2010 Seat Ibiza ABS coding (ESP8.2i)
Vagcar
C?ID=39700
Hi guys, got a car in today that's lost its ABS coding ive attached a full read and a data sticker shot if anyone can help, its long coding and believe its a dealer only SVM job but noticed someone else on here had the same issue and was resolved by a member on here.
Wednesday,24,August,2016,17:41:29:12016
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
VIN: VSSZZZ6JZCR045103   License Plate: DY61WSE
Mileage: 157760km-98027mi   Repair Order:
Chassis Type: 6J (6R0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZCR045103   Mileage: 157760km-98027miles
Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 AB    HW: 03P 906 021 BC
   Component: R3 1.2 DCM3.7 H06 9069
   Revision: 12005001    Serial number:
   Coding: 00114014032501080000
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_ECM12TDI03103P906021AB 001010
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 68D463E2935D2B020A-803C
15971 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 153935 km
                    Date: 2016.05.18
                    Time: 23:01:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 79 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.257 V
                    Unlearning counter according OBD: 178
                    Engine status: Engine stopped
                    OBD Driver demand indicated torque: 0 %
                    Mean injection quantity: 0.0 mg/stroke
                    Exhaust gas temperature sensor 1: 84 °C
                    Outside air temperature: 17 °C
                    Sensor for engine block temperature; raw value: 80 °C
                    Terminal 15 status: On
16275 - ROD - Unknown Error Code
          - 00 [088]
                    Mileage: 157387 km
                    Date: 2016.08.10
                    Time: 07:52:14
                    Coolant temperature: 55 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.210 V
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 04941 000 00000
   VCID: 0716405EB203C47AE3-8052
            000 -  -
                    Reset counter: 51
                    Mileage: 153491 km
                    Date: 2016.05.06
                    Time: 01:24:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3213
                    Hex Value: 0x14A3
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Reset counter: 51
                    Mileage: 154756 km
                    Date: 2016.06.08
                    Time: 00:50:28
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1251
                    Hex Value: 0x1B9E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 51
                    Mileage: 153491 km
                    Date: 2016.05.06
                    Time: 01:24:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x32E1
                    Hex Value: 0x20A3
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Fault Frequency: 12
                    Reset counter: 91
                    Mileage: 157767 km
                    Date: 2016.08.24
                    Time: 02:28:26
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x12E7
                    Hex Value: 0x259D
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7E00
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0320
   Revision: 00 25 08    Serial number: 0000001986183-
   VCID: 244C37D2E7F50F62E6-8070
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 57
                    Reset counter: 31
                    Mileage: 153491 km
                    Date: 2016.05.06
                    Time: 01:23:09
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 BCM PQ25 Re4  H50 03510351
   Revision: BU050001    Serial number: 0456 207111386
   Coding: 258829E888612500922001F06E0B8CC8CF80620F7E8C0409200000000000
   Shop #: WSC 64564 324 38760
   VCID: 41829E46D8A73A4AED-8014
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3130
   Coding: 430000
   Subsystem 2 - Part No: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT
   Coding: 420000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00
   Component: LIN BACKUP HO
   Subsystem 5 - Part No: 1K8 951 171 A
No Faults Found
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA05 H09 0020
   Revision: --------    Serial number: 003GX00TA9N.
   Coding: 003035
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250_VW31.rod
   VCID: 4A90B96AED91F9123C-801E
   Serial number: 3495RRB40690LCOSG9TT
   Serial number: 3505RRB40650LCOSOH15
   Part No SW: 6J0 920 903 J    HW: 6J0 920 903 J
   Component: KOMBI         H02 0504
   Coding: 410200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3162CE866007AACA1D-8064
Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0034
   Revision:   H38       Serial number: 170811F2001857
   Coding: 2542C1
   VCID: 346CC79297159FE276-8060
   Component: IMMO          H02 0504
   VCID: 6AD019EA8D5119121C-803E
   Part No: 6R0 423 156 B
   Coding: 11211
   Shop #: WSC 06402
   VCID: 2F66C8FEEA33BC3A0B-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70E40B82638DE3C252-8024
Address 56: Radio (J503)       Labels: 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H15 0204
   Revision: R0000000    Serial number: SEZAZ2L1953714
   Coding: 0501020002
   VCID: 2A50D9EA45D1D912DC-807E
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0034
   Coding: 0303185A
   VCID: 74EC0792D795DFE2B6-8020
   Subsystem 1 - Part No SW: 6R0 915 181 B    HW: 6R0 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370215607
End-------------------------(Elapsed Time: 02:28)--------------------------
Vagcar
C?ID=39700
automech
Poland
C?ID=14925
130224DB817100B7882624E281D400420000
130224DB817100B7882624E281D400421000
130224DB817100B7882624E281D400421300
Vagcar
C?ID=39700
Thanks for the reply, have tried those but unfortunately won't accept coding values
Appreciate u trying tho 👍🏻
automech
Poland
C?ID=14925
OK so, try them with 11 not 13 at the beginning
Vagcar
C?ID=39700
Tried those today but unfortunately won't accept that either, appreciate your effort again tho
automech
Poland
C?ID=14925
Done even some more research, if this is not OK, then I don't know what is...
130224DB817100B7882624E281D400521300
Vagcar
C?ID=39700
Thanks again for the reply, only got round to trying the code this morning as we have had a long bank holiday weekend.
Unfortunately that code wasn't accepted either
Dutchie
C?ID=125479
If not ok, please post engine code, size of Brakes, dsg or Manuel station or hatchback
Dutchie
C?ID=125479
Please try 230224E3417100B7C42624E282D400921300
Vagcar
C?ID=39700
Thanks Dutchie,
its all above on the photo but ive added it here
engine : CFWA 1.2 3 cylinder
Brakes : 1KM 200 x 40
Gearbox : Manual
Body : Hatchback
Dutchie
C?ID=125479
210224E3417100B7842624E282D400521300
If not, please go to the dealer for a svm and post here the coding for future referance
Vagcar
C?ID=39700
Wouldn't accept that one either unfortunately,
Thanks for all the effort
Vagcar
C?ID=39700
Thanks for all your help guys, despite all of your help still can't get any code to be accepted. There must be some formula to work these out surely without dealer svm. Be advantageous to us all if we could work it out. I believe chassis encryption is part of it but can't 100% sure
Shame to have to go to the dealers but it's looking like we may have to
Still open to any ideas or suggestions anyone has.
NostraJackAss
OP Find scans from other seats with similar attributes please............post them!
:D
2010 Seat Ibiza
Gearbox : Manual
Body : Hatchback
String length: 18
VIN strip attributes.
Coding:
VIN: VSSZZZ6JZBR097551
Address 01: Engine (J623-CBZB)
Part No SW: 03F 906 070 BL HW: 03F 906 070 BL <<<<<<< Hardware displacement different!
Component: SIMOS10.23H02 9872
Coding: 00110096202401080000
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF <<<<< Hit same part # & chassis
Revision: --------
000000092B0001001000E9901A000000000
Coding: 110228DB217600B9882A14E784D20050170
100200DB007100B3082700E200D70000000
113B20DB0A2B0001881004E9001A0050350
113B20DB0A2B0001881004E9001A0051350
00000000092B0001001000E9901A0000000
100200DB007100B3082700E200D700000000 <<<<<< string length 18 below same chassis dif part #
Scans of the net start compare even close chassis and research cross for reversing notes:
dam no vin#....
Teilenummer SW: 03P 906 021 P HW: 03P 906 021 P
Bauteil: R3 1.2 DCM3.7 H04 8408
Revision: 11001001 Seriennummer:
Codierung: 00114014002400080000
Adresse 03: Bremsenelektronik (J104) Labeldatei: DRV\6J0-907-37x-ABS.clb
Teilenummer SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Bauteil: ABS8.2 front H03 0001
Revision: --------
Codierung: 100200DB007100B3082700E200D700000000
Betriebsnr.: WSC 04941 000 00000
VCID: 8003830383038303833
VIN string verification based on same part # strip process dif chassis same part # ABS module
WVWZZZ6RZCY503706
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR ( 1.4TSI GAS 6R (6N0) VW25 )
Coding: 00250012002400000000
Part No SW: 0AM 300 052 B HW: 0AM 927 769 D ( Auto DSG )
Revision: --------
Coding: 230248E3416D02B5C42C12E282D740811700
VIN: WVWZZZ6RZBY277278
Part No SW: 03E 906 019 B HW: 03E 906 019 B
Component: SIMOS11.1 H03 9878
Coding: 00110016000400080000
Coding: 210224E3217400B9842724E984D900401300
ESP 8.2i 6r0907379BC
VW Polo 6R
VIN: WVWZZZ6R*********
210228E3217300B8842E14EB84D200401300
210228E3417100B2842A14EA82D600421700
210224E3416D00BB842E24E782D300421500
210228E3417100B2842A14EA82D600421300
210248E3417202B7842712EA82D640411700
210248E3416D02B2842612E482D240411700
Vagcar
C?ID=39700
OK finally got this sorted guys, thanks for all the help and effort made by everyone above who took the time to look into this for me.
Had to surrender to this in the end and send it into the dealers.
Below firstly is the correct code followed by all the numbers you and others suggested.
Also attached is a new full scan, would be great to get a breakdown of this for the future.
The first part had been suggested a few times previously....
130224DB817100B7
(is this chassis encryption?)
The correct coding is
130224DB817100B7C82624E281D400921000
110224DB817100B7882624E281D400420000
110224DB817100B7882624E281D400421000
110224DB817100B7882624E281D400421300
110224DB817000B8882924E381D300521300
110224DB817400B7882D24E381D500521300
110228DB217200B8882514EA84D300501700
110224DB817500B6882624E681D100521300
110228DB216E00B5882D14EB84D900401700
110224DB817100B7882624E281D400521000
130224DB817000BAC82D24EB81D300921000
210224E3417100BB842524E882D600521300
210228E3417500BB842914E582D800521300
210248E3417002B5842D12E582D940411700
210228E3416D00B2842714E982D100521300
210228E3416D00B2842614E682D800521300
210224E3216E00B2842E24E284D900401300
210224E3416D00B5842A24EA82D400521300
210228E3426D00B9842714E842D600421300
210224E3216E00B6842E24E684D300501100
Tuesday,06,September,2016,14:53:38:12016
VIN: VSSZZZ6JZCR045103   Mileage: 157800km-98052miles
   Revision: --------
   Coding: 130224DB817100B7C82624E281D400921000
   Shop #: WSC 48349 001 1048576
                    Reset counter: 52
                    Mileage: 157785 km
                    Date: 2016.09.04
                    Time: 21:15:31
   Component: BCM PQ25 Re4  H50 0351
   Coding: 430000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3130
   Coding: 420000
   Component: DWA-Sensor 00  001 0103
   Coding: 003035
   Coding: 410200
   Coding: 2542C1
   Coding: 11211
   Shop #: WSC 06402
   Coding: 0000001
   Coding: 0501020002
   Coding: 0303185A
End-------------------------(Elapsed Time: 02:39)--------------------------
Regards
Dutchie
C?ID=125479
Yes, the vin is part of the long coding. Thanks for feedback :).
