VW T5 2010 mod Engine CAAC in limp mode
distrub
Norway
C?ID=192694
Hello
I got a 2010 T5 Whit a CAAC enging. Every now and then it goes into limp mode and the glowing light is flashing. VCDS autoscan says P0087 fuel preassure to low. Ive been struggeling whit this problem a while. Last week i meassured return flow on injectors. The walues where to high and i replased all injectors. They are all coded inn ECU, so thats ok. The car is much better now, but it still goes in limp mode when i drive 30-40 km. Its enough to stopp/start, and it goes well a long time. Does anyone have some tips for mee?
Just so its said, the fuel filter is new and the low and high preassure pump is also replaced ( privious owner )
Monday,29,August,2016,18:39:04:44240
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WV1ZZZ7HZAHxxxxx   License Plate:
Mileage: 127050km-78945mi   Repair Order:
Chassis Type: 7H (6N0)
Scan: 01 03 04 08 09 15 17 18 19 22 25 56 69 0B
VIN: WV1ZZZ7HZAH227650   Mileage: 127050km-78945miles
Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DK    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H32 9135
   Revision: 26H32---    Serial number: 00000000000000
   Coding: 0119401A231600080000
   Shop #: WSC 00610 218 178670
   ASAM Dataset: EV_ECM20TDI01103L906019DK 002007
   ROD: EV_ECM20TDI01103L906019DK.rod
   VCID: 77FD05D5CE6194FA91-8022
5211 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
                    Mileage: 127051 km
                    Date: 2016.08.29
                    Time: 18:18:09
                    Engine speed: 1979.00 /min
                    Normed load value: 98.8 %
                    Vehicle speed: 68 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.280 V
                    Fuel temperature: 37.1 °C
                    Mean injection quantity: 58.73 mg/stroke
                    Rail pressure regulation: status-Bit 0: 00000101
                    Fuel high pressure: actual value: 637700 hPa
                    High fuel pressure: specified value: 1.3317e+006 hPa
                    Pressure control valve adaptation factor: 1.1697
                    Fuel level: 24.00 l
5212 - Fuel Rail/System Pressure
          P0087 00 [101] - Too Low
                    Mileage: 127051 km
                    Date: 2016.08.29
                    Time: 18:18:10
                    Engine speed: 2046.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 70 km/h
                    Unlearning counter according OBD: 79
                    Fuel temperature: 37.3 °C
                    Mean injection quantity: 30.45 mg/stroke
                    Fuel high pressure: actual value: 941400 hPa
                    High fuel pressure: specified value: 1.0946e+006 hPa
                    Fuel level: 24.00 l
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 508724AD91A60A9C24A88976695E10
   Shop #: WSC 02736 790 49152
   VCID: 3467F2D99797BFE274-8060
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 Q    HW: 7E5 907 047 Q
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 3D71D7FDACDD7EAA8B-8068
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 086 B    HW: 7H0 937 086 B
   Component: BCM T5GP M++4 H46 0207
   Revision: BM046001    Serial number: 0154 341090379
   Coding: A0A0293A0E212002002000003C2B8CD40000430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 326BF4C16D83B1D266-8066
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  002 3310
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 248
                    Mileage: 126894 km
                    Date: 2011.01.13
                    Time: 07:43:11
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E5000RLSC
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3467F2D99F97BFE274-8060
   Part No SW: 7E0 920 860 A    HW: 7E0 920 860 A
   Component: KOMBI         H16 0111
   Coding: 160000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 26431891594BDD72FA-8072
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 A
   Component: J737__Standheizung  0404
   Revision: 00085000    Serial number: 09019275D00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 23450185E279285A9D-8076
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 086 B
   Component: GW-K-CAN TP20 0207
   Coding: 042200
   VCID: 70EF3EC9A30FC3C250-8024
   Part No SW: 09N 907 554 A    HW: 09N 907 554 A
   Component: Haldex 4Motion      6007
   Coding: 0000001
   VCID: 3663C8D141EBADF24A-8062
   Component: IMMO          H16 0111
   Part No SW: 7E0 035 156     HW: 7E0 035 156
   Component: Radio         H21 0058
   Revision: R0000000    Serial number: VWZAZ1I9808309
   Coding: 0000020001
   VCID: 60CF4E8973EF7342C0-8034
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000123088244
   Coding: 4100000100000000
   VCID: 2F6DFDB57EB19C3A09-807A
End-------------------------(Elapsed Time: 02:22)--------------------------
Dutchie
C?ID=125479
Has the feulfilter been replaced recently, before the first time the DTC showed up?
Preform a test drive and check the requested high pressure and the measert high pressuse. The best way to check that, is to go in 3rd gear, a low rpm (+/-1000) and give full throttle.
Please report those findings back
distrub
Norway
C?ID=192694
I replaced the fuelfilter today. I have cheked the MVB while driving, but it seams like tha fault is only there for a verye short time.
Dutchie
C?ID=125479
That is correct, as soon the ECM detects an rail pressure error its goes in to limp home as an safety. Please post the log of the pressure during an testdrive to see what happens.
