CAN Gateway problem
mikutzu99
Romania
C?ID=277394
Hello, I have a problem with a Skoda Octavia 2. CAN Gateway can you help me?
Wednesday,31,August,2016,17:19:28:14813
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: TMBCS41ZX62232467   License Plate: PH 27 BBU
Mileage: 429910km-267133mi   Repair Order: 1
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 7D
VIN: TMBCS41ZX62232467   Mileage: 429910km-267133miles
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 DJ    HW: 028 101 188 3
   Component: R4 1,9L EDC G000SG  6250
   Revision: 12345678    Serial number: SKZ7Z0F3464767
   Coding: 0050071
   Shop #: WSC 73430 790 00000
   VCID: 6ED3BAED79AED83242-803A
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021633
   VCID: 71E9A1916890C7CA5F-8024
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   VCID: 346768855702B2E274-8060
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000003938751
   Coding: 00020E130004140000110D000000000000087B065C
   VCID: 2A5B76FD85C6F412DE-807E
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 07 AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR0AJVEB
   Coding: 0012343
   Shop #: WSC 10200 599 94742
   VCID: 7DF18DA124C8B3AACB-8028
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E3928D01FEE0F28A-8022
   Part No: 1Z0 920 841 E
   Component: KOMBIINSTRUMENT VD1 0920
   Coding: 0004101
   Shop #: WSC 12345 012 32131
   VCID: 387F5CB54B6A568258-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001062030391
   Coding: 7D0F0B40071302
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 124
                    Mileage: 429823 km
                    Time: 00:38:45
                    Fault Frequency: 48
                    Reset counter: 164
                    Mileage: 429823 km
                    Time: 00:52:50
01304 - Radio
                    Fault Frequency: 44
                    Reset counter: 164
                    Mileage: 429823 km
                    Time: 00:53:02
   Component: IMMO            VD1 0920
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2345
   Coding: 0000244
   VCID: 3663528D417EA0F24A-8062
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 000    3305
   Revision: 00H22000
   VCID: 377D5F89467459FA51-8062
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 18D002407F2D0F0FC84BC61004CC
   Shop #: WSC 73430 790 12345
   VCID: 79F999B130E08F8AE7-802C
   Subsystem 5 - Part No: 1Z0 951 171 A
   Component: NeigungsSensor  008 4802
   Coding: 00000000
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 7 - Part No: 1Z0 951 171 A
   Component: Innenraumueberw.008 4802
   Part No: 1T0 959 702 B
   Coding: 0000244
   Part No: 1T0 907 357
   Coding: 0000007
   VCID: 74E7A8851782F2E2B4-8020
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       013 0029
   Revision: 00013000    Serial number: SKZ7Z3F0121543
   Coding: 0000200
   Shop #: WSC 10112 599 82830
   VCID: 2D517DE1B428E32A3B-8078
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End-------------------------(Elapsed Time: 01:33)--------------------------
The One
Australia
C?ID=277442
Your infotainmant is runing on single wire mode - open circuit. Check all CAN wires @ radio 56 (communication error) to gateway 19, you've either got a broken wire in one of your CAN HIGH or CAN LOW wires, pushed out pin @ radio or gateway, or your radio/gateway is bad (more than likely break in one of the CAN wires). I would scope can signal from 56 radio to 19 gateway, you'll need a wiring diagram.
   Coding: 0050071
   Revision: 00H13001
   Coding: 0021633
   Coding: 00065525
   Shop #: WSC 73430
   Coding: 0012343
   Coding: 0000042
   Coding: 0004101
                    Reset counter: 124
                    Mileage: 429823 km
                    Time: 00:38:45
                    Fault Frequency: 48
                    Reset counter: 164
                    Mileage: 429823 km
                    Time: 00:52:50
01304 - Radio
                    Fault Frequency: 44
                    Reset counter: 164
                    Mileage: 429823 km
                    Time: 00:53:02
   Coding: 0000244
   Revision: 00H22000
   Coding: 00000000
   Coding: 0000244
   Coding: 0000007
   Coding: 0000200
mikutzu99
Romania
C?ID=277394
Can you give the diagram for this, please. Because i don't have!
Jef
HQ
You can get the factory wiring diagram via the ERWIN service:
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
But some simple dirty testing you can try with a simple volt meter... unplug the radio and locate the orange twisted wires (Gateway wiring) and with the ignition turned on, see if you have some sort of voltage signal across those 2 wires. It doesn't matter which wire you hook the red VS black leads up to. What you are looking for is any kind of voltage signal to show that the Gateway wiring is to design. If there is no voltage, then put the black lead to chassis ground (clean metal) and see if one of the wires has some sort of voltage signal. If you find 1 wire does, and the other doesn't, then you need to trace out the wire that doesn't have voltage.
Also verify your power/grounds are good at the radio as well. It looks like you should find 2 large red/white wires for power, and a large brown wire for ground.
