16486 - Mass Air Flow Sensor (G70)
COBHONIAN
Philadelphia PA USA
C?ID=270149
RE : Address #1
I'm looking for suggestions on my best approach to this issue.
Firstly I have removed/ unscrewed the sensor and cleaned it as good as I could . Is there anything that I can do using the hex net to determine whether the sensor is the issue before replacing parts. Also Im reading that there are quite a few sensors that will fit but not necessarily be correct. I looked at the identifiers on the sensor but I cant be sure that its the correct one since the manufacturing date was in 2005 even though the car is a vw cabrio 2002.
Thanks for your time
EDIT . I did this but not sure if i followed the procedure correctly. I'm looking for the log from the procedure but I cant find it anywhere. Maybe I didn't do it right. Finally what is 3e gear , is that 3rd gear?
" You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)"
Friday,02,September,2016,11:12:47:42100
VCDS Version: 16.8.0.3 (x64)  HEX-NET CB: 0.4321.4
Data version: 20160803 DS255
VIN: XXXXXXXXXXXXXXXXX   License Plate:
Chassis Type: XX (1V - VW Golf Cabriolet (1997 > 2002))
Scan: 01 02 03 08 15 25 35 56
Address 01: Engine        Labels: 037-906-018-ABA.lbl
   Part No: 037 906 018 H
   Component: 2.0l R4/2V  MOTR AT V04
   Coding: 00003
   Shop #: WSC 00066
   VCID: 9A78996F043B4D92CE-4B3C
            P0102 - 35-00 - Signal too Low
Readiness: 0010 1101
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 LA
   Component: AG4 Getriebe 01M    4899
   Coding: 00000
   VCID: FAB8B9EFE47BAD926E-0964
Address 03: ABS Brakes        Labels: 3A0-907-379.lbl
   Part No: 3A0 907 379 D
   Component: ABS     ITTAE 20 GI V00
   Coding: 03704
   VCID: AB164CAB5BA1C41AA5-4AC2
            16-00 - Signal Outside Specifications
            35-10 -  -  - Intermittent
            16-10 - Signal Outside Specifications - Intermittent
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
   Part No: 6X0 953 257
   Component: IMMO                0008
   Coding: 00001
   Shop #: WSC 40629
   VCID: FDB2B2F3F5559AAA4B-4B3C
   XXXXXXXXXXXXXXXXX     VWZ1Z0A1666169
   Part No: 1JM 035 157 A
   Component:  Radio DE2         0005
   Coding: 07403
   Shop #: WSC 09144
   VCID: BE3075FFB8D341B212-51F2
00856 - Radio Antenna
            36-00 - Open Circuit
End----------(Elapsed Time: 02:13, VBatt start/end: 12.3V/12.1V)-----------
Dutchie
C?ID=125479
Please check the MAF data and the EGR at the same time, if the EGR is stuck open, on older cars, you get a MAF error, wilst the EGR is the cause
I would indeed take a look at what the ECU is seeing in [01-Engine] [MVB 003.2]. Start with just checking it at idle. I would expect to see 2-4 g/s at idle. If that's OK, then log it throughout the RPM range at full throttle in the highest gear you can. If you're in the city, that may be 2nd rather than 3rd gear.
NostraJackAss
What MAF part # is installed?
Please post pictures ..........
Coding: 00003
Based on the part # above for engine controller, you have the later production, and require MAF part # 06A-906-461C or CX
Another example how an auto-scan helps us help you............
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
This is common problem on ABA engines.The problem is that breather hose is design very bad , above air boot and what happens , oil from breather hose goes down to air flow meter.
Is you car idling up/down?
When you Remove air boot did you see lot of oil at air flow meter?
In most cases cleaning whole air boot and air flow meter will fix problem.
I suggest to use Air Flow mater cleaner form retail store like Napa , o'reilly and Etc, if you use Carb cleaner, or similar stuff you will kill sensor.
I know JACK will not agree with me on this one for cleaning with Air flow meter cleaner, :).
COBHONIAN
Philadelphia PA USA
C?ID=270149
Thanks for the response. The air boot was cleaned and every other part of that system prior to this problem.
COBHONIAN
Philadelphia PA USA
C?ID=270149
Hi Jack, i cant find the paper clip symbol to attach pictures .The manufacturing date for the part (just the sensor ,not the box unit) was july of 2005 even though its a 2002 car. So who knows if this is actually the correct sensor. The numbers on the MAF sensor are BOSCH F00C-262034 Also 587-21-3c ( another marking on there) and an encircled 3 digit number 816.
VIN 3VWDC21VX2M803667
This car does not have an EGR but rather a Secondary air control valve.
PS How am I to attach a picture?
COBHONIAN
Philadelphia PA USA
C?ID=270149
Thanks Dutchie, will do , just so you know this model is a 2002 non californian car . The Californians have an EGR and from what I understand , the rest have a secondary air control valve /pump system.Group number 077
COBHONIAN
Philadelphia PA USA
C?ID=270149
Thanks Uwe. I just completed doing that. However I'm not sure if I followed your instruction to a T . "then log it throughout the RPM range" I started at idle , hit the log button (not the add to log ,,not sure sure what the difference or purpose is yet of that) Took it out on Stenton Ave to 309 , came back and hit STOP.
Then attached the data to a LOG SUBMISSION FORM and sent it in.
So did i do that much correctly. ? Did I leave anything out?
BTW could you tell me how to attach a csv or and jpeg to this forum , I cant find the paper clip symbol. Thanks again
Dutchie
C?ID=125479
There is a trick for some MAF to check them if they are good. It must be from Bosch, and it has to be a 5 pin (4 pin works to some times :P ). Leave the connector on the MAF, decouple the MAF from the hoses and duct tape both side shut, so there is no movement of the air. Then use a digital volt meterv or a scoop, and check the voltage from the MAF, it has to be 1V (+/- 0.01V), any thing else, then its not trust worthy and needs to be replaced.
MartinsX
Riga, Latvia
C?ID=268515
The MAF sensor insert is not intended to be replaced separately by Bosch nor by VW. So the Bosch internal part number F00C262034 of separate insert is not recognized by any spare parts catalogues.
The only one known exception is Pierburg. Separate MAF insert 7.22684.14.0 is the right replacement for Your car. Or complete MAF unit 06A906461C (CX) = Bosch 0280218023/0986280209.
(09xxxxxxxx part numbers by Bosch have the same meaning as xxxxxxxxxX by VW - remanufactured exchange part)
COBHONIAN
Philadelphia PA USA
C?ID=270149
THIS IS THE LOG I MADE FOR AN MAF CODE
Andy asked me to post this here, not sure if i did it right.
Monday,05,September,2016,16:22:04:42100-VCID:9A78996F043B4D92CE-4B3C,VCDS Version: Release 16.8.0 (x64),Data version: 20160803 DS255
037 906 018 H,,2.0l R4/2V  MOTR AT V04,
,Group A:,'003,,,,Group B:,'077,,,,Group C:,'078
,,Engine Speed,Mass Air Flow,Throttle Valve Angle,Ignition,,Coolant,Lambda Control, ,Secondary Air,, , , ,
,TIME,(G28),Sensor (G70),,Timing Angle,TIME,Temperature (G62),,,Injection Test B1,TIME,,,,
Marker,STAMP, /min, g/s,°, °BTDC,STAMP,°C, %,,,STAMP,,,,
,0.01,840,2.84,3.9,4.5,0.29,91.5,25.0, ,Test OFF,0.59, , , ,
,0.89,880,3.06,3.5,4.5,1.19,91.5,25.0, ,Test OFF,1.49, , , ,
,1.79,880,2.98,3.5,4.5,2.09,91.5,25.0, ,Test OFF,2.39, , , ,
,2.69,840,2.92,3.9,9.0,2.99,91.5,25.0, ,Test OFF,3.30, , , ,
,3.59,840,2.92,3.9,10.5,3.89,91.5,25.0, ,Test OFF,4.19, , , ,
,4.49,840,2.84,3.5,9.0,4.79,91.5,25.0, ,Test OFF,5.09, , , ,
,5.40,880,3.06,3.9,4.5,5.69,91.5,25.0, ,Test OFF,5.99, , , ,
,6.29,1120,4.58,5.6,13.5,6.59,91.5,25.0, ,Test OFF,6.89, , , ,
,7.19,1560,4.09,4.8,13.5,7.50,91.5,25.0, ,Test OFF,7.79, , , ,
,8.09,1440,4.03,5.2,13.5,8.39,91.5,25.0, ,Test OFF,8.69, , , ,
,9.05,1560,4.79,6.1,14.3,9.46,91.5,0.0, ,Test OFF,9.77, , , ,
,10.06,1080,3.26,4.3,21.0,10.37,91.5,2.3, ,Test OFF,10.66, , , ,
,10.96,1440,6.04,7.8,15.0,11.26,91.5,7.0, ,Test OFF,11.56, , , ,
,11.87,1480,4.58,6.1,14.3,12.18,91.5,13.3, ,Test OFF,12.46, , , ,
,12.75,1520,4.58,5.6,13.5,13.05,91.5,19.5, ,Test OFF,13.35, , , ,
,13.64,1520,4.37,5.6,13.5,13.94,91.5,25.0, ,Test OFF,14.24, , , ,
,14.54,1440,3.61,3.9,8.3,14.84,91.5,0.0, ,Test OFF,15.15, , , ,
,15.44,1000,3.54,4.8,13.5,15.74,91.5,3.1, ,Test OFF,16.04, , , ,
,16.34,1200,4.09,5.6,14.3,16.64,91.5,7.8, ,Test OFF,16.94, , , ,
,17.24,1160,3.89,5.2,14.3,17.54,91.5,11.7, ,Test OFF,17.84, , , ,
,18.15,1240,4.09,5.2,13.5,18.44,91.5,15.6, ,Test OFF,18.74, , , ,
,19.04,1240,3.82,4.8,13.5,19.34,91.5,20.3, ,Test OFF,19.64, , , ,
,19.94,1320,3.82,4.8,13.5,20.24,91.5,25.0, ,Test OFF,20.53, , , ,
,20.83,1400,3.82,4.8,12.8,21.13,91.5,25.0, ,Test OFF,21.43, , , ,
,21.73,1400,3.75,4.8,12.8,22.04,91.5,25.0, ,Test OFF,22.33, , , ,
,22.63,1400,3.82,4.8,12.8,22.93,91.5,25.0, ,Test OFF,23.23, , , ,
,23.53,1480,3.96,4.8,13.5,23.83,91.5,25.0, ,Test OFF,24.13, , , ,
,24.44,1480,3.96,4.8,13.5,24.73,91.5,0.0, ,Test OFF,25.03, , , ,
,25.33,1000,2.78,3.9,24.0,25.63,91.5,1.6, ,Test OFF,25.93, , , ,
,26.23,880,3.33,3.9,13.5,26.53,91.5,3.9, ,Test OFF,26.82, , , ,
,27.11,1920,6.04,6.9,13.5,27.41,91.5,10.2, ,Test OFF,27.72, , , ,
,28.02,1200,3.26,4.3,21.0,28.31,91.5,3.1, ,Test OFF,28.61, , , ,
,28.91,960,3.89,5.6,12.8,29.21,91.5,6.3, ,Test OFF,29.51, , , ,
,29.82,840,3.89,5.6,12.8,30.12,91.5,8.6, ,Test OFF,30.41, , , ,
,30.72,840,3.96,5.6,14.3,31.01,91.5,10.9, ,Test OFF,31.33, , , ,
,31.61,840,4.09,5.2,9.8,31.91,91.5,13.3, ,Test OFF,32.21, , , ,
,32.52,840,4.09,5.2,8.3,32.82,91.5,14.8, ,Test OFF,33.12, , , ,
,33.41,880,4.03,4.8,3.8,33.71,91.5,17.2, ,Test OFF,34.01, , , ,
,34.30,880,4.03,4.3,3.8,34.61,91.5,19.5, ,Test OFF,34.91, , , ,
,35.21,880,3.75,4.8,1.5,35.51,91.5,21.9, ,Test OFF,35.80, , , ,
,36.10,840,3.61,4.8,6.8,36.40,91.5,24.2, ,Test OFF,36.70, , , ,
,37.00,880,3.54,4.8,4.5,37.29,91.5,25.0, ,Test OFF,37.60, , , ,
,37.89,920,3.68,4.3,-0.8,38.20,91.5,25.0, ,Test OFF,38.50, , , ,
,38.80,880,3.26,4.8,7.5,39.10,91.5,25.0, ,Test OFF,39.40, , , ,
,39.70,840,3.61,4.8,9.0,40.00,91.5,25.0, ,Test OFF,40.29, , , ,
,40.59,840,3.96,5.2,7.5,40.90,91.5,25.0, ,Test OFF,41.19, , , ,
,41.49,1200,5.97,8.2,14.3,41.80,91.5,25.0, ,Test OFF,42.10, , , ,
,42.39,1400,7.43,10.0,15.8,42.69,91.5,25.0, ,Test OFF,43.00, , , ,
,43.30,1440,5.62,6.1,12.8,43.59,91.5,25.0, ,Test OFF,43.90, , , ,
,44.20,1120,4.03,7.4,13.5,44.49,91.5,25.0, ,Test OFF,44.79, , , ,
,45.09,1160,3.33,4.3,10.5,45.40,91.5,25.0, ,Test OFF,45.69, , , ,
,45.99,960,3.06,3.9,10.5,46.30,91.5,25.0, ,Test OFF,46.59, , , ,
,46.89,840,2.78,3.5,12.8,47.19,91.5,25.0, ,Test OFF,47.49, , , ,
,47.79,840,2.92,3.9,13.5,48.10,91.5,25.0, ,Test OFF,48.40, , , ,
,48.70,880,3.75,6.1,13.5,49.00,91.5,25.0, ,Test OFF,49.30, , , ,
,49.60,1600,7.98,9.5,18.0,49.89,91.5,25.0, ,Test OFF,50.20, , , ,
,50.48,1200,3.19,3.9,10.5,50.79,91.5,25.0, ,Test OFF,51.09, , , ,
,51.38,1000,2.71,3.5,12.0,51.69,91.5,25.0, ,Test OFF,51.98, , , ,
,52.29,840,2.71,3.5,16.5,52.58,91.5,25.0, ,Test OFF,52.89, , , ,
,53.19,840,2.78,3.5,11.3,53.49,91.5,25.0, ,Test OFF,53.79, , , ,
,54.09,840,3.06,3.9,9.8,54.39,91.5,25.0, ,Test OFF,54.73, , , ,
,55.15,880,3.19,3.9,5.3,55.45,91.5,25.0, ,Test OFF,55.75, , , ,
,56.06,1600,4.72,6.9,9.8,56.36,91.5,22.7, ,Test OFF,56.66, , , ,
,56.96,1360,6.32,6.9,12.0,57.25,91.5,21.9, ,Test OFF,57.55, , , ,
,57.85,1600,9.37,12.2,17.3,58.15,91.5,18.0, ,Test OFF,58.45, , , ,
,58.75,1520,11.25,16.5,15.8,59.05,91.5,19.5, ,Test OFF,59.35, , , ,
,59.65,1840,13.33,20.0,20.3,59.95,91.5,22.7, ,Test OFF,60.25, , , ,
,60.55,2080,16.59,25.2,21.0,60.86,91.5,17.2, ,Test OFF,61.15, , , ,
,61.45,2360,20.56,30.4,20.3,61.75,91.5,17.2, ,Test OFF,62.06, , , ,
,62.36,2680,23.26,31.7,21.0,62.65,91.5,21.1, ,Test OFF,62.95, , , ,
,63.25,2600,25.07,34.7,1.5,63.55,91.5,18.0, ,Test OFF,63.86, , , ,
,64.15,2480,26.46,36.5,17.3,64.46,91.5,20.3, ,Test OFF,64.75, , , ,
,65.05,2520,26.67,36.9,17.3,65.37,91.5,19.5, ,Test OFF,65.66, , , ,
,65.95,2600,27.64,36.9,18.0,66.25,91.5,18.0, ,Test OFF,66.55, , , ,
,66.85,2600,24.51,33.9,19.5,67.16,91.5,22.7, ,Test OFF,67.45, , , ,
,67.75,2720,28.68,38.2,18.0,68.06,91.5,15.6, ,Test OFF,68.35, , , ,
,68.66,2800,27.78,36.5,18.8,68.95,91.5,22.7, ,Test OFF,69.25, , , ,
,69.56,2800,24.72,33.4,21.0,69.86,91.5,21.1, ,Test OFF,70.16, , , ,
,70.45,2840,26.32,34.3,20.3,70.75,91.5,18.0, ,Test OFF,71.05, , , ,
,71.35,2840,24.31,32.1,21.0,71.65,91.5,21.9, ,Test OFF,71.96, , , ,
,72.25,2720,16.53,23.0,22.5,72.56,91.5,15.6, ,Test OFF,72.85, , , ,
,73.15,1800,4.79,6.1,12.8,73.45,91.5,0.0, ,Test OFF,73.75, , , ,
,74.05,1440,3.19,2.6,6.8,74.35,91.5,0.0, ,Test OFF,74.65, , , ,
,74.96,1280,2.84,2.6,9.8,75.25,91.5,0.0, ,Test OFF,75.55, , , ,
,75.84,1040,2.43,3.0,12.0,76.14,91.5,2.3, ,Test OFF,76.44, , , ,
,76.74,880,2.36,2.6,11.3,77.04,91.5,4.7, ,Test OFF,77.34, , , ,
,77.64,800,2.57,3.5,17.3,77.94,91.5,7.0, ,Test OFF,78.24, , , ,
,78.54,920,2.98,3.5,6.0,78.83,91.5,9.4, ,Test OFF,79.13, , , ,
,79.43,840,3.06,3.9,13.5,79.73,91.5,10.9, ,Test OFF,80.03, , , ,
,80.33,800,3.06,3.9,15.8,80.63,91.5,13.3, ,Test OFF,80.93, , , ,
,81.23,1640,10.83,15.6,18.0,81.53,91.5,20.3, ,Test OFF,81.83, , , ,
,83.96,2360,24.23,34.7,17.3,84.26,93.0,20.3, ,Test OFF,84.58, , , ,
,84.86,2400,24.37,34.7,18.0,85.16,93.0,21.1, ,Test OFF,85.47, , , ,
,85.76,2400,22.84,33.0,19.5,86.06,93.0,18.8, ,Test OFF,86.36, , , ,
,86.66,2400,21.46,31.2,20.3,86.96,93.0,18.8, ,Test OFF,87.27, , , ,
,87.56,2360,20.14,29.9,21.0,87.86,94.5,17.2, ,Test OFF,88.16, , , ,
,88.46,2400,20.00,29.1,21.0,88.76,94.5,18.8, ,Test OFF,89.07, , , ,
,89.36,2520,20.28,29.1,21.0,89.66,94.5,14.8, ,Test OFF,89.96, , , ,
,90.25,2560,18.06,25.2,21.0,90.55,94.5,10.2, ,Test OFF,90.85, , , ,
,91.15,2160,14.93,22.6,9.0,91.45,94.5,18.0, ,Test OFF,91.75, , , ,
,92.05,2040,14.37,20.8,21.8,92.35,94.5,21.9, ,Test OFF,92.65, , , ,
,92.96,1800,6.32,9.1,15.8,93.25,94.5,22.7, ,Test OFF,93.55, , , ,
,93.85,1440,3.33,3.5,9.0,94.15,94.5,0.0, ,Test OFF,94.45, , , ,
,94.75,1320,2.92,2.6,9.0,95.05,94.5,0.0, ,Test OFF,95.35, , , ,
,95.65,1240,2.71,2.6,9.8,95.95,94.5,0.0, ,Test OFF,96.24, , , ,
,96.54,1080,2.50,3.0,12.0,96.84,94.5,1.6, ,Test OFF,97.14, , , ,
,97.44,1000,2.50,2.6,9.8,97.74,94.5,4.7, ,Test OFF,98.04, , , ,
,98.34,800,2.36,2.6,18.8,98.64,94.5,7.0, ,Test OFF,98.94, , , ,
,99.24,800,2.64,3.5,16.5,99.54,94.5,9.4, ,Test OFF,99.85, , , ,
,100.14,840,3.12,3.9,15.0,100.44,94.5,11.7, ,Test OFF,100.75, , , ,
,101.21,800,2.92,3.9,18.8,101.51,94.5,14.1, ,Test OFF,101.80, , , ,
,102.11,800,3.26,4.3,15.0,102.41,94.5,16.4, ,Test OFF,102.71, , , ,
,103.01,840,3.33,4.3,9.0,103.31,94.5,18.0, ,Test OFF,103.61, , , ,
,103.91,840,3.33,4.3,9.8,104.21,94.5,20.3, ,Test OFF,104.51, , , ,
,104.80,840,3.33,4.3,9.8,105.11,94.5,22.7, ,Test OFF,105.40, , , ,
,105.71,840,3.54,4.3,9.8,106.01,94.5,25.0, ,Test OFF,106.31, , , ,
,106.61,880,3.47,4.3,5.3,106.91,94.5,25.0, ,Test OFF,107.21, , , ,
,107.51,880,3.47,4.3,5.3,107.81,94.5,25.0, ,Test OFF,108.11, , , ,
,108.42,840,3.40,4.3,6.8,108.70,94.5,25.0, ,Test OFF,108.99, , , ,
,109.29,840,3.40,4.3,7.5,109.59,94.5,25.0, ,Test OFF,109.89, , , ,
,110.19,880,3.40,4.3,5.3,110.49,94.5,25.0, ,Test OFF,110.79, , , ,
,111.09,840,3.19,4.3,12.0,111.39,94.5,25.0, ,Test OFF,111.68, , , ,
,111.99,840,3.26,4.3,11.3,112.29,94.5,25.0, ,Test OFF,112.62, , , ,
,113.11,840,3.40,4.3,7.5,113.52,94.5,25.0, ,Test OFF,113.82, , , ,
,114.13,880,3.40,4.3,6.0,114.42,94.5,25.0, ,Test OFF,114.72, , , ,
,115.02,840,3.40,4.3,5.3,115.32,94.5,25.0, ,Test OFF,115.63, , , ,
,115.92,840,3.40,4.3,3.8,116.22,94.5,25.0, ,Test OFF,116.52, , , ,
,116.82,880,3.47,4.3,4.5,117.11,94.5,25.0, ,Test OFF,117.41, , , ,
,117.72,880,3.47,3.9,2.3,118.01,94.5,25.0, ,Test OFF,118.30, , , ,
,118.62,840,3.40,4.3,5.3,118.91,94.5,25.0, ,Test OFF,119.21, , , ,
,119.51,840,3.33,4.3,9.0,119.81,94.5,25.0, ,Test OFF,120.10, , , ,
,120.41,840,3.40,4.3,6.8,120.70,94.5,25.0, ,Test OFF,121.00, , , ,
,121.31,840,3.33,4.3,6.0,121.61,94.5,25.0, ,Test OFF,121.91, , , ,
,122.22,840,3.33,4.3,7.5,122.50,94.5,25.0, ,Test OFF,122.80, , , ,
,123.11,840,3.40,4.3,9.0,123.40,94.5,25.0, ,Test OFF,123.70, , , ,
,124.00,840,3.40,4.3,7.5,124.30,94.5,25.0, ,Test OFF,124.59, , , ,
,124.89,840,3.40,4.3,7.5,125.19,94.5,25.0, ,Test OFF,131.20, , , ,
,149.89,880,3.40,4.3,6.0,149.30,96.0,25.0, ,Test OFF,149.59, , , ,
,150.80,840,3.19,3.9,6.8,150.19,96.0,25.0, ,Test OFF,150.49, , , ,
,151.69,800,2.98,4.3,17.3,151.09,96.0,25.0, ,Test OFF,151.39, , , ,
,154.41,840,3.40,4.3,6.0,151.99,96.0,25.0, ,Test OFF,152.28, , , ,
,155.32,800,3.26,4.3,12.8,154.73,96.0,25.0, ,Test OFF,155.01, , , ,
,156.21,1200,8.54,13.5,12.8,155.61,96.0,25.0, ,Test OFF,155.91, , , ,
,157.11,1760,9.72,13.0,19.5,156.51,96.0,21.1, ,Test OFF,156.80, , , ,
,158.00,1480,5.62,6.9,13.5,157.40,96.0,20.3, ,Test OFF,157.70, , , ,
,158.90,1080,3.54,4.8,9.0,158.32,96.0,25.0, ,Test OFF,158.63, , , ,
,159.80,1160,3.33,4.8,15.0,159.21,96.0,25.0, ,Test OFF,159.50, , , ,
,160.70,1520,10.34,15.2,15.8,160.10,96.0,25.0, ,Test OFF,160.40, , , ,
,161.60,1760,11.81,16.9,19.5,161.00,96.0,18.8, ,Test OFF,161.30, , , ,
,162.50,2120,15.83,24.3,21.0,161.90,96.0,20.3, ,Test OFF,162.20, , , ,
,163.40,2440,18.40,26.9,21.0,162.80,96.0,24.2, ,Test OFF,163.10, , , ,
,164.30,2360,19.51,29.5,-2.3,163.70,96.0,16.4, ,Test OFF,164.00, , , ,
,165.20,2320,21.25,31.7,19.5,164.60,96.0,21.1, ,Test OFF,164.90, , , ,
,166.10,2400,23.47,33.9,18.8,165.50,96.0,19.5, ,Test OFF,165.81, , , ,
,167.00,2520,25.07,34.7,18.8,166.40,96.0,16.4, ,Test OFF,166.70, , , ,
,167.93,2600,25.21,34.7,19.5,167.30,96.0,19.5, ,Test OFF,167.60, , , ,
,168.96,2680,25.76,34.7,18.8,168.36,96.0,20.3, ,Test OFF,168.68, , , ,
,169.86,2800,24.93,33.4,20.3,169.26,96.0,23.4, ,Test OFF,169.56, , , ,
,170.79,2840,24.51,33.0,20.3,170.16,96.0,16.4, ,Test OFF,170.46, , , ,
,171.66,2920,24.58,32.5,21.0,171.06,96.0,18.0, ,Test OFF,171.36, , , ,
,172.59,2480,23.12,33.0,19.5,171.96,96.0,19.5, ,Test OFF,172.26, , , ,
,173.63,2480,21.81,31.2,19.5,173.03,96.0,20.3, ,Test OFF,173.33, , , ,
,174.53,2480,21.25,30.4,20.3,173.93,96.0,17.2, ,Test OFF,174.23, , , ,
,175.43,2600,23.96,33.4,19.5,174.83,96.0,17.2, ,Test OFF,175.13, , , ,
,176.34,2560,21.94,30.8,20.3,175.73,96.0,21.1, ,Test OFF,176.03, , , ,
,177.22,2560,19.93,28.2,20.3,176.62,96.0,14.1, ,Test OFF,176.92, , , ,
,178.11,2520,19.31,27.8,20.3,177.52,96.0,12.5, ,Test OFF,177.81, , , ,
,179.01,2360,18.75,27.8,21.0,178.41,96.0,11.7, ,Test OFF,178.71, , , ,
,179.91,2360,18.75,27.3,20.3,179.31,96.0,15.6, ,Test OFF,179.61, , , ,
,180.81,2440,14.51,20.8,21.0,180.21,96.0,10.2, ,Test OFF,180.51, , , ,
,181.71,1760,13.61,20.0,18.8,181.11,96.0,6.3, ,Test OFF,181.41, , , ,
,182.62,1800,13.89,20.0,19.5,182.00,96.0,7.8, ,Test OFF,182.31, , , ,
,183.51,1800,14.03,20.4,19.5,182.91,96.0,6.3, ,Test OFF,183.21, , , ,
,184.41,1880,14.44,21.7,19.5,183.81,96.0,4.7, ,Test OFF,184.11, , , ,
,185.30,1880,12.78,18.7,20.3,184.70,96.0,2.3, ,Test OFF,185.00, , , ,
,186.20,1840,11.73,16.5,20.3,185.60,96.0,2.3, ,Test OFF,185.90, , , ,
,187.10,1880,11.67,16.9,20.3,186.50,96.0,0.8, ,Test OFF,186.80, , , ,
,188.00,1840,8.47,12.2,19.5,187.40,96.0,-1.6, ,Test OFF,187.70, , , ,
,188.90,1880,13.54,20.0,20.3,188.30,96.0,-0.8, ,Test OFF,188.60, , , ,
,189.80,1840,14.79,23.0,18.8,189.20,96.0,2.3, ,Test OFF,189.50, , , ,
,190.70,1840,16.81,27.8,15.8,190.10,96.0,5.5, ,Test OFF,190.40, , , ,
,191.58,1840,18.26,29.9,13.5,190.99,96.0,5.5, ,Test OFF,191.29, , , ,
,192.48,1840,16.18,25.2,15.8,191.88,96.0,11.7, ,Test OFF,192.18, , , ,
,193.38,1840,13.96,20.8,17.3,192.78,96.0,10.2, ,Test OFF,193.08, , , ,
,194.28,1840,13.82,20.8,17.3,193.68,96.0,6.3, ,Test OFF,193.98, , , ,
,195.18,1800,14.31,21.3,18.8,194.57,96.0,3.9, ,Test OFF,194.88, , , ,
,196.08,1800,14.37,21.3,16.5,195.47,96.0,2.3, ,Test OFF,195.78, , , ,
,196.97,1880,12.64,18.2,20.3,196.37,96.0,0.8, ,Test OFF,196.67, , , ,
,197.88,1880,12.22,17.8,20.3,197.27,96.0,0.0, ,Test OFF,197.57, , , ,
,198.77,1800,6.11,6.9,12.8,198.18,96.0,-1.6, ,Test OFF,198.48, , , ,
,199.68,1720,3.96,4.8,13.5,199.08,96.0,3.9, ,Test OFF,199.37, , , ,
,200.57,1640,3.96,5.6,13.5,199.97,96.0,10.9, ,Test OFF,200.27, , , ,
,201.48,1840,6.25,9.1,15.8,200.88,96.0,2.3, ,Test OFF,201.17, , , ,
,202.38,1720,4.37,5.6,14.3,201.77,96.0,8.6, ,Test OFF,202.07, , , ,
,203.28,1560,3.47,2.6,6.8,202.67,96.0,15.6, ,Test OFF,202.97, , , ,
,204.18,1520,3.33,2.2,4.5,203.58,96.0,0.0, ,Test OFF,203.88, , , ,
,205.07,1480,3.26,2.2,5.3,204.48,96.0,0.0, ,Test OFF,204.78, , , ,
,205.98,1440,3.19,2.2,6.0,205.38,96.0,0.0, ,Test OFF,205.67, , , ,
,206.88,1760,7.01,9.1,17.3,206.28,96.0,0.0, ,Test OFF,206.58, , , ,
,207.77,1800,7.50,10.4,18.0,207.18,96.0,1.6, ,Test OFF,207.48, , , ,
,208.67,1560,3.75,3.5,6.8,208.08,96.0,8.6, ,Test OFF,208.37, , , ,
,209.58,1440,3.19,2.2,6.0,208.97,96.0,0.0, ,Test OFF,209.27, , , ,
,210.48,1400,3.12,2.6,6.8,209.88,96.0,0.0, ,Test OFF,210.17, , , ,
,211.38,1680,6.81,9.1,16.5,210.77,96.0,0.0, ,Test OFF,211.07, , , ,
,212.27,1480,3.40,2.6,8.3,211.67,96.0,6.3, ,Test OFF,211.97, , , ,
,213.17,1360,2.98,2.2,8.3,212.57,96.0,0.0, ,Test OFF,212.87, , , ,
,214.07,1280,2.84,2.2,9.0,213.47,96.0,0.0, ,Test OFF,213.77, , , ,
,214.97,1240,2.71,2.2,9.8,214.38,96.0,0.0, ,Test OFF,214.68, , , ,
,215.88,1200,2.64,2.2,9.8,215.27,96.0,0.0, ,Test OFF,215.57, , , ,
,216.77,1200,2.64,2.2,9.0,216.18,96.0,0.0, ,Test OFF,216.47, , , ,
,217.67,1440,5.21,6.9,15.0,217.07,96.0,0.0, ,Test OFF,217.37, , , ,
,218.57,1560,6.04,8.2,15.8,217.97,96.0,3.9, ,Test OFF,218.27, , , ,
,219.47,1520,6.39,9.1,15.8,218.87,96.0,10.2, ,Test OFF,219.17, , , ,
,220.36,1520,5.14,7.8,14.3,219.77,96.0,15.6, ,Test OFF,220.07, , , ,
,221.25,1680,7.84,10.9,18.0,220.67,96.0,21.9, ,Test OFF,220.96, , , ,
,222.15,1400,3.33,3.5,9.8,221.55,96.0,21.9, ,Test OFF,221.85, , , ,
,223.05,1080,2.50,2.6,9.8,222.45,96.0,0.0, ,Test OFF,222.75, , , ,
,223.94,1000,2.50,2.6,4.5,223.35,96.0,2.3, ,Test OFF,223.65, , , ,
,224.84,1520,5.56,8.7,15.0,224.24,96.0,5.5, ,Test OFF,224.54, , , ,
,225.74,1960,10.56,14.8,21.0,225.14,96.0,3.1, ,Test OFF,225.44, , , ,
,226.63,1800,9.79,14.8,20.3,226.03,96.0,10.9, ,Test OFF,226.33, , , ,
,227.53,1800,13.06,19.1,20.3,226.94,94.5,14.8, ,Test OFF,227.23, , , ,
,228.45,1880,12.29,17.8,20.3,227.84,94.5,15.6, ,Test OFF,228.13, , , ,
,229.50,1840,8.47,12.2,19.5,228.73,94.5,18.8, ,Test OFF,229.13, , , ,
,230.40,1840,5.62,7.8,15.0,229.80,94.5,23.4, ,Test OFF,230.09, , , ,
,231.34,1880,8.12,12.6,18.8,230.69,94.5,25.0, ,Test OFF,230.99, , , ,
,232.34,1920,10.62,14.8,20.3,231.75,94.5,21.9, ,Test OFF,232.04, , , ,
,233.23,1880,11.32,16.5,20.3,232.64,94.5,22.7, ,Test OFF,232.93, , , ,
,234.13,1920,11.67,16.5,20.3,233.53,94.5,23.4, ,Test OFF,233.84, , , ,
,235.03,1920,7.43,9.1,16.5,234.43,94.5,21.1, ,Test OFF,234.73, , , ,
,235.93,1960,10.14,14.8,21.0,235.33,94.5,22.7, ,Test OFF,235.64, , , ,
,236.83,1960,11.59,16.5,20.3,236.23,94.5,18.0, ,Test OFF,236.53, , , ,
,237.74,2000,12.15,17.4,21.8,237.13,94.5,21.1, ,Test OFF,237.43, , , ,
,238.64,2000,13.12,19.5,21.8,238.03,94.5,24.2, ,Test OFF,238.33, , , ,
,239.53,2040,14.72,21.7,21.0,238.93,94.5,20.3, ,Test OFF,239.23, , , ,
,240.43,2080,15.21,22.1,21.0,239.83,94.5,21.1, ,Test OFF,240.13, , , ,
,241.33,2120,12.15,16.9,21.8,240.73,94.5,24.2, ,Test OFF,241.03, , , ,
,242.23,2120,11.46,16.1,21.8,241.63,94.5,18.8, ,Test OFF,241.93, , , ,
,243.13,2120,10.69,14.8,21.8,242.53,94.5,21.1, ,Test OFF,242.83, , , ,
,244.03,2120,6.87,9.1,18.0,243.43,94.5,20.3, ,Test OFF,243.73, , , ,
,244.93,2080,6.94,10.0,17.3,244.33,94.5,0.0, ,Test OFF,244.66, , , ,
,245.83,2080,13.12,18.7,21.8,245.23,94.5,7.0, ,Test OFF,245.53, , , ,
,246.73,2160,14.23,20.8,21.8,246.13,94.5,17.2, ,Test OFF,246.43, , , ,
,247.63,2160,14.37,20.8,21.8,247.03,94.5,16.4, ,Test OFF,247.33, , , ,
,248.53,2200,14.86,21.7,21.8,247.93,94.5,20.3, ,Test OFF,248.23, , , ,
,249.60,2200,14.17,20.0,21.8,248.86,94.5,16.4, ,Test OFF,249.30, , , ,
,250.50,2240,12.98,18.2,21.8,249.90,94.5,18.0, ,Test OFF,250.20, , , ,
,251.40,2240,13.12,18.2,21.8,250.80,94.5,17.2, ,Test OFF,251.10, , , ,
,252.29,2280,10.76,14.8,22.5,251.69,94.5,13.3, ,Test OFF,251.99, , , ,
,253.19,1720,10.14,14.3,18.8,252.59,94.5,20.3, ,Test OFF,252.89, , , ,
,254.09,1840,10.42,14.8,20.3,253.49,94.5,20.3, ,Test OFF,253.79, , , ,
,254.99,1760,10.48,14.8,19.5,254.39,94.5,22.7, ,Test OFF,254.69, , , ,
,255.89,1800,10.90,15.6,20.3,255.29,94.5,24.2, ,Test OFF,255.59, , , ,
,256.79,1800,10.62,14.3,20.3,256.19,94.5,25.0, ,Test OFF,256.49, , , ,
,257.69,1640,3.89,5.2,13.5,257.09,94.5,21.1, ,Test OFF,257.39, , , ,
,258.59,1800,6.11,8.7,15.0,257.99,94.5,2.3, ,Test OFF,258.29, , , ,
,259.49,1840,6.67,9.1,15.8,258.89,94.5,9.4, ,Test OFF,259.19, , , ,
,260.39,1840,5.97,8.7,15.0,259.79,94.5,16.4, ,Test OFF,260.09, , , ,
,261.28,1800,4.86,5.2,12.0,260.69,94.5,23.4, ,Test OFF,260.99, , , ,
,262.18,1520,3.33,2.2,4.5,261.58,94.5,0.0, ,Test OFF,261.88, , , ,
,263.08,1440,3.19,2.6,6.0,262.48,94.5,0.0, ,Test OFF,262.78, , , ,
,263.98,1280,2.84,2.6,9.0,263.38,94.5,0.0, ,Test OFF,263.68, , , ,
,264.88,1200,2.64,2.6,9.8,264.27,94.5,0.0, ,Test OFF,264.58, , , ,
,265.78,1200,2.71,1.7,2.3,265.18,94.5,0.0, ,Test OFF,265.48, , , ,
,266.68,1400,3.12,2.2,6.8,266.09,94.5,0.0, ,Test OFF,266.38, , , ,
,267.58,1320,2.84,2.6,9.8,266.98,94.5,0.0, ,Test OFF,267.28, , , ,
,268.48,1200,2.64,2.6,9.8,267.88,94.5,0.0, ,Test OFF,268.18, , , ,
,269.38,1160,2.57,2.6,9.8,268.78,94.5,0.0, ,Test OFF,269.07, , , ,
,270.28,1080,2.50,2.6,10.5,269.67,94.5,0.0, ,Test OFF,269.98, , , ,
,271.17,1000,2.50,2.2,9.8,270.57,94.5,2.3, ,Test OFF,270.87, , , ,
,272.07,1040,2.57,2.2,9.8,271.47,94.5,5.5, ,Test OFF,271.77, , , ,
,272.97,1080,2.57,2.2,9.0,272.37,94.5,9.4, ,Test OFF,272.67, , , ,
,273.86,1120,2.57,2.2,9.8,273.27,94.5,12.5, ,Test OFF,273.57, , , ,
,274.77,1040,2.57,2.2,9.8,274.17,94.5,1.6, ,Test OFF,274.46, , , ,
,275.67,1600,9.65,12.6,17.3,275.06,94.5,4.7, ,Test OFF,275.36, , , ,
,276.57,1760,9.51,13.9,19.5,275.97,94.5,10.2, ,Test OFF,276.27, , , ,
,277.48,1920,11.81,16.9,20.3,276.87,94.5,18.8, ,Test OFF,277.17, , , ,
,278.37,1880,11.39,16.5,20.3,277.79,94.5,21.9, ,Test OFF,278.07, , , ,
,279.27,1920,8.12,10.4,19.5,278.67,94.5,20.3, ,Test OFF,278.97, , , ,
,280.17,1800,6.11,8.7,15.0,279.57,94.5,23.4, ,Test OFF,279.87, , , ,
,281.07,1960,10.34,14.3,21.0,280.46,94.5,25.0, ,Test OFF,280.77, , , ,
,281.97,2000,9.79,13.5,21.8,281.37,94.5,21.9, ,Test OFF,281.67, , , ,
,282.86,1840,4.37,5.2,11.3,282.27,94.5,21.1, ,Test OFF,282.56, , , ,
,283.77,1640,3.61,2.6,3.0,283.17,94.5,0.0, ,Test OFF,283.47, , , ,
,284.66,1960,10.21,14.8,21.0,284.06,94.5,0.0, ,Test OFF,284.37, , , ,
,285.57,1920,4.86,6.1,12.0,284.97,94.5,5.5, ,Test OFF,285.26, , , ,
,286.47,1680,3.68,2.6,3.0,285.88,94.5,0.0, ,Test OFF,286.17, , , ,
,287.37,1640,3.61,2.6,3.0,286.76,94.5,0.0, ,Test OFF,287.06, , , ,
,288.27,1680,3.68,2.6,3.0,287.66,94.5,0.0, ,Test OFF,287.97, , , ,
,289.17,1640,3.61,2.6,3.0,288.56,94.5,0.0, ,Test OFF,288.87, , , ,
,290.06,1640,3.61,2.6,3.0,289.47,94.5,0.0, ,Test OFF,289.76, , , ,
,290.96,1640,3.61,2.6,3.0,290.36,94.5,0.0, ,Test OFF,290.67, , , ,
,291.87,1640,4.03,6.5,13.5,291.27,94.5,0.0, ,Test OFF,291.57, , , ,
,292.76,2080,11.39,16.5,21.8,292.16,94.5,2.3, ,Test OFF,292.46, , , ,
,293.67,2160,12.08,17.4,21.8,293.07,94.5,10.9, ,Test OFF,293.37, , , ,
,294.56,2160,7.84,10.9,18.0,293.96,94.5,15.6, ,Test OFF,294.26, , , ,
,295.46,2240,11.53,16.1,21.8,294.87,94.5,19.5, ,Test OFF,295.16, , , ,
,296.36,2240,14.17,20.0,21.8,295.76,94.5,18.8, ,Test OFF,296.07, , , ,
,297.26,2320,12.64,17.4,21.8,296.66,94.5,14.8, ,Test OFF,296.97, , , ,
,298.50,1520,3.54,3.5,6.8,297.60,94.5,20.3, ,Test OFF,298.08, , , ,
,299.40,1440,3.19,2.2,6.0,298.80,94.5,0.0, ,Test OFF,299.10, , , ,
,300.30,1440,3.12,2.2,6.0,299.70,94.5,0.0, ,Test OFF,300.00, , , ,
,301.20,1800,9.65,14.3,20.3,300.60,94.5,0.0, ,Test OFF,300.90, , , ,
,302.10,2040,13.54,19.5,21.8,301.50,94.5,6.3, ,Test OFF,301.81, , , ,
,303.00,1960,13.19,20.4,20.3,302.40,94.5,16.4, ,Test OFF,302.70, , , ,
,303.90,1760,15.42,24.3,18.0,303.30,94.5,20.3, ,Test OFF,303.60, , , ,
,304.80,1840,18.26,29.5,12.8,304.20,94.5,21.9, ,Test OFF,304.50, , , ,
,305.70,1920,19.23,30.8,12.8,305.10,94.5,21.9, ,Test OFF,305.40, , , ,
,306.59,1960,17.50,27.3,15.8,306.00,94.5,18.0, ,Test OFF,306.29, , , ,
,307.49,2040,14.65,20.8,21.0,306.89,94.5,15.6, ,Test OFF,307.19, , , ,
,308.39,2080,13.68,19.5,21.8,307.79,94.5,19.5, ,Test OFF,308.09, , , ,
,309.29,2120,12.64,18.2,21.8,308.69,94.5,18.8, ,Test OFF,308.99, , , ,
,310.19,2120,5.76,7.4,12.0,309.59,94.5,18.0, ,Test OFF,309.89, , , ,
,311.09,2120,3.96,3.5,6.8,310.49,94.5,0.0, ,Test OFF,310.79, , , ,
,311.99,2120,3.89,3.0,6.8,311.39,94.5,0.0, ,Test OFF,311.69, , , ,
,312.88,2080,3.89,3.5,6.8,312.29,94.5,0.0, ,Test OFF,312.58, , , ,
,313.78,2040,3.82,4.3,6.8,313.18,94.5,0.0, ,Test OFF,313.48, , , ,
,314.68,2040,5.21,7.4,17.3,314.08,94.5,0.0, ,Test OFF,314.38, , , ,
,315.58,2000,3.89,4.8,6.8,314.98,94.5,0.0, ,Test OFF,315.28, , , ,
,316.48,2000,6.94,10.4,17.3,315.88,94.5,0.0, ,Test OFF,316.18, , , ,
,317.38,2000,10.69,14.8,21.8,316.78,94.5,5.5, ,Test OFF,317.08, , , ,
,318.28,2040,11.39,16.1,21.8,317.68,94.5,14.1, ,Test OFF,317.98, , , ,
,319.18,2000,7.01,10.0,17.3,318.58,94.5,22.7, ,Test OFF,318.88, , , ,
,320.08,1960,3.89,3.5,6.0,319.48,94.5,25.0, ,Test OFF,319.78, , , ,
,320.98,1880,3.75,3.0,6.0,320.38,94.5,0.0, ,Test OFF,320.68, , , ,
,321.88,1600,3.54,2.6,6.0,321.28,94.5,0.0, ,Test OFF,321.58, , , ,
,322.78,1360,2.98,2.6,10.5,322.18,94.5,0.0, ,Test OFF,322.48, , , ,
,323.68,1240,2.78,2.6,9.8,323.08,94.5,0.0, ,Test OFF,323.38, , , ,
,324.58,1120,2.57,2.2,9.8,323.98,94.5,0.0, ,Test OFF,324.28, , , ,
,325.48,1640,13.40,20.8,15.8,324.88,94.5,0.0, ,Test OFF,325.18, , , ,
,326.38,1280,3.61,4.3,13.5,325.78,94.5,1.6, ,Test OFF,326.08, , , ,
,327.27,1360,2.98,2.2,-3.0,326.68,94.5,4.7, ,Test OFF,326.98, , , ,
,328.17,1800,10.56,14.8,19.5,327.57,94.5,0.0, ,Test OFF,327.87, , , ,
,329.07,2200,18.61,27.8,16.5,328.47,94.5,4.7, ,Test OFF,328.77, , , ,
,329.97,2080,21.32,34.3,17.3,329.37,94.5,16.4, ,Test OFF,329.67, , , ,
,330.87,1720,21.81,40.4,7.5,330.27,94.5,18.0, ,Test OFF,330.57, , , ,
,331.76,1800,23.33,42.5,6.8,331.16,94.5,15.6, ,Test OFF,331.46, , , ,
,332.66,1840,22.36,37.3,8.3,332.06,94.5,20.3, ,Test OFF,332.36, , , ,
,333.56,1920,23.61,39.9,10.5,332.96,94.5,19.5, ,Test OFF,333.26, , , ,
,334.46,1960,22.84,37.3,9.8,333.86,94.5,16.4, ,Test OFF,334.16, , , ,
,335.36,2000,22.92,36.5,12.0,334.76,94.5,16.4, ,Test OFF,335.06, , , ,
,336.26,2000,21.81,34.3,15.0,335.66,94.5,20.3, ,Test OFF,335.96, , , ,
,337.16,2080,18.75,28.6,19.5,336.56,94.5,16.4, ,Test OFF,336.86, , , ,
,338.08,2120,21.11,32.1,18.0,337.46,94.5,17.2, ,Test OFF,337.76, , , ,
,338.96,2160,20.56,31.2,18.8,338.36,94.5,16.4, ,Test OFF,338.66, , , ,
,339.86,2240,20.90,31.2,19.5,339.26,94.5,22.7, ,Test OFF,339.56, , , ,
,340.76,2280,20.97,31.2,19.5,340.16,94.5,15.6, ,Test OFF,340.46, , , ,
,341.66,2320,21.11,31.2,19.5,341.06,94.5,20.3, ,Test OFF,341.36, , , ,
,342.56,2360,17.36,24.3,21.0,341.96,94.5,19.5, ,Test OFF,342.26, , , ,
,343.46,2400,11.18,15.2,22.5,342.86,94.5,18.0, ,Test OFF,343.16, , , ,
,344.36,1760,6.53,9.1,15.8,343.76,94.5,15.6, ,Test OFF,344.06, , , ,
,345.26,1640,3.68,3.5,6.0,344.66,94.5,24.2, ,Test OFF,344.96, , , ,
,346.16,1560,3.40,2.2,3.8,345.56,94.5,0.0, ,Test OFF,345.86, , , ,
,347.06,1600,3.47,2.2,3.0,346.46,94.5,0.0, ,Test OFF,346.76, , , ,
,347.96,1600,3.54,2.6,3.0,347.36,94.5,0.0, ,Test OFF,347.66, , , ,
,348.86,1520,3.40,2.6,7.5,348.26,94.5,0.0, ,Test OFF,348.56, , , ,
,349.76,1520,3.33,2.2,7.5,349.16,94.5,0.0, ,Test OFF,349.46, , , ,
,350.66,1480,3.33,2.2,8.3,350.06,94.5,0.0, ,Test OFF,350.36, , , ,
,351.56,1360,3.06,2.6,10.5,350.96,94.5,0.0, ,Test OFF,351.25, , , ,
,352.46,1280,2.84,2.2,9.0,351.86,94.5,0.0, ,Test OFF,352.15, , , ,
,353.35,1080,2.50,2.6,11.3,352.75,94.5,0.0, ,Test OFF,353.06, , , ,
,354.25,1120,2.64,1.7,0.8,353.66,94.5,0.0, ,Test OFF,353.96, , , ,
,355.16,920,2.50,2.6,12.8,354.56,94.5,0.8, ,Test OFF,354.86, , , ,
,356.05,760,2.57,3.5,19.5,355.45,94.5,3.9, ,Test OFF,355.76, , , ,
,356.95,840,2.98,3.9,9.8,356.36,94.5,6.3, ,Test OFF,356.65, , , ,
,357.85,880,4.23,6.5,12.0,357.25,94.5,8.6, ,Test OFF,357.56, , , ,
,358.75,1760,11.81,16.5,19.5,358.16,94.5,10.9, ,Test OFF,358.46, , , ,
,359.66,1800,11.87,17.4,20.3,359.06,94.5,18.8, ,Test OFF,359.35, , , ,
,360.55,1880,13.26,19.1,21.0,359.95,94.5,25.0, ,Test OFF,360.26, , , ,
,361.45,1920,13.33,19.1,20.3,360.86,94.5,25.0, ,Test OFF,361.15, , , ,
,362.36,1880,11.39,15.6,20.3,361.75,94.5,24.2, ,Test OFF,362.05, , , ,
,363.25,1760,8.06,10.0,18.8,362.66,94.5,20.3, ,Test OFF,362.96, , , ,
,364.15,1480,3.61,3.5,7.5,363.55,94.5,25.0, ,Test OFF,363.86, , , ,
,365.05,1760,8.26,11.3,18.8,364.45,94.5,0.0, ,Test OFF,364.76, , , ,
,365.95,1720,5.90,7.8,15.0,365.36,94.5,3.9, ,Test OFF,365.66, , , ,
,366.85,1600,3.54,3.5,6.0,366.26,94.5,10.9, ,Test OFF,366.56, , , ,
,367.76,1560,3.40,2.6,3.8,367.15,94.5,0.0, ,Test OFF,367.45, , , ,
,368.65,1560,3.47,2.6,3.8,368.05,94.5,0.0, ,Test OFF,368.35, , , ,
,369.55,1600,3.54,2.6,3.0,368.95,94.5,0.0, ,Test OFF,369.26, , , ,
,370.44,1640,3.61,2.6,3.0,369.84,94.5,0.0, ,Test OFF,370.14, , , ,
,371.33,1680,3.68,2.6,3.0,370.73,94.5,0.0, ,Test OFF,371.03, , , ,
,372.23,1680,3.68,2.6,3.0,371.63,94.5,0.0, ,Test OFF,371.93, , , ,
,373.13,1720,3.82,2.6,6.0,372.53,94.5,0.0, ,Test OFF,372.83, , , ,
,374.02,1680,3.68,2.6,6.0,373.43,94.5,0.0, ,Test OFF,373.73, , , ,
,374.93,1720,3.75,2.6,6.0,374.32,94.5,0.0, ,Test OFF,374.62, , , ,
,375.82,1720,3.75,2.6,6.0,375.22,94.5,0.0, ,Test OFF,375.54, , , ,
,376.90,1680,3.75,2.6,6.0,376.15,94.5,0.0, ,Test OFF,376.59, , , ,
,377.79,1600,3.47,2.6,6.0,377.20,94.5,0.0, ,Test OFF,377.49, , , ,
,378.85,1360,2.98,2.6,10.5,378.14,94.5,0.0, ,Test OFF,378.55, , , ,
,379.75,1360,2.98,2.6,7.5,379.15,94.5,0.0, ,Test OFF,379.45, , , ,
,380.64,1360,2.98,2.2,7.5,380.05,94.5,0.0, ,Test OFF,380.35, , , ,
,381.54,1280,2.84,2.2,9.8,380.94,94.5,0.0, ,Test OFF,381.24, , , ,
,382.44,1240,2.71,2.6,9.8,381.84,94.5,0.0, ,Test OFF,382.14, , , ,
,383.34,1240,2.78,2.2,9.0,382.74,94.5,0.0, ,Test OFF,383.04, , , ,
,384.24,1160,2.57,2.2,9.8,383.64,94.5,0.0, ,Test OFF,383.94, , , ,
,385.14,760,2.50,4.3,24.0,384.54,94.5,0.0, ,Test OFF,384.84, , , ,
,386.04,800,3.26,4.3,16.5,385.44,94.5,2.3, ,Test OFF,385.74, , , ,
,386.93,840,3.12,3.9,5.3,386.33,94.5,4.7, ,Test OFF,386.64, , , ,
,387.83,800,2.92,3.9,9.0,387.23,94.5,7.0, ,Test OFF,387.53, , , ,
,388.72,800,3.06,3.9,16.5,388.13,94.5,9.4, ,Test OFF,388.42, , , ,
,389.62,880,3.47,3.9,6.0,389.02,94.5,11.7, ,Test OFF,389.33, , , ,
,390.51,840,3.19,4.3,10.5,389.92,94.5,13.3, ,Test OFF,390.22, , , ,
,391.41,840,3.26,4.3,10.5,390.82,94.5,15.6, ,Test OFF,391.11, , , ,
,392.31,840,3.47,4.3,8.3,391.71,94.5,18.0, ,Test OFF,392.01, , , ,
,393.20,840,3.54,4.3,6.8,392.61,94.5,20.3, ,Test OFF,392.91, , , ,
,394.10,840,3.40,4.3,9.8,393.51,94.5,22.7, ,Test OFF,393.81, , , ,
,395.00,840,3.47,4.3,9.0,394.40,94.5,24.2, ,Test OFF,394.70, , , ,
,395.90,840,3.47,4.3,5.3,395.30,94.5,25.0, ,Test OFF,395.60, , , ,
,396.79,840,3.40,4.3,8.3,396.19,94.5,25.0, ,Test OFF,396.49, , , ,
,397.75,800,3.33,4.3,11.3,397.09,94.5,25.0, ,Test OFF,397.39, , , ,
,398.76,840,3.33,4.3,12.0,398.16,94.5,25.0, ,Test OFF,398.46, , , ,
,399.66,840,3.47,4.3,8.3,399.06,94.5,25.0, ,Test OFF,399.36, , , ,
,400.56,880,3.54,4.3,3.8,399.96,94.5,25.0, ,Test OFF,400.26, , , ,
,401.46,840,3.61,4.3,9.8,400.86,94.5,25.0, ,Test OFF,401.16, , , ,
,402.35,880,3.47,3.9,3.0,401.75,94.5,25.0, ,Test OFF,402.05, , , ,
,403.25,1240,3.75,4.3,11.3,402.65,94.5,25.0, ,Test OFF,402.95, , , ,
,404.32,960,3.40,4.3,7.5,403.59,94.5,25.0, ,Test OFF,404.02, , , ,
,405.21,880,3.06,3.9,6.0,404.62,94.5,25.0, ,Test OFF,404.91, , , ,
,406.11,880,3.26,3.9,1.5,405.51,94.5,25.0, ,Test OFF,405.81, , , ,
,407.01,880,3.06,3.9,5.3,406.41,94.5,25.0, ,Test OFF,406.71, , , ,
,407.91,800,3.12,4.3,15.8,407.31,94.5,25.0, ,Test OFF,407.61, , , ,
,408.81,840,3.33,4.3,12.0,408.21,94.5,25.0, ,Test OFF,408.51, , , ,
,409.71,880,3.54,4.3,6.8,409.11,94.5,25.0, ,Test OFF,409.41, , , ,
,410.61,840,3.47,4.3,6.8,410.01,94.5,25.0, ,Test OFF,410.31, , , ,
,411.51,840,3.47,4.3,6.8,410.91,94.5,25.0, ,Test OFF,411.21, , , ,
,412.40,840,3.40,4.3,9.8,411.80,94.5,25.0, ,Test OFF,412.10, , , ,
,413.30,840,3.33,4.3,10.5,412.70,94.5,25.0, ,Test OFF,413.00, , , ,
,414.20,840,3.33,4.3,9.0,413.61,94.5,25.0, ,Test OFF,413.90, , , ,
,415.10,800,3.26,4.3,10.5,414.50,94.5,25.0, ,Test OFF,414.81, , , ,
,416.00,840,3.26,3.9,5.3,415.40,94.5,25.0, ,Test OFF,415.70, , , ,
,416.90,880,3.54,4.3,4.5,416.30,94.5,25.0, ,Test OFF,416.60, , , ,
,417.80,840,3.40,4.3,5.3,417.20,94.5,25.0, ,Test OFF,417.50, , , ,
,418.69,880,3.54,4.3,5.3,418.10,94.5,25.0, ,Test OFF,418.39, , , ,
,419.59,840,3.40,4.3,10.5,418.99,94.5,25.0, ,Test OFF,419.29, , , ,
,420.49,840,3.47,4.3,12.0,419.89,94.5,25.0, ,Test OFF,420.19, , , ,
,421.39,840,3.54,4.3,6.8,420.79,94.5,25.0, ,Test OFF,421.09, , , ,
,422.32,840,3.54,4.3,6.0,421.69,94.5,25.0, ,Test OFF,421.99, , , ,
,423.18,840,3.54,4.3,6.8,422.59,94.5,25.0, ,Test OFF,422.89, , , ,
,424.09,840,3.47,4.3,9.0,423.49,94.5,25.0, ,Test OFF,423.79, , , ,
,424.99,800,3.26,4.3,14.3,424.39,94.5,25.0, ,Test OFF,424.69, , , ,
,425.89,840,3.47,4.3,6.8,425.29,94.5,25.0, ,Test OFF,425.59, , , ,
,426.79,800,3.33,4.3,13.5,426.20,94.5,25.0, ,Test OFF,426.48, , , ,
,427.69,1600,15.34,21.7,8.3,427.09,94.5,25.0, ,Test OFF,427.39, , , ,
,428.59,1960,14.58,21.3,21.0,427.99,94.5,25.0, ,Test OFF,428.29, , , ,
,429.49,2080,13.54,19.1,21.8,428.89,94.5,22.7, ,Test OFF,429.19, , , ,
,430.38,2360,15.28,20.8,21.8,429.79,94.5,17.2, ,Test OFF,430.08, , , ,
,431.29,2080,17.22,26.0,21.0,430.69,94.5,21.1, ,Test OFF,430.98, , , ,
,432.19,2280,20.14,29.9,20.3,431.59,94.5,21.1, ,Test OFF,431.89, , , ,
,433.09,2520,23.89,33.4,19.5,432.49,94.5,21.1, ,Test OFF,432.79, , , ,
,433.99,2640,24.93,33.9,20.3,433.38,94.5,21.9, ,Test OFF,433.69, , , ,
,434.89,2800,25.56,33.9,20.3,434.29,94.5,15.6, ,Test OFF,434.60, , , ,
,435.79,2960,27.29,35.2,20.3,435.19,94.5,18.0, ,Test OFF,435.49, , , ,
,436.69,3040,25.21,33.0,21.0,436.09,94.5,19.5, ,Test OFF,436.38, , , ,
,437.59,2600,26.25,35.2,18.8,436.98,94.5,24.2, ,Test OFF,437.29, , , ,
,438.48,2680,25.48,34.7,19.5,437.89,94.5,15.6, ,Test OFF,438.19, , , ,
,439.39,2760,25.83,34.3,20.3,438.79,94.5,18.0, ,Test OFF,439.08, , , ,
,440.46,2600,20.00,28.2,21.8,439.68,94.5,22.7, ,Test OFF,440.02, , , ,
,441.36,2520,17.15,24.7,21.8,440.76,94.5,11.7, ,Test OFF,441.05, , , ,
,442.26,2560,19.86,27.8,21.0,441.66,94.5,14.1, ,Test OFF,441.96, , , ,
,443.16,2600,16.53,22.6,21.8,442.55,94.5,9.4, ,Test OFF,442.86, , , ,
,444.05,2000,12.84,18.2,21.8,443.45,94.5,3.9, ,Test OFF,443.76, , , ,
,444.95,2040,13.54,20.0,21.8,444.36,94.5,14.1, ,Test OFF,444.65, , , ,
,445.86,2040,15.21,23.0,21.0,445.26,94.5,9.4, ,Test OFF,445.55, , , ,
,446.76,2040,16.94,26.0,21.0,446.16,94.5,3.9, ,Test OFF,446.46, , , ,
,447.65,2120,17.08,25.6,21.0,447.06,94.5,4.7, ,Test OFF,447.36, , , ,
,448.55,2120,16.87,25.2,21.0,447.95,94.5,3.9, ,Test OFF,448.25, , , ,
,449.46,2160,16.39,24.3,21.0,448.85,94.5,3.1, ,Test OFF,449.15, , , ,
,450.36,2160,14.65,20.8,21.8,449.75,94.5,3.9, ,Test OFF,450.05, , , ,
,451.26,2160,13.40,19.1,21.8,450.66,94.5,-2.3, ,Test OFF,450.95, , , ,
,452.15,2160,13.47,18.7,21.8,451.55,94.5,-2.3, ,Test OFF,451.85, , , ,
,453.04,2160,4.03,5.2,6.8,452.44,94.5,-5.5, ,Test OFF,452.74, , , ,
,453.94,2160,9.09,12.6,20.3,453.36,94.5,1.6, ,Test OFF,453.64, , , ,
,454.84,2160,9.31,13.0,21.0,454.24,94.5,6.3, ,Test OFF,454.54, , , ,
,455.75,2120,3.96,3.5,6.8,455.15,96.0,7.8, ,Test OFF,455.44, , , ,
,456.65,2080,3.89,3.0,6.8,456.04,96.0,0.0, ,Test OFF,456.34, , , ,
,457.54,2040,3.82,3.0,6.8,456.94,96.0,0.0, ,Test OFF,457.24, , , ,
,458.44,2000,3.96,3.0,6.8,457.84,96.0,0.0, ,Test OFF,458.14, , , ,
,459.35,1960,3.89,3.0,6.0,458.73,96.0,0.0, ,Test OFF,459.03, , , ,
,460.23,1920,3.82,3.0,6.0,459.63,96.0,0.0, ,Test OFF,459.93, , , ,
,461.30,1880,3.75,3.0,6.0,460.59,96.0,0.0, ,Test OFF,461.00, , , ,
,462.20,1880,11.25,16.1,20.3,461.60,96.0,0.0, ,Test OFF,461.90, , , ,
,463.10,1880,12.78,18.2,20.3,462.50,96.0,0.0, ,Test OFF,462.81, , , ,
,464.00,1920,15.14,22.6,19.5,463.40,96.0,0.0, ,Test OFF,463.70, , , ,
,464.90,1920,10.48,13.0,20.3,464.30,96.0,3.9, ,Test OFF,464.61, , , ,
,465.80,1960,5.21,6.9,9.8,465.20,96.0,14.1, ,Test OFF,465.50, , , ,
,466.72,1920,4.44,6.1,15.0,466.10,96.0,21.1, ,Test OFF,466.40, , , ,
,467.60,1880,3.75,4.8,15.0,467.00,96.0,25.0, ,Test OFF,467.30, , , ,
,468.50,1800,3.68,3.0,6.0,467.90,94.5,25.0, ,Test OFF,468.20, , , ,
,469.40,2080,12.92,19.5,21.8,468.80,94.5,0.0, ,Test OFF,469.11, , , ,
,470.30,1880,4.79,6.1,12.8,469.70,94.5,7.8, ,Test OFF,470.00, , , ,
,471.20,1640,3.61,2.6,3.0,470.60,94.5,0.0, ,Test OFF,470.90, , , ,
,472.10,1600,3.47,2.6,3.0,471.50,94.5,0.0, ,Test OFF,471.80, , , ,
,473.00,1560,3.40,2.2,3.8,472.40,94.5,0.0, ,Test OFF,472.70, , , ,
,473.90,1520,3.33,2.2,4.5,473.30,94.5,0.0, ,Test OFF,473.60, , , ,
,474.80,1480,3.33,2.2,4.5,474.20,94.5,0.0, ,Test OFF,474.50, , , ,
,475.70,2040,13.96,19.1,21.8,475.10,94.5,0.0, ,Test OFF,475.40, , , ,
,476.60,2120,16.11,25.6,21.0,476.00,94.5,1.6, ,Test OFF,476.30, , , ,
,477.50,1800,14.86,22.1,18.0,476.90,94.5,10.9, ,Test OFF,477.20, , , ,
,478.40,1840,14.86,21.3,18.8,477.80,94.5,15.6, ,Test OFF,478.10, , , ,
,479.30,1920,14.79,23.0,20.3,478.70,94.5,17.2, ,Test OFF,479.00, , , ,
,480.20,1960,17.29,27.3,18.8,479.60,94.5,17.2, ,Test OFF,479.90, , , ,
,481.10,2000,16.81,25.6,20.3,480.50,94.5,13.3, ,Test OFF,480.80, , , ,
,482.00,2040,16.94,25.6,20.3,481.40,94.5,12.5, ,Test OFF,481.70, , , ,
,482.90,2080,16.11,24.3,21.0,482.30,94.5,7.0, ,Test OFF,482.60, , , ,
,483.80,2120,16.11,23.0,21.0,483.20,94.5,10.2, ,Test OFF,483.50, , , ,
,484.70,2160,14.17,20.0,21.8,484.10,94.5,3.9, ,Test OFF,484.40, , , ,
,485.60,2200,14.03,19.5,21.8,485.00,94.5,2.3, ,Test OFF,485.30, , , ,
,486.50,2200,13.12,18.7,21.8,485.90,94.5,-1.6, ,Test OFF,486.20, , , ,
,487.40,2240,15.48,22.1,21.8,486.80,94.5,-4.7, ,Test OFF,487.10, , , ,
,488.30,2280,16.18,23.4,21.0,487.70,94.5,0.0, ,Test OFF,488.00, , , ,
,489.20,2320,15.90,23.0,21.8,488.60,94.5,4.7, ,Test OFF,488.90, , , ,
,490.10,2320,16.11,22.1,21.8,489.50,94.5,-2.3, ,Test OFF,489.80, , , ,
,491.00,2360,14.37,18.7,21.8,490.40,94.5,-1.6, ,Test OFF,490.70, , , ,
,491.90,2400,11.46,16.1,21.8,491.30,94.5,-3.1, ,Test OFF,491.60, , , ,
,492.80,2400,4.09,5.6,6.8,492.20,94.5,1.6, ,Test OFF,492.50, , , ,
,493.70,2360,3.26,3.5,6.8,493.10,94.5,0.0, ,Test OFF,493.40, , , ,
,494.60,2320,3.19,3.5,6.8,494.00,94.5,0.0, ,Test OFF,494.30, , , ,
,495.50,2280,3.19,3.5,6.8,494.90,94.5,0.0, ,Test OFF,495.20, , , ,
,496.40,2280,3.12,3.5,6.8,495.80,94.5,0.0, ,Test OFF,496.10, , , ,
,497.29,2240,3.40,3.5,6.8,496.70,94.5,0.0, ,Test OFF,497.00, , , ,
,498.20,2200,3.54,3.5,6.8,497.60,94.5,0.0, ,Test OFF,497.90, , , ,
,499.10,2200,3.54,3.5,6.8,498.50,94.5,0.0, ,Test OFF,498.80, , , ,
,500.00,2160,3.75,3.5,6.8,499.40,94.5,0.0, ,Test OFF,499.70, , , ,
,500.90,2120,3.96,3.0,6.8,500.30,94.5,0.0, ,Test OFF,500.60, , , ,
,501.80,2120,8.54,11.3,19.5,501.20,94.5,0.0, ,Test OFF,501.50, , , ,
,502.70,2080,3.96,4.8,6.8,502.10,94.5,0.0, ,Test OFF,502.40, , , ,
,503.61,2040,3.75,3.0,6.8,503.00,94.5,0.0, ,Test OFF,503.30, , , ,
,504.50,2040,12.50,18.2,21.8,503.90,94.5,0.0, ,Test OFF,504.20, , , ,
,505.40,2040,12.57,18.7,21.8,504.80,94.5,0.0, ,Test OFF,505.10, , , ,
,506.30,2040,15.34,21.7,21.0,505.70,94.5,0.0, ,Test OFF,506.00, , , ,
,507.20,2040,12.01,15.6,21.8,506.60,94.5,2.3, ,Test OFF,506.90, , , ,
,508.09,2040,4.03,4.8,9.0,507.50,94.5,12.5, ,Test OFF,507.79, , , ,
,508.99,2000,3.96,3.0,6.8,508.39,94.5,0.0, ,Test OFF,508.69, , , ,
,509.89,2000,3.89,3.0,6.0,509.28,94.5,0.0, ,Test OFF,509.58, , , ,
,510.78,1960,3.82,3.0,6.0,510.18,94.5,0.0, ,Test OFF,510.48, , , ,
,511.68,1840,3.82,2.6,6.0,511.07,94.5,0.0, ,Test OFF,511.38, , , ,
,512.57,1440,3.19,3.0,9.0,511.98,94.5,0.0, ,Test OFF,512.28, , , ,
,513.48,1320,2.92,2.2,6.8,512.88,94.5,0.0, ,Test OFF,513.18, , , ,
,514.38,1400,3.12,2.2,6.8,513.78,94.5,0.0, ,Test OFF,514.08, , , ,
,515.27,1920,11.94,16.5,20.3,514.68,94.5,0.0, ,Test OFF,514.97, , , ,
,516.17,1960,12.15,17.4,20.3,515.58,94.5,0.8, ,Test OFF,515.87, , , ,
,517.07,1880,13.47,21.3,20.3,516.47,94.5,10.2, ,Test OFF,516.77, , , ,
,517.97,1760,14.65,21.7,18.0,517.37,94.5,20.3, ,Test OFF,517.67, , , ,
,518.87,1760,14.31,20.8,17.3,518.27,94.5,20.3, ,Test OFF,518.57, , , ,
,519.77,1840,8.26,11.7,19.5,519.18,94.5,24.2, ,Test OFF,519.48, , , ,
,520.68,1840,6.46,6.9,14.3,520.07,94.5,25.0, ,Test OFF,520.38, , , ,
,521.57,1560,3.40,2.2,3.8,521.00,93.0,0.0, ,Test OFF,521.27, , , ,
,522.47,1520,3.33,2.2,4.5,521.87,93.0,0.0, ,Test OFF,522.18, , , ,
,523.54,1480,3.26,2.2,5.3,522.83,93.0,0.0, ,Test OFF,523.24, , , ,
,524.45,1440,3.19,2.2,6.0,523.84,93.0,0.0, ,Test OFF,524.15, , , ,
,525.35,1520,6.73,11.7,15.8,524.74,93.0,0.0, ,Test OFF,525.05, , , ,
,526.24,2000,13.82,20.0,21.8,525.64,93.0,3.1, ,Test OFF,525.94, , , ,
,527.15,1800,14.37,21.7,18.8,526.55,91.5,12.5, ,Test OFF,526.84, , , ,
,528.05,1720,11.81,13.5,18.8,527.44,91.5,22.7, ,Test OFF,527.74, , , ,
,528.94,1520,3.40,3.0,7.5,528.34,91.5,19.5, ,Test OFF,528.64, , , ,
,529.85,1480,3.26,2.2,5.3,529.24,91.5,0.0, ,Test OFF,529.54, , , ,
,530.73,1440,3.19,2.2,6.0,530.14,91.5,0.0, ,Test OFF,530.43, , , ,
,531.63,1400,3.06,2.2,7.5,531.04,91.5,0.0, ,Test OFF,531.33, , , ,
,532.53,1360,2.98,2.2,8.3,531.93,91.5,0.0, ,Test OFF,532.23, , , ,
,533.43,1320,2.92,2.2,8.3,532.83,91.5,0.0, ,Test OFF,533.13, , , ,
,534.33,1280,2.84,2.2,8.3,533.73,91.5,0.0, ,Test OFF,534.03, , , ,
,535.23,1200,2.71,2.2,9.8,534.63,91.5,0.0, ,Test OFF,534.93, , , ,
,536.12,1160,2.50,2.2,9.8,535.53,93.0,0.0, ,Test OFF,535.82, , , ,
,537.03,1040,2.50,2.2,10.5,536.42,93.0,0.0, ,Test OFF,536.73, , , ,
,537.93,2120,19.51,29.5,19.5,537.32,93.0,3.1, ,Test OFF,537.62, , , ,
,538.82,2360,23.26,33.0,18.0,538.22,93.0,7.0, ,Test OFF,538.52, , , ,
,539.72,2160,17.29,25.2,21.0,539.12,93.0,20.3, ,Test OFF,539.43, , , ,
,540.62,2160,15.90,22.6,21.0,540.02,93.0,17.2, ,Test OFF,540.32, , , ,
,541.51,1480,3.61,3.5,8.3,540.92,93.0,17.2, ,Test OFF,541.21, , , ,
,542.41,1240,2.71,2.6,10.5,541.81,94.5,0.0, ,Test OFF,542.11, , , ,
,543.31,1160,2.57,2.6,9.8,542.71,94.5,0.0, ,Test OFF,543.01, , , ,
,544.20,1120,2.57,2.2,10.5,543.61,94.5,0.0, ,Test OFF,543.90, , , ,
,545.10,1200,2.71,2.2,9.8,544.50,93.0,2.3, ,Test OFF,544.80, , , ,
,546.00,960,2.43,3.0,18.0,545.40,94.5,0.0, ,Test OFF,545.70, , , ,
,546.90,760,2.43,3.5,24.0,546.30,94.5,2.3, ,Test OFF,546.60, , , ,
,547.80,760,2.84,4.3,19.5,547.20,94.5,4.7, ,Test OFF,547.50, , , ,
,548.70,880,4.79,9.1,12.8,548.10,94.5,7.0, ,Test OFF,548.40, , , ,
,549.60,1600,10.90,14.8,17.3,549.00,94.5,10.2, ,Test OFF,549.31, , , ,
,550.50,1720,12.01,17.8,19.5,549.90,94.5,17.2, ,Test OFF,550.20, , , ,
,551.40,2000,16.59,26.0,21.0,550.80,94.5,24.2, ,Test OFF,551.10, , , ,
,552.29,2280,21.94,32.1,18.8,551.69,94.5,17.2, ,Test OFF,551.99, , , ,
,553.19,2400,25.34,34.7,17.3,552.59,94.5,21.1, ,Test OFF,552.89, , , ,
,554.09,2560,29.72,39.9,16.5,553.49,94.5,20.3, ,Test OFF,553.79, , , ,
,554.99,2720,34.31,43.4,16.5,554.39,94.5,20.3, ,Test OFF,554.69, , , ,
,555.89,2840,36.39,44.3,16.5,555.29,94.5,20.3, ,Test OFF,555.59, , , ,
,556.79,2880,37.43,44.7,16.5,556.19,94.5,18.0, ,Test OFF,556.49, , , ,
,557.69,2880,36.87,44.3,16.5,557.09,94.5,12.5, ,Test OFF,557.39, , , ,
,558.59,2880,35.42,43.0,16.5,557.99,94.5,14.1, ,Test OFF,558.29, , , ,
,559.49,2880,32.29,39.1,16.5,558.89,94.5,16.4, ,Test OFF,559.19, , , ,
,560.39,2640,22.50,31.2,21.0,559.79,94.5,15.6, ,Test OFF,560.09, , , ,
,561.29,2400,13.68,19.5,21.8,560.69,94.5,17.2, ,Test OFF,560.99, , , ,
,562.19,2280,14.17,20.8,21.8,561.59,94.5,18.0, ,Test OFF,561.89, , , ,
,563.09,1680,19.09,34.7,11.3,562.49,94.5,14.1, ,Test OFF,562.79, , , ,
,563.99,1720,21.73,39.9,6.8,563.39,94.5,16.4, ,Test OFF,563.69, , , ,
,564.89,1720,23.19,43.8,6.0,564.29,94.5,14.8, ,Test OFF,564.59, , , ,
,565.79,1760,23.75,44.7,3.0,565.19,94.5,12.5, ,Test OFF,565.49, , , ,
,566.69,1800,24.86,46.9,3.8,566.09,94.5,16.4, ,Test OFF,566.39, , , ,
,567.59,1880,25.69,47.3,5.3,566.99,94.5,19.5, ,Test OFF,567.29, , , ,
,568.49,1920,26.04,46.9,5.3,567.89,94.5,15.6, ,Test OFF,568.19, , , ,
,569.39,1920,26.11,44.7,6.8,568.79,94.5,13.3, ,Test OFF,569.09, , , ,
,570.29,1960,26.11,44.3,6.8,569.69,94.5,14.8, ,Test OFF,569.99, , , ,
,571.19,2000,27.15,47.3,9.0,570.59,94.5,17.2, ,Test OFF,570.89, , , ,
,572.09,2000,27.36,47.7,8.3,571.49,94.5,12.5, ,Test OFF,571.79, , , ,
,572.99,2040,27.98,47.7,5.3,572.39,94.5,16.4, ,Test OFF,572.69, , , ,
,573.89,2120,28.33,46.9,9.0,573.29,94.5,14.8, ,Test OFF,573.59, , , ,
,574.79,2120,28.26,45.6,9.8,574.19,94.5,16.4, ,Test OFF,574.49, , , ,
,575.69,2160,29.23,46.0,3.8,575.09,94.5,14.8, ,Test OFF,575.39, , , ,
,576.59,2200,29.51,46.4,7.5,575.99,94.5,15.6, ,Test OFF,576.29, , , ,
,577.49,2240,30.69,47.7,11.3,576.89,94.5,14.1, ,Test OFF,577.19, , , ,
,578.39,2280,30.76,46.9,11.3,577.79,94.5,15.6, ,Test OFF,578.09, , , ,
,579.28,2280,31.04,46.9,9.0,578.69,94.5,11.7, ,Test OFF,578.99, , , ,
,580.18,2320,32.08,49.0,6.0,579.58,94.5,14.8, ,Test OFF,579.88, , , ,
,581.08,2360,32.64,48.6,9.8,580.48,94.5,16.4, ,Test OFF,580.78, , , ,
,581.98,2400,33.19,47.7,10.5,581.38,94.5,12.5, ,Test OFF,581.68, , , ,
,582.87,2400,33.06,46.9,10.5,582.28,94.5,13.3, ,Test OFF,582.58, , , ,
,583.77,2440,33.54,46.9,7.5,583.17,96.0,14.1, ,Test OFF,583.47, , , ,
,584.67,2480,33.61,46.9,12.0,584.07,96.0,14.1, ,Test OFF,584.37, , , ,
,585.57,2520,34.03,45.1,12.0,584.97,96.0,18.8, ,Test OFF,585.27, , , ,
,586.47,2560,32.57,43.0,13.5,585.87,96.0,14.8, ,Test OFF,586.17, , , ,
,587.37,2600,32.36,42.5,14.3,586.77,96.0,14.1, ,Test OFF,587.07, , , ,
,588.27,2600,31.32,40.8,12.0,587.67,96.0,17.2, ,Test OFF,587.96, , , ,
,589.17,2640,24.03,32.1,18.8,588.57,96.0,18.8, ,Test OFF,588.87, , , ,
,590.07,2640,19.79,27.8,21.8,589.47,96.0,15.6, ,Test OFF,589.77, , , ,
,590.97,2680,24.31,33.0,18.0,590.37,96.0,19.5, ,Test OFF,590.67, , , ,
,591.87,2680,20.21,27.3,21.8,591.27,96.0,20.3, ,Test OFF,591.57, , , ,
,592.77,2680,19.65,26.9,21.8,592.17,96.0,17.2, ,Test OFF,592.47, , , ,
,593.67,2680,21.59,29.5,21.8,593.07,96.0,15.6, ,Test OFF,593.37, , , ,
,594.57,2680,20.69,28.2,21.8,593.97,96.0,16.4, ,Test OFF,594.27, , , ,
,595.46,2680,21.18,29.5,21.8,594.87,96.0,15.6, ,Test OFF,595.17, , , ,
,596.37,2720,14.51,16.1,22.5,595.77,96.0,18.0, ,Test OFF,596.07, , , ,
,597.28,2720,14.93,20.4,22.5,596.67,96.0,20.3, ,Test OFF,596.97, , , ,
,598.16,2720,16.39,22.6,22.5,597.56,96.0,15.6, ,Test OFF,597.86, , , ,
,599.06,2720,22.50,30.8,21.8,598.46,96.0,17.2, ,Test OFF,598.76, , , ,
,599.97,2760,18.68,25.6,21.8,599.37,96.0,21.1, ,Test OFF,599.67, , , ,
,600.86,2720,19.03,26.0,21.8,600.26,96.0,16.4, ,Test OFF,600.57, , , ,
,601.77,2720,19.79,26.9,21.8,601.17,96.0,8.6, ,Test OFF,601.47, , , ,
,602.67,2720,20.07,27.3,21.8,602.07,96.0,10.2, ,Test OFF,602.36, , , ,
,603.56,2720,20.28,27.8,21.8,602.96,96.0,4.7, ,Test OFF,603.27, , , ,
,604.47,2720,20.42,27.8,21.8,603.87,96.0,7.0, ,Test OFF,604.16, , , ,
,605.37,2720,20.42,28.2,21.8,604.77,96.0,0.8, ,Test OFF,605.07, , , ,
,606.26,2720,21.67,29.5,21.8,605.66,96.0,4.7, ,Test OFF,605.96, , , ,
,607.16,2720,19.79,26.9,21.8,606.56,96.0,6.3, ,Test OFF,606.86, , , ,
,608.06,2720,19.72,26.9,21.8,607.46,96.0,0.8, ,Test OFF,607.76, , , ,
,608.96,2720,19.65,26.9,21.8,608.36,96.0,3.1, ,Test OFF,608.67, , , ,
,609.86,2720,19.79,27.3,21.8,609.26,96.0,7.8, ,Test OFF,609.56, , , ,
,610.76,2720,19.86,27.3,21.8,610.16,96.0,4.7, ,Test OFF,610.47, , , ,
,611.66,2680,20.07,27.3,21.8,611.06,96.0,1.6, ,Test OFF,611.36, , , ,
,612.57,2680,20.07,27.3,21.8,611.96,96.0,3.9, ,Test OFF,612.26, , , ,
,613.51,2680,20.00,27.8,21.8,612.86,96.0,7.8, ,Test OFF,613.16, , , ,
,614.52,2680,20.00,27.8,21.8,613.92,96.0,7.8, ,Test OFF,614.22, , , ,
,615.42,2680,20.00,27.8,21.8,614.82,96.0,8.6, ,Test OFF,615.12, , , ,
,616.32,2680,21.53,29.5,21.8,615.72,96.0,6.3, ,Test OFF,616.02, , , ,
,617.22,2680,21.87,29.9,21.8,616.62,96.0,3.9, ,Test OFF,616.92, , , ,
,618.12,2680,21.87,29.9,21.8,617.52,96.0,8.6, ,Test OFF,617.82, , , ,
,619.02,2680,21.73,29.5,21.8,618.42,96.0,7.0, ,Test OFF,618.72, , , ,
,619.92,2680,21.59,29.5,21.8,619.32,96.0,2.3, ,Test OFF,619.62, , , ,
,620.81,2680,21.67,29.5,21.8,620.21,96.0,4.7, ,Test OFF,620.51, , , ,
,621.71,2680,21.67,29.5,21.8,621.11,96.0,7.8, ,Test OFF,621.41, , , ,
,622.61,2720,21.46,29.5,21.8,622.01,96.0,6.3, ,Test OFF,622.31, , , ,
,623.50,2720,21.59,29.5,21.8,622.91,96.0,3.1, ,Test OFF,623.21, , , ,
,624.40,2720,21.67,29.5,21.8,623.80,96.0,7.8, ,Test OFF,624.10, , , ,
,625.30,2760,21.46,29.5,21.8,624.71,96.0,3.9, ,Test OFF,625.00, , , ,
,626.20,2760,21.59,29.5,21.8,625.60,96.0,5.5, ,Test OFF,625.90, , , ,
,627.10,2760,21.67,29.5,21.8,626.50,96.0,3.9, ,Test OFF,626.80, , , ,
,628.00,2760,21.67,29.5,21.8,627.40,96.0,7.8, ,Test OFF,627.70, , , ,
,628.90,2800,21.46,29.5,21.8,628.30,96.0,4.7, ,Test OFF,628.60, , , ,
,629.80,2800,21.53,29.5,21.8,629.20,96.0,5.5, ,Test OFF,629.50, , , ,
,630.70,2800,21.18,28.6,21.8,630.10,96.0,4.7, ,Test OFF,630.40, , , ,
,631.60,2800,20.34,27.8,21.8,631.00,96.0,3.1, ,Test OFF,631.30, , , ,
,632.50,2800,19.93,27.3,21.8,631.90,96.0,3.1, ,Test OFF,632.20, , , ,
,633.40,2800,19.23,26.0,21.8,632.80,96.0,-0.8, ,Test OFF,633.10, , , ,
,634.30,2800,18.96,26.0,21.8,633.70,96.0,-3.1, ,Test OFF,634.00, , , ,
,635.20,2800,18.61,25.2,21.8,634.60,96.0,1.6, ,Test OFF,634.90, , , ,
,636.10,2800,18.61,25.2,21.8,635.50,96.0,-7.0, ,Test OFF,635.80, , , ,
,637.00,2800,18.61,25.2,21.8,636.40,96.0,-4.7, ,Test OFF,636.70, , , ,
,637.90,2800,18.89,25.6,21.8,637.30,96.0,-2.3, ,Test OFF,637.60, , , ,
,638.80,2800,18.89,25.6,21.8,638.20,96.0,1.6, ,Test OFF,638.50, , , ,
,639.70,2800,17.92,24.3,22.5,639.10,96.0,-0.8, ,Test OFF,639.40, , , ,
,640.60,2800,15.90,21.7,22.5,640.00,96.0,-0.8, ,Test OFF,640.30, , , ,
,641.50,2800,16.25,22.1,22.5,640.90,96.0,-1.6, ,Test OFF,641.20, , , ,
,642.40,2760,16.94,23.4,22.5,641.80,96.0,0.8, ,Test OFF,642.10, , , ,
,643.30,2760,18.12,24.7,21.8,642.70,96.0,1.6, ,Test OFF,643.00, , , ,
,644.20,2760,19.09,26.0,21.8,643.60,96.0,-0.8, ,Test OFF,643.90, , , ,
,645.10,2760,19.09,26.0,21.8,644.50,96.0,-1.6, ,Test OFF,644.80, , , ,
,646.00,2760,18.75,25.6,21.8,645.40,96.0,2.3, ,Test OFF,645.70, , , ,
,646.90,2760,19.03,26.0,21.8,646.30,96.0,-0.8, ,Test OFF,646.60, , , ,
,647.79,2760,19.03,26.0,21.8,647.19,96.0,-3.1, ,Test OFF,647.49, , , ,
,648.68,2760,18.96,26.0,21.8,648.08,96.0,1.6, ,Test OFF,648.38, , , ,
,649.58,2760,18.61,25.6,21.8,648.98,96.0,2.3, ,Test OFF,649.28, , , ,
,650.48,2720,18.12,24.3,21.8,649.88,96.0,0.8, ,Test OFF,650.18, , , ,
,651.38,2720,17.64,24.3,21.8,650.78,96.0,-1.6, ,Test OFF,651.08, , , ,
,652.28,2680,17.78,23.9,21.8,651.68,96.0,1.6, ,Test OFF,651.98, , , ,
,653.18,2680,17.22,23.4,21.8,652.58,96.0,-0.8, ,Test OFF,652.88, , , ,
,654.08,2640,16.39,22.6,21.8,653.48,96.0,-3.1, ,Test OFF,653.78, , , ,
,654.98,2640,17.43,23.9,21.8,654.38,96.0,-0.8, ,Test OFF,654.68, , , ,
,655.92,2600,18.33,25.6,21.8,655.28,96.0,0.8, ,Test OFF,655.58, , , ,
,656.95,2600,20.48,28.6,21.8,656.35,96.0,3.1, ,Test OFF,656.65, , , ,
,657.84,2560,22.78,31.2,20.3,657.25,96.0,3.9, ,Test OFF,657.55, , , ,
,658.74,2560,22.84,31.2,20.3,658.14,96.0,6.3, ,Test OFF,658.44, , , ,
,659.64,2560,23.12,31.7,20.3,659.04,96.0,8.6, ,Test OFF,659.34, , , ,
,660.54,2560,24.58,33.4,19.5,659.94,96.0,7.0, ,Test OFF,660.24, , , ,
,661.44,2560,25.56,34.7,18.8,660.84,96.0,7.8, ,Test OFF,661.14, , , ,
,662.34,2600,25.69,34.7,18.8,661.74,96.0,10.9, ,Test OFF,662.04, , , ,
,663.24,2560,25.28,34.3,18.8,662.64,96.0,14.8, ,Test OFF,662.93, , , ,
,664.14,2560,24.72,33.9,19.5,663.54,96.0,7.8, ,Test OFF,663.84, , , ,
,665.04,2600,24.31,33.0,20.3,664.44,96.0,10.9, ,Test OFF,664.74, , , ,
,665.94,2600,24.09,33.0,20.3,665.34,96.0,10.9, ,Test OFF,665.64, , , ,
,666.84,2600,24.09,32.5,20.3,666.24,96.0,7.8, ,Test OFF,666.54, , , ,
,667.91,2640,23.96,33.0,20.3,667.14,96.0,7.8, ,Test OFF,667.48, , , ,
,668.81,2640,24.86,33.4,20.3,668.21,96.0,11.7, ,Test OFF,668.51, , , ,
,669.71,2680,21.25,29.5,21.8,669.11,96.0,11.7, ,Test OFF,669.41, , , ,
,670.61,2680,19.72,26.9,21.8,670.01,96.0,6.3, ,Test OFF,670.31, , , ,
,671.51,2680,16.59,22.6,22.5,670.91,96.0,0.0, ,Test OFF,671.21, , , ,
,672.41,2680,13.61,13.5,22.5,671.81,96.0,-5.5, ,Test OFF,672.11, , , ,
,673.30,2680,9.93,14.8,21.0,672.71,96.0,-3.9, ,Test OFF,673.01, , , ,
,674.20,2680,14.65,20.0,22.5,673.60,96.0,1.6, ,Test OFF,673.89, , , ,
,675.10,2680,17.15,24.3,21.8,674.50,96.0,-3.1, ,Test OFF,674.80, , , ,
,676.00,2720,19.58,27.3,21.8,675.40,96.0,-1.6, ,Test OFF,675.70, , , ,
,676.89,2760,19.86,27.8,21.8,676.30,96.0,0.0, ,Test OFF,676.60, , , ,
,677.80,2760,21.39,29.1,21.8,677.20,96.0,-0.8, ,Test OFF,677.50, , , ,
,678.70,2800,21.32,29.1,21.8,678.10,96.0,1.6, ,Test OFF,678.40, , , ,
,679.60,2840,18.54,25.2,21.8,679.00,96.0,6.3, ,Test OFF,679.30, , , ,
,680.50,2880,17.92,24.3,21.8,679.90,96.0,-2.3, ,Test OFF,680.20, , , ,
,681.40,2880,12.78,17.8,21.8,680.79,96.0,-3.1, ,Test OFF,681.09, , , ,
,682.30,2920,13.68,18.7,21.8,681.70,96.0,-1.6, ,Test OFF,682.00, , , ,
,683.20,2920,13.89,19.1,21.8,682.60,96.0,-6.3, ,Test OFF,682.90, , , ,
,684.09,2920,15.69,21.7,21.8,683.50,96.0,-3.9, ,Test OFF,683.79, , , ,
,685.00,2920,15.42,21.3,21.8,684.40,96.0,-1.6, ,Test OFF,684.69, , , ,
,685.90,2960,16.46,23.0,21.8,685.30,96.0,-2.3, ,Test OFF,685.59, , , ,
,686.80,2960,19.09,26.5,21.8,686.19,96.0,-3.9, ,Test OFF,686.49, , , ,
,687.69,2960,20.69,28.6,21.0,687.10,96.0,-0.8, ,Test OFF,687.39, , , ,
,692.45,2960,18.19,24.7,21.8,687.99,96.0,5.5, ,Test OFF,688.29, , , ,
,693.39,2920,23.75,31.7,21.0,692.79,96.0,8.6, ,Test OFF,693.09, , , ,
,694.29,2880,22.71,30.8,21.0,693.69,96.0,6.3, ,Test OFF,693.99, , , ,
,695.19,2880,22.50,30.8,21.0,694.59,96.0,7.8, ,Test OFF,694.89, , , ,
,696.09,2880,20.07,27.8,21.0,695.49,96.0,11.7, ,Test OFF,695.79, , , ,
,696.99,2840,23.61,33.0,21.0,696.39,96.0,-5.5, ,Test OFF,696.69, , , ,
,697.89,2840,29.93,37.3,17.3,697.29,96.0,5.5, ,Test OFF,697.59, , , ,
,698.79,2840,26.04,33.9,19.5,698.19,96.0,13.3, ,Test OFF,698.49, , , ,
,699.69,2840,26.18,34.3,19.5,699.09,96.0,10.2, ,Test OFF,699.39, , , ,
,700.59,2840,26.04,33.9,19.5,699.99,96.0,10.9, ,Test OFF,700.29, , , ,
,701.49,2840,24.93,33.0,20.3,700.90,96.0,10.2, ,Test OFF,701.19, , , ,
,702.39,2880,26.39,34.3,19.5,701.79,96.0,14.1, ,Test OFF,702.09, , , ,
,703.28,2880,26.53,34.7,19.5,702.69,96.0,13.3, ,Test OFF,702.98, , , ,
,704.17,2880,27.64,35.2,18.8,703.58,96.0,12.5, ,Test OFF,703.87, , , ,
,705.07,2920,27.22,35.2,19.5,704.47,96.0,9.4, ,Test OFF,704.77, , , ,
,705.97,2920,27.29,34.7,19.5,705.37,96.0,10.9, ,Test OFF,705.67, , , ,
,706.87,2960,27.22,35.2,19.5,706.27,96.0,14.8, ,Test OFF,706.57, , , ,
,707.77,2960,27.36,34.7,19.5,707.17,96.0,14.1, ,Test OFF,707.47, , , ,
,708.67,3000,27.15,34.7,19.5,708.07,96.0,10.9, ,Test OFF,708.37, , , ,
,709.57,3000,26.59,34.3,20.3,708.97,96.0,9.4, ,Test OFF,709.27, , , ,
,710.47,3000,26.32,33.9,20.3,709.87,96.0,10.9, ,Test OFF,710.17, , , ,
,711.37,3000,25.69,33.0,21.0,710.77,96.0,14.8, ,Test OFF,711.07, , , ,
,712.27,3040,24.65,32.5,21.0,711.67,96.0,5.5, ,Test OFF,711.97, , , ,
,713.17,3040,24.37,32.1,21.0,712.57,96.0,7.8, ,Test OFF,712.87, , , ,
,714.07,3040,23.33,31.2,21.0,713.47,96.0,8.6, ,Test OFF,713.77, , , ,
,714.97,3040,21.53,29.5,21.0,714.37,96.0,7.8, ,Test OFF,714.67, , , ,
,715.87,3040,21.53,29.5,21.0,715.27,96.0,2.3, ,Test OFF,715.57, , , ,
,716.77,3040,23.61,31.2,21.0,716.17,96.0,3.1, ,Test OFF,716.47, , , ,
,717.67,3000,20.34,27.8,21.8,717.07,96.0,4.7, ,Test OFF,717.37, , , ,
,718.57,3000,21.46,29.9,21.8,717.97,96.0,-3.1, ,Test OFF,718.27, , , ,
,719.47,3000,21.18,29.1,21.8,718.87,96.0,6.3, ,Test OFF,719.17, , , ,
,720.37,3000,21.04,29.1,21.8,719.77,96.0,7.0, ,Test OFF,720.07, , , ,
,721.27,3000,20.62,28.2,21.8,720.67,96.0,0.0, ,Test OFF,720.97, , , ,
,722.17,3000,23.33,31.7,21.8,721.57,96.0,0.8, ,Test OFF,721.87, , , ,
,723.07,3000,24.86,32.5,21.0,722.47,96.0,3.9, ,Test OFF,722.77, , , ,
,723.97,3000,24.17,32.1,21.8,723.37,96.0,8.6, ,Test OFF,723.67, , , ,
,724.86,3000,20.62,28.2,21.8,724.27,96.0,10.9, ,Test OFF,724.57, , , ,
,725.76,3000,26.73,34.3,20.3,725.15,96.0,-2.3, ,Test OFF,725.45, , , ,
,726.65,3000,26.18,33.4,20.3,726.05,96.0,8.6, ,Test OFF,726.36, , , ,
,727.55,3000,23.40,31.2,21.8,726.95,96.0,10.2, ,Test OFF,727.25, , , ,
,728.45,3000,23.33,31.2,21.8,727.85,96.0,3.1, ,Test OFF,728.15, , , ,
,729.35,3000,23.61,31.7,21.8,728.75,96.0,5.5, ,Test OFF,729.05, , , ,
,730.25,3000,23.96,31.7,21.0,729.65,96.0,7.0, ,Test OFF,729.95, , , ,
,731.15,2960,21.87,29.9,21.0,730.55,96.0,7.8, ,Test OFF,730.85, , , ,
,732.05,2960,20.07,27.3,21.8,731.45,96.0,3.9, ,Test OFF,731.75, , , ,
,732.95,2960,14.65,19.5,21.8,732.35,96.0,-5.5, ,Test OFF,732.65, , , ,
,733.85,2920,7.01,7.8,9.0,733.25,96.0,-0.8, ,Test OFF,733.55, , , ,
,734.76,2880,6.04,4.3,6.8,734.15,96.0,0.0, ,Test OFF,734.46, , , ,
,735.66,2760,5.34,4.3,6.8,735.05,96.0,0.0, ,Test OFF,735.35, , , ,
,736.55,2680,4.37,3.9,6.8,735.95,96.0,0.0, ,Test OFF,736.25, , , ,
,737.45,2600,3.61,3.9,6.8,736.88,96.0,0.0, ,Test OFF,737.15, , , ,
,738.35,2560,3.54,3.9,6.8,737.75,96.0,0.0, ,Test OFF,738.05, , , ,
,739.25,2440,3.40,3.9,6.8,738.65,96.0,0.0, ,Test OFF,738.95, , , ,
,740.15,2280,3.12,3.5,6.8,739.55,96.0,0.0, ,Test OFF,739.85, , , ,
,741.22,2080,3.89,3.0,6.8,740.53,96.0,0.0, ,Test OFF,740.92, , , ,
,742.46,2000,3.96,3.0,6.8,741.59,96.0,0.0, ,Test OFF,742.02, , , ,
,743.56,1960,3.89,3.0,6.0,742.81,96.0,0.0, ,Test OFF,743.25, , , ,
,744.76,1840,3.89,3.0,6.0,743.99,96.0,0.0, ,Test OFF,744.45, , , ,
,745.65,1560,3.40,2.6,6.8,745.06,96.0,0.0, ,Test OFF,745.35, , , ,
,746.55,1320,2.92,2.2,9.0,745.95,96.0,0.0, ,Test OFF,746.25, , , ,
,747.45,1160,2.57,2.6,11.3,746.85,96.0,0.0, ,Test OFF,747.15, , , ,
,748.35,1040,2.50,2.6,11.3,747.74,96.0,0.0, ,Test OFF,748.06, , , ,
,749.25,1320,2.92,2.2,8.3,748.66,96.0,0.0, ,Test OFF,748.95, , , ,
,750.15,1120,2.50,3.0,12.0,749.55,96.0,0.0, ,Test OFF,749.85, , , ,
,752.24,800,2.36,2.6,14.3,750.45,96.0,0.0, ,Test OFF,751.96, , , ,
,753.14,800,2.36,3.0,16.5,752.54,96.0,6.3, ,Test OFF,752.84, , , ,
,754.04,840,2.84,3.5,7.5,753.43,96.0,8.6, ,Test OFF,753.74, , , ,
,754.93,800,2.78,3.5,15.0,754.34,96.0,10.9, ,Test OFF,754.64, , , ,
,755.83,880,2.71,3.5,4.5,755.23,96.0,13.3, ,Test OFF,755.54, , , ,
,756.74,840,2.84,3.5,12.8,756.14,96.0,15.6, ,Test OFF,756.44, , , ,
,758.49,800,3.06,3.9,12.8,757.04,96.0,17.2, ,Test OFF,757.34, , , ,
,759.38,840,3.12,3.9,12.0,758.78,96.0,21.9, ,Test OFF,759.08, , , ,
,760.28,840,3.06,4.3,14.3,759.68,96.0,24.2, ,Test OFF,759.98, , , ,
,761.17,840,3.40,4.3,5.3,760.57,96.0,25.0, ,Test OFF,760.86, , , ,
,762.06,840,3.12,4.3,11.3,761.47,96.0,25.0, ,Test OFF,761.76, , , ,
,762.96,840,3.33,4.3,12.0,762.36,96.0,25.0, ,Test OFF,762.66, , , ,
,763.86,840,3.06,3.9,5.3,763.26,96.0,25.0, ,Test OFF,763.56, , , ,
,764.74,840,3.33,4.3,11.3,764.16,96.0,25.0, ,Test OFF,764.46, , , ,
,765.65,840,3.12,3.9,7.5,765.05,96.0,25.0, ,Test OFF,765.35, , , ,
,766.55,840,3.40,4.3,4.5,765.94,96.0,25.0, ,Test OFF,766.25, , , ,
,767.45,840,3.19,3.9,6.0,766.85,96.0,25.0, ,Test OFF,767.14, , , ,
,768.35,840,3.33,4.3,8.3,767.74,96.0,25.0, ,Test OFF,768.04, , , ,
,771.08,1160,8.75,14.8,11.3,768.65,96.0,25.0, ,Test OFF,770.77, , , ,
,771.96,1960,14.72,22.1,18.8,771.37,96.0,25.0, ,Test OFF,771.66, , , ,
,772.86,2160,17.36,26.0,21.0,772.27,96.0,16.4, ,Test OFF,772.56, , , ,
,773.75,2480,19.37,27.3,21.0,773.16,96.0,20.3, ,Test OFF,773.45, , , ,
,774.66,2200,17.57,26.9,10.5,774.06,96.0,9.4, ,Test OFF,774.35, , , ,
,775.56,2280,19.72,29.5,20.3,774.96,96.0,9.4, ,Test OFF,775.27, , , ,
,776.45,2240,16.04,22.6,21.0,775.86,96.0,14.1, ,Test OFF,776.16, , , ,
,777.36,2280,14.93,21.3,21.8,776.75,96.0,0.8, ,Test OFF,777.06, , , ,
,778.25,2360,15.56,21.7,21.8,777.65,96.0,2.3, ,Test OFF,777.96, , , ,
,779.15,2120,16.81,25.2,21.0,778.54,96.0,-2.3, ,Test OFF,778.85, , , ,
,780.04,2240,19.51,29.1,20.3,779.44,96.0,-4.7, ,Test OFF,779.74, , , ,
,780.94,2240,17.92,26.0,21.0,780.34,96.0,5.5, ,Test OFF,780.65, , , ,
,781.84,2280,16.53,20.8,21.0,781.24,96.0,-1.6, ,Test OFF,781.54, , , ,
,782.74,1800,4.51,9.5,14.3,782.14,96.0,-2.3, ,Test OFF,782.44, , , ,
,783.64,2400,18.75,27.8,21.0,783.04,96.0,-0.8, ,Test OFF,783.35, , , ,
,784.54,2600,24.09,33.0,20.3,783.93,96.0,0.8, ,Test OFF,784.23, , , ,
,785.43,2640,21.32,29.5,21.0,784.84,96.0,9.4, ,Test OFF,785.13, , , ,
,786.33,2480,19.37,27.3,21.0,785.73,96.0,4.7, ,Test OFF,786.03, , , ,
,787.22,2560,15.00,19.1,21.8,786.63,96.0,0.0, ,Test OFF,786.93, , , ,
,788.12,1880,3.89,3.5,6.0,787.52,96.0,0.0, ,Test OFF,787.82, , , ,
,789.01,1600,3.54,2.6,6.0,788.42,96.0,0.0, ,Test OFF,788.71, , , ,
,789.91,1560,3.47,2.6,6.8,789.31,96.0,0.0, ,Test OFF,789.61, , , ,
,790.81,1520,3.33,2.2,7.5,790.21,96.0,0.0, ,Test OFF,790.51, , , ,
,791.70,1440,3.19,2.2,9.0,791.10,96.0,0.0, ,Test OFF,791.40, , , ,
,792.60,1400,3.12,2.2,9.8,792.00,96.0,0.0, ,Test OFF,792.30, , , ,
,793.50,2120,17.22,26.5,21.0,792.90,96.0,0.0, ,Test OFF,793.20, , , ,
,794.40,2440,27.50,38.6,16.5,793.80,96.0,0.0, ,Test OFF,794.10, , , ,
,795.29,1840,23.06,39.5,11.3,794.70,96.0,0.0, ,Test OFF,794.99, , , ,
,796.19,1960,23.19,37.3,9.8,795.59,96.0,7.0, ,Test OFF,795.89, , , ,
,797.09,2000,12.57,17.4,21.8,796.50,96.0,14.1, ,Test OFF,796.79, , , ,
,797.99,2000,5.69,6.9,14.3,797.39,96.0,14.1, ,Test OFF,797.69, , , ,
,798.89,1760,3.89,2.6,6.0,798.29,96.0,0.0, ,Test OFF,798.59, , , ,
,799.79,1640,3.68,2.6,6.0,799.19,96.0,0.0, ,Test OFF,799.49, , , ,
,800.69,1600,3.54,2.6,6.0,800.09,96.0,0.0, ,Test OFF,800.39, , , ,
,801.59,1520,3.40,2.2,7.5,800.99,97.5,0.0, ,Test OFF,801.29, , , ,
,802.49,1400,3.12,2.6,9.8,801.89,96.0,0.0, ,Test OFF,802.19, , , ,
,803.39,1320,2.92,1.7,8.3,802.79,96.0,0.0, ,Test OFF,803.09, , , ,
,804.29,1200,2.71,2.6,10.5,803.69,96.0,0.0, ,Test OFF,803.99, , , ,
,805.19,1160,2.57,2.2,9.8,804.59,96.0,0.0, ,Test OFF,804.89, , , ,
,806.09,1120,2.64,1.7,9.8,805.49,96.0,0.0, ,Test OFF,805.79, , , ,
,806.99,1080,2.57,2.2,9.8,806.39,96.0,0.0, ,Test OFF,806.69, , , ,
,807.88,1520,3.33,2.6,4.5,807.29,96.0,0.0, ,Test OFF,807.58, , , ,
,808.78,1440,3.19,2.6,6.0,808.18,96.0,0.0, ,Test OFF,808.48, , , ,
,809.68,1280,2.78,2.6,9.8,809.08,96.0,0.0, ,Test OFF,809.38, , , ,
,810.58,1120,2.57,2.6,11.3,809.98,96.0,0.0, ,Test OFF,810.28, , , ,
,811.48,1080,2.57,2.2,9.8,810.88,96.0,1.6, ,Test OFF,811.18, , , ,
,812.38,1080,2.57,1.7,9.8,811.78,96.0,5.5, ,Test OFF,812.08, , , ,
,813.29,1040,2.43,2.2,9.8,812.68,96.0,9.4, ,Test OFF,812.98, , , ,
,814.18,1000,2.50,2.6,10.5,813.58,96.0,13.3, ,Test OFF,813.88, , , ,
,815.08,920,2.57,2.2,9.8,814.48,96.0,16.4, ,Test OFF,814.78, , , ,
,815.98,920,2.57,2.2,9.8,815.38,96.0,18.8, ,Test OFF,815.68, , , ,
,817.04,920,2.50,2.6,10.5,816.28,96.0,21.9, ,Test OFF,816.61, , , ,
,817.94,920,2.57,2.2,9.8,817.34,96.0,25.0, ,Test OFF,817.64, , , ,
,818.84,960,2.57,2.2,9.8,818.24,96.0,25.0, ,Test OFF,818.54, , , ,
,819.74,960,2.57,2.2,9.8,819.14,96.0,25.0, ,Test OFF,819.44, , , ,
,820.64,920,2.57,2.2,9.8,820.04,96.0,25.0, ,Test OFF,820.34, , , ,
,821.54,840,2.43,2.6,11.3,820.94,96.0,25.0, ,Test OFF,821.24, , , ,
,822.44,880,2.57,5.2,12.0,821.84,96.0,25.0, ,Test OFF,822.14, , , ,
,823.34,1760,10.21,13.9,19.5,822.74,96.0,25.0, ,Test OFF,823.04, , , ,
,824.24,1920,14.65,22.1,20.3,823.64,96.0,22.7, ,Test OFF,823.94, , , ,
,825.14,2120,17.43,26.0,21.0,824.54,96.0,25.0, ,Test OFF,824.84, , , ,
,826.08,1920,13.40,19.5,20.3,825.44,96.0,17.2, ,Test OFF,825.74, , , ,
,827.11,2160,17.29,25.2,21.0,826.51,96.0,18.8, ,Test OFF,826.81, , , ,
,828.01,2040,10.21,14.3,21.8,827.41,96.0,18.8, ,Test OFF,827.71, , , ,
,828.91,1680,8.54,12.2,17.3,828.31,96.0,18.8, ,Test OFF,828.61, , , ,
,829.80,1880,16.59,26.5,18.8,829.21,96.0,25.0, ,Test OFF,829.49, , , ,
,830.70,2320,21.53,31.7,19.5,830.09,96.0,25.0, ,Test OFF,830.40, , , ,
,831.60,2480,26.87,36.9,17.3,831.00,96.0,14.1, ,Test OFF,831.30, , , ,
,832.50,2320,14.31,10.0,21.0,831.90,96.0,17.2, ,Test OFF,832.20, , , ,
,833.39,1440,3.26,3.0,9.0,832.80,96.0,16.4, ,Test OFF,833.10, , , ,
,834.30,1240,2.78,2.6,9.8,833.70,96.0,0.0, ,Test OFF,834.00, , , ,
,835.19,1160,2.78,5.2,12.0,834.60,96.0,0.0, ,Test OFF,834.89, , , ,
,836.10,2080,19.79,30.8,19.5,835.50,96.0,-1.6, ,Test OFF,835.80, , , ,
,837.00,2400,24.44,34.3,17.3,836.40,96.0,4.7, ,Test OFF,836.70, , , ,
,837.90,2400,22.57,32.1,19.5,837.30,96.0,9.4, ,Test OFF,837.60, , , ,
,838.80,2280,19.31,28.6,20.3,838.20,96.0,3.9, ,Test OFF,838.50, , , ,
,839.69,2240,18.68,27.3,21.0,839.10,96.0,-1.6, ,Test OFF,839.40, , , ,
,840.60,2200,16.59,22.1,21.0,839.99,96.0,-0.8, ,Test OFF,840.29, , , ,
,841.49,2160,15.48,22.1,21.0,840.90,96.0,-3.9, ,Test OFF,841.20, , , ,
,842.40,2080,7.43,8.7,18.0,841.80,96.0,0.0, ,Test OFF,842.09, , , ,
,843.29,1600,3.54,2.6,3.0,842.69,96.0,0.0, ,Test OFF,843.00, , , ,
,844.19,1520,6.87,13.9,15.8,843.59,96.0,0.0, ,Test OFF,843.90, , , ,
,845.10,1680,4.37,5.2,11.3,844.49,96.0,-3.1, ,Test OFF,844.79, , , ,
,845.99,1440,3.19,2.6,6.8,845.39,96.0,3.1, ,Test OFF,845.70, , , ,
,846.89,1320,2.92,2.6,9.0,846.29,96.0,0.0, ,Test OFF,846.59, , , ,
,847.79,1120,2.57,2.6,11.3,847.19,96.0,0.0, ,Test OFF,847.49, , , ,
,848.68,960,2.50,2.6,11.3,848.09,97.5,1.6, ,Test OFF,848.38, , , ,
,849.59,920,2.64,2.2,10.5,848.99,97.5,4.7, ,Test OFF,849.29, , , ,
,850.48,760,2.43,3.5,19.5,849.88,97.5,7.0, ,Test OFF,850.18, , , ,
,851.38,840,2.84,3.5,10.5,850.78,97.5,8.6, ,Test OFF,851.08, , , ,
,852.28,840,2.84,3.5,13.5,851.68,97.5,10.9, ,Test OFF,851.98, , , ,
,853.18,800,2.71,3.5,12.0,852.58,97.5,13.3, ,Test OFF,852.88, , , ,
,854.08,840,2.98,3.5,6.0,853.49,99.0,15.6, ,Test OFF,853.78, , , ,
,854.98,840,3.06,3.9,8.3,854.38,99.0,18.0, ,Test OFF,854.69, , , ,
,855.88,840,3.06,3.9,6.0,855.28,99.0,19.5, ,Test OFF,855.58, , , ,
,856.78,880,2.98,3.5,3.8,856.18,99.0,21.9, ,Test OFF,856.48, , , ,
,857.68,880,3.06,3.5,3.8,857.08,99.0,24.2, ,Test OFF,857.38, , , ,
,858.59,800,2.84,3.9,12.8,857.99,99.0,25.0, ,Test OFF,858.28, , , ,
,859.48,840,2.84,3.9,9.0,858.88,99.0,25.0, ,Test OFF,859.18, , , ,
,860.38,880,3.06,3.9,6.0,859.78,99.0,25.0, ,Test OFF,860.09, , , ,
,861.28,840,3.06,3.9,6.0,860.68,99.0,25.0, ,Test OFF,860.98, , , ,
,862.18,840,2.92,3.9,9.8,861.58,99.0,25.0, ,Test OFF,861.88, , , ,
,863.08,840,3.12,3.5,9.0,862.48,99.0,25.0, ,Test OFF,862.78, , , ,
,863.99,840,3.06,3.9,6.8,863.38,99.0,25.0, ,Test OFF,863.68, , , ,
,864.88,840,2.98,3.9,8.3,864.28,99.0,25.0, ,Test OFF,864.58, , , ,
,865.78,840,3.06,3.9,6.8,865.18,99.0,25.0, ,Test OFF,865.48, , , ,
,866.68,840,2.98,3.5,9.0,866.08,99.0,25.0, ,Test OFF,866.38, , , ,
,867.58,840,3.12,3.9,10.5,866.99,99.0,25.0, ,Test OFF,867.29, , , ,
,868.48,840,3.06,3.9,13.5,867.88,99.0,25.0, ,Test OFF,868.18, , , ,
,869.38,840,3.06,3.9,8.3,868.78,99.0,25.0, ,Test OFF,869.08, , , ,
,870.28,840,3.06,3.9,12.0,869.68,99.0,25.0, ,Test OFF,869.99, , , ,
,871.18,840,3.06,3.9,7.5,870.59,99.0,25.0, ,Test OFF,870.88, , , ,
,872.08,840,2.98,3.9,11.3,871.48,99.0,25.0, ,Test OFF,871.78, , , ,
,872.98,840,3.06,3.9,12.0,872.38,99.0,25.0, ,Test OFF,872.68, , , ,
,873.88,840,2.98,3.9,9.8,873.28,99.0,25.0, ,Test OFF,873.58, , , ,
,874.79,840,3.06,3.9,4.5,874.18,99.0,25.0, ,Test OFF,874.48, , , ,
,875.68,840,3.12,3.9,6.0,875.08,99.0,25.0, ,Test OFF,875.38, , , ,
,876.58,840,3.12,3.9,9.8,875.98,99.0,25.0, ,Test OFF,876.28, , , ,
,877.48,840,3.12,3.9,7.5,876.88,99.0,25.0, ,Test OFF,877.18, , , ,
,878.38,840,3.19,4.3,6.0,877.78,99.0,25.0, ,Test OFF,878.08, , , ,
,879.29,840,3.12,3.9,6.8,878.68,99.0,25.0, ,Test OFF,878.98, , , ,
,880.18,1000,2.98,4.8,21.0,879.58,99.0,25.0, ,Test OFF,879.88, , , ,
,881.07,880,3.26,4.3,12.0,880.48,99.0,25.0, ,Test OFF,880.78, , , ,
,881.96,880,3.54,4.3,2.3,881.36,99.0,25.0, ,Test OFF,881.66, , , ,
,882.85,840,3.26,4.3,6.0,882.27,99.0,25.0, ,Test OFF,882.55, , , ,
,883.75,840,3.47,4.3,6.0,883.15,99.0,25.0, ,Test OFF,883.45, , , ,
,884.65,840,3.26,3.9,6.0,884.05,99.0,25.0, ,Test OFF,884.35, , , ,
,887.07,840,3.19,4.3,6.8,886.43,100.5,25.0, ,Test OFF,886.77, , , ,
,887.97,840,3.33,3.9,4.5,887.37,100.5,25.0, ,Test OFF,887.67, , , ,
,888.87,840,3.33,4.3,9.8,888.27,100.5,25.0, ,Test OFF,888.57, , , ,
,889.77,840,2.98,4.3,10.5,889.17,100.5,25.0, ,Test OFF,889.47, , , ,
,890.67,800,3.12,4.3,15.0,890.07,100.5,25.0, ,Test OFF,890.37, , , ,
,891.57,840,3.26,3.9,4.5,890.97,100.5,25.0, ,Test OFF,891.27, , , ,
,892.47,800,2.98,4.3,15.0,891.87,100.5,25.0, ,Test OFF,892.17, , , ,
,893.37,840,3.40,4.3,3.8,892.77,100.5,25.0, ,Test OFF,893.07, , , ,
,894.27,840,3.26,4.3,7.5,893.67,100.5,25.0, ,Test OFF,893.97, , , ,
,895.17,840,3.12,3.9,8.3,894.57,100.5,25.0, ,Test OFF,894.87, , , ,
,896.07,840,3.12,3.9,9.8,895.47,100.5,25.0, ,Test OFF,895.77, , , ,
,896.97,840,3.47,4.3,7.5,896.37,100.5,25.0, ,Test OFF,896.67, , , ,
,897.86,840,3.26,3.9,6.8,897.27,100.5,25.0, ,Test OFF,897.57, , , ,
,898.76,800,3.12,3.9,12.8,898.16,100.5,25.0, ,Test OFF,898.46, , , ,
,899.66,840,3.19,4.3,9.0,899.06,100.5,25.0, ,Test OFF,899.36, , , ,
,900.55,840,3.19,4.3,12.0,899.96,100.5,25.0, ,Test OFF,900.25, , , ,
,901.45,840,3.47,4.3,6.0,900.85,100.5,25.0, ,Test OFF,901.15, , , ,
,902.35,840,3.12,3.9,6.8,901.75,100.5,25.0, ,Test OFF,902.05, , , ,
,903.25,840,3.12,3.9,8.3,902.65,100.5,25.0, ,Test OFF,902.95, , , ,
,904.15,840,3.47,3.9,6.0,903.55,100.5,25.0, ,Test OFF,903.85, , , ,
,905.05,880,3.40,3.9,3.0,904.44,100.5,25.0, ,Test OFF,904.74, , , ,
,905.94,840,3.26,3.9,10.5,905.35,100.5,25.0, ,Test OFF,905.64, , , ,
,906.84,880,3.33,3.9,3.8,906.25,100.5,25.0, ,Test OFF,906.54, , , ,
,907.75,840,3.40,4.3,12.8,907.14,100.5,25.0, ,Test OFF,907.45, , , ,
,908.65,880,3.47,3.9,4.5,908.05,100.5,25.0, ,Test OFF,908.35, , , ,
,909.55,840,3.26,3.9,6.8,908.94,100.5,25.0, ,Test OFF,909.25, , , ,
,910.45,840,3.12,4.3,9.8,909.85,100.5,25.0, ,Test OFF,910.15, , , ,
,911.36,880,3.40,4.3,5.3,910.74,100.5,25.0, ,Test OFF,911.05, , , ,
,912.25,1720,13.19,17.8,15.8,911.65,100.5,25.0, ,Test OFF,911.94, , , ,
,913.14,2040,17.08,26.0,19.5,912.55,100.5,16.4, ,Test OFF,912.85, , , ,
,914.04,2240,20.62,30.4,19.5,913.45,100.5,13.3, ,Test OFF,913.75, , , ,
,914.95,2480,22.15,31.2,19.5,914.35,100.5,18.8, ,Test OFF,914.65, , , ,
,915.85,2640,17.15,23.4,21.0,915.25,100.5,13.3, ,Test OFF,915.55, , , ,
,916.92,1920,12.43,17.4,20.3,916.15,100.5,7.8, ,Test OFF,916.50, , , ,
,917.81,1880,10.90,15.2,20.3,917.22,100.5,20.3, ,Test OFF,917.52, , , ,
,918.70,1560,4.44,5.6,9.8,918.11,100.5,18.8, ,Test OFF,918.40, , , ,
,919.60,1200,2.84,3.5,15.8,919.00,100.5,24.2, ,Test OFF,919.32, , , ,
,920.50,920,2.57,3.0,19.5,919.90,100.5,0.0, ,Test OFF,920.20, , , ,
,921.41,800,3.12,4.3,16.5,920.80,100.5,3.1, ,Test OFF,921.10, , , ,
,922.30,1000,6.94,12.6,12.0,921.71,99.0,4.7, ,Test OFF,922.01, , , ,
,923.21,1680,11.18,16.5,18.8,922.61,100.5,8.6, ,Test OFF,922.90, , , ,
,924.10,2000,17.36,27.3,20.3,923.51,100.5,18.0, ,Test OFF,923.80, , , ,
,925.01,2320,22.92,33.0,17.3,924.40,100.5,14.1, ,Test OFF,924.70, , , ,
,925.90,2440,24.79,34.7,17.3,925.31,99.0,19.5, ,Test OFF,925.60, , , ,
,926.81,2480,24.31,33.9,18.0,926.20,99.0,19.5, ,Test OFF,926.51, , , ,
,927.71,2520,23.26,32.1,19.5,927.10,99.0,15.6, ,Test OFF,927.40, , , ,
,928.60,2560,21.32,29.9,20.3,928.01,99.0,15.6, ,Test OFF,928.30, , , ,
,929.67,2640,19.93,27.8,21.0,928.91,99.0,12.5, ,Test OFF,929.28, , , ,
,930.58,2880,26.53,34.7,19.5,929.97,99.0,14.1, ,Test OFF,930.27, , , ,
,931.47,2920,24.86,33.0,21.0,930.88,99.0,15.6, ,Test OFF,931.17, , , ,
,932.37,2560,24.93,33.4,18.0,931.78,99.0,21.1, ,Test OFF,932.07, , , ,
,933.28,2480,20.00,27.8,20.3,932.68,99.0,14.1, ,Test OFF,932.98, , , ,
,934.18,2440,15.34,10.0,21.0,933.58,99.0,13.3, ,Test OFF,933.88, , , ,
,935.07,1800,3.89,3.0,6.0,934.47,99.0,0.0, ,Test OFF,934.77, , , ,
,935.97,1280,2.92,3.0,6.8,935.38,99.0,0.0, ,Test OFF,935.67, , , ,
,936.87,1000,2.43,2.6,15.8,936.27,99.0,0.0, ,Test OFF,936.57, , , ,
,937.76,840,3.19,3.9,17.3,937.17,99.0,0.0, ,Test OFF,937.46, , , ,
,938.67,840,3.33,3.9,7.5,938.06,99.0,0.0, ,Test OFF,938.36, , , ,
,939.56,800,3.47,4.8,12.8,938.96,99.0,2.3, ,Test OFF,939.26, , , ,
,940.46,840,3.75,4.8,14.3,939.86,99.0,4.7, ,Test OFF,940.16, , , ,
,941.36,840,3.82,4.8,12.0,940.76,99.0,7.0, ,Test OFF,941.07, , , ,
,942.26,880,3.89,4.8,3.8,941.66,99.0,8.6, ,Test OFF,941.96, , , ,
,943.16,840,3.89,5.2,6.8,942.56,99.0,10.9, ,Test OFF,942.86, , , ,
,944.06,880,3.89,4.8,3.0,943.46,99.0,13.3, ,Test OFF,943.76, , , ,
,944.98,880,3.75,4.8,2.3,944.37,99.0,15.6, ,Test OFF,944.66, , , ,
,945.86,880,3.75,4.8,4.5,945.26,99.0,18.0, ,Test OFF,945.57, , , ,
,946.76,880,3.47,4.8,5.3,946.16,99.0,20.3, ,Test OFF,946.47, , , ,
,947.66,880,3.68,4.3,2.3,947.06,99.0,22.7, ,Test OFF,947.36, , , ,
,948.56,840,3.47,4.8,7.5,947.96,99.0,24.2, ,Test OFF,948.26, , , ,
,949.46,880,3.54,4.3,3.8,948.86,99.0,25.0, ,Test OFF,949.16, , , ,
,950.36,840,3.61,4.8,6.0,949.76,99.0,25.0, ,Test OFF,950.06, , , ,
,951.26,880,3.33,4.3,3.0,950.68,99.0,25.0, ,Test OFF,950.96, , , ,
,952.16,880,3.68,4.8,5.3,951.56,99.0,25.0, ,Test OFF,951.86, , , ,
,953.05,840,3.40,4.3,5.3,952.46,99.0,25.0, ,Test OFF,952.77, , , ,
,953.95,840,3.19,4.3,7.5,953.35,99.0,25.0, ,Test OFF,953.66, , , ,
,954.85,880,3.40,4.3,3.8,954.26,99.0,25.0, ,Test OFF,954.55, , , ,
,955.75,840,3.19,3.9,6.0,955.15,99.0,25.0, ,Test OFF,955.44, , , ,
,956.64,880,3.33,3.9,3.0,956.04,99.0,25.0, ,Test OFF,956.34, , , ,
,957.54,840,3.19,4.3,11.3,956.94,99.0,25.0, ,Test OFF,957.24, , , ,
,958.43,880,3.26,3.9,4.5,957.84,99.0,25.0, ,Test OFF,958.13, , , ,
,959.34,880,3.54,4.3,3.0,958.73,99.0,25.0, ,Test OFF,959.03, , , ,
,960.23,840,3.26,4.3,6.8,959.63,99.0,25.0, ,Test OFF,959.93, , , ,
,961.13,840,3.47,4.3,2.3,960.53,99.0,25.0, ,Test OFF,960.83, , , ,
,962.03,880,3.19,3.9,3.8,961.43,99.0,25.0, ,Test OFF,961.73, , , ,
,964.93,880,3.33,3.9,3.0,962.33,99.0,25.0, ,Test OFF,962.63, , , ,
,965.83,840,3.26,4.3,7.5,965.23,99.0,25.0, ,Test OFF,965.53, , , ,
,966.73,880,3.33,3.9,4.5,966.13,99.0,25.0, ,Test OFF,966.43, , , ,
,967.63,840,3.33,4.3,9.0,967.03,99.0,25.0, ,Test OFF,967.33, , , ,
,968.53,840,3.12,3.9,7.5,967.93,99.0,25.0, ,Test OFF,968.25, , , ,
,969.60,880,3.33,3.9,3.0,968.87,99.0,25.0, ,Test OFF,969.30, , , ,
,970.50,840,3.12,3.9,6.0,969.90,99.0,25.0, ,Test OFF,970.21, , , ,
,971.40,880,3.33,3.9,3.8,970.80,99.0,25.0, ,Test OFF,971.10, , , ,
,972.30,880,3.40,3.9,3.8,971.70,99.0,25.0, ,Test OFF,972.00, , , ,
,973.19,840,3.12,3.9,3.8,972.60,99.0,25.0, ,Test OFF,972.90, , , ,
,974.09,840,3.06,3.9,10.5,973.52,99.0,25.0, ,Test OFF,973.79, , , ,
,974.99,840,3.12,3.9,7.5,974.39,99.0,25.0, ,Test OFF,974.69, , , ,
,975.89,880,3.33,3.9,4.5,975.29,99.0,25.0, ,Test OFF,975.59, , , ,
,976.79,840,3.19,4.3,6.8,976.19,99.0,25.0, ,Test OFF,976.50, , , ,
,977.69,880,3.26,3.9,3.8,977.09,97.5,25.0, ,Test OFF,977.39, , , ,
,978.59,840,3.33,3.9,7.5,977.99,97.5,25.0, ,Test OFF,978.30, , , ,
,979.49,840,4.51,16.5,8.3,978.89,97.5,25.0, ,Test OFF,979.18, , , ,
,980.39,1960,15.97,24.7,17.3,979.79,97.5,25.0, ,Test OFF,980.08, , , ,
,981.29,2200,20.48,30.8,18.8,980.69,97.5,17.2, ,Test OFF,980.99, , , ,
,982.19,2600,26.73,36.0,17.3,981.59,97.5,19.5, ,Test OFF,981.89, , , ,
,983.09,3080,31.67,38.2,18.0,982.49,96.0,21.1, ,Test OFF,982.80, , , ,
,983.99,2600,28.89,39.1,16.5,983.39,96.0,20.3, ,Test OFF,983.69, , , ,
,984.89,2760,32.43,41.2,15.8,984.29,96.0,15.6, ,Test OFF,984.59, , , ,
,985.79,2800,31.11,39.5,16.5,985.20,96.0,12.5, ,Test OFF,985.51, , , ,
,986.69,2960,31.67,39.1,17.3,986.09,96.0,14.1, ,Test OFF,986.39, , , ,
,987.59,3000,26.53,34.3,20.3,986.99,96.0,15.6, ,Test OFF,987.29, , , ,
,988.49,2720,25.48,34.7,9.8,987.89,96.0,21.1, ,Test OFF,988.19, , , ,
,989.39,2720,29.72,39.1,16.5,988.79,96.0,22.7, ,Test OFF,989.09, , , ,
,990.27,2760,28.89,37.3,17.3,989.69,96.0,14.1, ,Test OFF,989.99, , , ,
,991.18,2760,26.94,36.0,18.0,990.59,96.0,18.0, ,Test OFF,990.88, , , ,
,992.07,2480,23.47,32.5,18.8,991.48,96.0,20.3, ,Test OFF,991.78, , , ,
,992.98,2480,18.26,25.6,17.3,992.37,96.0,14.1, ,Test OFF,992.67, , , ,
,993.88,2560,17.57,24.7,21.0,993.27,96.0,12.5, ,Test OFF,993.58, , , ,
,994.78,1880,15.56,24.3,16.5,994.18,96.0,10.2, ,Test OFF,994.48, , , ,
,995.68,1920,21.67,35.6,9.8,995.07,96.0,12.5, ,Test OFF,995.37, , , ,
,996.58,1920,17.78,27.3,18.0,995.97,96.0,7.8, ,Test OFF,996.28, , , ,
,997.47,1920,15.97,24.3,15.8,996.87,96.0,4.7, ,Test OFF,997.18, , , ,
,998.37,1920,19.44,31.2,15.8,997.78,96.0,6.3, ,Test OFF,998.08, , , ,
,999.28,1960,18.19,28.2,15.0,998.67,96.0,1.6, ,Test OFF,998.97, , , ,
,1000.18,1960,19.65,31.7,13.5,999.58,96.0,2.3, ,Test OFF,999.87, , , ,
,1001.07,2000,22.50,36.5,15.0,1000.47,96.0,7.0, ,Test OFF,1000.78, , , ,
,1001.98,2040,24.37,38.6,9.0,1001.37,96.0,11.7, ,Test OFF,1001.67, , , ,
,1002.91,2040,22.43,34.7,10.5,1002.27,96.0,7.8, ,Test OFF,1002.57, , , ,
,1003.94,2120,24.23,37.3,15.0,1003.35,96.0,10.2, ,Test OFF,1003.65, , , ,
,1004.89,2160,22.15,33.0,14.3,1004.24,96.0,11.7, ,Test OFF,1004.54, , , ,
,1005.92,2240,19.51,29.5,19.5,1005.32,96.0,7.8, ,Test OFF,1005.61, , , ,
,1006.82,2240,18.47,27.3,20.3,1006.21,96.0,2.3, ,Test OFF,1006.51, , , ,
,1007.71,2320,21.53,31.7,18.8,1007.11,96.0,7.8, ,Test OFF,1007.41, , , ,
,1008.61,2360,22.84,32.5,18.0,1008.01,96.0,8.6, ,Test OFF,1008.31, , , ,
,1009.51,2360,23.06,33.0,18.0,1008.91,96.0,8.6, ,Test OFF,1009.21, , , ,
,1010.41,2400,21.25,30.8,19.5,1009.81,96.0,14.1, ,Test OFF,1010.11, , , ,
,1011.49,2400,21.67,31.2,19.5,1010.72,96.0,7.0, ,Test OFF,1011.06, , , ,
,1012.38,2440,28.06,39.1,15.8,1011.78,96.0,11.7, ,Test OFF,1012.08, , , ,
,1013.27,2480,26.67,35.2,16.5,1012.67,96.0,11.7, ,Test OFF,1012.97, , , ,
,1014.16,2440,4.03,6.1,6.8,1013.56,96.0,8.6, ,Test OFF,1013.86, , , ,
,1015.06,2480,33.89,50.8,8.3,1014.46,94.5,0.0, ,Test OFF,1014.77, , , ,
,1015.96,2520,36.39,55.6,12.0,1015.36,94.5,0.0, ,Test OFF,1015.66, , , ,
,1016.86,2560,35.07,47.7,10.5,1016.26,94.5,0.0, ,Test OFF,1016.57, , , ,
,1017.76,2560,24.44,34.3,18.8,1017.17,94.5,10.9, ,Test OFF,1017.46, , , ,
,1018.66,2480,3.68,5.2,6.8,1018.07,94.5,16.4, ,Test OFF,1018.37, , , ,
,1019.57,2440,3.33,3.9,6.8,1018.97,94.5,0.0, ,Test OFF,1019.27, , , ,
,1020.47,2360,3.26,3.5,6.8,1019.86,94.5,0.0, ,Test OFF,1020.17, , , ,
,1021.36,2280,3.12,3.5,6.8,1020.76,94.5,0.0, ,Test OFF,1021.06, , , ,
,1022.25,2200,9.65,20.8,18.0,1021.66,94.5,0.0, ,Test OFF,1021.95, , , ,
,1023.16,2240,15.28,21.7,21.0,1022.55,94.5,0.0, ,Test OFF,1022.85, , , ,
,1024.05,2120,5.34,7.8,11.3,1023.45,94.5,0.0, ,Test OFF,1023.76, , , ,
,1024.96,2120,13.68,26.0,21.0,1024.35,94.5,0.0, ,Test OFF,1024.66, , , ,
,1025.86,2040,7.29,9.5,15.0,1025.25,94.5,0.0, ,Test OFF,1025.56, , , ,
,1026.75,2040,9.58,13.0,21.8,1026.15,94.5,0.0, ,Test OFF,1026.45, , , ,
,1027.66,2000,8.96,14.3,19.5,1027.05,94.5,0.8, ,Test OFF,1027.36, , , ,
,1028.55,1960,7.57,8.2,16.5,1027.95,94.5,9.4, ,Test OFF,1028.26, , , ,
,1029.45,1920,7.43,12.2,16.5,1028.86,94.5,18.0, ,Test OFF,1029.15, , , ,
,1030.35,1960,9.44,9.1,20.3,1029.75,94.5,3.1, ,Test OFF,1030.05, , , ,
,1031.25,2080,15.42,23.4,20.3,1030.65,94.5,10.9, ,Test OFF,1030.95, , , ,
,1032.15,2440,22.64,33.0,18.0,1031.55,94.5,6.3, ,Test OFF,1031.85, , , ,
,1033.05,2520,23.75,33.0,18.8,1032.45,94.5,12.5, ,Test OFF,1032.76, , , ,
,1034.01,2480,22.64,32.1,19.5,1033.35,94.5,14.8, ,Test OFF,1033.65, , , ,
,1035.02,1800,4.03,4.8,6.0,1034.42,94.5,12.5, ,Test OFF,1034.72, , , ,
,1035.92,1600,3.47,2.6,3.0,1035.34,94.5,0.0, ,Test OFF,1035.62, , , ,
,1036.82,1480,3.26,2.6,5.3,1036.23,94.5,0.0, ,Test OFF,1036.56, , , ,
,1037.72,1280,2.78,2.6,10.5,1037.12,94.5,0.0, ,Test OFF,1037.42, , , ,
,1038.63,1120,2.57,2.6,6.8,1038.02,94.5,0.0, ,Test OFF,1038.32, , , ,
,1039.69,1400,3.12,2.2,6.8,1038.96,94.5,0.0, ,Test OFF,1039.39, , , ,
,1040.59,1240,2.78,2.6,10.5,1039.99,94.5,0.0, ,Test OFF,1040.29, , , ,
,1041.49,1120,2.57,2.6,9.8,1040.90,94.5,0.0, ,Test OFF,1041.19, , , ,
,1042.38,1040,2.57,2.2,9.8,1041.78,94.5,1.6, ,Test OFF,1042.08, , , ,
,1043.27,1000,2.43,2.2,10.5,1042.68,94.5,5.5, ,Test OFF,1042.98, , , ,
,1044.17,880,2.36,2.6,12.0,1043.57,94.5,8.6, ,Test OFF,1043.87, , , ,
,1045.07,800,2.36,3.0,15.0,1044.47,94.5,10.9, ,Test OFF,1044.77, , , ,
,1045.97,840,2.50,3.0,8.3,1045.37,94.5,13.3, ,Test OFF,1045.67, , , ,
,1046.87,880,2.57,3.0,6.0,1046.28,94.5,15.6, ,Test OFF,1046.57, , , ,
,1047.77,840,2.50,3.5,12.0,1047.17,94.5,18.0, ,Test OFF,1047.47, , , ,
Monday,05,September,2016,16:42:51:42100-VCID:D5E2CA532CA5A2EA23-FFFE,VCDS Version: Release 16.8.0 (x64),Data version: 20160803 DS255
,Group A:,'003,,,,Group B:,'077,,,,Group C:,'078
,,Engine Speed,Mass Air Flow,Throttle Valve Angle,Ignition,,Coolant,Lambda Control, ,Secondary Air,, , , ,
,TIME,(G28),Sensor (G70),,Timing Angle,TIME,Temperature (G62),,,Injection Test B1,TIME,,,,
Marker,STAMP, /min, g/s,°, °BTDC,STAMP,°C, %,,,STAMP,,,,
Not good for a MAF test. RPM was never over 3080, throttle was never more than about half open.
COBHONIAN
Philadelphia PA USA
C?ID=270149
I thought that I read that if in the city that I should be at 2nd or 3rd gear. I was at about 55mph at one point. How fast should I be going. In an automatic I don't know how to know if I'm in 2nd or 3rd. I would assume that i a was above that gear doing 50mph. So how many RPMs should I be at ?
When you say not good for a MAF test , do you mean "bad results " for a MAF test or not fast enough to be able to do a proper MAF test ?
It needs to be done at full throttle -- pedal to the metal, all the way to redline, and I don't see that.
Get the car rolling in first gear, shift to 2nd as soon as possible, then floor it and keep it floored to 6000 rpm -- while logging Group 003. What you want to know is the mass airflow in g/s with the throttle wide open and the RPMs at the horsepower peak.
This is a 115 hp engine, right? If the MAF is healthy, it should show a peak flow of around 90 g/s.
COBHONIAN
Philadelphia PA USA
C?ID=270149
That's what i'm talking about. So should 1 minute at 6000rpm suffice, or , what do you think ,is 5-10-15 minutes better?
A few seconds, while you're accelerating is all that's needed. You do not need to hold it there. In fact, it's impossible to hold it at full power unless you have load-cell type dyno or you're pushing the car's top speed.
So again, just accelerate through 2nd gear (all the way to redline) with the pedal to the metal while logging group 003.
COBHONIAN
Philadelphia PA USA
C?ID=270149
A sincere thank you. Oh and to answer your question about the HP , it's actually 116 hp , but who's counting :popcorn:
