Audi A6 C5 1998 TCS light on
Paulius
C?ID=225211
Hello fellas, i hope you are doing well. I have a TCS light on and a code 00647 - ABS-TCS / Engine; Electrical Connection 2 35-10 - - - Intermittent. Any ideas how to fix it? I already changed ABS pump Electric side but the code is still the same. I checked continuity on the wire from Abs electric side to ECU and it looks fine. Car is Audi A6 C5 1998 2.8. Any ideas?
Friday,05,August,2016,16:20:21:15269
VCDS Version: 16.8.0.0 (x64)
Data version: 20160731 DS254
VIN:    License Plate: A6
Mileage: 302500km-187964mi   Repair Order:
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
          75 76 77
   Mileage: 302500km-187964miles
Address 01: Engine        Labels: 078-907-551-ACK.lbl
   Part No: 4D0 907 551 AE
   Component: 2.8L V6/5V  MOTR HS D02
   Coding: 05102
   Shop #: WSC 00111
   VCID: 69DE34AA1342470A14-4B26
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
            26-10 - Output Open - Intermittent
Readiness: N/A
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 8E0 614 111 C
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00000
   Shop #: WSC 02325
   VCID: 1E3457769A8C70B2B1-5164
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 G
   Component: A6-Klimavollautomat D55
   Coding: 00060
   Shop #: WSC 02325
   VCID: 1E3457769A8C70B2B1-258C
Address 15: Airbags        Labels: 4B0-959-655-AI7.lbl
   Part No: 4B0 959 655 J
   Component: Airbag 7 Audi      0501
   Coding: 00106
   Shop #: WSC 02324
   VCID: 377AA2D2157621FA52-5182
Address 17: Instruments        Labels: 4B0-919-xxx-17.lbl
   Part No: 4B0 919 881 AX
   Component: C5-KOMBIINSTR. VDO D19
   Coding: 05062
   Shop #: WSC 37826
   VCID: 03020602112EBD5ABE-5164
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: AUZ7Z0D2574982
   IMMO-IDENTNR: AUZ7Z0D2574982
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 A
   Component: Zentralverriegelung D30
   Coding: 04672
   Shop #: WSC 02325
   VCID: 275A7292C5D6B17AC2-4F0E
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D000
   Coding: 00005
   Shop #: WSC 02325
   VCID: 65C6389AFF5A636A30-51DA
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 186
   Component:  Radio             0001
   Coding: 00205
   Shop #: WSC 02325
   VCID: 5DB6107AD70A2BAAE8-4B26
00852 - Loudspeaker(s); Front
            36-10 - Open Circuit - Intermittent
00854 - Radio Display Output in dash Panel insert
My money is on a failing ABS control module.
Paulius
C?ID=225211
I have changed ABS control module from another car with no lights. It looks like that my engine is swapped. On VIN plate is ALF which is 2.4 ,but if i check car by vin decoder it's ALG witch is 2.8. Maybe the pump is not for this engine.
MartinsX
Riga, Latvia
C?ID=268515
   [COLOR="#FF0000"]Coding: 00000[/COLOR]
   Shop #: WSC 02325
Code the replaced ABS module first ;)
Paulius
C?ID=225211
   Shop #: WSC 02325
It is coded ;)
000?x: Engine
0 = Gasoline Engine 2.4l-2.8l (without CAN-Databus)
1 = Diesel Engine
2 = Gasoline Engine 1.8T
3 = Gasoline Engine 2.4l-2.8l (with CAN-Databus)
000x?: Transmission
0 = Manual Transmission (012) (without CAN-Databus)
1 = Automatic Transmission (01V) (with CAN-Databus)
2 = Manual Transmission (01E) (with CAN-Databus)
3 = Multitronic (01J) (with CAN-Databus)
3 = Automatic Transmission (01V) (without CAN-Databus)
MartinsX
Riga, Latvia
C?ID=268515
It's good You know the coding table, but as we can see by Your autoscan, module is not coded.
Paulius
C?ID=225211
I replaced ABS electric side which had 00003 coding. I coded to 00000 and ecu accepted it. What do you mean it's not coded?
MartinsX
Riga, Latvia
C?ID=268515
Sorry, I didn't look carefully enough to all equipment of Your car. In Your case coding must be 00000. If module is not coded at all, it is 00000, too. Sorry!
8E0614111C fits both 2,4 and 2,8l engines.
MartinsX
Riga, Latvia
C?ID=268515
Check wiring from ABS pin 27 to ECU pin 5. Green/black wire, goes through 2 multipin connectors: T15u - red in ECU housing, pin 7 and T10au - gray at right A-pillar connection point, pin 2.
Paulius
C?ID=225211
Hello, I just checked the ABS pin 27 to Ecu pin 5 wiring and it has continuity. Any more ideas?
MartinsX
Riga, Latvia
C?ID=268515
Does the part number on ECU match that one recognized by VCDS: 4D0907551AE?
Paulius
C?ID=225211
One more thing to mention. When TCS light is on I can't connect to 01-Engine module. Usually, when i turn on the ignition, the TCS light is on and I can't start the car. I turn off the ignition, turn on ignition again and usually it will be gone, sometimes it takes couple of times until TCS light is gone. When it's gone, I can start the engine, but sometimes when I am on the road, engine cuts and I have to restart it.
Paulius
C?ID=225211
Yes, it does.
MartinsX
Riga, Latvia
C?ID=268515
As far as I can see by spare parts catalogue 4D0907551AE is for ALG engine but for Audi A4 or VW Passat B5. Probably wiring/pinouts are not 100% the same on A6.
Try to compare WD for A4 and A6 for connections of ABS and ECU
Paulius
C?ID=225211
I will try to compare A4 and A6 WD. What do you think about engine cutting off with no reason and no communication with ecu when the TCS light is on?
MartinsX
Riga, Latvia
C?ID=268515
I have seen exactly the same. Exactly ALF on sticker and another engine installed in car. It could be some missprinting of sticker, as VIN is on the same sticker. Don't care for it, let's focus on different ECU's and pinouts. You should have 4D0907551AF with ALG in A6.
MartinsX
Riga, Latvia
C?ID=268515
By some reason ECU has interruptions of power supply. Main relay, aftermarket additional alarm/imo.
MartinsX
Riga, Latvia
C?ID=268515
Actually this is the most important information. Probably You can leave alone ECU versions and ABS connections and check power supply circuits of ECU.
Paulius
C?ID=225211
As I see you live in Latvia. Greeting from Lithuania ;) In my car i have Sheriff alarm. It's Russian alarm system. Do you think it could effect ABS and ecu intermittent power loss?
