2009 Passat Cambelt Tensioner Bolt failed
66Cobra
C?ID=211142
2007 Passat Cambelt Tensioner Bolt failed
My son just had his vw passat cambelt, tensioner and waterpump replaced and two weeks later on the way home from work the car lost all power. Garage that done the work told him the tensioner bolt had failed.!
Now the engine management light is on and wondering how much of the scan below is relevant.?
Also notice that the Date: 2000.00.00..?
Friday,02,September,2016,17:51:01:13798
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 16.8.0.0
Data version: 20160731 DS254
VIN: WVWZZZ3CZ8E110584   License Plate: AJ57 MEU
Mileage: 258580km-160674mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ8E110584   Mileage: 258580km-160674miles
37-Navigation -- Status: Not registered 0001
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
   Component: R4 2.0l PPD1.5 G    0907
   Revision: --H45---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 05314 000 00000
   VCID: 6FEDDD167EA8EA3A4A-803A
012296 - Camshaft Position Sensor (G40)
               P3008 - 006 - Signal Out of Range - Intermittent
                    Fault Status: 00100001
                    Reset counter: 36
                    Mileage: 258550 km
                    Time: 07:11:23
                    RPM: 1632 /min
                    Torque: 72.0 Nm
                    Speed: 81.0 km/h
                    Steering Angle: 6.74°
                    Angle: 0.0 °
                    (no units): 1.0
                    Steering Angle: 3.37°
000833 - Camshaft Position Sensor (G40)
               P0341 - 006 - Implausible Signal - Intermittent
                    Reset counter: 36
                    Mileage: 258550 km
                    Time: 07:12:04
                    RPM: 224 /min
                    Torque: 0.0 Nm
                    (no units): 0.0
                    Steering Angle: 0.00°
                    Angle: 0.0 °
                    (no units): 1.0
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 006 - Electrical Fault - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 258560 km
                    Time: 17:32:00
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 14.24 V
                    Bin. Bits: 10110000
                    Temperature: 19.0°C
000801 - Engine Speed Sensor (G28)
               P0321 - 006 - Implausible Signal - Intermittent
                    Reset counter: 36
                    Mileage: 258560 km
                    Time: 17:32:08
                    RPM: 160 /min
                    Torque: 0.0 Nm
                    Time: 0.02 s
                    Angle: 0.0 °
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
Readiness: N/A
   Part No SW: 02E 300 051     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1817
   Revision: 04843012    Serial number: 00000807280730
   Shop #: WSC 00229 210 88099
   VCID: 50AF7EEAC3D6D5C273-8004
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000776233489
   Coding: 0001294
   Shop #: WSC 05311 000 00000
   VCID: 1F4DEDD6CE883ABABA-804A
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BF5F9463AD0869AF6-802E
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007618410
   Coding: 00880F0700041A00470A00000F000000000859435C000100000000000000
   Shop #: WSC 05124 000 00000
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 180907 022  0601
   Coding: 00046997
   Shop #: WSC 05124
                    Reset counter: 253
                    Mileage: 258560 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.40 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0C AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1PL3NVD2
   Coding: 0012355
   VCID: 306F1E6AA316B5C213-8064
   Subsystem 1 - Serial number: 6332MSME1806424E
   Subsystem 2 - Serial number: 6342MSME167E765E
   Subsystem 3 - Serial number: 6351HTS6L4IOOQP6
   Subsystem 4 - Serial number: 6361HTS6L4ISGQV6
   Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
   Component: Lenksäulenmodul 006 0010
   Revision: 00006000    Serial number: 3C9953507BE
   Coding: 0001014
   VCID: 3365116652008EDA6E-8066
   Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 00229 067 57207
   VCID: 2E530012B922A33201-807A
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P07A100550
   Coding: FD807F0E0002022003
   VCID: 2345E126E2E01E5A9E-8076
                    Reset counter: 234
                    Mileage: 257409 km
                    Time: 20:52:13
01304 - Radio
                    Reset counter: 234
                    Mileage: 257409 km
                    Time: 20:52:16
            000 -  -
                    Reset counter: 194
                    Mileage: 257409 km
                    Time: 21:04:35
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 3979234E706C748AA4-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 FX
   Component:      Navigation     0030
   Coding: 0000101
   Shop #: WSC 00591 210 182040
   VCID: 1427B2FA374E69E217-8040
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000539779002
   Coding: 0000693
   VCID: 3B7539467A50469AB6-806E
                    Fault Status: 00101100
                    Fault Frequency: 68
                    Reset counter: 250
                    Mileage: 248299 km
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 3663287241729BF249-8062
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0191020051030E763004941570085FCE1078A0
   Component: LIN BACKUP HORN H07 9001
   Component: Neigungssensor  004 0611
00956 - Key 2
                    Fault Status: 01100101
                    Fault Frequency: 32
                    Reset counter: 201
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000003379009
   Coding: 0000692
   VCID: 3C773A5A7F5E41A2BF-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000191369
   Coding: 0000057
   VCID: 2959F30E80CCC40AD4-807C
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 GX
   Component:        Radio        0030
   Coding: 0012072
   VCID: 01098BAE583CEC4AAC-8054
00857 - CD Changer Unit (R41)
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1119
   Revision: 11006001    Serial number: 00000002462866
   Coding: 0000144
   VCID: 3D71375E644448AA88-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1119
   Revision: 11006001    Serial number: 00000002456787
   Coding: 0000144
   VCID: 3E733052694253B291-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90640727801387
   Coding: 0001024
End-------------------------(Elapsed Time: 02:27)--------------------------
Regards
Dutchie
C?ID=125479
All of them are relevant. Camshaft- and crankshaftsensor error indicate a timing issue. Did the garage repair the issue? The bolts tent to break if they where not torqed down to spec. In the EU VW timingbelt kits from Gates, Conti tech etc include new bolts:rolleyes:
66Cobra
C?ID=211142
Thank you for the reply.
When the car was returned to the garage they said they had to replace the bolt, which we think they used the old one originally but he is still left with these error codes and the engine management light.
Hopefully it's not caused any more damage.!
Regards
Dutchie
C?ID=125479
Does the engine idle good? Try clearing and if you are sure you can start the engine start it and check if the fault came back. If so there is most likley a timing issue that needs to be adressed. I think that you are entiteld for warenty on this.
66Cobra
C?ID=211142
Yes engine starts and idles ok, But a little tap pity.
Have cleared the codes and most of the faults reaper as below, Will have to get in touch with him monday and see what the outcome is.
Friday,02,September,2016,18:01:21:13798
VIN: WVWZZZ3CZ8E110584   License Plate: 02-09-16 - AJ57 MEU
   Coding: 0000078
                    Reset counter: 36
                    Mileage: 258550 km
                    Time: 07:11:23
                    RPM: 1632 /min
                    Torque: 72.0 Nm
                    Speed: 81.0 km/h
                    Angle: 0.0 °
                    (no units): 1.0
                    Reset counter: 36
                    Mileage: 258550 km
                    Time: 07:12:04
                    RPM: 224 /min
                    Torque: 0.0 Nm
                    (no units): 0.0
                    Angle: 0.0 °
                    (no units): 1.0
                    Mileage: 258560 km
                    Time: 17:32:00
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 14.24 V
                    Bin. Bits: 10110000
                    Temperature: 19.0°C
                    Reset counter: 36
                    Mileage: 258560 km
                    Time: 17:32:08
                    RPM: 160 /min
                    Torque: 0.0 Nm
                    Time: 0.02 s
                    Angle: 0.0 °
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
Readiness: N/A
   Coding: 0001294
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 0012355
   Coding: 0001014
   Coding: 0007405
            000 -  -
                    Reset counter: 217
                    Mileage: 258587 km
                    Time: 17:57:23
   Coding: 0000101
   Coding: 0000693
   Coding: 0000692
   Coding: 0000057
Address 56: Radio        Labels: None
   VCID: 55A18FFEBC34B0EAA0-FFFE
No Faults Found
   Coding: 0000144
   Coding: 0000144
   Coding: 0001024
End-------------------------(Elapsed Time: 02:52)--------------------------
Thanks again.:thumbs:
flat12
USA (Alabama)
C?ID=88836
Did you by chance get the old bolt back from the shop? Doesn't this bolt simply hold the belt tensioner in place, and the tensioner regulates belt tension via hydraulic pressure?
66Cobra
C?ID=211142
No didn't think we would need it, Thought the job would have been done right first time. That's my understanding from what I have been is how it works.
The guy is supposed to be sorting the rest of the problems, So hopefully should be sorted by weekend......!
Regards
