Audi A6 C5 1998 TCS light on
   #21
MartinsX
Riga, Latvia
C?ID=268515
It depends on installer of alarm system. Almost every car alarm have at least one "blocking" circuit that don't allow engine to start if alarm is triggered. Installer can use it or not. He can freely take any circuit of car's wiring, cut it and add a relay, controlled by car alarm. Some simply installations blocks starter or fuel pump. More advanced ones interrupts power supply of whole ECU or some ECU sensor circuits. As You know at the end of 90's Audi was one of most stolen brands in Eastern Europe. If alarm was installed when this car was new and expensive, probably You will find a lot of surprises in wiring :D
   #22
Paulius
C?ID=225211
You are absolutely right! I think i am going to remove this. It was good thing 10 years ago but yust pain in the ass right now.Thanks for you help. I will let you know if i will succeed.
   #23
MartinsX
Riga, Latvia
C?ID=268515
You can leave alarm and remote control, just remove blocking relays and connect back original wires to ECU ;)
   #24
NostraJackAss
I would remove all of that ............
Don't like.............
Hide a toggle switch if that concerned.
   #25
Paulius
C?ID=225211
Good idea. Two wires is splitted and connected by relays. Red/Black and Blue/Black. One more thing to mention, when I turn ignition on, i can't see ABS light, but at night i barely see that abs light is on just possible hidden under black tape :)
   #28
Paulius
C?ID=225211
Some news for you guys. So, I managed to remove TCS light and engine cutting off issue. Problem was faulty alarm relay. Now I can start the car without turning ignition off and on :) Sad, but it didn't fix fault code on ABS module. Still the same code and I think that ABS light is still on, just I can't see it on day time.
NostraJackAss
Check communications between engine and ABS as per WD and advanced VCDS blocks for broadcast verification.
   #30
Paulius
C?ID=225211
News for you guys. I checked the wiring from ABS module to instrument cluster and it looks fine. Also, I removed instrument cluster and I was hoping to find black tape under ABS light but there was nothing. So, I suspected burned LED. I checked resistance between ABS LED and it was 0.335 KOhms and the light which is working for example Airbag LED is 0.245 KOhms. It is not a big difference but I am not sure is it right or not. What do you think about that?
   #31
Paulius
C?ID=225211
LED is burnt. I am just wondering can burnt led give 00647 code...
   #33
MartinsX
Riga, Latvia
C?ID=268515
Damaged LED can't give fault code. LED could be damaged by someone who didn't know how to hide indication that ABS have faults but wanted to do it.
   #34
Paulius
C?ID=225211
I checked all wires from ABS module except 10 and 11 pins. I am not sure how to check it because these wires is going to microchip. Any idea how to check them?
   #35
MartinsX
Riga, Latvia
C?ID=268515
Pin 11 (A76) is K-line. If You have no connection here, You can't connect with diagnostics.
Pin 10 (A120) is called "stationary time". I have never pay attention what is this signal for. But it is not "ABS-TCS / Engine; Electrical Connection 2".
Try to recode ECU to match Your A6, as it is from A4.
Paulius
C?ID=225211
When I do Auto-Scan or when I go to ABS module and I choose Faults, I can't see this fault anymore. The only thing is left when I go to ABS module and after I connect to it, Instrument cluster gives me TCS light and big handbrake sign in the middle together with 3 beeps. The same is when I do auto-scan. No fault, but tcs light, huge handbrake sign and 3 beeps. Possible, abs light would come on aswell, but it looks like somebody had this abs problem for so long time, that abs led is burnt :D I was thinking maybe my ecu not matching with my abs module? If somebody changed ecu but left the same abs module maybe it doesn't match?
Wednesday,14,September,2016,19:29:17:15269
VCDS Version: 16.8.0.0 (x64)
Data version: 20160731 DS254
VIN: License Plate: 20160914
Mileage: 305260km-189679mi Repair Order:
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
75 76 77
Mileage: 305260km-189679miles
Address 01: Engine Labels: 078-907-551-ACK.lbl
Part No: 4D0 907 551 AE
Component: 2.8L V6/5V MOTR HS D02
Coding: 05102
Shop #: WSC 00111
VCID: 69DE34AA1342470A14-4B40
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 C
Component: ABS/ASR 5.3 FRONT D00
Coding: 00000
Shop #: WSC 02325
VCID: 1E3457769A8C70B2B1-5164
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D55
Coding: 00060
Shop #: WSC 02325
VCID: 1E3457769A8C70B2B1-258C
Address 15: Airbags Labels: 4B0-959-655-AI7.lbl
Part No: 4B0 959 655 J
Component: Airbag 7 Audi 0501
Coding: 00106
Shop #: WSC 02324
VCID: 377AA2D2157621FA52-5164
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 881 AX
Component: C5-KOMBIINSTR. VDO D19
Coding: 05062
Shop #: WSC 37826
VCID: 03020602112EBD5ABE-5164
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0D2574982
IMMO-IDENTNR: AUZ7Z0D2574982
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 A
Component: Zentralverriegelung D30
Coding: 04672
Shop #: WSC 02325
VCID: 275A7292C5D6B17AC2-4F0E
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D000
Coding: 00005
Shop #: WSC 02325
VCID: 65C6389AFF5A636A30-51DA
End-------------------------(Elapsed Time: 05:33)--------------------------
   #37
MartinsX
Riga, Latvia
C?ID=268515
Several brake warnings are normal when You connect to ABS with VCDS or whatever diagnostic equipment. If no fault codes stored and no warning lights on, You are done!
P.S. The same story for airbag - warning light in dashboard on when diagnostic equipment in active connection to Airbag module.
   #38
Paulius
C?ID=225211
Would be great if it's true :) I will try to change ABS led and if the light will not stay, i am done. Thank you MartinsX for your patient, you are really helpful. I am glad that I met you :)
