- Nov 10, 2014
- 1,517
- 2,259
- New Zealand
- C?ID=230482
Hi guys,
A little help please
this is related to my R32 Touran conversion, so there is some total FOD, Jack ;-)
AUtoscan:
My issue, is related to these two codes in the engine ECU:
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
000259 - Mass Air Flow Sensor (G70)
P0103 - 001 - Signal too High
When I turned on the ignition today, the engine air intake read 17C, and the ambient temperature on the dash read 19C - close enough for me.
As soon I a started the engine, the engine air intake temperature jumped down to -48C (or thereabouts). It stayed there.
The MAF readings were sitting about mid 300's at idle, and didn't seem to vary much with throttle blips of upto 4000 rpm (up to high 300's, though it had no load). I ran the engine until the thermostat opened (I was bleeding the cooling system) and nothing changed much.
The MAF has the IAT built in, according to the wiring diagrams. It has 4 wires to the ECU (the wiring diagram doesn't specify which is which signal), and the 12V feed is switched by the fuel pump relay, just as it would have been in the R32 golf - the MAF has 12V at the same time the fuel pump is running.
Why does it read normally with ignition on, engine off, but doesn't read normally with the engine running?!?!
AUtoscan:
Monday,05,September,2016,15:35:26:42165
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WVWZZZ1KZ6W124470 License Plate: R32RAN
Mileage: 71120km-44191mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W124470 Mileage: 71120km-44191miles
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CE HW:
Component: MOTRONIC ME7.1.1G 6733
Revision: --H01--- Serial number: VWZ7Z0E3138758
Coding: 0000178
Shop #: WSC 01279 785 00200
VCID: 50AF5F7AC34786C270-8004
012313 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004738
VCID: 72EBF5F26D0B94D2A6-8026
8 Faults Found:
013 - Check DTC Memory
01324 - Control Module for All Wheel Drive (J492)
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
VCID: 6ADBED9245DB5C121E-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005382893
Coding: 008D0F210004100000120C000000000000097B075C
Shop #: WSC 01324 785 00200
VCID: 2A5B2D92855B9C12DE-807E
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00063445
Shop #: WSC 01324
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0H4NRK
Coding: 0012338
VCID: 35610EEE5CE5C3EA43-8060
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E3C9E2016388F28A-8022
Part No: 1K6 920 862 F
Component: KOMBIINSTRUMENT VDD 4316
Coding: 0001103
Shop #: WSC 00070 824 83288
VCID: 336530F65291DDDA6D-8066
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus
00438 - Fuel Supply Sensor 2 (G169)
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106127113D
Coding: BD3F0340078003
Reset counter: 111
Mileage: 71127 km
Time: 00:05:11
Address 22: AWD
Component: IMMO VDD 4316
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2302
Coding: 0000692
VCID: 366309E241E3C8F24A-8062
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.0 D06 1701
VCID: 346733EA579FDAE274-8060
02546 - Steering Limit Stop
Mileage: 1120 km
Temperature: 18.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802087F2D8405485FC61010CC
Shop #: WSC 00010 824 05318
VCID: 79F9C2DE307DE78AE7-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000692
VCID: 377D04E646E931FA51-8062
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2F3751220
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326B35F2AD8BD4D266-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
End-------------------------(Elapsed Time: 01:44)--------------------------
