asselen
I have replaced an abs module with a used abs module,tried coding with vcds but the system refuses to accept
Can anybody throw some light pleeeeasee..
Following is a copy of an auto scan :
VIN: WVWL091K5AA550307 License Plate: 123
Mileage: 95250km-59185mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWL091K5AA550307 Mileage: 95250km-59185miles
Address 01: Engine Labels: None
Part No SW: 03G 906 056 AC HW: 03G 906 021 AN
Component: R4 1,9L EDC G000AG 5415
Revision: --H11--- Serial number:
Coding: 0000078
Shop #: WSC 73430 790 00000
VCID: 68DFEB5E5BC5857ED6-803C
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 051 S HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1909
Revision: 04844002 Serial number: 00000908281307
Shop #: WSC 44551 111 44551
VCID: 2345BC72E263A62643-8076
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Shop #: WSC 73430 790 00051
VCID: 7AFBA116F56907EE30-802E
Reset counter: 204
Mileage: 95253 km
Date: 2011.01.28
Time: 07:49:50
Count: 16391
Count: 12
Count: 8192
Count: 195
Count: 43520
Count: 512
Fault Status: 01100101
Reset counter: 204
Mileage: 95253 km
Date: 2011.01.28
Time: 07:49:31
Count: 3
Count: 12
Count: 12288
Count: 279
Count: 43520
Count: 512
Reset counter: 204
Mileage: 95253 km
Date: 2011.01.28
Time: 07:49:31
Count: 3
Count: 12
Count: 12288
Count: 295
Count: 43520
Count: 512
Reset counter: 204
Mileage: 95253 km
Date: 2011.01.28
Time: 07:49:31
Count: 3
Count: 12
Count: 12288
Count: 270
Count: 43520
Count: 512
Fault Status: 01101100
Reset counter: 204
Mileage: 95253 km
Date: 2011.01.28
Time: 07:49:52
Count: 7
Count: 12
Count: 12288
Count: 107
Count: 43520
Count: 512
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BR HW: 5K0 907 044 BR
Component: Climatronic H14 0609
Revision: 00003001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: 7CF7A70EF75D39DE22-8028
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 HW: 5K0 937 086
Component: BCM PQ35 M 008 0019
Revision: BC008001
Coding: 40000A3A982DE1E0440800800400012001702388512085605C8000000000
VCID: 71E9863AA81F44B681-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 07070 21 0501
Coding: 009795
Component: RLS 230708 05 54 0402
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 5 - Part No: 1K8 951 171
Reset counter: 244
Term 15 Off
Voltage: 9.35 V
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 27 AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08WG9P
Coding: 0012855
VCID: 6DD19A4A7427A056A5-8038
Subsystem 1 - Serial number: 6332MSME4A132D3FM
Subsystem 2 - Serial number: 6342MSME49450F27I
Subsystem 3 - Serial number: 6351HSME1D2D5F2CU
Subsystem 4 - Serial number: 6361HSME1D3406724
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001631
VCID: 76E3B5260171638E54-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Part No SW: 5M0 920 870 C HW: 5M0 920 870 C
Component: KOMBI H04 0207
Coding: 171B00
VCID: 2F6D404276AB1246D7-807A
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 070709F1000767
Coding: ED807F06000202001003
VCID: 66C3E56651D1930EE4-8032
Component: IMMO H04 0207
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1520
Revision: 71009005 Serial number: 00000500398714
Coding: 0004790
VCID: 71E9863A681F44B681-8024
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5B51568549776E00-807E
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 8.7 V
PD
Temperature: 28.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1520
Revision: 71009005 Serial number: 00000540588829
Coding: 0005046
VCID: 72EB89366D197FAE78-8026
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Reset counter: 204
Mileage: 94719 km
Date: 2011.01.15
Time: 18:35:18
Fault Frequency: 96
Reset counter: 244
Mileage: 94719 km
Date: 2011.01.15
Time: 18:35:18
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 039 0144
Revision: 00000001 Serial number: VWZ1Z3I5393790
Coding: 0500040004
VCID: 65C1E26A6CD79816ED-8030
03138 - Input AUX IN
Reset counter: 190
Mileage: 94719 km
Date: 2011.01.15
Time: 18:33:03
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000004086875
Coding: 0000144
VCID: 75E1B22A1C7768965D-8020
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000004057546
Coding: 0000144
00099 - Rear Right Central Locking (Safe) Motor (V164)
Reset counter: 204
Mileage: 94719 km
Date: 2011.01.15
Time: 18:35:18
Fault Frequency: 96
Reset counter: 244
Mileage: 94719 km
Date: 2011.01.15
Time: 18:35:18
End-------------------------(Elapsed Time: 02:18)--------------------------
