Sticky Acronyms
Sticky
   #61
hadez16
C?ID=289891
i'll do some brainstorming...
eBKV = elektronischer Bremskraftverstärker (wtf is the english translation...idk lol)
MO_StSt = Motor Start-Stop??
AGA = Abgasanlage (exhaust)
Freilauf = ...sailing fr automatic transmission
MO = Motor
GE = Getriebe (Transmission)
AEB = Automatic emergency Brake
MXB = Matrix Beam
I think there should be some VAG acronym rap song. Can RT recruit Eminem?
   #62
DiegotheCat
Australia
C?ID=76260
Does anyone know what OCU is in central electrics, it refers to indicator flashing and something to do with a signal from the key fob
   #64
Dana
Western PA, USA
I'm looking for: ASW
Crash repaired NAR 2018 Q5 with ASW_HMI_defekt:
   Part No SW: 80A 907 566     HW: 80A 907 566
   Component: MRR1Rear      H18 0420
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
1192187 - Databus
          [databus error value received - ASW_HMI_defekt]
                    Reset counter: 104
                    Mileage: 23715 km
                    Date: 2019.03.19
                    Time: 10:45:05
                    Control Module temperature: 27 °C
                    Voltage terminal 30: 12.10 V
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: On
                    Voltage terminal 15: Measured value not available
ASW is used in Exp coding charts for modules such as Address A5 and it makes numerous FF appearances in Andy's A3 e-tron after a flat 12V battery. The only other DTC in this car is:
   Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
   Component: TSG HBFS006 0737
   Coding: 000D0B000000148040000020
   ROD: EV_DCU2RearPasseMAXHCONT.rod
196887 - Function Lighting for Exit Warning LED
          B1791 01 [009] - Electrical Failure
                    Reset counter: 104
                    Mileage: 23715 km
                    Date: 2019.03.19
                    Time: 10:44:58
We will advise them to fix the known rear door problem but I don't think that's gonna help. HMI = History Memory Information so ASW might clear things up if anyone can help.
   #65
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Automatic Lane Change maybe? You're in 3C after all...
SWA = Spurwechselassistent
So ASW = auto Spur Wechsel?
I think Audi knows how to safely steer to change lanes instead of just warn of traffic in your blind spot, using fusion of data from the forward camera, rear radar, and maybe side ultrasonic sensors.
HMI may also mean Human Machine Interface, think infotainment user interface. See references like SportHMI referring to the infotainment performance monitor on GTI and R.
I'd guess that error to mean a config mismatch between 5F, A5, 3C and maybe 10.
Edit: front ACC radar might be involved in the fusion as well, so check 13.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I'm going to revise my answer:
Actually I bet it will!
1192187 - Databus
That's Audi Vehicle Exit Assist. Warns you if you're trying to open your door into traffic or bicycles or whatnot. One of your customer's door exit warning LEDs is busted. Those being the human-machine interface for Exit Assist feature, 3C is warning you the feature functionality is impaired.
   #67
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Looking for: TSK
It comes up in some CAN messaging. I believe it'll have something to do with drivetrain coordination, possibly with Haldex engagement.
   #68
hadez16
C?ID=289891
Looking for: TSK
Treibstrang-Koordinator.
So you gave yourself the answer: drivetrain coordination
DV52
C?ID=194404
Should the term " FeC " be included into the forum lexicon-perhaps?
ASCII and ye shall receive.
golfi_vend
Tartu, Estonia
C?ID=195131
VKMS?
Something to do with immobiliser.
   #73
NEtech
C?ID=56995
I doubt this is correct, but I have this:
VerbrennungsKraftMaschine
and S for Sicherheit/Security
I know long shot..
   #74
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Not excactly. "Triebstrang-Koordinator". There is no "Treibstrang" in German...
   #75
DV52
C?ID=194404
How about enshrining " AFS " into the forum's Funk-and-Wagnalls (which I understand to be an American thing) as something like "Advanced Frontlighting System - initials for the cornering light CAN bus"?
And, while thinking about headlight related stuff, how about the inclusion of " FLA " with words like "Main Beam Assist - assistance system which supports the driver when changing from main beam to low beam"
Andy
Sector 7G
HC424490
MIB= Modular Infotainment Platform (somehow) ... guess it's MIB: Modularen Infotainmentbaukasten
TWs/VW
NW Florida
C?ID=369048
Newbie Question: Meaning of Acronym DSL (in 05 ACC/Start Auth. adaptation context)
I know it’s probably a dumb newbie question - I’ve searched the Forum(s) and just haven’t found the meaning of acronym “DSL” as used in the following adaptation lines. I don’t really think it refers to Diesel fuel or Digital subscriber line in this context - likely something else, in German ofcourse. Anybody?
05 Acc/Start Auth. –
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL
ENG129015-Passive Entry Exit: control by pulling the doorhandle during active DSL_timeout
TW
   #79
DiegotheCat
Australia
C?ID=76260
Hey TW
After have a look through all the info and Acronyms I have, I cant find anything but your right in saying that the oonly time it apears is in the door locking section.
So Im taking a stab at it and it could be Delayed Self Lock, or it could be something to do with the proximity locking, Distance Safe Lock.
Im still a little unsure on the whole Term "passive" with regards to enty / exit. Can anyone explain that to me?
I hope I helped a little TW.
   #80
TWs/VW
NW Florida
C?ID=369048
Hey TW
Thanks DiegotheCat. Good guesses, as good as mine - Door Slam Lock; it might be related to another line in O5 ACC/Start Auth.:
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock
I believe the term Passive, in this context, refers to the locking feature being automatic, but I'm still guessing here to.
TW
