Catalytic Converter - reset "readiness" for emission tests on 2005 Audi TT 3.2
   #21
Artstudio56
Verified VCDS-Lite User
Los Angeles, USA
C?ID=417142
I've confirmed the car has a factory MAF and after clearing all the codes and running through all the readiness steps here is the auto scan log:
[CODE]VCDS-Lite Version: Release 1.2
Wednesday, 23 September 2020, 19:30:14:52212
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
Address 01: Engine       Labels: 022-906-032-BMX.LBL
   Controller: 022 906 032 DR
   Component: MOTRONIC ME7.1.1G   9970
   Coding: 0000133
   Shop #: WSC 22308
   VCID: 5ECFD68FC92F
Readiness: 0000 0001
Address 02: Auto Trans       Labels: 02E-300-0xx.LBL
   Controller: 02E 300 046 G
   Component: GSG DSG             0604
   Shop #: WSC 01236
   VCID: 1B499F9B9ABD
Address 03: ABS Brakes       Labels: None
   Controller: 8N0 907 379 K
   Component: ESP ALLRAD MK60     0102
   Coding: 0022548
   Shop #: WSC 01236
   VCID: 44FB04E74783
Address 08: Auto HVAC       Labels: 8N0-820-043.LBL
   Controller: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 2823B057DBEB
Address 15: Airbags       Labels: 8N0-959-655.LBL
   Controller: 8N0 959 655 D
   Component: Airbag Front+Seite 0000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 41F50DF35891
Address 17: Instruments       Labels: 8Nx-920-xxx-17.LBL
   Controller: 8N1 920 980 E
   Component: KOMBI+WEGFAHRS. M73 D07
   Coding: 17262
   Shop #: WSC 22164
   VCID: 380360170B4B
   TRUUF28N241019358     AUZ5Z0CN255010
01304 -  Radio
            49-00 -  No Communications
01305 -  Databus for Infotainment
            37-00 -  Faulty
Address 22: AWD       Labels: 02D-900-554.LBL
   Controller: 02D 900 554 D
   Component: HALDEX LSC  ECC     0011
   VCID: 2135AD73B8D1
Address 35: Centr. Locks       Labels: 8Nx-962-267.LBL
   Controller: 8N7 962 267 F
   Component: Central Lock/Alarm  D09
   Coding: 15900
   Shop #: WSC 01236
   VCID: 43F907FB428D
01366 -  Opened Due to Crash Signal
            35-00 -   -
01371 -  Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -   -
01374 -  Alarm triggered by Terminal 15
            35-00 -   -
01368 -  Alarm triggered by Luggage Compartment Switch
            35-00 -   -
Address 55: Xenon Range       Labels: 4B0-907-357-AUT.LBL
   Controller: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: E5BD79636C79
End   --------------------------------------------------------------------------------------------------
[/CODE]
And the Readiness screen:
I will read into the fuel trim wiki posted above next and give that a try.
   #22
NostraJackAss
Are you doing to to the readii script or individual tests?
Have you attempted a recode default of controller with alternate wsc?
Please list tests and order commenced if you did force generation procedures?
Would you like to do a remote session to see if I can help with this?
   #23
Artstudio56
Los Angeles, USA
C?ID=417142
@Jack@European_Parts Thank you for your continued support with my issue. I went through the various tests I found on this forum 30-46 and 70, 71, and 77. I was not aware there is an actual readiness script I can run. I have not attempted to recode the default controller. I will be testing the fuel trim levels tomorrow and will also post those numbers. If you are available for remote help, I would greatly appreciate it, please let me know if there is a fee involved. Thank you.
   #24
NostraJackAss
I'm too expensive, so I will do it for donation you choose and only accept if successful. :p
I'm tied up next few days & so I suggest you hop to it and do what I aforementioned in questions and go to links I already gave you and start cracking the books!
   #25
United States
Hi guys,
VCDS-Lite doesn't have the Set Readiness feature so manual Basic Setting group number entry is the only option.
Have a great weekend,
   #29
NostraJackAss
So did you make readiness doing all aforementioned tests or do you need remote help still?
   #30
Artstudio56
Los Angeles, USA
C?ID=417142
Sorry for the delay in my reply, been tied up with work. I did all the tests that were suggested, still the same result. @Jack@European_Parts I would appreciate a remote session if you are still up for it. Please let me know what day/time works for you, I'm in the pacific timezone.
   #31
NostraJackAss
Contact form completed with some credentials please and let me know when car is on battery charger with VCDS ready to go and take call + access with a TV?
   #32
Artstudio56
Los Angeles, USA
C?ID=417142
Hi @Jack@European_Parts are you referencing this contact form on your website? I can set up a zoom meeting or google hangout if that works. The car has a full battery charge and I will be able to connect with you remotely and give you control of my pc connected to the car.
   #34
Artstudio56
Los Angeles, USA
C?ID=417142
@Jack@European_Parts thank you for taking the time to do a remote test session with me last night. For others that may have similar issues with this engine, we ran the 200 block macro test and was able to get a P0420 fault on the cat. After some further testing, we discovered that the amplitude on bank 2 was high and noticed cylinder 5 and 6 running lean. Going to look for vacuum leaks and check the fuel pump regulator and lines. Will do some troubleshooting this weekend and test again.
   #35
NostraJackAss
NEIN!
INDUCED FOD STARTING!
BANK 1
NOT BANK 2!
5 & 6 SHOWED MISFIRE DURING WARM-UP 0x01-08-016
INDEED 0x01-04-200 IS SUPPORTED BY K LINE ME7 IN SOME CARS!
Test for Arthur stalled at step 19.
FORCE readiness & manual tests commence and two simulated DCY's performed resulting in force a DTC to get the car to think it was on dyno or lab environment!
Tests of interest to bifurcate the banks and qualify fuel quickly + MAF were done below with these actual results.
0x01-04-227 amplitude .89 ( result 111 P0420 Tissues needed :cry: ) BANK 1 P0420
0X01-04-228 amplitude .03 ( not an issue, no Tissues :thumbs: ) BANK 2 P0430 IF A FAULT WOULD OF BEEN PRESENT
The aforementioned screams vacuum leak or faulty injectors and a balance wire test was advised if up to qualify diagnostic stack!
   #36
NostraJackAss
Excessive heat from water flange T stat area is right beneath or in very close proximity, in addition to timing chain friction points are the reason the intake gasket + injectors suffer at the 5/6 zylinders on VR!
FYI:
In race cars.
I make a shield and supply air from a set of fans to intake banks split & to remove or block heat by air curtain.
These work well!
   #37
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Same here , from my long term experience VW will never take aftermarket CAT for good. Some will hold up 6 to moths and that is most I have seen, some will never work .
ONLY Original VW CAT will work .
