Problem coding Audi A5 door controller
tech1
C?ID=112762
Hi, this I my first post to this forum. I have been using VCDS for several years without any problems but recently I have encountered a problem whilst attempting to configure a door controller as part of a retrofit to install power folding mirrors to my 2015 Audi A5 Sportback.
The door controllers that came with the car were ‘lowline’ and needed to be replaced with ‘highline’ to support power fold.
I replaced 8T0 959 792 Q with 8T0 959 792 P and 8T0 959 793 Q with 8T0 959 793 P.
I am fairly confident that these are the correct controllers to support power fold mirrors for post 2012 A5’s.
One of the controllers I bought online was originally in an A5 cabriolet and the other was from an A4 Saloon/Sedan. I proceeded to recode both controllers to be A5 Sportback using the same coding as Q version from factory.
The controller that was originally in the A5 cabriolet worked first time and everything behaved as expected. In particular, the window dropped slightly when door was opened with window up and window rose slightly when door was opened with window fully down.
The controller that was originally in the A4 after being recoded to A5 refuses to exhibit A5 behaviour even though the A5 coding is accepted and visible after reopening controller in VCDS. I have tried many variations but it refuses to switch to ‘A5 mode’. The ‘Short Lift Active’ option is one of the features that is ignored. I decided to buy another controller that was again originally from an A4 and this behaves the same. I thought these controllers worked for A4 and A5.
Has anyone experienced this before, is there something I should be doing to further configure the controller or perhaps hard reset them? Perhaps it has additional coding performed at factory that makes it remain in A4 mode?
Any assistance on this would be much appreciated.
tech1
C?ID=112762
Wednesday,07,September,2016,19:04:09:44254
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WAUZZZ8T4GA0XXXXX   License Plate:
Chassis Type: 8T (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72 AC
VIN: WAUZZZ8T4GA0XXXXX   Mileage: 17580km-10923miles
Address 01: Engine (J623-CNHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BG    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8478
   Revision: 85H23---
   Coding: 0A034012232401080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021BG 002006
   ROD: EV_ECM20TDI01104L906021BG.rod
   VCID: 6BDEDF5082292E1A6D-803E
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K2 927 155 R    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H08 0002
   Revision: --H08---    Serial number: 0000001348
   Coding: 000002
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381_AU48.rod
   VCID: 448C54ECCF370162CC-8010
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 421DCC01
   VCID: 071683E0B681EA7AE9-8052
   Part No SW: 8K0 907 064 KE    HW: 8K0 907 064 KE
   Component: BCM2 2.0      H15 0711
   Coding: 01B44040000000000000
   VCID: 7DFAE108E45DB0AAC3-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0815000094093009
   Serial number: 3215000138948012
   Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
   Revision: D1000000    Serial number: 01120820151747
   Coding: 342400A000
   VCID: 6AD0DA5485D3371216-803E
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001146915702
   Coding:
2600001180348FC00081400300001D0D001D43082709020100000800440002010000002400
0000
   Shop #: WSC 06325 123 12345
   VCID: 78F4F01CCB7F958290-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels:
1KX-955-119.CLB
   Component: WWS 030815  H13 0080
   Serial number: SWF15088035107
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels:
8U0-955-559.CLB
   Serial number: 20516632
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000308150638
   Serial number: 3B188EB7000000000001
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003KFDD165LB
   Coding: 30533938363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 489440DCF31F250220-801C
   Serial number: 6334MSME536D572CQ
   Serial number: 6344MSME536D5A0DT
   Serial number: 6352QSME65580E74Q
   Serial number: 6362QSME18500D54E
   Serial number: 63732SME0552167AZ
   Serial number: 63832SME02522470M
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OHJ00073
   Coding: 000036
   VCID: 489440DCFB1F250220-801C
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 984 K    HW: 8T0 920 984 K
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5L+302C8G
   Coding: 33A7300003012600010000
   VCID: 479643E0F6012A7A29-8012
   Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0070
   Revision: 1Y090032    Serial number: 3241Y1570406CD
   Coding: 80CF07FF00
   VCID: 50A468BC034FEDC278-8004
   Serial number: 1576207503
   Serial number: 15217002099011200181
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011D02625001450005
   Shop #: WSC 02391 785 00200
   VCID: 56A89EA421AB83F2A2-8002
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0015033787
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X.rod
   VCID: 3E782604A1DB6BB29A-806A
   Revision: 00002001    Serial number: 0376530414
   Coding: 013B0622A0B900808320043680000047
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011002225C01450005
   VCID: 55AA99A83CAD88EAAB-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001704277
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3A702A14BDF34792A6-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109H$0F8061294
   Coding: 010103020100000001
   VCID: 2B5E1F504AA9EE1A2D-807E
   Part No SW: 8R2 035 666 J    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 0941
   Revision: --------    Serial number: 515HA0F7548298
   Coding: 130101040006A1ED01808B5E00000403E40000020000000000
   VCID: 408458FCD32F1D42E8-8014
   Subsystem 1 - Part No: 8R0 060 884 CR
   Component: EUR 2015  2102
   Component: DU7 High  H42 0104
   Serial number: A130H-0F3436368
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002339117
   Component: CD-Database  6208
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C02224001450005
   VCID: 59B2959850B5AC8A8F-800C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H08 0305
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151971049
   ROD: EV_RDCMA00100.rod
   VCID: 2F660B4076B1923A01-807A
End-------------------------(Elapsed Time: 03:30)--------------------------
tech1
C?ID=112762
Forgot to mention that it's the passenger side that has the problem
tech1
C?ID=112762
Noticed a couple of things in scan. What does BF mean after TSG? Also what does the 0305 mean?
Cheers
German acronyms:
TSG = TuerSteuerGeraet -- Door Control Module
FA = Fahrer -- Driver
BF = BeiFahrer -- Passenger (or more literally co-driver)
0305 is the software version in those modules.
tech1
C?ID=112762
Ok thanks, so supposedly correct module then
tech1
C?ID=112762
I tried adjusting drivers side to be an A4 to see if it applied changes but it stayed in A5 mode with regards to the short lift active, this makes me wonder if additional config is required somewhere else that I'm missing as controllers are accepting coding changes but not acting on the coding
tech1
C?ID=112762
Is there a command in vcds to restart or factory reset a controller?
tech1
C?ID=112762
Also, what would the security code be to allow security access to 792 controller? Maybe I need to login to enable changes. Thanks
rlarsen
Copenhagen, Denmark
C?ID=78998
Unit 42 and 52 are normally coded the same way - so maybe you can just take the coding from 42 and then paste it into 52 - it might be worth a try :)
tech1
C?ID=112762
I gave that a go but no luck, I have tried lots and lots of variations.
tech1
C?ID=112762
Problem resolved, these controllers appear to have additional settings to govern the position of the window regulator when the door is opened/closed if they are fitted to an A5 at factory. Settings not visible in VCDS so its more than just coding the controller to suit A4/A5 as the settings will be missing if originally fitted to A4 and you wish to use on an A5.
South Molton, UK
Do these controllers have any adaptation channels?
If they do, maybe that's where the additional settings are?
andyhud
C?ID=32695
Hi Tech1
Can you elaborate "where" these additional settings were and how you resolved them please?
Many thanks
Andy
