Enabling Adaptive Lane Tracking on NAR Golf 7 R
dmc
Toronto, Canada
C?ID=8335
The Lane Assist feature of my MY2016 NAR Golf 7 R seems to be pretty mild. Left to its own devices, the car often "ping pongs" between lines until the "hands off" timer gives up and asks the driver to take control.
I've recently been playing around with the A5 control module and I found this tweak pretty interesting:
The adaptation channel Intervention moment is by default is set to Late. There are options for Early, Late, Early (setting via menu), and Late (setting via menu). Changing the adaptation channel to the latter two (using SA 20103) enables an Adaptive lane tracking menu option under Lane Assist:
I believe the Early setting corresponds to having Adaptive lane tracking set to on. With adaptive lane tracking, Lane Assist very noticeably keeps the car centred between the lines, rather than "ping ponging" off them. It's quite a big difference! Adaptive lane tracking feels much more like an auto-pilot mode.
Give it a try and see what you think. Enabling the menu option lets you toggle between the two modes without VCDS.
Finally, it's important to note that I think this might only be possible on MY2016 vehicles.
I have a Canadian MY2016 with the Technology Package, equivalent to the Driver's Assistance Package in the U.S. My A5 module is 5Q0-980-653-G. I had a chance to work on a new Canadian MY2017 on the weekend, and I don't see the same channel in its much-smaller adaptation map. The MY2017 has the new frameless rearview mirror and lower-profile camera module, part 3Q0-980-654-G. It has less than one-third the available adaptation channels, so it doesn't appear as hackable.
I don't suppose you have scan data and/or maps from both of these modules that you could share?
dmc
Toronto, Canada
C?ID=8335
Sure. This is A5 from my car, a Canadian MY2016 7R with Technology Package:
;SW:5Q0-980-653-G   HW:5Q0-980-653 ---  Frt Sens. Drv. Assist
;Component:MQB_MFK       H06 0060, Coding:0100010000020308000400010100000100
;EV_MFKBoschAU370,001001,EV_MFKBoschAU370.rod
;Sunday,11,September,2016,15:46:08:25905
;VCDS Version: Release 16.8.1  Data version: 20160902 DS256
;VCID: BC7D2C87370E16A232-80E9
IDE00707-Operating mode,vibration_on
IDE02001-Body height left front wheel house edge,668 mm
IDE02002-Body height right front wheel house edge,667 mm
IDE02003-Body height left rear wheel house edge,676 mm
IDE02004-Body height right rear wheel house edge,676 mm
IDE02065-Night vehicle detection activation brightness,3 lx
IDE02066-Windshield heat. direct. stabilize. assist. activation duration,2 min
IDE03221-Night vehicle detection deactivation brightness,20 lx
IDE03280-Static calibration (end of assembly line),76 0F 3C 0F 5A 0A 70 0A 6C 0A 90 0A 90 26 70 4A 18 17 64 26 70 32 E8 17 64 26 70 4A 18 0E 1C 26 70 32 E8 0E 1C
IDE03885-Speed threshold for high beam recommendation off,17 km/h
IDE03886-Activation speed for high beam assistant,47 km/h
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h
IDE04726-Intervention moment,Late
IDE04733-Road sign detection fusion mode,Road sign fusion
IDE04736-Display end of speed limit symbol,not activated
IDE04737-Display no passing allowed,activated
IDE04738-Predictive route data run time,0 ms
IDE04815-Display valid additional signs,00100111
IDE05984-Directional stabilization assist driver inact deactiv threshold,Medium
IDE05985-Directional stab. assist.: intensity: steering wheel vibration,Medium
IDE05986-Directional stab. assist.: intensity: power steering support,Medium
IDE07358-Distance to calibration field,1500 mm
IDE07596-Personalization of lane dept. warning Cl. 15 on,Last setting
IDE10676-FDD: activation at standstill,not activated
MAS05331-IDE03355-Calibration result-Static calibration: yaw angle,180623977120.42 ∞
MAS05331-IDE03356-Calibration result-Static calibration: pitch angle,-57942157254.79 ∞
MAS05331-IDE03357-Calibration result-Static calibration: roll angle,-179764170057.77 ∞
MAS05331-IDE03358-Calibration result-Static calibration: camera height,1.06775e+012 mm
ENG120320-BAP_Personalisierung,not activated
ENG120312-CCP_interface,not activated
ENG120311-Country_Code_Signal_Consideration_Active,inputsignal_considered
ENG120315-Dev_Messages_EHR_deaktivation,Dev_Messages_not_activated
ENG120318-Dev_Messages_FDD_FLA_deaktivation,Dev_Messages_not_activated
ENG120316-Dev_Messages_HCA_deaktivation,Dev_Messages_not_activated
ENG120317-Dev_Messages_MOD_deaktivation,Dev_Messages_not_activated
ENG120313-Dev_Messages_VZE_deaktivation,Dev_Messages_not_activated
ENG120314-Dev_Messages_VZF_deaktivation,Dev_Messages_not_activated
ENG111405-Function_Module_Main_Beam_Assist,activated
ENG111404-Function_Module_Road_Sign_Recognition,activated
ENG120321-Hands_Off_Gong,Gong Typ 2
ENG120322-Hands_Off_Gong_Verzoegerung,0.0 s
ENG111386-HCA_On_State,Menu
ENG111414-HCA_Warning_Intensity,Medium
ENG111393-Main_Beam_Assist_Urban_Area_Detection,On
ENG120319-Mask_error_reactions_for_development,not activated
ENG107577-ENG107577-Masked_fault_classes-,255
ENG120323-Urban_Leaving_Velocity,255 km/h
ENG111412-VZE_Prioritize_moisture,not activated
ENG111410-VZE_show_administrative_speed_limits,show_always
ENG111411-VZE_Show_valid_additional_signs,activated
ENG111428-VZE_Sorting_alternative_signs,425
ENG111413-VZE_Sorting_valid_signs,174
ENG120310-VZF_Country_Code,0
ENG120307-VZMin_Attributierungs_Guete_Hauptverkehrszeichen,0 %
ENG120309-VZMin_Attributierungs_Guete_Zusatzzeichen,0 %
ENG120308-VZMin_Klassifizierungs_Guete_Hauptverkehrszeichen,0 %
ENG110127-ENG120122-Windscreen_heater_for_lane_departure_warning_settings-par_Heater_Control_Power_Level,8.0 W
ENG110127-ENG120121-Windscreen_heater_for_lane_departure_warning_settings-par_High_threshhold_temp,2 ∞C
ENG110127-ENG120119-Windscreen_heater_for_lane_departure_warning_settings-par_Init_heating_time,4 min
ENG110127-ENG120120-Windscreen_heater_for_lane_departure_warning_settings-par_Low_threshhold_temp,-20 ∞C
ENG110127-ENG120117-Windscreen_heater_for_lane_departure_warning_settings-par_Max_activation_temp,75 ∞C
ENG110127-ENG120116-Windscreen_heater_for_lane_departure_warning_settings-par_Max_camera_temp,85 ∞C
ENG110127-ENG120114-Windscreen_heater_for_lane_departure_warning_settings-par_Min_heating_time,2 min
ENG110127-ENG120115-Windscreen_heater_for_lane_departure_warning_settings-par_Min_idle_time,3 min
ENG110127-ENG120118-Windscreen_heater_for_lane_departure_warning_settings-par_Qualification_time,0 s
Elapsed Time: 00:19
This is A5 from a Canadian MY2017 with Technology Package. This car has the newer frameless rearview mirror/front-facing camera unit:
;SW:3Q0-980-654-G   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H04 0230, Coding:0003070000000201002223548040490084000E100000
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB.rod
;Sunday,11,September,2016,11:03:44:25905
;VCID: BB7F2F9B3200119A3B-80EF
IDE00001-Production mode,Deactivating
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated
IDE02332-Deactivate production mode,0
IDE06425-Roller test bench mode: functional,not activated
IDE09375-IDE05717-Axle offset-Front axle transverse position,-6.99999 mm
IDE09375-IDE05718-Axle offset-Rear axle transverse position,-5.99999 mm
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,670 mm
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,677 mm
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,678 mm
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,678 mm
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460 mm
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742 mm
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1497 mm
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460 mm
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742 mm
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1497 mm
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460 mm
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742 mm
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,903 mm
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460 mm
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742 mm
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,903 mm
IDE10407-Personalization of intervention moment at T. 15 on,Last setting
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu)
IDE10871-System mode: lane depart. warn:,Steering wheel vibration not active
IDE10872-Warning intensity: lane depart. warning,Medium
IDE10873-BAP personalization,activated
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.310 ∞
IDE10924-MAS05286-Initial calibration: result-Roll angle,-0.208 ∞
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.743 ∞
IDE10924-MAS10678-Initial calibration: result-Camera height,1321 mm
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled
ENG130777-standstill_mode,not activated
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,12.8
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,0
ENG130779-Xcp_interface,not activated
Elapsed Time: 00:09
I discovered this while trying to program Light Assist on the MY2017. I noticed LA moved from Byte 2 (on the 5Q0-980-653-G module) to Byte 21 (on the 3Q0-980-654-G module):
The various controllers accepted all of the coding, and the Light Assist icon illuminates in the MFD, but we haven't tested it on the road. Notably missing from the MY2017 are some of the adaptation channels that govern Light Assist behaviour (e.g. Speed threshold for high beam recommendation off, Activation speed for high beam assistant, etc.)
dmc
Toronto, Canada
C?ID=8335
By the way, I absolutely love how fast VCDS now pulls adaptation channel maps, even with my ancient serial HEX-CAN cable. Thanks! :)
daybun
Canada
HN1-004979
Hi DMC,
thank you for the info shown here!
Did you have any luck activating the FLA? I have a MY2016 Golf Sportwagon Highline with Light and Technology Packages, and it was delivered with FLA. However, in a recent recall VW actually deactivated my FLA (WITHOUT my consent or even telling me they were changing anything), and I am trying to reactivate it.
With the above it doesn't seem to happen just yet. I'm sure it is a multi-module approach. Any chance that you could post a full Scan of your modules 09 and 55 as well?
Would love to get my car back to the state it was in when before VW started messing with it...
Cheers,
Wendelin
