Coding BOSE amp Audi Q7
El Polaco
Central FL
C?ID=148074
Can anyone help with the proper coding of the BOSE amp in 47 Sound System or will this vehicle have to go to the dealer? The amp got wet and I sent it out for repair. I did not have a log of this car prior to the amp getting wet. When it came in there was no communication with 47 SOUND SYSTEM. Its now communicating but the sound is not coming from all the speakers and there are faults for coding/basic settings.
Software coding 0000000 Should be 00000?6
workshop code 00000
importer number 000
equipment number 00000
The coding helper says:
Sound system bose coding j525
00000?X Microphone
1=1 microphone for vol. control
2=2 mic for vol control
4=1 mic for vol control and analog input (AUX)
5=2 mic for vol control and analog input (AUX)
00000X? Equipment
1 not applicable
2 not applicable
3 not applicable
4 not applicable
5 not applicable
6 Left-hand drive with leather trim and petrol engine
7 not applicable
8 not applicable
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 36 3C 42 46 47
          4F 52 55 56 61 62 65 69 6C 6D 6F 72 76 77
VIN: WA1BY74L97D076408   Mileage: 192980km-119912miles
0E-Media Player 1 -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 1010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (BHK)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 BG    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G   1634
   Revision: 5CH05---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 68D5A0E95B026E0208-803C
               P0300 - 008 -  - Intermittent
                    Mileage: 191782 km
                    Date: 2016.09.05
                    Time: 13:00:42
                    RPM: 1737 /min
                    Load: 41.9 %
                    Speed: 20.0 km/h
                    Temperature: 60.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 13.716 V
000774 - Cylinder 6
               P0306 - 008 - Misfire Detected - Intermittent
                    Mileage: 191782 km
                    Date: 2016.09.05
                    Time: 13:01:04
                    RPM: 1270 /min
                    Load: 38.0 %
                    Speed: 22.0 km/h
                    Temperature: 59.0°C
                    Temperature: 36.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
               P0302 - 008 - Misfire Detected - Intermittent
                    Mileage: 191782 km
                    Date: 2016.09.05
                    Time: 13:01:04
                    RPM: 1270 /min
                    Load: 38.0 %
                    Speed: 22.0 km/h
                    Temperature: 59.0°C
                    Temperature: 36.0°C
                    Voltage: 14.097 V
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4L0 910 156 C    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0010
   Revision: --H01---    Serial number:        4013838
   Coding: 0000002
   VCID: 2953E5ED8088970AD7-807C
Address 03: ABS Brakes        Labels: 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H22001
   Coding: 0033809
   VCID: 2855E0E99B82AE02C8-807C
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100640432
   Coding: 0000131
   Shop #: WSC 64034 000 1048576
   VCID: 63CFB7C5A2240D5ADD-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
                    Reset counter: 169
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 354AN077516363
   Coding: 0002003
   VCID: 356B399D5C30C3EA43-8060
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000000624055
   Subsystem 3 - Serial number: 0103.01.070000000100010723ÿ
   Subsystem 4 - Serial number: 010723ÿ
02849 - Control Module for Lane Change Assistance (J769)
                    Reset counter: 161
                    Time Indication: 15
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 128
                    Mileage: 188484 km
                    Date: 2016.07.17
                    Time: 13:25:16
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:06
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---012    Serial number: 00000030022429
   Coding: 0786470
   VCID: 61C3BDCDB8381F4ACF-8034
            000 -  -  - Intermittent
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:06
                    Voltage: 8.60 V
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Coding: 0014123
   VCID: 31630D8DA858EFCA1F-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0080
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H43 0350
   Revision: 00043000    Serial number: AUZ5ZBG1028448
   VCID: 1D3BC13DC4C07BAAAB-8048
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:25
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 H    HW: 4E0 035 593 D
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7F0032050
   VCID: 2C5D1CF98F7A82222C-8078
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:35
                    Voltage: 8.30 V
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH41 0230
   Revision: 05H41000    Serial number: 0038QD050AR6
   Coding: 0014131
   VCID: 2B5F1FE58A74851A25-807E
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME1C5A2763L
   Subsystem 3 - Serial number: 6342QSME1C5C4153J
   Subsystem 4 - Serial number: 6352QSME1C54233DK
   Subsystem 5 - Serial number: 6362QSME1C58395F-
   Subsystem 6 - Serial number: 63734SME1C463509+
   Subsystem 7 - Serial number: 63834SME1C493161$
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90055063630090
   Coding: 0002022
   VCID: 66C9AED1511678723A-8032
   Component: Lenkradmodul    H07 0090
                    Fault Frequency: 14
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:18
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4L0 920 950 B
   Component: KOMBIINSTR. M73 H11 0170
   Revision: 00400000    Serial number: 4ZS139817
   Coding: 0595263
   Shop #: WSC 42863 001 1048576
   VCID: 2045F8C9F3B2564280-8074
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.16
                    Time: 00:27:51
Address 19: CAN Gateway        Labels: 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D06C088063
   Coding: F7F7FE77741A02
   Shop #: WSC 20211 444 84457
   VCID: 6CDDDCF94FFA42226C-8038
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 04:16:59
                    Reset counter: 190
                    Mileage: 192981 km
                    Date: 2016.09.14
                    Time: 10:09:32
            000 -  -
                    Reset counter: 150
                    Mileage: 192981 km
                    Date: 2016.09.14
                    Time: 18:22:07
Address 1E: Media Player 2 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H09 0700
   Revision: 00000000
   VCID: 2757E3D5569CA17AC1-8072
   Part No SW: 4L0 910 158     HW: 4L0 919 158 D
   Revision: 00---009    Serial number: 00000000092349
   Coding: 0000006
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 8
                    Mileage: 172917 km
                    Date: 2016.02.03
                    Time: 14:31:27
02599 - Rear Left Temperature Flap Motor (V313)
                    Fault Frequency: 63
                    Reset counter: 160
                    Mileage: 188514 km
                    Date: 2016.07.17
                    Time: 18:13:48
                    Voltage: 13.30 V
                    Temperature: -100.0°C
                    (no units): 229.0
                    (no units): 61.0
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:06
                    Voltage: 8.50 V
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 129
                    Mileage: 191712 km
                    Date: 2016.08.16
                    Time: 00:06:10
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082946
   Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH07 0070
   Revision: 00H07000    Serial number: 6PZ 009 014-00
   Coding: 0010001
   VCID: 2D5B11FDB4608B2A3B-8078
   Subsystem 1 - Part No: 4L0 910 568 B
   Component: J0770_SWA_Slave_H06 0070
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F07.12.0600H0600000010196ÿ
   Subsystem 4 - Serial number: 010196ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 129
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 04:17:42
16365 - Control Module - Electrical Error; CPU 2
            014 - Defective
                    Reset counter: 120
                    Mileage: 190632 km
                    Date: 2016.08.05
                    Time: 12:39:53
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:10
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:10
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00000000    Serial number: 5W1
   Coding: 0035531
   VCID: 2F670BF5BE6CF93A09-807A
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01029550070000
   Coding: 7632925
02956 - Lamp in Trunk/Hatch Lid; Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 150
                    Mileage: 166463 km
                    Date: 2015.11.17
                    Time: 17:16:11
                    Bin. Bits:  001 010
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000012369
   Coding: 0000000
            000 -  -
                    Fault Frequency: 17
                    Reset counter: 150
02084 - Component Protection
                    Fault Status: 01100101
                    Mileage: 190036 km
                    Date: 2016.08.04
                    Time: 16:42:53
            000 -  -
                    Fault Frequency: 17
                    Reset counter: 150
                    Mileage: 192981 km
                    Date: 2016.09.14
                    Time: 18:21:35
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000068511
   Coding: 0012001
   VCID: 5EB98631894620B2F2-800A
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 23:14:00
                    Voltage: 9.500 V
                    Temperature: 31.0°C
                    Fault Status: 00110010
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:00
                    Voltage: 7.700 V
                    Temperature: 31.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00000000    Serial number: I”5
   Coding: 0035531
                    Reset counter: 169
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000021
   Component: AFS-Modul links H06 0002
   Component: AFS-Modul rechtsH06 0002
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 388L8067580598
   Coding: 0000002
   VCID: 2E5916F1B966F03202-807A
                    Reset counter: 190
                    Mileage: 182401 km
                    Date: 2016.05.12
                    Time: 16:17:47
                    Fault Frequency: 81
                    Reset counter: 190
                    Mileage: 182401 km
                    Date: 2016.05.12
                    Time: 16:08:02
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000072976
   VCID: 64CDB4D9A72A0A6224-8030
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  330423NOJD
   Coding: 34463039313531303544205641303333303432334E4F4A44
                    Fault Frequency: 79
                    Mileage: 171444 km
                    Date: 2016.01.12
                    Time: 11:59:28
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 73
                    Reset counter: 168
                    Mileage: 189991 km
                    Date: 2016.08.04
                    Time: 01:05:41
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 23:14:28
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0035338
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700040242
   Coding: 0062424
   VCID: 2241F2C1FDBE445296-8076
            002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100010
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2000.01.01
                    Time: 12:00:00
                    (no units): 255.0
                    Voltage: 6.50 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Fault Frequency: 29
                    Reset counter: 151
                    Mileage: 189663 km
                    Date: 2016.07.23
                    Time: 07:54:34
                    (no units): 54.0
                    Temperature: 26.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 69: Trailer        Labels: 4E0-910-383.lbl
   Part No SW: 4E0 910 383 C    HW: 4E0 907 383 C
   Component: ANHAENGERELEKTR 004 0060
   Coding: 0000002
   VCID: 244DF4D9E7AA4A62E4-8070
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6Z41FK
   Coding: 1001101
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 03:01:13
                        Term 15 Off
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD05.01.07--H21001001B0222ÿ
   Subsystem 4 - Serial number: 1B0222ÿ
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 002306545-----
   Coding: 0003595
   VCID: 2649EED19196B872FA-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE15_SKB09H10 0180
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE15_SKB09H10 0180
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE15_SKB09H10 0180
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                    Fault Status: 00101010
                    Reset counter: 190
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 03:14:57
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 190
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 03:14:57
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0050
   Coding: 0035338
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Component: Parkhilfe 4-Kan H09 0060
   Revision: 00H09000    Serial number: 06230634806562
   Coding: 0031246
   VCID: 2757E3D5969CA17AC1-8072
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:15
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007560035
   Coding: 0010900
End-------------------------(Elapsed Time: 04:01)--------------------------
Address 07: DTCs cleared
Address 01: DTCs cleared
Address 05: DTCs cleared
Address 0F: DTCs cleared
Address 46: DTCs cleared
Address 4F: DTCs cleared
Address 15: DTCs cleared
Address 19: DTCs cleared
Address 47: DTCs cleared
Address 28: DTCs cleared
Address 61: DTCs cleared
   Coding: 0001175
Readiness: 0110 0101
   Coding: 0000002
   Revision: 00H22001
   Coding: 0033809
   Coding: 0000131
   Coding: 0002003
   Coding: 0786470
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:06
                    Voltage: 8.60 V
   Coding: 0014123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:25
   Coding: 0014131
   Coding: 0002022
                    Fault Frequency: 14
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:18
   Coding: 0595263
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.16
                    Time: 00:27:51
            000 -  -
                    Reset counter: 151
                    Mileage: 192981 km
                    Date: 2016.09.15
                    Time: 13:48:57
   Revision: 00000000
   Coding: 0000006
                    Reset counter: 151
                    Mileage: 192981 km
                    Date: 2016.09.15
                    Time: 13:47:33
   Coding: 0082946
   Coding: 0010001
            014 - Defective
                    Reset counter: 129
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 04:17:42
            014 - Defective
                    Reset counter: 120
                    Mileage: 190632 km
                    Date: 2016.08.05
                    Time: 12:39:53
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:10
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:10
   Coding: 0035531
   Coding: 7632925
                    Reset counter: 151
                    Mileage: 166463 km
                    Date: 2015.11.17
                    Time: 17:16:11
                    Bin. Bits:  001 010
   Coding: 0000000
            000 -  -
                    Reset counter: 151
                    Mileage: 192981 km
                    Date: 2016.09.15
                    Time: 13:46:40
                    Mileage: 190036 km
                    Date: 2016.08.04
                    Time: 16:42:53
            000 -  -
                    Reset counter: 151
                    Mileage: 192981 km
                    Date: 2016.09.15
                    Time: 13:46:42
   Coding: 0012001
   Coding: 0035531
                    Reset counter: 169
   Coding: 0000021
   Coding: 0000002
                    Reset counter: 191
                    Mileage: 182401 km
                    Date: 2016.05.12
                    Time: 16:17:47
                    Fault Frequency: 80
                    Reset counter: 191
                    Mileage: 182401 km
                    Date: 2016.05.12
                    Time: 16:08:02
   Coding: 0035338
   Coding: 0062424
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2000.01.01
                    Time: 12:00:00
                    (no units): 255.0
                    Voltage: 6.50 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Frequency: 29
                    Reset counter: 151
                    Mileage: 189663 km
                    Date: 2016.07.23
                    Time: 07:54:34
                    (no units): 54.0
                    Temperature: 26.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0000002
   Coding: 1001101
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 03:01:13
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Coding: 0003595
                    Reset counter: 190
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 03:14:57
                    Reset counter: 190
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 03:14:57
   Coding: 0035338
   Coding: 0031246
                    Reset counter: 169
                    Mileage: 191712 km
                    Date: 2016.08.15
                    Time: 09:29:15
   Coding: 0010900
End-------------------------(Elapsed Time: 03:55)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
What happened with old amp? If You were closer to me, I could repair it for You. Now You should go to dealer to program CP and they will do other programming/adaptions for Your sound system, too.
P.S. Don't forget to charge battery :)
El Polaco
Central FL
C?ID=148074
The amp got wet from the sunroof drains. It was dry when I took it apart and its been raining like crazy here for the past week and its still all dry in the car. I also verified all the drains were working. The owners took the car to Audi awhile back and had the drains fixed so I can only conclude this is a result of a past leak. I was told when the amp was fixed that 80% of the time the repaired amp will work plug and play without the need to be recoded. I guess this one fell into the 20% group. So is there no way around a trip to the dealer at this point?
MartinsX
Riga, Latvia
C?ID=268515
You have got PCB with all chips inside amp replaced by repairer and all original coding and CP data are gone. It is possible to recode unit by Yourself using VCDS, but no way to go around Component Protection.
El Polaco
Central FL
C?ID=148074
Ok, down to two codes for the component protection. The module not coded fault is gone. Looks like that's all I can do here. The vehicle will have to go to the dealer.
thanks
j.
geforce007
C?ID=303008
Hi did anyone find a way to do this with vcds ?
