Audi a7 tail light coding USA=>EU
xxmatixx
Poland
C?ID=169703 (NRRT)
Hi.
I need change coding tail lights for eu.
This is my coding :
Channel number 196:
value 166
Channel number 195:
value 134
Channel number 197:
value 6
Channel number 198:
value 38
channel number 199:
value 51201
channel number 200:
value 51233
channel number 201:
value 51201
channel number 202:
value 51233
channel number 203:
value 9
channel number 204:
value 41
channel number 205:
value 13
channel number 206:
value 45
channel number 207:
value 6
channel number 208:
value 38
channel number 209:
value 51219
channel number 210:
value 51251
B/D
Channel number 211:
value 51214
Channel number 212:
value 51215
Channel number 213:
value: 21043
channel number 214:
value: 3
If anyone could calculate the coding I will be grateful
Thx
Sebastian
Magdeburg, Germany
HN0-nnnnnn
#1 Auto-Scan (incl. VIN)
#2 Control Module Map from #46 with Security Access for higher Channels
#3 Part Numbers of the actual Tail Lights which have been installed
rlarsen
Copenhagen, Denmark
C?ID=78998
Channel 195, 196, 197, 198, 207 and 208 need to be changed - If I have mapped the correct brake and signal channels - I don't know, but if not just use the values where they fit between the 6 channels I've listed at the beginning.
Channel number 195:
value 134 - 0000 0000 1000 0110 - (Brake, Signal) - [B]0000 0000 1000 0101 - (Brake) - 133[/B]
Channel number 196:
value 166 - 0000 0000 1010 0110 - (Brake, Signal) - [B]0000 0000 1010 0101 - (Brake) - 165[/B]
Channel number 197:
value 6 - 0000 0000 0000 0110 - (Brake, Signal) - [B]0000 0000 0000 0101 - (Brake) - 5[/B]
Channel number 198:
value 38 - 0000 0000 0010 0110 - (Brake, Signal) - [B]0000 0000 0010 0101 - (Brake) - 37[/B]
channel number 199:
value 51201 - 1100 1000 0000 0001 - (Tail, CH/LH)
channel number 200:
value 51233 - 1100 1000 0010 0001 - (Tail, CH/LH)
channel number 201:
channel number 202:
channel number 203:
value 9 - 0000 0000 0000 1001 - (Fog)
channel number 204:
value 41 - 0000 0000 0010 1001 - (Fog)
channel number 205:
value 13 - 0000 0000 0000 1101 - (Reverse)
channel number 206:
value 45 - 0000 0000 0010 1101 - (Reverse)
channel number 207:
value 6 - 0000 0000 0000 0110 - (Brake, Signal) - [B]0000 0000 0000 1100 - (Signal) - 12[/B]
channel number 208:
value 38 - 0000 0000 0010 0110 - (Brake, Signal) - [B]0000 0000 0010 1100 - (Signal) - 44[/B]
channel number 209:
value 51219 - 1100 1000 0001 0011 - (Tail, CH/LH) - Side marker
channel number 210:
value 51251 - 1100 1000 0011 0011 - (Tail, CH/LH) - Side marker
Channel number 211:
value 51214
Channel number 212:
value 51215
Channel number 213:
value: 21043
channel number 214:
value: 3
xxmatixx
Poland
C?ID=169703 (NRRT)
Channel number 195:
Channel number 196:
Channel number 197:
Channel number 198:
channel number 199:
channel number 200:
channel number 201:
channel number 202:
channel number 203:
channel number 204:
channel number 205:
channel number 206:
channel number 207:
channel number 208:
channel number 209:
channel number 210:
Channel number 211:
value 51214
Channel number 212:
value 51215
Channel number 213:
value: 21043
channel number 214:
value: 3
It's not correct but I modeled on your description and changed coding.
Everything is ok now.
Thanx
InfiniteReality
C?ID=351343
Fixing to tackle this on my S7. I bought the car with EU tail lights and right now my brake lights also flash the signal as well. I'm glad to have a starting point as I'm new to VCD, any chance you'd mind sharing what else you changed to allow them to operate properly?
InfiniteReality
C?ID=351343
In case anyone else is searching for what coding works for S7 FL EU taillights, here's the coding that worked for me. All credit goes to RLARSEN
rlarsen
Copenhagen, Denmark
C?ID=78998
I think channel 202 should only be 51233 - because it should be 32 larger than channel 201 (+32 (bit 5) means coding for right side)
InfiniteReality
C?ID=351343
But channel 202 is +32 larger than channel 201 at 51234. Everything works as it should.
InfiniteReality
C?ID=351343
Ahh - yes, you’re right, it was my own previous calculation that was wrong :)
No worries. Huge thanks for sharing the coding, thankful to have no amber signals come on with my brakes now!
mpcmetal
Unverified
Poland
hello I am looking for coding tail lamps audi a7 2016 lift will you help?
my coding :
Kanał 181: 65535
Kanał 182: 7
Kanał 183: 65535
Kanał 184: 7
Kanał 185: 65535
Kanał 186: 7
Kanał 187: 49152
Kanał 188: 0
Kanał 189: 49152
Kanał 190: 4
Kanał 191: 65535
Kanał 192: 3
Kanał 193: 6
Kanał 194: 7
Kanał 195: 51201
Kanał 196: 51233
Kanał 197: 9
Kanał 198: 41
Kanał 199: 6
Kanał 200: 38
Kanał 201: 51201
Kanał 202: 51233
Kanał 203: 134
Kanał 204: 166
Kanał 205: 13
Kanał 206: 45
Kanał 207: 0
Kanał 208: 32
Kanał 209: 51201
Kanał 210: 51233
Kanał 211: 51214
Kanał 212: 51215
Kanał 213: 21045
Kanał 214: 3
Kanał 221: 51400
Kanał 222: 51400
InfiniteReality
C?ID=351343
my coding :
Kanał 181: 65535
Kanał 182: 7
Kanał 183: 65535
Kanał 184: 7
Kanał 185: 65535
Kanał 186: 7
Kanał 187: 49152
Kanał 188: 0
Kanał 189: 49152
Kanał 190: 4
Kanał 191: 65535
Kanał 192: 3
Kanał 193: 6
Kanał 194: 7
Kanał 195: 51201
Kanał 196: 51233
Kanał 197: 9
Kanał 198: 41
Kanał 199: 6
Kanał 200: 38
Kanał 201: 51201
Kanał 202: 51233
Kanał 203: 134
Kanał 204: 166
Kanał 205: 13
Kanał 206: 45
Kanał 207: 0
Kanał 208: 32
Kanał 209: 51201
Kanał 210: 51233
Kanał 211: 51214
Kanał 212: 51215
Kanał 213: 21045
Kanał 214: 3
Kanał 221: 51400
Kanał 222: 51400
bantumi
Bulgaria
Can someone help me with this coding? I am new to VCDS and don't know where to find these channels. Thanks in advance.
Please post an Auto-Scan so people can see exactly what car you are working on and how it is equipped.
