Jetta Mk5 no rear fog light
MartinsX
Riga, Latvia
C?ID=268515
Tuesday,06,September,2016,09:41:25:32442
VCDS Version: 16.8.1.1
Data version: 20160902 DS256
VIN: WVWZZZ1KZ6M663611   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6M663611   Mileage: 143640km-89253miles
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 EM
   Component: SIMOS71 1.6l 2V     9428
   Revision: --H01---    Serial number: VWZ7Z0E2502088
   Coding: 0000071
   Shop #: WSC 38282 000 1048576
   VCID: 6ED3A48779E9BF324A-803A
17698 - Coolant Temp Sensor at Radiator Outlet (G83)
            P1290 - 006 - Signal too Small - Intermittent
                    RPM: 1600 /min
                    Voltage: 4.940 V
                    Temperature: -40.5°C
                    Hex Value: 0x0001
                    RPM: 640 /min
                    Voltage: 5.080 V
                    Hex Value: 0x0001
   Part No: 1K0 907 379 P
   Coding: 0017025
   Shop #: WSC 00066 000 00000
   VCID: 3F8D29C36E0306BA91-806A
   Part No: 1K0 820 047 DF
   Component: Climatic PQ35   090 0505
   VCID: 6BD5AD934AFB4A1A6D-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000000095602
   Coding: 09050E2700041800000A00000F00000000095D035C
   VCID: 2B556D938A7B8A1A2D-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00066
00093 - Terminal 15 for Starting Relevant Consumers
                    Reset counter: 157
                    Mileage: 143648 km
                    Voltage: 12.15 V
01049 - Supply Voltage Term 50
                    Fault Status: 00101100
                    Reset counter: 140
                    Mileage: 139872 km
                    Voltage: 12.30 V
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 1G AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0HU3VX
   Coding: 0012615
   VCID: 377D41E346333EFA59-8062
   Subsystem 1 - Serial number: 6332MSME0B443A08B
   Subsystem 2 - Serial number: 6342MSME0A6B5864M
   Subsystem 3 - Serial number: 6351HSME080D173ED
   Subsystem 4 - Serial number: 6361HSME0805141E1
   Part No SW: 1K0 953 549 AE    HW: 1K0 953 549 AE
   Component: Lenksдulenmodul 634 0070
   Coding: 0000001
   VCID: 75E18BEB1CBF8CEA8B-8020
   Part No: 1K0 920 852 A
   Component: KOMBIINSTRUMENT 3HL 1012
   Coding: 0019103
   Shop #: WSC 09104 002 1048576
   VCID: 275D91A39693AE7AC9-8072
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056288A65
   Coding: 3D3F0340071002
   VCID: 2A5B689785819312D6-807E
   Component: IMMO            3HL 1012
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2475
   Coding: 0000244
   Shop #: WSC 00874 461 82170
00912 - Window Regulator Switch; Front Left (E40)
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326B70F7AD51DBD26E-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 01D802087F2D8405484FC6F011A0
   VCID: 79F987DB30A7E88AEF-802C
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2377
   Coding: 0000244
   Part No: 1K0 035 186 P
   Component: Radio BVX       017 0023
   Coding: 0020200
   VCID: 336575F3524BD2DA65-8066
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2434
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 346776EF5745D5E27C-8060
End-------------------------(Elapsed Time: 01:57)--------------------------
No serious questions, just exchange of experience and maybe someone will have some ideas?
The only one question I have: do the "09, Central Electric" module of this car have some rules to be fulfilled to switch the rear fog light on? Or vice versa, not to switch it on without registering any fault codes? Like Golf MK5 or Passat Variant B6 will not switch on rear wiper if trunk is open (or bad microswitch in trunk lock).
Car is without towbar. Wiring from 09 module to fog light lamp and lamp itself ok. MVB in 09 correctly shows all light switch positions/commands as inputs and 100% output activation of rear fog light, when it switched on. RFL indication in instruments ok. Only no voltage at connector B pin 4. My guess is bad output stage inside 09 module.
Reasons of all other faults are clear to me and will be fixed when this car will came to me next time.
17698 - wiring in engine compartment, near G83;
00093 and 01049 - stupid aftermarket car alarm/additional immo;
00883 - worn-out ignition switch
00912 - bad contacts inside E40, it's "normal" for a lot of cars with window regulator switches placed horizontally in driver's door handle/armrest. Rain and snow gets directly inside switch module every time door is opened.
01134 - by FSM H12 should be replaced each 6 years because of service life of built-in backup battery. This one is 10 years old :-)
00933 - did adaption, will check next time. if this will come back, will look deeper. Could be mechanical problem causing overload of window lifter motor or damaged wiring between door and right A-pillar.
NostraJackAss
Sounds like retrofits...........Beware of voltage values being unacceptable in DTC stamps.
