Code (G201 Implausible Signal)
jgxironman
C?ID=271122
Been having some issues with my ABS ran some codes today let me know what you think
Thursday,08,September,2016,11:09:17:00886
VCDS Release 16.8.1 (x64):  Generic OBD2
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P2404 - EVAP Leak Detection Pump Sense Circuit: Implausible Signal
Address 7EC: No fault code found.
Thursday,08,September,2016,11:14:18:00886
VCDS Version: Release 16.8.1 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 4F0-910-517.lbl
Control Module Part Number: 4F0 910 517 L    HW: 4F0 614 517 L
  Component and/or Version: ESP 8.0 quattro H03 0090
           Software Coding: 0020895
            Work Shop Code: WSC 23435 444 53523
                      VCID: 2D508ACFB412482A35-8078
                    Fault Status: 01101000
                    Reset counter: 151
                    Mileage: 202763 km
                    Date: 2016.09.08
                    Time: 11:11:33
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x001C
                    Hex Value: 0xB19C
                    Hex Value: 0x00FF
                    Reset counter: 151
                    Mileage: 202763 km
                    Date: 2016.09.08
                    Time: 11:11:33
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x002D
                    Hex Value: 0x059C
                    Hex Value: 0x00FF
Been here?
jgxironman
C?ID=271122
I have been there, but the lights came on at the same time so I wanted to see if there was any ideas since they came up together.
jgxironman
C?ID=271122
I'll look this afternoon but here is a full scan. Also it happened just driving normally with no charge of parts.
Thursday,08,September,2016,11:07:28:00886
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WAUDG74F85N116221   License Plate: GHP670
Mileage: 202760km-125989mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53 55
          56 61 62 67 72 77
VIN: WAUDG74F85N116221   Mileage: 202760km-125989miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0020
   Revision: --H15---    Serial number:
   Coding: 01050109190F0120
   Shop #: WSC 23435 444 82899
   VCID: 2B5484D78A06461A2B-807E
               P1653 - 008 -
                    Mileage: 173200 km
                    Date: 2005.02.06
                    Time: 06:46:34
                    RPM: 864 /min
                    Mass Air / Rev.: 87.2 mg/str
                    Temperature: 91.5°C
                        Idle
                    Load: 14.9 %
009220 - EVAP Leak Detection Pump Sense Circuit
               P2404 - 006 - Implausible Signal - MIL ON
                    Fault Status: 10100001
                    Mileage: 173200 km
                    Date: 2005.02.06
                    Time: 10:14:14
                    RPM: 1824 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Temperature: 51.0°C
                        Overrun
                    Voltage: 12.65 V
                    Speed: 29.0 km/h
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        4018127
   Coding: 0000002
   Shop #: WSC 02327 785 00200
   VCID: 29587EDF80FA540AD9-807C
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0020895
   Shop #: WSC 23435 444 53523
00265 - ABS Outlet Valve; Front Left (N102)
            000 -  -
                    Reset counter: 151
                    Mileage: 178409 km
                    Date: 2005.09.22
                    Time: 21:38:20
                    Hex Value: 0x0000
                    Hex Value: 0x5782
                    Hex Value: 0x000C
                    Hex Value: 0xB868
                    Hex Value: 0x00FF
                    Reset counter: 151
                    Mileage: 160817 km
                    Date: 2014.02.16
                    Time: 18:16:37
                    Hex Value: 0x1A00
                    Hex Value: 0x4702
                    Hex Value: 0x001C
                    Hex Value: 0xB1AA
                    Hex Value: 0x00FF
                    Fault Frequency: 191
                    Reset counter: 151
                    Mileage: 200251 km
                    Date: 2016.07.28
                    Time: 16:39:08
                    Hex Value: 0x00C0
                    Hex Value: 0x4782
                    Hex Value: 0x002D
                    Hex Value: 0x0599
                    Hex Value: 0x00FF
01420 - High Pressure Switch Valve 1 for Electronic Stability Program (N227)
            000 -  -  - Intermittent
                    Reset counter: 185
                    Mileage: 201084 km
                    Date: 2016.08.15
                    Time: 15:03:26
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0018
                    Hex Value: 0xC0A4
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0160
   Revision: 27100401    Serial number: 10600300153793
   Coding: 0000011
   Shop #: WSC 23597 444 12572
   VCID: 63C42CF7A256CE5AD3-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H44 0070
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H39 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 730 E    HW: 4E0 035 729
   Component: Interfacebox    H43 1070
   Revision: 00000000    Serial number: 360DT057522959
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 23446CF7E2D68E5A93-8076
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000131899
   Subsystem 3 - Serial number: 0130.03.050000000100010389ÿ
   Subsystem 4 - Serial number: 010389ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0150
   Revision: 00000026    Serial number: 00000000132056
   Coding: 0524326
   VCID: 5BB414179A26F69A9B-800E
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 153624 km
                    Date: 2013.07.31
                    Time: 14:07:31
                    Temperature: 28.0°C
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   VCID: 66C235E35164BB7234-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
                    Fault Status: 00101010
                    Reset counter: 174
                    Mileage: 200656 km
                    Date: 2016.08.05
                    Time: 22:07:00
                    Fault Status: 01101010
                    Reset counter: 151
                    Mileage: 173224 km
                    Date: 2005.02.07
                    Time: 14:08:00
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7141452
   VCID: 1B345417DAA6B69A5B-804E
                    Reset counter: 185
                    Mileage: 202652 km
                    Date: 2016.09.06
                    Time: 14:34:04
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH30 0300
   Revision: 15H30000    Serial number: 00359D0G2U4$
   Coding: 0013878
   VCID: 2A5A81D385FC5F12D0-807E
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME093C662BA
   Subsystem 3 - Serial number: 6342CSME093C6007%
   Subsystem 4 - Serial number: 6351HSME07075830/
   Subsystem 5 - Serial number: 6361HSME070A0C120
   Subsystem 6 - Serial number: 6371VSME07284157H
   Subsystem 7 - Serial number: 6381VSME070C4871N
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026050910204
   Coding: 0002041
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H10 0630
   Revision: 00800000    Serial number: 4R810Y345
   Coding: 2113263
   Shop #: WSC 23597 444 84415
   VCID: 1E325D03C9B4A3B2BC-804A
Address 19: CAN Gateway        Labels: 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 1200805330804D
   Coding: 6CFE73CC1B5104
   Shop #: WSC 02325 785 00200
   VCID: 275C78E796EE627ACF-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   VCID: 61C826FFB84ADC4AC1-8034
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00-00000
   Coding: 0035563
                    Reset counter: 191
                    Mileage: 158411 km
                    Date: 2013.12.17
                    Time: 18:57:58
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H15 0100
   Revision: 01000015    Serial number: 01003516090000
   Coding: 0423997
   VCID: 2C5687CB8F08412222-8078
   Component: LIN BACKUP HORN H02 1301
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
   Component: DSP-High C6     H14 0310
   Revision: PROD_01     Serial number: 00000000028312
   Coding: 0000026
   VCID: 24466FEBE7D88962EA-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000081459
   Coding: 0001114
   VCID: 5EB21D038934E3B2FC-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00-00000
   Coding: 0035563
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DB01A0F8432F8AAE5-8008
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Frequency: 193
                    Reset counter: 74
                    Mileage: 200248 km
                    Date: 2016.07.28
                    Time: 15:31:40
                    Voltage: 10.97 V
                    Count: 116
                    Fault Status: 00101101
                    Reset counter: 191
                    Mileage: 178408 km
                    Date: 2005.09.22
                    Time: 22:24:24
                    Voltage: 12.01 V
                    Count: 236
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000016
   VCID: 285E7BDB9BF06D02C6-807C
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394DQ057534343
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000013511
   Shop #: WSC 23435 444 58960
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2503120128
   Coding: 344630393135313035432056413032353033313230313238
   Shop #: WSC 00000 384 00290
02273 - Quiescent Current Stage 2
                    Fault Frequency: 220
                    Mileage: 150464 km
                    Date: 2013.04.05
                    Time: 12:42:17
02276 - Quiescent Current Stage 5
                    Fault Frequency: 199
                    Mileage: 150464 km
                    Date: 2013.04.05
                    Time: 12:42:27
02274 - Quiescent Current Stage 3
                    Fault Frequency: 195
                    Mileage: 150464 km
                    Date: 2013.04.05
                    Time: 12:42:38
02277 - Quiescent Current Stage 6
                    Mileage: 150464 km
                    Date: 2013.04.05
                    Time: 12:42:48
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0035370
   VCID: 69D83EDF407A940A19-803C
   Part No SW: 4E0 910 753 S    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0550
   Revision: 00000000    Serial number: 00000503290244
   Shop #: WSC 12336 024 394758
   VCID: 3560A2AF5C4200EA4D-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0035370
   Part No SW: 4F0 910 336 A    HW: 4E0 862 335
   Component: Handyvorb2      H10 0120
   Revision: 00000000    Serial number: 00000007520949
   Coding: 0010900
   VCID: 214866FFF8CA9C4A81-8074
End-------------------------(Elapsed Time: 02:30)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Internal faults of ESP module. Time to look for replacement one.
NostraJackAss
Take unit apart and re-solder the welds first.........if unsuccessful buy a new module.
MartinsX
Riga, Latvia
C?ID=268515
Have You did any successful internal repairs of Bosch ABS/ESP 8.0, Jack? I have repaired 5.3 and 5.7 by myself. For 8.0 I can't find any information someone repaired those successfully.
NostraJackAss
Affirmative ............same crap channel............. same crap shovel joints..........just do them all.
Stay tuned for the next episode of Bosch crimp weld follies.........lets do it again!
Retarded.........!
MartinsX
Riga, Latvia
C?ID=268515
Ok, Jack, probably I'm retarded with Bosch 8.0. Will try to take apart some bad ones laying somewhere under my table :D
BTW have You find any chemicals able to wash away silicone gel like in this video (0:35-0:40)? https://www.youtube.com/watch?v=NxumtQskqTY
NostraJackAss
MEK = Methyl Ethyl Ketone
Martin you are far from retarded from what I have observed so far.
Be forewarned I can be an asshole sometimes both intentionally & unintentionally.
It's not my fault.....I'm product of my environment, & I pass that buck to my parental units, however, I accept their responsibility.
:cool:
MartinsX
Riga, Latvia
C?ID=268515
MEK = Methyl Ethyl Ketone =C4H8O, also called butanone? Will try.
