rot_VW,-48.00, °C
ENG100992,Compressor regulating flap: activation,15.405, %
ENG100398,Consumption equivalent: substitute value,0.00000016,
ENG102996,Coolant temperature,97.50, °C
ENG99145,Coolant temperature (unfiltered),97.50, °C
ENG100260,Coolant temperature at engine start,29.25, °C
ENG101525,Coolant temperature: specified,90.00, °C
ENG102214,CPU_LOAD,44.8, %
ENG125286,CRLC_BAS_DIAGCPS,0.00,
ENG125287,CRLC_COR_DIAGCPS,0.00,
ENG102284,CRU_SWI_POS_CAN,1,
ENG102136,Cruise control: switch settings,0,
ENG101127,CTR_CDN_OBD_RBM,1301,
ENG103696,CTR_CDN_RBM_CAT_1,1301,
ENG100331,CTR_CDN_RBM_CAT_2,1301,
ENG99655,CTR_COMP_RBM_CAT_1,2142,
ENG103187,CTR_COMP_RBM_CAT_2,2154,
ENG112956,CTR_END_SWI_CWP_FCT_CUS,2146,
ENG100536,CTR_IGK_CYC_RBM,3688,
ENG102005,CTR_KM_CAN,45761, km
ENG102445,CTR_MIS_DC_MMV_CYL[0],1,
ENG99590,CTR_MIS_DC_MMV_CYL[1],0,
ENG99754,CTR_MIS_DC_MMV_CYL[2],1,
ENG102025,CTR_MIS_DC_MMV_CYL[3],0,
ENG101583,CTR_MIS_DC_MMV_CYL[4],1,
ENG102075,CTR_MIS_DC_MMV_CYL[5],0,
ENG102250,CTR_MIS_TOT_NVMY,3267,
ENG125288,CTR_NR_DIAG_SMALL_LEAK_NVLD,0,
ENG125289,CTR_NR_DIAG_TGT_NVLD,255,
ENG125290,CTR_NR_RESP_REP_COMC_NVLD,138,
ENG125291,CTR_NR_RESP_REP_COMC_NVLD_ENVD,138,
ENG112957,CTR_SAF_DIAG_LAM_COR,180,
ENG121095,CTR_STST_STC_ENG_VEH_STOP,0,
ENG121096,CTR_STST_STC_VEH_STOP,0,
ENG100764,CTR_SUM_SRV_INTL,0.00,
ENG125292,CTR_VLD_CAT_GAP_COR_AFL[1],0,
ENG125293,CTR_VLD_CAT_GAP_COR_AFL[2],0,
ENG125294,CTR_VLD_CAT_GAP_COR_AFR[1],0,
ENG125295,CTR_VLD_CAT_GAP_COR_AFR[2],0,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,95,
ENG100943,Cycle flags: (completed cycles): lambda probes: ,24,
ENG103229,Cycle flags: (completed tests): camshaft adj.: knock sensors,207,
ENG99495,Cycle flags: (completed tests): lambda adaption:,40,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,24,
ENG102526,Cycle flags:(completed tests):clutch: brake:idle controller,169,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG100989,DELTA_CRK_CYL_LAM_1,0, °
ENG99927,DELTA_CRK_CYL_LAM_2,0, °
ENG102657,DIAG_INST[0],no_error,
ENG99120,DIAG_INST[1],no_error,
ENG103260,DIAG_INST[2],no_error,
ENG99710,DIAG_INST[3],no_error,
ENG102667,DIAG_INST[4],no_error,
ENG102739,DIAG_INST[5],no_error,
ENG100162,DIAG_INST[6],no_error,
ENG99103,DIAG_INST[7],no_error,
ENG99261,DIAG_INST[8],no_error,
ENG103622,DIAG_INST[9],no_error,
ENG99472,DIST_DTC_CLR,19119, km
ENG103766,DIST_ENG_RUN_IN,45640178.3, m
ENG100531,DIST_ST,4.56363e+007, m
ENG121099,EFF_CAT_DIAG[0],0.01563,
ENG103712,EFPPWM_MIN_AD,22.574, %
ENG104044,Engine load,8.203125, %
ENG103936,Engine mount 1: right (only vehicles with engine mounting),00000000 ,
ENG102957,Engine mounting 2: left (only vehicles with engine mounting),00000000 ,
ENG102494,Engine speed: actual,704, /min
ENG99273,Engine speed: specified,700, /min
ENG104182,Engine temperature: thermostat diagnosis,90.00, °C
ENG100261,Engine torque,29.96875, Nm
ENG102783,Engine: operating status,IS,
ENG101147,ENVD_0_CRU_ACT_MON,0,
ENG102968,ENVD_0_GS_INC_MON,0,
ENG99874,ENVD_0_MAF_NOT_PLAUS_MON,0,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG102888,ENVD_0_MSR_MON,0,
ENG99438,ENVD_0_N_MAX_MON,0,
ENG100658,ENVD_0_TQI_MON,0,
ENG102106,ENVD_1_CRU_ACT_MON,0,
ENG103210,ENVD_1_GS_INC_MON,0,
ENG101907,ENVD_1_MAF_NOT_PLAUS_MON,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG102767,ENVD_1_MSR_MON,0,
ENG100092,ENVD_1_N_MAX_MON,0,
ENG99136,ENVD_1_TQI_MON,0,
ENG103816,ENVD_2_CRU_ACT_MON,0,
ENG100080,ENVD_2_GS_INC_MON,0,
ENG101890,ENVD_2_MAF_NOT_PLAUS_MON,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG100185,ENVD_2_MSR_MON,0,
ENG103232,ENVD_2_N_MAX_MON,0,
ENG101780,ENVD_2_TQI_MON,0,
ENG103490,ENVD_3_CRU_ACT_MON,0,
ENG102482,ENVD_3_GS_INC_MON,0,
ENG102566,ENVD_3_MAF_NOT_PLAUS_MON,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG101949,ENVD_3_MSR_MON,0,
ENG100841,ENVD_3_N_MAX_MON,0,
ENG99810,ENVD_3_TQI_MON,0,
ENG100532,ENVD_CAM_IN_1,0,
ENG101418,ENVD_CAM_IN_2,0,
ENG99852,ENVD_CRK,0,
ENG99600,ENVD_EEPROM,0,
ENG102271,ENVD_KNK_RTD_LIM,0,
ENG101912,ENVD_LSL_UP_1,0,
ENG101170,ENVD_LSL_UP_2,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: ,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG102855,ESI (extended service intervals) oil level,68.3750, mm
ENG101942,ESI (extended service intervals) oil warning threshold,51.3750, mm
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG103178,FAC_H_RNG_LAM_AD[2],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],1.205, %
ENG101035,FAC_L_RNG_LAM_AD[2],0.458, %
ENG112958,FAC_LAM_CHK_DIAG_MV[1],5.135, %
ENG112959,FAC_LAM_CHK_DIAG_MV[2],3.954, %
ENG100298,FAC_LAM_CP,-3.030, %
ENG112960,FAC_LAM_DIF_SAV_TOL_SAE,15.001, %
ENG100108,FAC_LAM_LIM[1],-2.873, %
ENG100987,FAC_LAM_LIM[2],-3.284, %
ENG112961,FAC_LAM_MAX_DIAG_SAV_FIL[1],4.837, %
ENG112962,FAC_LAM_MAX_DIAG_SAV_FIL[2],3.571, %
ENG99722,FAC_LAM_TCO_A[1],-11.978, %
ENG99699,FAC_LAM_TCO_A[2],-11.978, %
ENG103521,FAC_LAM_TCO_B[1],-12.131, %
ENG99478,FAC_LAM_TCO_B[2],-11.873, %
ENG103641,FAC_LAM_TCO_C[1],-13.045, %
ENG102483,FAC_LAM_TCO_C[2],-12.032, %
ENG101578,FAC_LAM_TCO_D[1],-9.894, %
ENG103438,FAC_LAM_TCO_D[2],-9.338, %
ENG100685,FAC_LAM_TCO_E[1],-9.894, %
ENG103729,FAC_LAM_TCO_E[2],-9.338, %
ENG103307,FAC_MAF_MAX,0.11435,
ENG103161,Fan control relay: auxiliary water pump,00000000 ,
ENG99630,Fan control relay: fan run-on,0,
ENG101437,Fan request from air conditioner,0.0, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG101210,FTL_CAN,25, l
ENG104248,Fuel consumption signal,52052, µl
ENG99715,Fuel pump: activation,26.825, %
ENG100489,Fuel pump: actual fuel pressure,5404.9, hPa
ENG101667,Fuel pump: adaption value,-9.067, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.047, %
ENG100409,Fuel rail pressure: specified,35862.8, hPa
ENG100250,Fuel regulating valve: duty cycle,9.718, %
ENG101692,Fuel supply system: high-pressure regulator,31.84, hPa
ENG100362,FUEL_MASS_AD,5.45, mg
ENG103903,FUEL_MASS_AD_ENVD,4.710938,
ENG103916,FUEL_MASS_REQ_I_CTL_ENVD,-4.710938,
ENG103559,FUP_EFP_ENVD,4773.4, hPa
ENG103553,FUP_EFP_ST_H,173888, hPa
ENG101056,FUP_EFP_ST_L,6909.35, hPa
ENG99950,FUP_EFP_STOP_H,173888, hPa
ENG100784,FUP_EFP_STOP_L,5086.49, hPa
ENG102754,FUP_ENVD,44831.0841, hPa
ENG102108,FUP_H,35868.1, hPa
ENG111847,FUP_SP_ENVD,45688.2, hPa
ENG98594,Gear,0,
ENG103368,Gearbox -CAN bus messages,126839,
ENG102883,Gearbox: status,00000000 ,
ENG100957,Height correction,976.4219, hPa
ENG99170,Height correction,975.28, hPa
ENG103575,High-pressure system: regulator,0.00, mg
ENG103879,High-pressure system: regulator: mobile part,-2.73, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,0.8, Nm
ENG102289,Idling speed stabilisation: idling speed controller,-1.25000, Nm
ENG101472,Idling speed stabilisation: learned value,-4.28125, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100449,IGA_AD_1_KNK[0],0.000, °
ENG101025,IGA_AD_1_KNK[1],0.000, °
ENG100399,IGA_AD_1_KNK[2],0.000, °
ENG99087,IGA_AD_1_KNK[3],0.000, °
ENG100814,IGA_AD_1_KNK[4],0.000, °
ENG100030,IGA_AD_1_KNK[5],0.000, °
ENG103801,IGA_IGC_0,7.500, °
ENG101919,IGA_IGC_1,7.500, °
ENG102065,IGA_IGC_2,7.500, °
ENG103873,IGA_IGC_3,10.125, °
ENG99337,IGA_IGC_4,11.250, °
ENG100633,IGA_IGC_5,10.500, °
ENG102932,Ignition angle: actual,8.625, °
ENG100204,Intake air change-over: pressure,295.35, hPa
ENG101741,Intake air temperature,55.50, °C
ENG101388,Intake manifold pressure: absolute,297.18, hPa
ENG114847,IVVTHPWM_IN[1],9.375, %
ENG114848,IVVTHPWM_IN[2],9.375, %
ENG99742,Kickdown adaption: switch,00000000 ,
ENG101640,Kilometres driven with MIL,0, km
ENG103143,Kilometres driven with MIL,0, min
ENG103876,Knock control: knock sensor voltage: cyl. 1,0.82993, V
ENG99646,Knock control: knock sensor voltage: cyl. 2,0.61516, V
ENG102129,Knock control: knock sensor voltage: cyl. 3,0.56450, V
ENG102735,Knock control: knock sensor voltage: cyl. 4,0.59082, V
ENG100457,Knock control: knock sensor voltage: cyl. 5,0.51964, V
ENG100093,Knock control: knock sensor voltage: cyl. 6,0.53696, V
ENG102464,LAM_CYL_SEL_ADJ_FAC[0],-0.278, %
ENG100498,LAM_CYL_SEL_ADJ_FAC[1],-0.768, %
ENG100758,LAM_CYL_SEL_ADJ_FAC[2],1.341, %
ENG102261,LAM_CYL_SEL_ADJ_FAC[3],0.360, %
ENG103470,LAM_CYL_SEL_ADJ_FAC[4],-1.067, %
ENG102999,LAM_CYL_SEL_ADJ_FAC[5],0.407, %
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],-0.00592,
ENG102871,LAMB_DELTA_AD_LAM_ADJ[2],-0.00293,
ENG102085,LAMB_DELTA_AD_O2L_CAT[1],-0.00299,
ENG102521,LAMB_DELTA_AD_O2L_CAT[2],-0.00421,
ENG112963,LAMB_MV_SA[1],1.3730,
ENG112964,LAMB_MV_SA[2],1.4424,
ENG112965,LAMB_SP_MV_SA[1],0.6953,
ENG112966,LAMB_SP_MV_SA[2],0.6953,
ENG102144,Lambda control value: bank 1,-3.253, %
ENG102393,Lambda control value: bank 2,-2.620, %
ENG99674,Lambda controller: bank 1 (averaged value),-3.201, %
ENG100249,Lambda controller: bank 2 (averaged value),-3.072, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG99812,Lambda probe 1: bank 2: status,00000001 ,
ENG99373,Lambda probe 1: bank 2: status,00000000 ,
ENG103920,Lambda probe 1: bank 2: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG99313,Lambda probe 2: bank 2: status,00000000 ,
ENG99124,Lambda probe 2: bank 2: status,00000001 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,328.2875, °C
ENG99891,Lambda probe ageing: bank 1: probe 2: short trip result,255.4750, °C
ENG103962,Lambda probe ageing: bank 2: dynamic factor,0.0000,
ENG103203,Lambda probe ageing: bank 2: probe 1: short trip result,327.9125, °C
ENG103040,Lambda probe ageing: bank 2: probe 2: short trip result,254.4125, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,-0.00195,
ENG100459,Lambda probe correction: duty cycle offset: bank 2,-0.00177,
ENG101813,Lambda probe heater: bank 1: probe 1: short trip result,00000000 ,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG101739,Lambda probe heater: bank 2: probe 1: short trip result,00000000 ,
ENG101102,Lambda probe heater: bank 2: probe 2: short trip result,00000000 ,
ENG102717,Lambda probe heater: resistance: bank 1: probe 1,79.75, Ohm
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,210, Ohm
ENG101429,Lambda probe heater: resistance: bank 2: probe 1,79.75, Ohm
ENG102703,Lambda probe heater: resistance: bank 2: probe 2,200, Ohm
ENG103233,Lambda probe readiness: bank 1: probe 1: short trip result,00000001 ,
ENG101214,Lambda probe readiness: bank 1: probe 2: short trip result,00000001 ,
ENG103087,Lambda probe readiness: bank 2: probe 1: short trip result,00000001 ,
ENG101319,Lambda probe readiness: bank 2: probe 2: short trip result,00000001 ,
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),2.036, V
ENG102863,Lambda probe voltage: bank 1: probe 2,0.815, V
ENG100603,Lambda probe voltage: bank 2: probe 1 (broadband probe),1.997, V
ENG103421,Lambda probe voltage: bank 2: probe 2,0.811, V
ENG102763,Lambda probes actual: bank1,1.0283,
ENG102040,Lambda probes actual: bank2,0.9941,
ENG102170,Lambda probes learned values: bank 1: probe 1: idle,0.000, %
ENG104246,Lambda probes learned values: bank 1: probe 1: part throttle,1.205, %
ENG104025,Lambda probes learned values: bank 2: probe 1: idle,0.708, %
ENG102016,Lambda probes learned values: bank 2: probe 1: part throttle,0.458, %
ENG100365,Lambda probes specification: bank 1,1.0010,
ENG101457,Lambda probes specification: bank 2,1.0010,
ENG104114,Lambda probes specified: bank1,1.0010,
ENG102953,Lambda probes specified: bank2,1.0010,
ENG100402,LOIL_SUM_SRV_INTL,0.00000, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG101153,LV_AD_END_IVVT,00000001 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG111848,LV_CUR_H_IV,00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG112970,LV_END_DIAG_SA_SAV[1],00000001 ,
ENG112971,LV_END_DIAG_SA_SAV[2],00000001 ,
ENG112968,LV_END_DIAG_SAF[1],00000001 ,
ENG112969,LV_END_DIAG_SAF[2],00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG99924,LV_INH_AUT_ST,00000000 ,
ENG103773,LV_INH_STR_RLY,00000000 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG100804,LV_RFP_AD_EXT_ADJ_ON,00000000 ,
ENG99593,LV_RFP_CUR_OFF,00000000 ,
ENG102334,LV_RFP_POS_GRD,00000000 ,
ENG112973,LV_SA_DIAG_LS_UP_END[1],00000000 ,
ENG112974,LV_SA_DIAG_LS_UP_END[2],00000000 ,
ENG112975,LV_SA_DIAG_LS_UP_ERR[1],00000000 ,
ENG112976,LV_SA_DIAG_LS_UP_ERR[2],00000000 ,
ENG112977,LV_SAF_DIAG_OK[1],00000001 ,
ENG112978,LV_SAF_DIAG_OK[2],00000001 ,
ENG112979,LV_SAV_DIAG_OK[1],00000001 ,
ENG112980,LV_SAV_DIAG_OK[2],00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,00000000 ,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG99280,LV_VCV_RLY,00000001 ,
ENG102523,MAF,88.81, mg/stroke
ENG103484,MAF_CYL,11.09375, kg/h
ENG112981,MAF_CYL_MV_SA,38.22, kg/h
ENG101509,MAF_ENVD,234.22352, mg/stroke
ENG103984,MAF_RFP,37.71875, kg/h
ENG103985,MAF_SCHA,49.53125, kg/h
ENG100807,MAF_THR,11.00000, kg/h
ENG101499,map,303.31, hPa
ENG102949,MAP_1_ENVD,557.19727, hPa
ENG102680,MAP_1_MES,305.97, hPa
ENG99737,MAP_1_MES_BAS,307.62, hPa
ENG102960,MAP_2_ENVD,551.89063, hPa
ENG102281,MAP_2_MES,313.43, hPa
ENG104243,MAP_2_MES_BAS,305.39, hPa
ENG103166,MAP_ENVD,0.0000, hPa
ENG122735,MASS_FUEL_INT_OIL,1.83, g
ENG99929,MAX_HLD_ICH,0, s
ENG101558,MAX_HLD_LAMP_RE,0, s
ENG100434,MAX_HLD_PSTE,0.000, s
ENG99171,MAX_HLD_SCU,0.000, s
ENG102618,Mean engine air mass,12.31, kg/h
ENG103857,Mean vehicle speed,0, km/h
ENG99199,MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[0],0.077, mg/stroke
ENG103758,MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[1],-0.068, mg/stroke
ENG100400,MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[2],-0.203, mg/stroke
ENG103502,MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[3],-0.154, mg/stroke
ENG100254,MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[4],0.126, mg/stroke
ENG100666,MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[5],0.223, mg/stroke
ENG103380,MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[0],0.213, mg/stroke
ENG103050,MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[1],0.492, mg/stroke
ENG101085,MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[2],0.051, mg/stroke
ENG103812,MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[3],-0.360, mg/stroke
ENG102659,MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[4],-0.265, mg/stroke
ENG102911,MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[5],-0.132, mg/stroke
ENG103346,MFF_ADD_LAM_AD[1],0.00, mg/stroke
ENG100447,MFF_ADD_LAM_AD[2],0.00, mg/stroke
ENG125296,MFF_KGH_ADD_LAM_AD[1],0.004, kg/h
ENG125297,MFF_KGH_ADD_LAM_AD[2],0.010, kg/h
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG99926,Misfires cylinder 1 from engine start to engine stop,0,
ENG103503,Misfires cylinder 1 per 1000 rpm,0,
ENG100235,Misfires cylinder 2 from engine start to engine stop,6,
ENG99825,Misfires cylinder 2 per 1000 rpm,0,
ENG101055,Misfires cylinder 3 from engine start to engine stop,0,
ENG101730,Misfires cylinder 3 per 1000 rpm,0,
ENG101998,Misfires cylinder 4 from engine start to engine stop,0,
ENG102032,Misfires cylinder 4 per 1000 rpm,0,
ENG100222,Misfires cylinder 5 from engine start to engine stop,0,
ENG101260,Misfires cylinder 5 per 1000 rpm,0,
ENG101221,Misfires cylinder 6 from engine start to engine stop,3,
ENG101947,Misfires cylinder 6 per 1000 rpm,0,
ENG98787,N,702, /min
ENG110570,N_CAM_32_DIAG_CRK_SIG_LOSS,704, /min
ENG110571,N_TOOTH_32_DIAG_CRK_SIG_LOSS,672, /min
ENG107737-ENG102260,NC_NR_DIAG_RBM-IdentDec,95,
ENG99870,O2L_1_MAX_BAS_AD_CAT[1],0.40446, g
ENG102018,O2L_1_MAX_BAS_AD_CAT[2],0.34173, g
ENG104137,O2L_1_MAX_BAS_AD_CAT_DIAG[1],0.39998, g
ENG100562,O2L_1_MAX_BAS_AD_CAT_DIAG[2],0.39998, g
ENG121100,O2L_MAX_CAT_GAP_AFL_ENVD_0,0.00000, g
ENG121101,O2L_MAX_CAT_GAP_AFL_ENVD_1,0.00000, g
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG121102,O2L_MAX_CAT_GAP_AFL_MV[2],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG121103,O2L_MAX_CAT_GAP_AFR_MV[2],0.00000, g
ENG101106,PDT_ENVD,557.19727, hPa
ENG125298,PRS_DIF_AMP_MAP_DIAGCPS,669.72, hPa
ENG125299,PRS_DIF_AMP_MAP_DIAGCPS_ENVD,400, hPa
ENG102451,PSN_EDGE_1_AD_CAM_IN_1,95.9375, °
ENG114849,PSN_EDGE_1_AD_CAM_IN_2,96.2500, °
ENG103487,PSN_EDGE_2_AD_CAM_IN_1,96.0000, °
ENG114850,PSN_EDGE_2_AD_CAM_IN_2,95.6250, °
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG102782,Radiator fan 1: activation,14.453125, %
ENG101201,Radiator fan 1: run-on: status,2,
ENG101514,Radiator fan 2: activation,10.156250, %
ENG102359,Radiator fan 2: run-on: status,2,
ENG125300,RATIO_MAF_MAX_COR_DIAGCPS,0.11181641,
ENG125301,RATIO_MAF_MAX_COR_DIAGCPS_ENVD,0.289,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG121104,RATIO_O2L_LIM_CAT_GAP_AFL_MV[2],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG121105,RATIO_O2L_LIM_CAT_GAP_AFR_MV[2],0.0000000,
ENG102377,Ready and error flags,0,
ENG102831,Ready bits (completed tests),132,
ENG100050,RFP_AD_STEP_CTR,255,
ENG103162,RFP_AD_STOP,0,
ENG99149,RFP_AD_STOP_SAVE,0,
ENG100790,RFP_AD_STOP_SAVE_HIGH_ENVD,0,
ENG101524,RFP_AD_STOP_SAVE_LOW_ENVD,0,
ENG99738,RFP_AV,59.14, °
ENG103313,RFP_AV_ENVD,64.4882,
ENG101571,RFP_SP,59.47, °
ENG102212,RFP_SP_ENVD,64.4882,
ENG100220,RFPPWM_ENVD,4.68750, %
ENG112982,SAF_DIAG_COR[1],33.59, kg/h
ENG112983,SAF_DIAG_COR[2],38.03, kg/h
ENG112984,SAF_DIF[1],-8.594, kg/h
ENG112985,SAF_DIF[2],-13.031, kg/h
ENG112986,SAF_DIF_TOL_SAE,18.000, kg/h
ENG112987,SAF_KGH_MV,26.23, kg/h
ENG103248,SEG_AD_MMV_ER[0],0.0000, ‰
ENG101135,SEG_AD_MMV_ER[1],-1.7588, ‰
ENG99078,SEG_AD_MMV_ER[2],-1.4989, ‰
ENG103257,SEG_AD_MMV_ER[3],-0.2901, ‰
ENG100125,SEG_AD_MMV_ER[4],-1.5025, ‰
ENG100241,SEG_AD_MMV_ER[5],-1.5879, ‰
ENG102511,SEG_AD_MMV_ER_H[0],0.0000, ‰
ENG103258,SEG_AD_MMV_ER_H[1],-1.3928, ‰
ENG99291,SEG_AD_MMV_ER_H[2],-1.2109, ‰
ENG99954,SEG_AD_MMV_ER_H[3],0.0012, ‰
ENG100348,SEG_AD_MMV_ER_H[4],-1.3494, ‰
ENG104100,SEG_AD_MMV_ER_H[5],-1.0378, ‰
ENG100568,SEG_AD_MMV_ER_L[0],0.0000, ‰
ENG100601,SEG_AD_MMV_ER_L[1],-1.7588, ‰
ENG102668,SEG_AD_MMV_ER_L[2],-1.4989, ‰
ENG101232,SEG_AD_MMV_ER_L[3],-0.2901, ‰
ENG102134,SEG_AD_MMV_ER_L[4],-1.5025, ‰
ENG99992,SEG_AD_MMV_ER_L[5],-1.5879, ‰
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000, ‰
ENG102964,SEG_AD_MMV_ER_MID[1],-1.6682, ‰
ENG100890,SEG_AD_MMV_ER_MID[2],-1.7280, ‰
ENG99793,SEG_AD_MMV_ER_MID[3],-0.0424, ‰
ENG103967,SEG_AD_MMV_ER_MID[4],-1.5225, ‰
ENG99413,SEG_AD_MMV_ER_MID[5],-1.5559, ‰
ENG103381,Shut-off time,1.93, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,37, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,52, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG101893,Starter control: clutch switch,00000000 ,
ENG100919,Starter control: interlock switch,00000000 ,
ENG102520,Starter: measure-back wire term. 50 R,00000000 ,
ENG100800,Starter: start relay 1,00000000 ,
ENG99979,Starter: start relay 2,00000000 ,
ENG99368,Starter: starter request terminal 50,00000000 ,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112988,STATE_DIAG_SA_LSL,SA_DIAG_END,
ENG101327,STATE_LS_ENVD[1],2,
ENG101384,STATE_LS_ENVD[2],2,
ENG104238,STATE_NVLD,Stop,
ENG101078,STATE_READY_OBD_1,7,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG112989,STATE_SA,Finished,
ENG109090-ENG101799,STATE_SW_MVB-Param to DOP,S85L1010 CBK01P0,
ENG122706,Strt_Stop_Stc_ct_Deac_Strt_Stop_Swt_VW,0,
ENG122707,Strt_Stop_Stc_ct_Stop_Not_Req_VW,0,
ENG103546,T_AST_ENVD,25.70, s
ENG104148,T_COOL_LOIL,537.3, ms
ENG101072,T_DTC_CLR,20647, min
ENG102790,T_EFP_MEM_H,655.35, s
ENG102123,T_EFP_MEM_L,0.01, s
ENG99831,T_FAC_MAF_MAX_ORNG,0.0, s
ENG99128,T_INT_DIAG_TH,1627.5, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG100808,T_RAMP_RFP_SP_OSC,0.00, s
ENG101325,T_TEMP_SIG_LOIL,62.1, ms
ENG121106,T_VLS_DOWN_DLY_CAT_ENVD_0,0.00, s
ENG121107,T_VLS_DOWN_DLY_CAT_ENVD_1,0.00, s
ENG125302,T_VLS_DOWN_DLY_L2R_SAE[1],0.01, s
ENG125303,T_VLS_DOWN_DLY_L2R_SAE[2],0.01, s
ENG125304,T_VLS_DOWN_DLY_R2L_SAE[1],0.01, s
ENG125305,T_VLS_DOWN_DLY_R2L_SAE[2],0.01, s
ENG112953,TAM_CAN,31.50, °C
ENG102048,Tank breather valve: duty cycle,14.843750, %
ENG101339,Tank breather valve: short trip result,0.6143, kg/h
ENG100439,Tank level,00000000 ,
ENG104029,TCO_1_2,0.00, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-5.25, °C
ENG100717,TCO_A_LAM_AD_WUP[2],-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP[1],9.75, °C
ENG101562,TCO_B_LAM_AD_WUP[2],9.75, °C
ENG101581,TCO_C_LAM_AD_WUP[1],24.75, °C
ENG101857,TCO_C_LAM_AD_WUP[2],24.75, °C
ENG100354,TCO_D_LAM_AD_WUP[1],35.25, °C
ENG101300,TCO_D_LAM_AD_WUP[2],35.25, °C
ENG101973,TCO_E_LAM_AD_WUP[1],41.25, °C
ENG103356,TCO_E_LAM_AD_WUP[2],41.25, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],40.50, °C
ENG103663,TCO_MIN_INTER_LAM_AD_WUP[2],40.50, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],-6.00, °C
ENG103733,TCO_MIN_LAM_AD_WUP[2],-6.00, °C
ENG102279,TCS/ESP: specified torque,1022.00, Nm
ENG99857,TCS: status,00000000 ,
ENG99437,TCYLH,104, °C
ENG103400,TEMP_CAT_ENVD[1],695.000000, °C
ENG102182,TEMP_CAT_ENVD[2],690.000000, °C
ENG101941,TEMP_CAT_STAT_MDL[1],437.6625, °C
ENG99592,TEMP_CAT_STAT_MDL[2],423.8500, °C
ENG112990,TEMP_DIF_SWI_CWP_FCT_CUS,4.5, °C
ENG101721,Throttle actuator angle (potentiometer 2),00000100 ,
ENG104173,Throttle adjustment: potentiometer 1 emergency gap,0.742, V
ENG101024,Throttle adjustment: potentiometer 2: emergency gap,4.258, V
ENG99608,Throttle valve adjuster: adaption status,0,
ENG100374,Throttle valve adjustment: potentiometer 1 lower adaption,0.498, V
ENG102367,Throttle valve adjustment: potentiometer 2 lower adaption,4.502, V
ENG101411,Throttle valve angle,2.123, °
ENG101155,Throttle valve angle: potentiometer 1,0.591, V
ENG101278,Throttle valve angle: potentiometer 2,4.409, V
ENG102845,Throttle valve deviation,0.046, %
ENG103149,TI_1_HOM[0],0.536, ms
ENG101279,TI_1_HOM[1],0.536, ms
ENG99190,TI_1_HOM[2],0.536, ms
ENG100436,TI_1_HOM[3],0.492, ms
ENG100317,TI_1_HOM[4],0.504, ms
ENG102588,TI_1_HOM[5],0.492, ms
ENG111849,TI_1_HOM_ENVD,1.4, ms
ENG104034,TI_2_HOM[0],0.000, ms
ENG103041,TI_2_HOM[1],0.000, ms
ENG100076,TI_2_HOM[2],0.000, ms
ENG100292,TI_2_HOM[3],0.000, ms
ENG101541,TI_2_HOM[4],0.000, ms
ENG99751,TI_2_HOM[5],0.000, ms
ENG111850,TI_2_HOM_ENVD,0.0, ms
ENG99834,TIA[NC_IDX_TIA_IM_CYL_1],56.25, °C
ENG101962,TIA[NC_IDX_TIA_IM_CYL_2],56.25, °C
ENG102627,TIA_AM_SCHA,54.00, °C
ENG103343,TIA_MES[NC_IDX_TIA_AM_SCHA],54.00, °C
ENG101694,TIA_MES[NC_IDX_TIA_IM_CYL_1],56.25, °C
ENG102135,TIA_MES[NC_IDX_TIA_IM_CYL_2],56.25, °C
ENG103351,Time since engine start,1714.3, s
ENG100558,TPS_ENVD,5.1, %
ENG103021,TQ_CONV,3.00, Nm
ENG102012,TQ_DIF_IS_AD_ACC,5.40625, Nm
ENG99851,TQ_LOSS,-30.12500, Nm
ENG99317,TQ_LOSS_ACC,0.00000, Nm
ENG103625,TQI_AV_ENVD,58, Nm
ENG100768,TQI_GS_FAST_DEC,1023.97, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG100355,V_FUP_EFP_MV,2.183, V
ENG101255,V_PORT_1_ENVD,0.91797, V
ENG99922,V_PORT_1_RAW,3.574, V
ENG100742,V_PORT_2_ENVD,0.68359, V
ENG99200,V_PORT_2_RAW,0.718, V
ENG99867,V_PVS_1_ENVD,0.74219, V
ENG100593,V_PVS_2_ENVD,0.37109, V
ENG100956,V_TPS_1_ENVD,0.72266, V
ENG99904,V_TPS_2_ENVD,4.25781, V
ENG99514,VBOOST,56.5, V
ENG103201,VCV_CLOSE_RNG,28.1, °
ENG99527,Vehicle speed: actual,0, km/h
ENG102311,Vehicle speed: filtered,0.00, km/h
ENG102035,Vehicle speed: specified,0.00, km/h
ENG103235,VLS_DOWN_1_ENVD,0.41016, V
ENG103269,VLS_DOWN_2_ENVD,0.41016, V
ENG125306,VLS_DOWN_GRD_L2R_SAE[1],5084, /s
ENG125307,VLS_DOWN_GRD_L2R_SAE[2],6114, /s
ENG121108,VLS_DOWN_GRD_R2L_AFL_ENVD_0,0, /s
ENG121109,VLS_DOWN_GRD_R2L_AFL_ENVD_1,0, /s
ENG125308,VLS_DOWN_GRD_R2L_SAE[1],5554, /s
ENG125309,VLS_DOWN_GRD_R2L_SAE[2],5638, /s
ENG103710,VLS_UP_1_ENVD,2.01172, V
ENG99196,VLS_UP_2_ENVD,1.99219, V
ENG100719,VLS_UP_DIAG_SAVE_PUC_LSL_UP[1],3.916, V
ENG103416,VLS_UP_DIAG_SAVE_PUC_LSL_UP[2],3.921, V
ENG102798,VP_RFP_1,3.3008, V
ENG102004,VP_RFP_1_ENVD,3.59375, V
ENG101126,VP_RFP_AD_BOL_1,0.5182, V
ENG102969,VP_RFP_AD_BOL_1_ENVD,0.50781, V
ENG102249,VP_RFP_AD_LIH_1,4.4629, V
ENG103425,VP_RFP_AD_LIH_1_ENVD,4.45313, V
ENG101394,VP_RFP_BOL_1,0.5182, V
ENG100243,VP_RFP_BOL_MTC_1,0.5182, V
ENG100671,VP_RFP_BOL_MTC_1_ENVD,0.50781, V
ENG101523,VP_RFP_LIH_1,4.4629, V
Elapsed Time: 01:00
