Sticky Acronyms
Sticky
   #81
DiegotheCat
Australia
C?ID=76260
Thanks DiegotheCat. Good guesses, as good as mine - Door Slam Lock; it might be related to another line in O5 ACC/Start Auth.:
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock
I believe the term Passive, in this context, refers to the locking feature being automatic, but I'm still guessing here to.
TW
I did think of that one too TW.
It's not a fun mod to do, it always freaked me out when I turned it on. Just always worried that the car would lock withy keys in it. Even tho that's not supposed to happen, but it did once.
Good luck with it.
   #82
TWs/VW
NW Florida
C?ID=369048
Good luck with it.
I know what you mean, me to. But so far I've not had a problem, I just keep my fob in my pocket (where it belongs). Anyway, I tried changing the "control by pulling the door handle during active DSL_timeout" to 5.00 s and it had no effect in delaying the instant 'Door Slam Lock', so I still really can't confirm the meaning of 'DSL'
TW
   #83
FAZIT = Fahrzeug-Auskunfts- Zentrales und Informations-Tool
Translation: Vehicle Central Database and Information/Intelligence? Tool -perhaps?
TMC - Traffic Message Channel -perhaps?
   #85
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Would you please add...
IMO = In My Opinion
IMHO = In My Humble Opinion
CP = Component Protection
  • Agree
Since that's a "perhaps", I'd like a confirmation.
Uwe: I used the term"perhaps" as a diminutive; an acknowledgement that my request was (of course) provisional on the judgement of the forum's decision maker. Apology if my sentence structure has caused confusion. Yes, I believe that the acronym can reliably be interpreted as I suggested.
Yeah, it could mean Too Much Chutzpah! :D :rolleyes:
@Bruce : Not true. In fact, entirely the opposite (completly without audacity - IMO, appropriately asked with due respect, timidity and diffidence)!! :thumbs:
   #91
Admin- should SWAP be in the forum lexicon?
I thought it was. Let me see if I can figure out what's up with that.
ETA: It was defined as "SWaP" and marked case-sensitive. I think we should keep it case-sensitive, since we don't want it to show up ever time someone uses the verb "swap", but I've changed it to "SWAP".
   #92
@Uwe: Arrrhh.......... that makes sense - thank you!!
As a related, but different question and case-sensitive restrictions notwithstanding, why do these defined terms exclude plurals?
For example, a single trouble-code DTC appears as a defined term, but multiple trouble codes DTCs do not! Is this purely a limitation in the forum software, or is there deliberate logic behind the dynamic?
   #93
<Split a Car Repair thread and brought here, where it belongs>
The way the forum software works is it looks for a word with white space (or certain punctuation marks) on either side of it. You wouldn't want it to try to define a three letter acronym sequence that happens to be embedded in or part of another word, right? So while 'DTC' is defined, 'DTCs' isn't. Of course, I could add an entry for 'DTCs'...
nugentp
C?ID=6386
Theres a few in here that I would like to know (from an LWR/AHLS controller):
FNS (something to do with natural frequency) ?
APSB ?
APSP ?
PWM (pretty sure is pulse width modulation)
   #98
nugentp
C?ID=6386
And then there is...
SKL (also light related as 'Leimo' has something to do with LED control module ?)
   #99
nugentp
C?ID=6386
And another couple from same controller (one of which I found elsewhere):
APK ???
PSD - Prädiktive StreckenDaten (predictive route guidance - applicable to higher end MMI only ?)
   #100
nugentp
C?ID=6386
A suggestion :
NSW - NebelScheinWerfer ==> Fog Light (memory tip is "Nasty Soggy Weather")
