customer states the gas pedal doesnt work right
stevenpierce83
Vestal NY
hexa193-00c6a4-0b4731-a38ba6-eajahh-5a19
ordered harness for throttle body and checked fans for restrictions found none any common problems with the fans i should know about?
Thursday,01,September,2016,13:40:01:18225
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WVWML73C89E532457   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
          65 72
VIN: WVWML73C89E532457   Mileage: 158270km-98344miles
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3319
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 05314 000 00000
   VCID: 6FED2B747EDA3D3A49-803A
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 16
                    Mileage: 157917 km
                    Date: 2011.01.19
                    Time: 21:44:17
                    RPM: 858 /min
                    Load: 18.8 %
                    Speed: 22.0 km/h
                    Temperature: 96.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.843 V
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 11
                    Mileage: 158118 km
                    Date: 2011.01.21
                    Time: 15:54:12
                    RPM: 760 /min
                    Load: 20.0 %
                    Temperature: 98.0°C
                    Temperature: 66.0°C
                    Voltage: 13.589 V
006472 - Control Module 2 for Cooling Fan
               P1948 - 000 - Output Short Circuit - Intermittent
                    Mileage: 157959 km
                    Date: 2011.01.19
                    Time: 22:51:08
                    RPM: 756 /min
                    Load: 21.6 %
                    Temperature: 98.0°C
                    Temperature: 56.0°C
                    Voltage: 13.589 V
000289 - Throttle Position Sensor (G69)
               P0121 - 000 - Implausible Signal - Intermittent
                    Mileage: 158273 km
                    Date: 2011.01.23
                    Time: 12:18:14
                    RPM: 3082 /min
                    Load: 52.1 %
                    Speed: 41.0 km/h
                    Temperature: 97.0°C
                    Temperature: 37.0°C
                    Voltage: 13.716 V
   Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
   Component: AQ 250 6F           1391
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 05311 000 00000
   VCID: 050169DC4C66176A93-8050
            013 - Check DTC Memory
                    Reset counter: 0
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786146487
   Coding: 0000376
   VCID: 2B55FF648A42011A25-807E
                    Fault Status: 01101101
                    Fault Frequency: 40
                    Reset counter: 45
                    Mileage: 157714 km
                    Date: 2010.11.24
                    Time: 17:24:28
                    Hex Value: 0x0002
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 217
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 E    HW: 3C8 907 336 E
   Component: Climatic      120 0102
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 2F6DEB74765A7D3A09-807A
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 12
                    Reset counter: 79
                    Mileage: 157834 km
                    Date: 2016.08.27
                    Time: 04:36:22
   Revision: 00H54000    Serial number: 00000008888154
   Coding: F1848F8B40041A0047970F00170000000028FF475C40017C170000000000
   Shop #: WSC 05124 000 08193
   VCID: 3365E704527259DA6D-8066
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 150908 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     101008 054  0402
   Coding: 00209133
   Shop #: WSC 05124
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0432109
   Coding: 0000100
            000 -  -
                    Reset counter: 17
                    Mileage: 157707 km
                    Date: 2010.11.15
                    Time: 14:40:04
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__313 VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPKW9HWT
   Coding: 0012595
   VCID: 7AFB0A2035986892EE-802E
   Subsystem 1 - Part No: 3C8 959 339
   Component: BF-Gewichtsens. 001 0003
   Subsystem 2 - Serial number: 000000000021KE
   Subsystem 3 - Serial number: 0014.08.080000100000660007ÿ†63
   Subsystem 4 - Serial number: 660007ÿ†6333FTS645932548 ÿ†63
   Subsystem 5 - Serial number: 32548 ÿ†6343FTS667332758 ÿ†63
   Subsystem 6 - Serial number: 32758 ÿ†6353ETS64H93VVNJ ÿ†63
   Subsystem 7 - Serial number: 3VVNJ ÿ†6363ETS6807BVVNJ ÿ†63
   Subsystem 8 - Serial number: BVVNJ ÿ†6374CTS6464GVVNJ ÿ†63
   Subsystem 9 - Serial number: GVVNJ ÿ†6384CTS6JI8CVVNR ÿ
   Subsystem 10 - Serial number: CVVNR ÿ
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0025
   Revision: 00030000    Serial number: 3C5953507CN
   Coding: 0001511
   Shop #: WSC 05311 000 08193
   VCID: 74E7241817FC1EE2B4-8020
   Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H2ÿ 0021
   Coding: 00000226
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 970 B    HW: 3C8 920 970 B
   Component: KOMBI         H19 0023
   Coding: 240F00
   Shop #: WSC 05311 115 08193
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 2B55FF644242011A25-807E
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08A0101DD
   Coding: FD80FF07001302009002
   VCID: 2A5BFA6085B81812DE-807E
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128T05PX02
   Coding: 0000002
   VCID: 75E1191C1C8607EA83-8020
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 08203 444 97442
   VCID: 73E5270412F219DAAD-8026
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000001
   VCID: 72EB22006DE810D2A6-8026
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1533
   Revision: 71009005    Serial number: 00000890188905
   Coding: 0001463
   VCID: 408FB8C813C4F242E0-8014
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.075 0401
   Revision: 1AH02234    Serial number: 00081540229402
   Coding: 0000258
   VCID: 3663DE1041004CF24A-8062
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13910F8001862E521204141FF08A8F0E085801
            000 -  -  - Intermittent
                    Fault Frequency: 8
                    Reset counter: 79
                    Mileage: 157794 km
                    Date: 2011.01.17
                    Time: 18:33:59
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1533
   Revision: 71009005    Serial number: 00000776688912
   Coding: 0001462
   VCID: 4189BDCC18CEFB4AEF-8014
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
                    Fault Status: 01101100
                    Fault Frequency: 50
                    Reset counter: 45
                    Mileage: 157707 km
                    Date: 2010.11.15
                    Time: 14:39:52
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
                    Fault Status: 01101000
                    Reset counter: 45
                    Mileage: 157707 km
                    Date: 2010.11.15
                    Time: 14:39:54
01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
                    Reset counter: 45
                    Mileage: 157707 km
                    Date: 2010.11.15
                    Time: 14:39:54
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000155039
   Coding: 0000057
   VCID: 285F00689BB42A02C8-807C
Address 56: Radio        Labels: None
   Part No SW: 3C8 035 180 A    HW: 3C8 035 180 A
   Component: Radio PM6       025 0046
   Revision: 00025000    Serial number: VWZ5Z7H2269282
   Coding: 0040401
   VCID: 204F1848F384D24280-8074
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000636520
   Coding: 0001168
   VCID: 3169ED0CA86E6BCA1F-8064
   Coding: 0100101
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000640684
   Coding: 0001168
   VCID: 326BE200AD6850D266-8066
End-------------------------(Elapsed Time: 02:40)--------------------------
stevenpierce83
Vestal NY
bump anyone
MartinsX
Riga, Latvia
C?ID=268515
Have tried TBA and cleaning TB?
Dutchie
C?ID=125479
Check in the MVB the voltage from the throttle pedal and do the same with a volt meter on it. THere are 2 types of TP's. Lane 2 runs in a criss cross patern from 1 thus, lane 1 has 0.5V, lane 2 has then 4.5v and visa versa. The other, lane 2 runs @ 50% of lane 1, thus lane 1 is at 4V, then lane 2 is at 2 V
