- May 20, 2015
- 63
- 18
- South Africa
- C?ID=163752
Thursday,15,September,2016,15:51:26:48700
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
Dealer/Shop Name:
Workshop Code: 000 12345 000001
VIN: WVWZZZ60ZBT034722 License Plate:
Chassis Type: 60 (6N0)
Scan: 01 03 09 15 17 19 25 44 56
VIN: WVWZZZ60ZBT034722 Mileage: 231040km-143561miles
Address 01: Engine (J623-CLPA) Labels: None
Part No SW: 03C 906 014 BJ HW: 03C 906 014
Component: CLPA-MM7GV H02 CLPA-MM7GV H02 10991099
Revision: --H02--- Serial number:
Coding: 00110012030400000000
VCID: 66C50E1F92D9F17232-513C
No Faults Found
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6RF 907 379 HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0002
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 02069 000 00000
VCID: 112F0DC3CCD746CA37-8044
Reset counter: 203
Mileage: 231041 km
Date: 2016.09.15
Time: 00:00:16
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3013
Hex Value: 0x1483
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 201102710
Coding: 22904ABF08E12400923000003C0B04900040414F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 4089F887D33DFF42E8-8014
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3420
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3420
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3420
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3420
Coding: 020000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagU04 H09 0020
Revision: -------- Serial number: 003GX00C77VN
Coding: 003034
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4A9DDAAFED01351236-801E
Serial number: 3495RRB405H0974OE9BI
Serial number: 3505RRB405H0974OCGSW
Part No SW: 6RF 920 860 HW: 6RF 920 860
Component: KOMBI H08 0008
Coding: 540200
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04061
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 071B239BBE93087AE9-8052
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 002300
VCID: 70E96847A31D2FC258-8024
Component: IMMO H08 0008
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03007
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 H HW: 6RF 909 144 G
Component: EPS_ECU H25 0321
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 004004
ROD: EV_SteerAssisUDSNSK.rod
VCID: 51AFCDC3005706CA77-8004
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 C HW: 5M0 035 156 C
Component: Radio 510 0521
Revision: R0510001 Serial number: VWZ5Z1K0421585
Coding: 0500040001
VCID: 295F452340471E0ADF-807C
End-------------------------(Elapsed Time: 02:29)--------------------------
Thursday,15,September,2016,16:09:30:48700
Dealer/Shop Name:
Address 25: Immobilizer (6RF 920 860 )
16:09:29
ENG109584 Transponder ID of 1st key 11 72 E3 40
ENG109585 Transponder ID of 2nd key 0D 77 9E 48
ENG109592 Transponder ID of current key N/A
this vehicle is none starting and I am pretty sure my instrument cluster is at fault as it is not reading the key ..I have already ruled out the key and the reader coil by testing with parts from a "ecu set" I have ..displaying "safe"
as can be seen by the loss of abs long coding I have also tried the cluster from my set and with my cluster the key is easily read
I have purchased a brand new cluster and would like to find out if I can adapt it with vcds?if so can someone guide me or point me to a guide?
are the security codes the same for the cluster and ecu on these vehicles?
also if someone could help me with long coding of the abs
