2006 A6 ESP/ABS/Brake lights
jakepusey
C?ID=9402
I have the ESP, ABS and brake lights on. Here is the scan:
Friday,02,September,2016,10:59:40:50675
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WAUDG74F36N044443   License Plate: ASHLEYAFTERSWITCH
Mileage: 196210km-121919mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUDG74F36N044443   Mileage: 196210km-121919miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0040
   Revision: --H15---    Serial number:
   Coding: 01050106190F0120
   Shop #: WSC 02325 785 00200
   VCID: 2E597E38B9D2B63202-807A
               P1653 - 008 -
                    Fault Frequency: 88
                    Mileage: 195074 km
                    Date: 2016.07.31
                    Time: 12:55:15
                    RPM: 1312 /min
                    Mass Air / Rev.: 196.2 mg/str
                    Temperature: 18.0°C
                        Idle
                    Load: 32.2 %
000832 - Camshaft Position Sensor (G40)
               P0340 - 006 - Malfunction - Intermittent
                    Reset counter: 15
                    Mileage: 195152 km
                    Date: 2016.08.02
                    Time: 12:59:40
                    RPM: 928 /min
                    Mass Air / Rev.: 228.9 mg/str
                    Temperature: 52.5°C
                        Idle
                    Bin. Bits: 00000100
   Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4050367
   Coding: 0000002
   Shop #: WSC 02327 785 00200
   VCID: 31636544A8ECA9CA1F-8064
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0020895
   VCID: 2D5B7934B4D4CD2A3B-8078
                    Fault Status: 01101000
                    Fault Frequency: 93
                    Reset counter: 94
                    Mileage: 195074 km
                    Date: 2016.07.31
                    Time: 12:50:39
                    Hex Value: 0x0000
                    Hex Value: 0x4382
                    Hex Value: 0x001C
                    Hex Value: 0xB192
                    Hex Value: 0x00FF
01418 - Switch Valve 1 for Electronic Stability Program (N225)
            000 -  -  - Intermittent
                    Fault Frequency: 26
                    Reset counter: 134
                    Mileage: 195144 km
                    Date: 2016.08.02
                    Time: 09:51:30
                    Hex Value: 0x3B00
                    Hex Value: 0x4302
                    Hex Value: 0x0016
                    Hex Value: 0xC0AD
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0180
   Revision: 30070501    Serial number: 10600500202465
   Coding: 0000015
   Shop #: WSC 08213 444 58939
   VCID: 63CFDF0CA2904B5ADD-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 KSG   H26 0080
   Component: FBSAUDIC6 IDG   H44 0060
00190 - Driver's Door Handle Touch Sensor (G415)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 52
                    Mileage: 195074 km
                    Date: 2016.07.31
                    Time: 13:15:09
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 731 T    HW: 4E0 035 729
   Component: Interfacebox    H43 3360
   Revision: 00000000    Serial number: 303GM057502927
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 336F6F4C52F09BDA6D-8066
   Component: Bedienteil MMIC6H09 0060
   Subsystem 2 - Serial number: 00000000912913
   Subsystem 3 - Serial number: 0131.10.070000000100010470ÿ
   Subsystem 4 - Serial number: 010470ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000157405
   Coding: 0524326
   VCID: 5BBFE7EC9AE0739A95-800E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H15 0080
   Coding: 0013123
   VCID: 66C9C61851A23E723A-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7182602
   VCID: 1C3DA4F0DF6E34A25C-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E5009895
   VCID: 285588209B36E802C8-807C
            000 -  -
                    Reset counter: 52
                    Mileage: 195074 km
                    Date: 2016.07.31
                    Time: 12:46:23
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 12H29000    Serial number: 00359D0A05XZ
   Coding: 0013878
   Shop #: WSC 08213 444 69273
   VCID: 2A517228853ADA12DE-807E
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0A4862685
   Subsystem 3 - Serial number: 6342CSME0A6E671DJ
   Subsystem 4 - Serial number: 6352QSME0228784BJ
   Subsystem 5 - Serial number: 6362QSME014E3B09K
   Subsystem 6 - Serial number: 63734SME02410C7B
   Subsystem 7 - Serial number: 63834SME04441D17-
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90022051720191
   Coding: 0002141
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H15 0630
   Revision: 01000000    Serial number: 4PY34CV65
   Coding: 2129263
   Shop #: WSC 09110 444 54122
   VCID: 21439504F80C194A8F-8074
Address 19: CAN Gateway        Labels: 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 1200805624801E
   Coding: ECFE73CD1B7904
   VCID: 27578B1C9628E77AC1-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 61C3D504B88C594ACF-8034
                    Reset counter: 134
                    Mileage: 196208 km
                    Date: 2016.08.28
                    Time: 15:03:42
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H45 0740
   Revision: 00000000    Serial number: 355F 057549647
   VCID: 387558604B96788258-806C
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00000000    Serial number: –ev
   Coding: 0051947
   VCID: 29538D24803CD10AD7-807C
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01005239070000
   Coding: 4618301
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000792125
   Coding: 0000026
   VCID: 254B8114EC24F56AF3-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000003258
   Coding: 0002114
   VCID: 5EB9EEF889F266B2F2-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00000000    Serial number: ƒ˜v
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DBBE9F484F47DAAEB-8008
                    Fault Status: 00101101
                    Reset counter: 134
                    Mileage: 195072 km
                    Date: 2016.07.31
                    Time: 13:23:39
                    Voltage: 12.84 V
                    Count: 236
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   VCID: 264986189122FE72FA-8072
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394G.057566157
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000064919
   Shop #: WSC 08213 444 57146
   VCID: 234F9F0CE2100B5A9D-8076
   Subsystem 1 - Part No: 4F0 915 105 DK
   Component: von VA0  340812C2KC
   Coding: 344630393135313035444B56413033343038313243324B43
   Shop #: WSC 12345 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0051754
   VCID: 69D3CD2440BC110A17-803C
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000700007745
   Coding: 0062221
   VCID: 60C5D000B3865042C0-8034
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000506230102
   Shop #: WSC 12336 024 394758
   VCID: 346D6C5057FE9CE274-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0051754
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 11720517308703
   Coding: 0001206
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 52
                    Mileage: 195074 km
                    Date: 2016.07.31
                    Time: 12:48:23
   Part No SW: 4F0 910 336 D    HW: 4E0 862 335
   Component: Handyvorb2      H11 0700
   Revision: 00000000    Serial number: 00000007504116
   Coding: 0010900
   VCID: 244D9C10E71E0C62E4-8070
End-------------------------(Elapsed Time: 02:55)--------------------------
Any thoughts on how to move forward would be appreciated.
DrPeter
16.4905° S, 151.7375° W
MartinsX
Riga, Latvia
C?ID=268515
G201 and N225 are parts inside the J104 ABS/ESP module.
For Bosch ESP 8.0 not repairable or replaceable separately.
