Problems with 16.8.1
Spacewalker
Poland
C?ID=159607
Uwe .
There is some issue with 16.8.1
I have on the bench lot of stuff, all is good, proper connection etc , doing test every day and last time (after update to 16.8.1) small issue
When you do Autoscan - Missing ROD file and display Unknow Errors ...etc (but not on all controlers)
but when you go do that module - all is ok , but not always
Sometime when you IN, show - missing ROD file , all you need is go back to main screen and go IN again and work
Already tested on 5F module few time , never seen that issue before.
All files are there , checked twice
Split from this thread since I don't see how it's related.
A report of problems like this would be more valuable if you posted the Auto-Scans that exhibit these problems.
MartinsX
Riga, Latvia
C?ID=268515
Similar issue, but probably because of my old, slow and overloaded PC.
When doing autoscan of K line cars, sometimes looks like VCDS is "too fast" for car showing
No Faults Found
or for my computer, showing
 Unlicensed Version. Not all DTCs
If trying to connect directly to each module, everything is ok. Today's scan for example:
Wednesday,07,September,2016,15:25:20:32442
VCDS Version: 16.8.1.1
Data version: 20160902 DS256
VIN: TRUZZZ8N341019357   License Plate:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUZZZ8N341019357   Mileage: 144380km-89713miles
Address 01: Engine        Labels: 06A-906-032-AJQ.lbl
   Part No: 8N0 906 018 BC
   Component: 1.8L R4/5VT         0002
   Coding: 11570
   Shop #: WSC 01236
   VCID: 73E5B5F341CB92DAA5-5140
   TRUZZZ8N341019357     AUZ5Z0CD035108
16795 - Secondary Air Injection System
            P0411 - 35-10 - Incorrect Flow Detected - Intermittent
18010 - Unlicensed Version. Not all DTCs
            P1602 - 35-10 -  - Intermittent
Readiness: 0000 1000
   Part No: 09G 927 750 AL
   Component: AQ 250 6F           0384
   Coding: 0008200
   Shop #: WSC 01236 785 00200
   VCID: 7BF59DD3399BDA9AFD-5140
00260 - Solenoid Valve 2 (N89)
            010 - Open or Short to Plus - Intermittent - MIL ON
17100 - Transmission Input Speed Sensor (G182)
            P0716 - 004 - Implausible Signal - Intermittent - MIL ON
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-F.lbl
   Part No: 8N0 907 379 J
   Coding: 0019473
   VCID: 4385253301EB625AF5-5140
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00040
   Shop #: WSC 01236
   VCID: 285F929FC88DA102C0-2580
No Faults Found
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 D
   Component: Airbag Front+Seite 0000
   Coding: 01102
   Shop #: WSC 01236
   VCID: 41892F3B4BF7704AE7-515E
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 930 Q
   Component: KOMBI+WEGFAHRS. M73 D07
   Coding: 04144
   VCID: 3F8D29C33D0306BA91-4B1A
            49-00 - No Communications
Address 35: Centr. Locks        Labels: 8Nx-962-267.lbl
   Part No: 8N8 962 267 D
   Component: Zentralverrieg.     D09
   Coding: 06720
   Shop #: WSC 01236
   VCID: 428B20374EF16B52FE-4EEA
   Part No: 4B0 035 186 S
   Component: concert II  GRO    0001
   Coding: 00310
   Shop #: WSC 01236
   VCID: 306F7AFFF05DE9C218-4B00
01317 - Unlicensed Version. Not all DTCs
            49-10 - will be decoded. - Intermittent
00856 - Unlicensed Version. Not all DTCs
            36-10 - will be decoded. - Intermittent
End-------------------------(Elapsed Time: 03:52)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Shortly:
HW: Dell Latitude D810, 1,86GHz CPU, 1Gb RAM, 100Gb HDD, split in two logical disks, C drive is 40Gb, approx. 3Gb left free
System: MS WinXP Professional, SP3
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
No Faults Found
You may see some improvement here if you turn on the two "Reduce CPU Usage" options in the Options screen. Give it a try and let us know.
Jason
Shortly:
I tried reproducing this on the slowest PC we have here:
We have three K-Line cars left.
1) A 2001 T4:
Wednesday,07,September,2016,14:19:05:64202
VIN: WV2KB47001H120059   License Plate: EEET4
Mileage: 94620km-58794mi   Repair Order: 16.8.1
Chassis Type: 70 (7D - VW Transporter/Multivan (1996 > 2004))
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
VIN: WV2KB47001H120059   Mileage: 94620km-58794miles
Address 01: Engine        Labels: 022-906-032-AXK.lbl
   Part No: 022 906 032 F
   Component:  MOTRONIC ME7.1 G   0004
   Coding: 00013
   Shop #: WSC 02743
   VCID: 0E18664E4AADAF322A-515A
Address 02: Auto Trans        Labels: 01P-927-733.lbl
   Part No: 01P 927 733 CE
   Component: AG4 Getriebe 01P    4841
   Coding: 00000
   VCID: 78F420965829818290-0960
Address 03: ABS Brakes        Labels: 7D0-907-379.lbl
   Part No: 7D0 907 379 D
   Component: ESP 5.3 T4 FRONT    V26
   Coding: 06639
   Shop #: WSC 02744
   VCID: 3260D2BEFED5ABD26E-515A
   Part No: 7D0 907 040
   Component: CLIMATRONIC         0003
   Coding: 00032
   Shop #: WSC 02743
   VCID: 5FC66B0ADDC756BAF1-2598
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 603 BM
   Component: AIRBAG VW3 -        V04
   Coding: 16973
   Shop #: WSC 02743
   VCID: 75EA29A24F3BFCEA8B-4B18
Address 17: Instruments        Labels: 7D0-920-xxx-17.lbl
   Part No: 7D0 920 905 A
   Component: T4-KOMBIINSTR. VDO V09
   Coding: 03235
   Shop #: WSC 02743
   VCID: 254A39E2BF1BCC6AFB-515A
   Part No: 6N0 909 901
   Coding: 00003
   Shop #: WSC 02743
   VCID: 70E418B63059D9C258-515A
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
   Part No: 6X0 953 257
   Component: IMMO                0008
   Coding: 00001
   Shop #: WSC 00066
   VCID: 7DFA3182770BA4AAC3-4B00
   WV2KB47001H120059     VWZ1Z0A1230888
Address 35: Centr. Locks        Labels: 7D0-959-800.lbl
   Part No: 7D0 959 800 C
   Component:    Funksteuergerát  0001
   Coding: 00001
   Shop #: WSC 02743
   VCID: 2D5AC1C2E7EBF42A33-4B18
   Part No: 1J0 035 180 B
   Component:  Radio DE2         0005
   Coding: 09400
   Shop #: WSC 02743
   VCID: 1E38160E9A4D1FB2BA-51D0
End-------------------------(Elapsed Time: 02:23)--------------------------
2) 2000 New Beetle:
Wednesday,07,September,2016,14:42:29:64202
VIN:    License Plate: EEE-NB
Mileage: 114520km-71159mi   Repair Order: 16.8.1
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
   Mileage: 114520km-71159miles
Address 01: Engine        Labels: 06A-906-032-AVC.lbl
   Part No: 06A 906 032 C
   Component: 1.8l 5VT NB HS  G01 3077
   Coding: 00001
   VCID: 1E38160E9A4D1FB2BA-515A
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-10 - Open Circuit - Intermittent
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
            P1198 - 35-00 - Electrical Malfunction
16518 - Oxygen (Lambda) Sensor B1 S1
            P0134 - 35-00 - No Activity
16522 - Oxygen (Lambda) Sensor B1 S2
            P0138 - 35-00 - Signal too High
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 R
   Component: ASR     20 IE CAN  0001
   Coding: 13204
   Shop #: WSC 00066
   VCID: 4084887640790942E8-4B18
   Part No: 6Q0 909 605 A
   Component: 06 AIRBAG VW5       0003
   Coding: 12342
   Shop #: WSC 00066
   VCID: 356AE9A20FBBBCEA4B-4B18
Address 17: Instruments        Labels: 1C0-920-xx0.lbl
   Part No: 1C0 920 901 F
   Component: KOMBI+WEGFAHRS. M73 V05
   Coding: 07202
   VCID: 1F462B0A9D4716BAB1-4B18
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0XD181495
   Ident.-Nr. Wegfahrs.:VWZ5Z0XD181495
   Component: Gateway K<->CAN    V052
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70E418B63059D9C258-4B18
   Part No: 1J0 959 799 AJ
   Component: 5X Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00066
   VCID: 06085E6E22DDE77292-4B18
   Subsystem 1 - Part No: 1J2959802C
   Component: 5X Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 5X Tõrsteuerger. BF0002r
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 B
   Component: Heckspoiler         0002
   VCID: 2A50CADED605E312D6-51EE
   Part No: 1C0 035 180 E
   Component:  RADIO 3CP         0001
   Coding: 00403
   Shop #: WSC 08113
   VCID: 1A301A1E8665739246-4B18
00853 - Loudspeaker(s); Rear
            36-00 - Open Circuit
End-------------------------(Elapsed Time: 03:15)--------------------------
3) A 1999.5 Mk.4 Jetta:
Wednesday,07,September,2016,14:56:34:64202
VIN:    License Plate: EEE-MX-JETT
Mileage: 325990km-202560mi   Repair Order: 16.8.1
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
   Mileage: 325990km-202560miles
Address 01: Engine        Labels: 06A-906-018-AEG.lbl
   Part No: 06A 906 018 JA
   Component: MOTRONIC M5.9.2  HS V01
   Coding: 00000
   Shop #: WSC 00066
   VCID: 6AD00ADE1685231216-4B00
16806 - Main Catalyst; Bank 1
            P0422 - 35-00 - Efficiency Below Threshold
   Part No: 1J0 907 379 G
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
            35-00 -  -
            35-00 -  -
            16-10 - Signal Outside Specifications - Intermittent
   Part No: 1J0 909 609
   Component:  C AIRBAG VW3 SG   0002
   Coding: 00067
   Shop #: WSC 00066
   VCID: 6CDC0CC61C713D2264-4B64
Address 17: Instruments        Labels: 1J0-919-xxx-17.lbl
   Part No: 1J0 919 951 B
   Component: A4-KOMBIINSTR. VDO V57
   Coding: 00242
   VCID: 2F66DBCAEDE7863A01-5178
   Component: 61 Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 00066
   Subsystem 1 - Part No: 1J1959801C
   Component: 61 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 61 Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 61 Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 61 Tõrsteuerger. HR0002r
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
            35-00 -  -
00913 - Window Regulator Switch; Front Right Driver (E81)
            35-00 -  -
00934 - Electric Window Motor; Rear Left (V26)
            35-10 -  -  - Intermittent
End-------------------------(Elapsed Time: 04:56)--------------------------
I see nothing indicative of the problems described.
Hey, look what I found in our computer bone yard -- a Latitude D800.
This was MY laptop for a while in the previous decade. Wow, it's heavy! It hasn't been used in a while. The most recent version of VCDS on it was 11.11.
FWIW, this computer feels MUCH FASTER than the horrible little EeePC.
Anyway, I scanned the same 3 K-line cars:
2001 T4:
Thursday,30,June,2016,16:04:11:64202
VIN: WV2KB47001H120059   License Plate: D800-T4
   Coding: 00013
   Shop #: WSC 02743
   Coding: 00000
   Coding: 06639
   Shop #: WSC 02744
   Coding: 00032
   Shop #: WSC 02743
   Coding: 16973
   Shop #: WSC 02743
   VCID: 75EA29A24F3BFCEA8B-4B32
   Coding: 03235
   Shop #: WSC 02743
   Coding: 00003
   Shop #: WSC 02743
   Coding: 00001
   Shop #: WSC 00066
   Coding: 00001
   Shop #: WSC 02743
No Faults Found
   Coding: 09400
   Shop #: WSC 02743
   VCID: 1E38160E9A4D1FB2BA-51EE
End-------------------------(Elapsed Time: 02:59)--------------------------
2000 NB:
Thursday,30,June,2016,16:27:07:64202
VIN:    License Plate: D800-NB
   Coding: 00001
   Coding: 13204
   Shop #: WSC 00066
   VCID: 4084887640790942E8-4B00
   Coding: 12342
   Shop #: WSC 00066
   Coding: 07202
   VCID: 1F462B0A9D4716BAB1-4B00
   Coding: 00006
   Shop #: WSC 00066
   Coding: 00257
   Shop #: WSC 00066
   VCID: 06085E6E22DDE77292-4B32
   VCID: 2A50CADED605E312D6-520C
   Coding: 00403
   Shop #: WSC 08113
End-------------------------(Elapsed Time: 03:57)--------------------------
1999.5 Jetta:
Thursday,30,June,2016,16:13:52:64202
VIN:    License Plate: D800-MXJ
          75 76
   Coding: 00000
   Shop #: WSC 00066
   VCID: 6AD00ADE1685231216-4B18
   Coding: 03504
   Shop #: WSC 00066
            35-00 -  -
            35-00 -  -
   Coding: 00067
   Shop #: WSC 00066
   VCID: 6CDC0CC61C713D2264-4B4A
   Coding: 00242
   VCID: 2F66DBCAEDE7863A01-515A
   Coding: 04097
   Shop #: WSC 00066
   VCID: 06085E6E22DDE77292-4B00
            35-00 -  -
            35-00 -  -
End-------------------------(Elapsed Time: 05:57)--------------------------
We have one "glitch" in 35-Central Locks on the T4. Eric is going to put the van on shore-power so we can see if it's reproducible...
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
1) A 2001 T4: ...
2) 2000 New Beetle: ...
3) A 1999.5 Mk.4 Jetta: ...
On the occasions I've seen this myself (see internal thread 5781, and additional emails after) it's been highly correlated with KWP-2000 rather than KWP-1281. My secret decoder ring came out of a cereal box, but I'll hazard a guess the above cars are mostly or fully KWP-1281, whereas the 2004 TT belonging to MartinsX is new enough that it might be some or all KWP-2000.
If your bench Touareg project ever came to fruition, that would be an interesting test.
Jason
True, there's literally nothing with KWP-2000 in any of the three cars I've posted scans from above.
But MartinsX's TT hardly has any either -- looks like only the tranny and the ABS use KWP-2000 and neither of those modules exhibit the problem.
Eric
HC800000
Other than the machine running out of battery, no issue to report. First a scan on my desktop:
Wednesday,07,September,2016,16:48:36:09452
VCDS Version: 16.8.1.1 (x64)
VIN: WV2KB47001H120059   License Plate: 16.8.1-X64-XPS8900
   Coding: 00013
   Shop #: WSC 02743
   VCID: 0E154F634A7389322A-5122
   Coding: 00000
   VCID: 78F909BB58F7A78290-095E
   Coding: 06639
   Shop #: WSC 02744
   VCID: 326DFB93FE0B8DD26E-5140
   Coding: 00032
   Shop #: WSC 02743
   VCID: 5FCB4227DD1970BAF1-2586
   Coding: 16973
   Shop #: WSC 02743
   VCID: 75E7008F4FE5DAEA8B-4B02
   Coding: 03235
   Shop #: WSC 02743
   VCID: 254710CFBFC5EA6AFB-5122
   Coding: 00003
   Shop #: WSC 02743
   VCID: 70E9319B3087FFC258-5140
   Coding: 00001
   Shop #: WSC 00066
   VCID: 7DF718AF77D582AAC3-4AE8
   Coding: 00001
   Shop #: WSC 02743
   VCID: 2D57E8EFE735D22A33-4B02
   Coding: 09400
   Shop #: WSC 02743
   VCID: 1E353F239A9339B2BA-51B6
End-------------------------(Elapsed Time: 03:20)--------------------------
Latitude scan #1
Thursday,30,June,2016,16:55:01:64202
VIN: WV2KB47001H120059   License Plate: ERIC1
   Coding: 00013
   Shop #: WSC 02743
   Coding: 00000
   VCID: 78F420965829818290-0962
   Coding: 06639
   Shop #: WSC 02744
   Coding: 00032
   Shop #: WSC 02743
   Coding: 16973
   Shop #: WSC 02743
   VCID: 75EA29A24F3BFCEA8B-4B4A
   Coding: 03235
   Shop #: WSC 02743
   VCID: 254A39E2BF1BCC6AFB-5178
   Coding: 00003
   Shop #: WSC 02743
   Coding: 00001
   Shop #: WSC 00066
   Coding: 00001
   Shop #: WSC 02743
   VCID: 2D5AC1C2E7EBF42A33-4B00
   Coding: 09400
   Shop #: WSC 02743
End-------------------------(Elapsed Time: 03:23)--------------------------
Latitude scan #2
Thursday,30,June,2016,16:59:00:64202
VIN: WV2KB47001H120059   License Plate: ERIC2
   Coding: 00013
   Shop #: WSC 02743
   VCID: 0E18664E4AADAF322A-513C
   Coding: 00000
   Coding: 06639
   Shop #: WSC 02744
   Coding: 00032
   Shop #: WSC 02743
   Coding: 16973
   Shop #: WSC 02743
   Coding: 03235
   Shop #: WSC 02743
   Coding: 00003
   Shop #: WSC 02743
   Coding: 00001
   Shop #: WSC 00066
   VCID: 7DFA3182770BA4AAC3-4B18
   Coding: 00001
   Shop #: WSC 02743
   Coding: 09400
   Shop #: WSC 02743
End-------------------------(Elapsed Time: 03:22)--------------------------
Latitude scan #3
Thursday,30,June,2016,17:12:56:64202
VIN: WV2KB47001H120059   License Plate: ERIC3
   Coding: 00013
   Shop #: WSC 02743
   Coding: 00000
   Coding: 06639
   Shop #: WSC 02744
   Coding: 00032
   Shop #: WSC 02743
   Coding: 16973
   Shop #: WSC 02743
   Coding: 03235
   Shop #: WSC 02743
   Coding: 00003
   Shop #: WSC 02743
   Coding: 00001
   Shop #: WSC 00066
   Coding: 00001
   Shop #: WSC 02743
   Coding: 09400
   Shop #: WSC 02743
End-------------------------(Elapsed Time: 03:50)--------------------------
Latitude scan #4
Thursday,30,June,2016,17:16:43:64202
VIN: WV2KB47001H120059   License Plate: ERIC4
   Coding: 00013
   Shop #: WSC 02743
   Coding: 00000
   Coding: 06639
   Shop #: WSC 02744
   Coding: 00032
   Shop #: WSC 02743
   VCID: 5FC66B0ADDC756BAF1-2592
   Coding: 16973
   Shop #: WSC 02743
   Coding: 03235
   Shop #: WSC 02743
   Coding: 00003
   Shop #: WSC 02743
   Coding: 00001
   Shop #: WSC 00066
   Coding: 00001
   Shop #: WSC 02743
   Coding: 09400
   Shop #: WSC 02743
Latitude scan #5
Thursday,30,June,2016,17:20:55:64202
VIN: WV2KB47001H120059   License Plate: ERIC5
   Coding: 00013
   Shop #: WSC 02743
   Coding: 00000
   Coding: 06639
   Shop #: WSC 02744
   Coding: 00032
   Shop #: WSC 02743
   Coding: 16973
   Shop #: WSC 02743
   Coding: 03235
   Shop #: WSC 02743
   Coding: 00003
   Shop #: WSC 02743
   Coding: 00001
   Shop #: WSC 00066
   Coding: 00001
   Shop #: WSC 02743
   Coding: 09400
   Shop #: WSC 02743
MartinsX
Riga, Latvia
C?ID=268515
Thanks a lot, Ross-Tech team for investigations!
I did my own investigations, too, and I can say that I can reproduce similar issues only with probably overloaded RAM of computer. If I have multiple large pdf's opened at a time of doing autoscan with VCDS. For example, couple 1000 page wiring diagrams, size of 100Mb each. And this one of my computers was used for testing multiple software without reinstalling Win XP, so registry should be full of old unneeded strings and probably running processes . I'm sure the fresh installation of Win will work perfectly.
I'm more hardware than software guy, not strong in programming science, but my opinion is that MS Windows operating system should have something like "priority list" - what application will get access to hardware resources (CPU, RAM, HDD) first and what last. If some application is already running and using all available RAM and then I start VCDS and do autoscan, some interrupts are taking place.
Yes, this has always been an issue with Windows. Back when I started working on VAG-COM in late 1999, the machine I was using was a dual Pentium 166 (overclocked to 200) running NT4 (Windows 2000 had not yet been released) with 128 MB of RAM. Early on, I concluded that it would have been easier to do it "right" on a 4.77 MHz PC running DOS than on a much more powerful computer running Windows. But it was obvious that making the product for Windows was a market necessity...
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Hrm, there goes that theory. Also, now that I'm reading closer, my interfaces have never spontaneously become unregistered during a scan. So this is Something Else. :)
I still have a fondness for the "Reduce CPU" options, and wouldn't mind seeing MartinsX try them, but I admit I'm without a concrete foundation for the suggestion.
Jason
MartinsX
Riga, Latvia
C?ID=268515
I'm repairing a 2000 Audi A6 C5 2,5 TDI with faulty injection pump right now. I can do multiple autoscans for test purposes. Is it necessary to post everything in forum or better use some forum PM or e-mail of Ross-Tech team?
Feel free to post all of the scans here.
MartinsX
Riga, Latvia
C?ID=268515
Here we go.
Autoscan #1:
Thursday,08,September,2016,22:35:16:32442
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
          75 76 77
   Mileage: 250220km-155479miles
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 4B0 907 401 AA
   Component: 2.5l/4VTEDC 0410SG  D66
   Coding: 01012
   Shop #: WSC 11564
   VCID: 5DB1F34BD74F34AAE3-4B00
01318 - Control Module for Injection Pump (J399)
            37-00 - Faulty
            37-00 - Faulty
00539 - Fuel Temperature Sensor (G81)
            37-00 - Faulty
Readiness: N/A
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 8E0 614 111 AH
   Component: ABS/ASR 5.3 FRONT   D10
   Coding: 00012
   Shop #: WSC 02325
   VCID: 64C7C6AFF42505622C-5140
            35-00 -  -
18258 - Powertrain Data Bus
            P1850 - 35-10 - Missing Message from ECU - Intermittent
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 J
   Component: A6-Klimavollautomat D64
   Coding: 00063
   Shop #: WSC 02325
   VCID: 21498FBBABB7504A87-25A6
Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
   Part No: 4B0 959 655 G
   Component: Airbag Front+Seite 1001
   Coding: 00106
   Shop #: WSC 02325
   VCID: 346776EF0445D5E27C-515E
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 900 C
   Component: C5-KOMBIINSTR. VDO D11
   Coding: 00060
   VCID: 1D31B34B97CF74AAA3-5140
   Component: AUZ7Z0Y1424610
   ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙     AUZ7Z0Y1424610
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 D
   Component: Zentralverriegelung D33
   Coding: 06721
   Shop #: WSC 02325
   VCID: 2A5B6897D6819312D6-4F20
01561 - Rear left door
            59-00 - Can't Unlock
01559 - Unlicensed Version. Not all DTCs
            60-10 - will be decoded. - Intermittent
            61-00 - will be decoded.
            61-00 - Won't De-Safe
End-------------------------(Elapsed Time: 06:13)--------------------------
Address 35 directly:
Thursday,08,September,2016,22:37:45:32442
VCDS Version: Release 16.8.1 Running on Windows XP x86
Control Module Part Number: 4B0 962 258 D
  Component and/or Version: Zentralverriegelung D33
           Software Coding: 06721
            Work Shop Code: WSC 02325
                      VCID: 2A5B6897D6819312D6-4F04
01559 - Drivers Door
            60-10 - Won't Safe - Intermittent
Weird. VCDS intermittently thinking it's unlicensed is not something I recall seeing before.
MartinsX
Riga, Latvia
C?ID=268515
Could it be some USB driver issue? I have several diagnostic software installed on my PC and some are made by similar principle as VCDS - USB to car adapter cable with FTDI or equivalent USB to serial chip + software sending and receiving data to/from car. What if some unneeded driver automatically starts up when I connect VCDS interface? Or left active after another USB device is disconnected? Couple of times after using amateur/enthusiast self made Opel diagnostics I can't connect to any VAG car with VCDS at all. After restart of PC everything works fine again.
I'll set up another PC for work with VAG cars only. Just testing right now. Unfortunately its not possible to take week off just for testing some new equipment. I have to repair real cars for real customers every day. Only nighttime is available for repairing cars for friends of mine and playing with equipment etc. :D
I honestly don't know what it could be. If I had any ideas, I would gladly share them.
I think trying another computer is a good idea.
I might also try just a "clean boot". Use MSCONFIG to disable *everything* in the Startup tab, as well as all non-MS services.
