MIB STD2 in SUPERB2
pab567
Poland
C?ID=233680
Hi,
I have replaced Columbus (RNS510) in my Superb 2 with Amundsen MIB STD2. There are ROD errors as you can se in below log. I know thios is not the standard configuration but if you find some time... :)
And there was no label file - I had to use 3V0-035-MIB-STD2.clb (which works pretty well).
BR,
Pawel
Friday,12,August,2016,16:57:32:12646
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
Dealer/Shop Name:
Workshop Code:
VIN: XXXXXXXXXXXXXXXXX   License Plate:
Mileage: 67960km-42228mi   Repair Order: 201608121655
Chassis Type: 3T (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 36 42 44 46 4C 52
          55 5F 62 69 6D 72
VIN: XXXXXXXXXXXXXXXXX   Mileage: 67960km-42228miles
Address 01: Engine (0-32-CDVA)       Labels: 03H-907-309-V1.clb
   Part No SW: 03H 906 023 AE    HW: 03H 907 309 C
   Component: 3,6 FSI EU5   H04 1642
   Revision: MFH04---    Serial number:
   Coding: 001D0012242600000000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM36FSI01103H906023AE 001002
   ROD: EV_ECM36FSI_SK46.rod
   VCID: 65C180BE6450A06A31-8030
Readiness: 0100 0001
   Part No SW: 02E 300 013 R    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2704
   Revision: 05351113    Serial number: 00001110030996
   Shop #: WSC 33361 790 00051
   VCID: 204FD1AAF3F2854282-8074
   Revision: 00H31001
   Coding: 843D8016192580FD210F01ED981C0141370C00
   Shop #: WSC 00567 048 00001
   VCID: 7BF5C6C6FAD4069AF7-802E
                    Reset counter: 123
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:00:55
                    Count: 7
                    Count: 12
                    Count: 28672
                    Count: 8223
                    Count: 39936
                    Count: 512
                    Count: 72
                    Reset counter: 123
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:01:05
                    Count: 2
                    Count: 12
                    Count: 28672
                    Count: 16390
                    Count: 41216
                    Count: 512
                    Count: 72
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0156635623
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   ROD: EV_KESSYPQ35G.rod
   VCID: 34672DFA9F0A09E276-8060
   Part No SW: 3T0 907 044 BQ    HW: 3T0 907 044 BQ
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 020BBB22953E7752B4-8056
   Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 46190AB8E849F1C040080080710089E4477900AE776D8FF05C814000A040
   Shop #: WSC 33361 790 00567
   VCID: 71E9E4EEA8987CCA5D-8024
   Subsystem 1 - Part No: 3T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 13101  26  0602
   Coding: 00D7B7
   Component: RLS 211011 05  54  0403
   Coding: 072BED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 3T0 919 475 C    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0005
   Revision: --------    Serial number: 13901127101192
   Coding: 318108
   VCID: 3D7108DEA440C8AA89-8068
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAK VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PM8V29-
   Coding: 0016715
   VCID: 4189742E18B8AC4AED-8014
   Subsystem 1 - Serial number: 6332MTS648082751
   Subsystem 2 - Serial number: 6342MTS648442751
   Subsystem 3 - Serial number: 6351HTS6IN83GAKR
   Subsystem 4 - Serial number: 6361HTS60EB9GAKJ
   Subsystem 5 - Serial number: 63727TS60SB8DAKR
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111014200283
   Coding: 1012140000
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 7DF1C8DEECC008AAC9-8028
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 830000
   Part No SW: 3T1 920 841 J    HW: 3T1 920 841 J
   Component: KOMBI         H05 0610
   Coding: 111F01
   Shop #: WSC 73430 031 00047
   VCID: 3A7B03C2BD6EFF92AC-806E
   Part No SW: 7N0 907 530 BA    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1663
   Revision:   H58       Serial number: 111114F1001375
   Coding: 354030
   VCID: 70EFE1EAA39275C252-8024
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 4581603E0C90806AD1-8010
   Component: IMMO          H05 0610
   Coding: 000007
   VCID: 6ADBF3828D4E8F121C-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000231600001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E533F927126233200-807A
   Part No SW: 3C8 959 760 C    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2901
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 356110FE9C7010EA41-8060
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011D0220DE00001000
   VCID: 4FAD42161EEC4A3A6B-801A
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 197    3201
   Revision: 00H20000
   VCID: 34672DFA570A09E276-8060
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 11.6 V
                        PD
                    Temperature: 20.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E935F1219E6433260-801A
   Coding: 1376839
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000021
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-STD2.clb
   Part No SW: 5L0 035 680 C    HW: 5L0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: SKZAZ2R8895048
   Coding: 03130601FF00000011111204008800002F0001C40120810046
   ROD: N/A
   VCID: 2A5B33824DCE4F12DC-807E
No ASAM data for: "EV_MUStd4CTSAT" (SK46)
11 Faults Found:
1543 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:18:06
0512 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0513 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0517 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0518 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0522 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0523 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0527 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
0528 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:25:09
1564 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:17:02
1637 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 124
                    Mileage: 67969 km
                    Date: 2016.08.12
                    Time: 00:17:03
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200000001000
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Revision: 3A001001    Serial number: 00000161130265
   Coding: 410D000100000000
   VCID: 306F21EA631235C212-8064
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7N0 959 107 C    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0804
   Revision: 41011001    Serial number: 284100061
   Coding: 082301C003
   ASAM Dataset: EV_HDSGSk462 301133
   ROD: EV_HDSGSk462_SK46.rod
   VCID: 377D1AF68E7CE2FA53-8062
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 03:48)--------------------------
ROD error is due to "foreign" (to this ASAM data) SK46 chassis.
Having at least the first 10 digits of your VIN might be useful here.
pab567
Poland
C?ID=233680
TMBRC93T2C
pab567
Poland
C?ID=233680
Any update? It's also quite annoying that in such case coding and adaptation are disabled.
