2015 B8 Passat Wagon (loaded)
Monday,12,September,2016,09:54:53:25460
VCDS Version: 16.8.1.3  HEX-V2 CB: 0.4324.4
Data version: 20160902 DS256
VIN: WVWZZZ3CZFE523801   License Plate: ANDY-PASSAT
Mileage: 20842km-12950mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 42 44 47
          52 55 5F 65 69 6C A5 BB BC CA
VIN: WVWZZZ3CZFE523801   Mileage: 20842km-12950miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA)       Labels: 03N-906-026-CUA.clb
   Part No SW: 03N 906 026     HW: 03N 907 309
   Component: R4 2,0L EDC   H23 1100
   Revision: A1H23---
   Coding: 0125003A047605083000
   Shop #: WSC 05311 115 00307
   ASAM Dataset: EV_ECM20BTD01103N906026 001009
   ROD: EV_ECM20BTD01103N906026.rod
   VCID: 68933BA09310AF0206-803C
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0DL 300 011     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 4701
   Revision: 00H10V01
   ROD: EV_TCMDQ500021_VW37.rod
   VCID: 658D32946402B26A3D-8030
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 61235000001226
   Coding: 0FEC6B8F54220B6F077F070041C469F0D62AD0E0E08296F5B86250884229
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_VW48.rod
   VCID: 49D5DE24E8DA760A39-801C
   Part No SW: 3Q0 959 435 A    HW: 3Q0 959 435 A
   Component: VWKESSYMQB    033 0524
   Revision: 00033000    Serial number: 0366675928
   Coding: 0F00200703
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 3833ABE08330FF8256-806C
   Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Revision: 00001K10
   Coding: 12020124204401012115500200101902
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 70A353C0ABC067C25E-8024
   Air quality sensor:
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86581804152351
   Coding: 00971E66C24102FF0B844084B11C07281C80000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 7DBD7AF4EC921AAAC5-8028
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150423  042 0607
   Serial number:         150428172758
   Component: RLHS  037 0059
   Serial number: S4Y15M05D11H06M35S39
   Coding: 90A8EE
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 28 02 2015  00000295
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150891XZM
   Serial number: 00000000000032331585
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 L    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0132
   Serial number: ATW-00122.04.15
   Coding: 0471163151
   Shop #: WSC 05311 115 00073
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_VW48.rod
   VCID: 48D3DB20F3D08F0226-801C
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0130
   Coding: 32C067CB18FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 33299CCC9A561CDA63-8066
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 28041541350352
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76AF65D8C9A449F284-8022
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1P8BRA9Z
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 01450604906A7E4AA1-8054
   Belt Pretensioner left:
   Serial number: 3G1857705E0127P00076
   Coding: 80000A
   Belt Pretensioner right:
   Serial number: 3G1857706E0127P00425
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 000 405 15
   Serial number: 3576U000000499CC641M
   Subsystem 4 - Part No SW: -----------    HW: 454 000 405 15
   Serial number: 3586U000000089CC641I
   Subsystem 5 - Part No SW: -----------    HW: 454 800 405 15
   Serial number: 3516R90908B06000000%
   Subsystem 6 - Part No SW: -----------    HW: 454 802 804 15
   Serial number: 3526RB3A2AE06000000D
   Subsystem 7 - Part No SW: -----------    HW: 454 802 504 15
   Serial number: 3556V2B2F5A06000000F
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150429400063
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FC1C0FCA61EC8BA97-806A
   Part No SW: 3G0 920 798 A    HW: 3G0 920 798 A
   Component: KOMBI         019 0450
   Coding: 07A40898FE84000800886A063001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009041
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 2E1F8DB8717431320C-807A
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 362FA5D8892409F244-8062
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001134820
   Revision: --------    Serial number: 16031510800883
   Coding: 0B0300344F017300EF00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 72A759C8A5CC55D2A8-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000888310055192
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6247145603
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H54 0033
   Serial number: 0061109
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 2404201500010237
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00013.04.15
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_VW48.rod
   VCID: 46CFD518F9C49972D4-8012
   Serial number: 15000078570003
   Coding: 0800000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71A556C4A0CA6ECA51-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 3Q0 959 760 A    HW: 3Q0 959 760 A
   Component: Sitzmemory    H03 0011
   Serial number: Y0006OEG17047
   Coding: 001000020000010081A080808080000000008181000000F4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_VW37.rod
   VCID: 3935AEE4B83AE68AA9-806C
   Serial number: 240415BDN03332
   Coding: 003F1A20D200028000001000
   VCID: 42C7C908D5ECA552F8-8016
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9303
   Shop #: WSC 00015 115 00307
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: 3731A8DC8E2EF0FA5F-8062
   Part No SW: 3Q0 035 466 B    HW: 3Q0 035 466 B
   Component: MIB2_amp_P_VW H40 0170
   Revision: 00000001    Serial number: VWZ8Z1EAT0046KA
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   Serial number: 260415BDP10523
   Coding: 003F1020DE00028200001000
   VCID: 41C5C604D0EABE4AE1-8014
   Component: AFS-ECU       H01 0110
   Coding: 03A203004F210200
   Shop #: WSC 45829 002 1048576
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
5538298 - LED Headlamp; Left
          C1177 F0 [008] - Over-Temp Protection Active
                    Reset counter: 145
                    Mileage: 20236 km
                    Date: 2016.08.24
                    Time: 15:46:59
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 021 A    HW: 3G0 035 021
   Component: MU-H-TND-EU   H41 0199
   Serial number: A596E0FB003512
   Coding: 028402010000000011111202000808101F0106E4012000009F
   VCID: 166F4558E9E4E9F264-8042
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301SC9
   Subsystem 2 - Part No SW: V03 959 800 QL    HW: -----------
   Component: ECE 2015  --- 0105
   Compact Disc Database:
   Component: Gracenote2  --- 1008
   Part No SW: 5Q0 907 273     HW: 5Q0 907 273
   Component: RDKBERU30     H04 0008
   Serial number: 40000000005715
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_VW37.rod
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0404719131
   Coding: 0100000202000000
   Shop #: WSC 60504 001 1048576
   VCID: 3B39B4ECB206D49ABB-806E
Address 6C: Back-up Cam. (J772)       Labels: Redir Fail!
   Part No SW: 5Q0 980 568     HW: 5Q0 980 568
   Component: RVC Compact+  H05 0100
   Coding: 0184020163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_VW37.rod
   VCID: 7AB771E8FDBC2D92E0-802E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 653 E    HW: 3Q0 980 653
   Component: MQB_B_MFK     H08 0120
   Serial number: 130515null0805
   Coding: 000408020000040100262345C040A100940004300040
   ROD: EV_MFKBoschMQBB.rod
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 160415BDE08499
   Coding: 000E10200100028000001000
   VCID: 44CBCF10CFF8AB62CA-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      020 0028
   Serial number: 160415BDE09175
Address CA: Sunroof (J245)       Labels: None
   Part No SW: 4M0 907 594 B    HW: 4M0 907 594
   Component: SAD_STG_1     010 0002
   Coding: 608040748202
   ROD: EV_SunRoofCONTIAU736_VW37.rod
   VCID: 352DA2D4942202EA4D-8060
End----------(Elapsed Time: 02:37, VBatt start/end: 12.3V/12.2V)-----------
If there's any data you needed from this car, it's here at the hotel for the week.
golfi_vend
Tartu, Estonia
C?ID=195131
Module A5 is coded to touran :) , byte 16 and 18 is missing information.
Eric
HC800000
Can you see if 16.8.1.3 works with a HUC on address 13?
Sure, will do when I get a chance.
hex.v2.belgium
Belgium
C?ID=293974
Hi Uwe,
did this Passat B8 Wagon also have Lane Assist?
If so this is a very interesting baseline for me to start from in comparing the long coding of the modules...
Hi Uwe,
All I really know about this car is what you see in the scan. I only had access to it for a short time when we were in Frankfurt in September. It belongs to Andy Vetter, one of our German distributors. IIRC, he said it does have Lane Assist but he was not happy at all with the way it worked; I think he said using it would likely get you pulled over for drunk driving. :rolleyes:
