ABS fault on VW Fox
CRSperformance
C?ID=266451
I am trying to repair a VW Fox 1.2 basic car . The other day the ABS Light came on and the brakes went into a massive judder ( like the ABS pump working but vicious ) , the Vag com shows front drivers side speed sensor faulty , I replaced it but the light continued to come on as you accelerate away , I replaced the bearing on that side also and the fault now comes on when you reach a speed of 20 to 30 MPH I have driven the car measuring the blocks and you can see the right front wheel clitching and the speed reading suddenly drops momentarily , and light comes on . Must say the car had a bashing on the same corner the hub took a big knock but no damage to the wires . I have pulled and pushed on the cables and cant find any pattern to the fault , Could the hub be a problem .
thanks
Dutchie
C?ID=125479
Please post an autoscan.
MartinsX
Riga, Latvia
C?ID=268515
BTW Front Driver Side in UK is the right side, in other world the left side. Maybe You have to replace front left ABS sensor?
CRSperformance
C?ID=266451
The right hand side of the car had the bashing here in UK the drivers side . The vag com continues to say the front right sensor , but changed it already and no better after a new bearing still shows fault , didnt fit genuine bearing from VW just a generic one from a spares shop . have done this before and no issues with after market bearings
Ill post the fault report asap , thank you
