Torque Management Request Input Signal A - P2545
mossback
C?ID=244676
2016 MK3 MBQ Audi TTS - STG1 APR
Error appeared while on race track, in uphill corner 110kph, 3500 RPM, feels like huge misfire, only once or twice, then everything fine for rest of lap. Problem only on this uphill corner, no other issues present or apparent. Car is very strong and never has had an issue in 5 track days so far until yesterday.
Any thoughts?
15327 - Torque Management Request Input Signal A
P2545 00 [032] - Implausible
Intermittent - Not Confirmed - Tested since memory clear
Freeze frame:
fault status: 00000001
fault priority: 2
Fault frequency: 1
mileage: 5044km
date: 2016.08.29
Engine speed 3427
Normed load value; 0.0%
Vehical speed 110km/h
coolant temp 83c
intake temp: 45c
ambeitn air pressure 1000mbar
Voltage terminal 30: 14.296v
Unlearning counter according ODB: 39
Engine: operating status: PU
STATE_LS_SAE[1]: CL
T_AST_SAE: 299 s
MAP_MES_SAE: 106kPa
Lambda probe voltage: bank 1: Probe 1 (broadband probe): 3.359v
FAC_TPS_1_SAE: 29.687500 %
FUP_H_SAE: 240.0 kPa
Westbury, UK
A full auto-scan might help.
mossback
C?ID=244676
Tuesday,30,August,2016,17:02:00:63869
VCDS Version: 16.8.0.3 (x64)  HEX-NET CB: 0.4321.4
Data version: 20160803 DS255
Dealer/Shop Name: Mossback
VIN:   License Plate:
Chassis Type: FV (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
          6C A9
VIN:
Address 01: Engine (J623-CYFB)       Labels: None
   Part No SW: 8S0 906 259 C    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00322426000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259C 001003
   ROD: EV_ECM20TFS0208S0906259C.rod
   VCID: 3D32EE95AC88D3AA8B-8068
                    Mileage: 5044 km
                    Date: 2016.08.29
                    Time: 15:53:00
                    Engine speed: 3427.00 /min
                    Vehicle speed: 110 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 14.296 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 299 s
                    MAP_MES_SAE: 106 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.359 V
   Part No SW: 0D9 300 013 D    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4905
   Revision: 06253104    Serial number: TFK01512051727
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 187C1F01E36AD68278-804C
   Part No SW: 8S0 907 379 D    HW: 8S0 907 379 D
   Component: ESC           H42 0522
   Revision: 00000000    Serial number: 63425000000324
   Coding: 24AA608D0A9B15AC0095086C8291910623240650A80010418960C4
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
   VCID: 42C89D69D576AC52F6-8016
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0389859552
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A38E589BDA6E492AE-806E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0030
   Revision: 20009000    Serial number: 16060000009000
   Coding: 400040100001041100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C9413D187728A226C-8038
   Serial number: 8AE80A08000000000001
   Operating and display unit 1 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000023249
   Operating and display unit 2 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Operating and display unit 3 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Operating and display unit 5 for air conditioning:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 085 BH    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061600900137
   Coding: 040D5C46C80106FD41444004531007A80080000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 004C57619BFA7E42A0-8054
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 151127  038 0371
   Serial number: 00000001511260301922
   Coding: 1BC7F7
   Serial number: 61139713
   Coding: 00005D
   Serial number: 22 09 2015  00000318
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0040
   Serial number: 0000009600335Z0DSO02
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
   Component: GTO BF  H05 0010
   Serial number: 20151215154112 00455
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064541528
   Valve Block 1 In Driver Side Front Seat:
   Subsystem 7 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N475 VB1 FSv  H07 0021
   Serial number: 7008173235E154916363
   Coding: 810500
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N477 VB1 BFSv  H06 0021
   Serial number: 7008173235D154415978
   Coding: 810500
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391534909766
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 43C6986DCA6CA55AFD-8016
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       111215031
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_AU37.rod
   Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
   Serial number: 003M9R002EVM
   Coding: BFCCF0C000800000A000001FC24800000065
   VCID: 4FEEA45D1624513A69-801A
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Serial number: IBH000000000004941DY
   Coding: 303330
   Subsystem 2 - Part No SW: -----------    HW: 480 000 401 16
   Serial number: 35700000000D8744471K
   Subsystem 3 - Part No SW: -----------    HW: 480 000 401 16
   Serial number: 3580000000085744471D
   Subsystem 4 - Part No SW: -----------    HW: 480 012 311 15
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A056661EF47C5F
   Subsystem 5 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3550002C51D1B5D4A19E
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3560002C51D1B5D35289
   Part No SW: 8S0 907 129 AJ    HW: 8S0 907 129 AJ
   Component: Lenks. Modul  H07 0140
   Revision: --------    Serial number: 91335PAB00866
   Coding: 2058
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 02485D6995F66C52B6-8056
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 8S0 920 890 A    HW: 8S0 920 890 A
   Component: FBenUSA       H35 0264
   Coding: 086F08413989D7050221E8C09800800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 383CFF8183AAF68258-806C
   Part No SW: 8S0 907 468 C    HW: 8S0 907 468
   Component: GW MQB TT3    012 0244
   Revision: --------    Serial number: 09121510802289
   Coding: 0301000424025A004B000228B80000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011003
   ROD: EV_GatewContiAU33X.rod
   VCID: 40CC9761DB7ABE42E0-8014
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20151214121441 01091
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 3764008303
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00026.11.15
   Coding: 0101
   ROD: EV_AllWheelContrHA1VW37X_VW48.rod
   VCID: 45C28675C4589B6AD3-8010
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H08 0050
   Serial number: 0388715503
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CB42391F7121AA2FC-8028
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H08 0050
   Serial number: 0388697105
   Coding: 030311
   Serial number: 281015BJO20231
   Coding: 001F53225C00040100000402
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: 393AFA85B8A0EF8AA7-806C
   Part No SW: 8S0 035 465 C    HW: 8S0 035 465
   Component: MIB2_amp_P_TT H06 0240
   Revision: 00000001    Serial number: AUZ8ZAFH700F8EW
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 3522F6B594B80BEA43-8060
   Serial number: 291015BJS16569
   Coding: 001F53225E00040100000402
Address 55: Headlight Range (J745)       Labels: None
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 0362001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   ROD: EV_HeadlRegulAUDIMXBAU64X_AU37.rod
   VCID: 3620F1B989BE00F24A-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 025 A    HW: 8S0 035 025
   Component: MU-H-LNS-US   043 0376
   Serial number: A263L0FB001269
   Coding: 013354020000000011220002041A00102F0000E1007000047E
   VCID: 2B16D0CD42FC4D1A25-807E
   Subsystem 1 - Part No SW: V03 959 801 GE    HW: -----------
   Component: NAR 2016  --- 0048
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
   Component: ControlUnit_H  H22 0136
   Serial number: APVAK109111500010173
   Compact Disc Database:
   Component: Gracenote2  --- 3007
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 5Q0 980 556 A    HW: 5Q0 980 556
   Component: RVC Compact   H08 0172
   Coding: 0233540102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   Part No SW: 8S0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0005
   Serial number: 151028202896
   VCID: 3B36E08DB29CDD9AB5-806E
End----------(Elapsed Time: 01:46, VBatt start/end: 12.2V/12.2V)-----------
                Address 01: Engine       Labels: None
Control Module Part Number: 8S0 906 259 C    HW: 06K 907 425 E
  Component and/or Version: 2.0l R4 TFSI  H13 0001
           Software Coding: 0A1D00322426000E3004
            Work Shop Code: WSC 06385 790 00016
              ASAM Dataset: EV_ECM20TFS0208S0906259C 001003 (AU37)
                    Mileage: 5044 km
                    Date: 2016.08.29
                    Time: 15:53:00
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 299 s
                    Mileage: 5044 km
                    Date: 2016.08.29
                    Time: 15:53:00
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 299 s
Readiness: N/A
mossback
C?ID=244676
APR has mentioned that they have seen something like this in a Golf R: under 1/4 tank and cornering forces cause fuel to slop past pickup on fuel pump.
So this might be a case of fuel starvation but think think that some kind of fuel error would have manifest. At another track I ran the car nearly dry without a hitch, this track has a unique high speed uphill right hander, which might be magic combo to move the fuel away from the pumps intake.?? Possible, i guess not knowing the inner design of the fuel tank.
I took the car to a dyno and NO events were recorded through 4 runs.
FYI the car made 365ft lbs of torque at the wheels, with 292whp.
