2013 Audi S4 DSG transmission problems
thowell
C?ID=120044
Hi,
I'm having what I think is a transmission problem with this car. It has the DL501 (0B5) DSG transmission, and it is driving very poorly. It shudders (vibrates) very noticeably when starting or shifting in D, and it surges in both D or M.
The car is not throwing any transmission codes to help narrow the problem down. I'm hoping somebody might be able to suggest some values to log?
Steps taken so far:
1. Drained old ATF. (BTW, when draining the fluid look an odd light tan or very light green color. Can provide pictures if it helps.)
2. Re-filled with 6.25L of RAVENOL J1D2111 following the procedure for correct fluid level.
3. Did a test drive and everything seemed better, but on the next (longer) drive the problems slowly returned.
4. Followed the Basic Setting steps here http://wiki.ross-tech.com/wiki/index.php/7-Speed_S-Tronic_Direct-Shift_Gearbox_(DSG/0B5). All 3 Basic Setting steps completed successfully, but didn't make any noticeable difference.
5. Checked for any new codes between all of these steps but it hasn't thrown any auto trans codes during the entire time.
Auto-Scan:
Saturday,03,September,2016,13:35:56:62027
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WAUBGAFL9DA113356   License Plate:
Mileage: 31970km-19865mi   Repair Order:
Chassis Type: FL (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUBGAFL9DA113356   Mileage: 31970km-19865miles
Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0002
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 3875C55783A1C08258-806C
Readiness: 0010 0100
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
   Component: 0B5 30TFSINAR H01 0004
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001010
   ROD: EV_TCMDL501021_AU48.rod
   VCID: 4085ADB7DB718842E0-8014
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   VCID: 040D61A787E9546284-8050
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H11 0621
   Coding: 0D814000000000000000
   VCID: 010368B398FB414AAF-8054
   Serial number: 2312000161098009
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01310720120951
   Coding: 6600228000
   VCID: 3973C053B0ABD98AA7-806C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000454639701
   Coding: 26000011863CAFE0210040C300003D0D4F9CD308A2090221000008004000030100000030000000
   Shop #: WSC 06325 123 12345
   VCID: 78F50557CB21008298-802C
   Component: WWS 260712  H07 0080
   Serial number: SWF12070265290
   Coding: 00FD11
   Serial number: 20458214
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001207120515
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2D5Q02
   Serial number: C408CD36000000000001
                    Fault Status: 01101100
                    Reset counter: 47
                    Mileage: 31929 km
                    Date: 2016.08.10
                    Time: 23:37:29
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90H8TW
   Coding: 303842354730303030304A55304C384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4A918F9FED4D42123E-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200009NB5
   Serial number: 6334MSME70124B3EF
   Serial number: 6344MSME6F652835O
   Serial number: 6352QSME721F5448N
   Serial number: 6362QSME7E1A0968X
   Serial number: 63732SME111B4774Z
   Serial number: 63832SME0A092D00Y
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120801000928
   Coding: 000036
   VCID: 51A398F3081B71CA7F-8004
   Component: E221 - MFL  H03 0003
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 982 L    HW: 8K0 920 982 L
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBN337V7D
   Coding: 83BF09008301D705020000
   Shop #: WSC 54321 321 11111
   VCID: 3D7BD443A483E5AA8B-8068
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y1271881D6
   Coding: 80C303FF00
   VCID: 448DA1A7C7699462C4-8010
   Serial number: 6083707801
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 002007120001007
   VCID: 2F67FE0B76EF073A09-807A
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000034264172
   Coding: 00581B00000000000000
   VCID: 3B7FDA5BBA97EB9AB5-806E
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13204E00410001
   VCID: 56A96BEF21F516F2AA-8002
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0003459682
   Coding: 100000010001
   Shop #: WSC 55474 001 1048576
   ROD: EV_RCEPSAU48X.rod
   VCID: 346DF1679FC924E274-8060
   Revision: 00002001    Serial number: 0180938853
   Coding: 01060E3A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000550813
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813004952302
   VCID: 2D5BE40374E3752A3B-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55AB6CE33CF31DEAA3-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000077285
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156G00C7619481
   Coding: 020007010000000001
   VCID: 21430833383BA14A8F-8074
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 204GX0C7514384
   Coding: 110200000206E1EF45028F4E00000403140000000000000000
   VCID: 3669CB6F81B536F24A-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130G-0C2508877
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001122586
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C13204000210001
   VCID: 59B360D350EB398A87-800C
   Revision: --H07---    Serial number: 525PA8-J2690SQ
   Coding: 1000006
   VCID: 3875C5574BA1C08258-806C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H07 0304
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120623201651
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   VCID: 72E1377FA55D6AD2A6-8026
End-------------------------(Elapsed Time: 04:00)--------------------------
Advanced Transmission ID:
Saturday,20,August,2016,11:54:28:62027
Mileage: TransAdvId   Repair Order:
Control Module Part Number: 8K2 927 156 M
  Component and/or Version: 0B5 30TFSINAR H01 0004
           Software Coding: 000001
            Work Shop Code: WSC 06325
Advanced Identification/FAZIT
     Identification: TFK-030
     Revision: --H01---
     Date: 05.07.12
     Manufacturer number: 0901
     Test stand number: 1321
Flash Status
     Programming Attempts(application): 1/1
     Successful Attempts(application): 1/1
     Programming Status: 00000000
     Flash Date: 05.12.08
     Flash Date: 0000.00.00
     Flash Tool Code: 00000 000 00000
Software
     UDS: 02.00.03
     ISO15765: 02.00.01
     CAN: 02.14.02
     HiSpd Net: 01.06.00
Misc.
     Hardware number: 0B5 927 156 J
     Workshop System Name: J217
     ASAM Dataset Revision: 001010
Car Info
     Chassis Number: WAUBGAFL9DA113356
VCDS Info:
I also tried logging some things that looked like they might be helpful, but I could really use some guidance here:
Monday,05,September,2016,14:49:13:62027-VCID:4085ADB7DB718842E0-8014,VCDS Version: Release 16.8.0 (x64),Data version: 20160803 DS255
8K2 927 156 M,ADVMB,0B5 30TFSINAR H01 0004,
,,G016,F0,G036,F0,G037,F0,G038,F0,G053,F0,G055,F0,G069,F0,G070,F0,G071,F0,G072,F0,G073,F0,G000,F0,
Marker,TIME,Loc. IDE00085,TIME,Loc. IDE00098,TIME,Loc. IDE00100-ENG98502,TIME,Loc. IDE00101-ENG98502,TIME,Loc. IDE00854-ENG98502,TIME,Loc. IDE00856-ENG98502,TIME,Loc. IDE00876-ENG98502,TIME,Loc. IDE00877-ENG98502,TIME,Loc. IDE00878-ENG98502,TIME,Loc. IDE02720-ENG98502,TIME,Loc. IDE02721-ENG98502,,,
,STAMP,Normed load value,STAMP,Transmission position,STAMP,Engine torque-Data,STAMP,Engine specified torque during transmission intervention-Data,STAMP,Clutch 1 upper adaptation point-Data,STAMP,Clutch 2 upper adaptation point-Data,STAMP,Clutch pressure: clutch 1-Data,STAMP,Clutch pressure: clutch 2-Data,STAMP,Clutch status-Data,STAMP,Transmission input speed (RPM) shaft 1-Data,STAMP,Transmission input speed (RPM) shaft 2-Data,,,
,, %,, ,, Nm,, Nm,, bar,, bar,, bar,, bar,, ,, /min,, /min,,,
,1.63,24.3,1.83,d,2.03,58,0.01,37,0.21,6.311,0.40,5.830,0.60,2.80,0.80,0.01,1.01,Creeping,1.23,0,1.45,0,,,
,3.85,37.3,4.05,d,4.26,123,2.25,115,2.46,6.311,2.64,5.830,2.83,4.22,3.04,0.00,3.24,Start up,3.46,1090,3.65,724,,,
,6.26,49.0,6.51,d,6.76,186,4.51,156,4.77,6.311,5.00,5.830,5.21,2.14,5.40,4.29,5.60,Driving,5.80,1625,6.01,1547,,,
,8.65,59.2,8.85,d,9.05,216,6.97,215,7.20,6.311,7.38,5.830,7.58,5.64,7.78,0.01,8.00,Driving,8.24,1502,8.46,2341,,,
,10.89,71.8,11.08,d,11.28,304,9.26,248,9.50,6.311,9.71,5.830,9.90,6.22,10.10,0.00,10.30,Driving,10.50,2028,10.71,3198,,,
,13.30,12.9,13.51,d,13.76,3261,11.51,333,11.78,6.311,12.02,5.830,12.27,2.72,12.50,7.54,12.71,Driving,12.89,2178,13.10,1930,,,
This car was partially rebuilt before I got it. I set the ATF level to the correct level when I finished the repairs, but I'm now kicking myself for not draining everything out. I can't verify if it had the right fluid when I topped it off. It feels like the clutches might be slipping even though this car has less than 20K miles. I don't mind getting into the transmission, but I don't know if I should be looking at the mechatronic or clutch disks or something else entirely. Does anyone have any suggestions to narrow down the problem?
thowell
C?ID=120044
Any other ideas?
Can anybody recomend values to log that can tell me if the clutches are working correctly?
