Reported Adapation Channels Missing in 16.8
Andy
Sector 7G
HC424490
We have gotten several reports from users of certain Adaptation channels showing a stored value of "ERROR: Channel Not Available" in 09-Cent.Elect. in MQB models using Release 16.8. I have been trying to reproduce this but have so far been able to read these two channels with every version of VCDS, every interface, and all three of the MQB vehicles I have access to. :confused:
Anyway, this thread can be a place to keep testing results all in one place.
Here are two of the channels that were reported as not working by two different users:
UDS Adaptation Channel: IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen
UDS Adaptation Channel: IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus
ref: FS#1175
Andy
Sector 7G
HC424490
First, here's a Micro-CAN with a Dell E5530 running W7-64 on my 2015 GTI:
Monday,22,August,2016,08:50:44:53578
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 3VW5T7AU6FM007769   License Plate: UC-1574
UDS Adaptation Channel: (2)-Turn signal control-Komfortblinken Blinkzyklen
Stored value 4
UDS Adaptation Channel: (24)-Access control 2-Funk Spiegelanklappung Modus
Stored value by convenience operation via remote control key
versus:
Monday,22,August,2016,08:52:54:53578
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: 3VW5T7AU6FM007769   License Plate: 16804-UC
Stored value 4
Andy
Sector 7G
HC424490
Next a HEX-NET with 16.8.0.3 via USB on my Dell E5530 W7-64 on a 2016 Golf R:
Monday,22,August,2016,13:26:55:58389
VCDS Version: 16.8.0.3 (x64)  HEX-NET CB: 0.4323.4
VIN: WVWUF7AU1GW196354   License Plate: HN-16-8-0-3
Stored value 3
Andy
Sector 7G
HC424490
Next a HEX-NET with 16.8.0.3 via USB on my Dell E5530 W7-64 on a 2015 Audi A3 convertible:
Monday,22,August,2016,17:47:13:58389
VIN: WAU3FLFF2F1131312   License Plate: HN-16-8-0-3
Stored value 3
Stored value by look command via remote control key
Andy
Sector 7G
HC424490
Maybe the PC is too fast? So here's a netbook that seems to be too slow to run Windows 10 reliably yet in the interests of science has had it installed. Asus 1015PX with Intel® Atom™ N455/N570 Processor born with W7 Starter, now running W10-64.
Agonizingly slow PC on GTI:
Tuesday,23,August,2016,07:30:34:58389
VIN: 3VW5T7AU6FM007769   License Plate: GTI-SLOW-PC
Mileage: 3982km-2474mi   Repair Order:
Stored value 4
Andy
Sector 7G
HC424490
Agonizingly slow PC on Golf R:
Tuesday,23,August,2016,07:20:00:58389
VIN: WVWUF7AU1GW196354   License Plate: R-SLOW-PC
Stored value 3
Andy
Sector 7G
HC424490
Agonizingly slow PC on Audi A3:
Tuesday,23,August,2016,07:40:48:58389
VIN: WAU3FLFF2F1131312   License Plate: A3-SLOW-PC
Stored value 3
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Take a look at those reports, do you see a pattern of control module versions? i.e. differences between MY 2015, MY 2016 and MY 2017?
Andy
Sector 7G
HC424490
C?ID=211952 sent a photo of a screen with UDS Adaptation Channel: IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus showing a stored value of "ERROR: Channel Not Available", his 09 info from a 2016 Seat Leon FR SE is:
Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
Serial number: 01061527801709
Coding: 0B000A42424102FB0BA44000B10403281000000000000000000000000000
Shop #: WSC 00049 770 00125
ROD: EV_BCMBOSCH_SE37.rod
VCID: 0937750EA857450AF7-805C
Andy
Sector 7G
HC424490
C?ID=285257 sent a photo of a screen with UDS Adaptation Channel: IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus showing a stored value of "ERROR: Channel Not Available", his 09 info from a 2016 Seat Leon SC Cupra LE is:
Serial number: 01061525803254
Coding: 08101A42C20102F34B644000400403281000000000000000000000000000
Shop #: WSC 00049 770 00197
VCID: 091925B0A8B1120BD5-805C
Yanping
If the ECU truly responds "ERROR: Channel Not Available" for specified ADP Request, then we need to check the ROD data..
DeeCee
C?ID=139409
Skoda Superb MY17 also has similar problems with "ERROR: Channel Not Available" in 09-Cent.Elect
I have the problem with the following two channels...
IDE04926-ENG115656-Comfort illumination Coming Home Leuchten
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
Have also tried to select Adaptations channels which were filtered by "Daytime"
This displays about 10 channels, all of which show "ERROR: Channel Not Available" when selected.
Address 09 noted below. The first is mine and the second is from Gizmo's car... from Reference Scans and Maps of Non-Broken Cars Forum.
Gizmo has also tried and tested the two channels I am trying to change.
UK MY17 Škoda Superb L&K 190 TDI DSG (My car)
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001613001662
Shop #: WSC 33361 790 00076
ROD: EV_BCMBOSCH_SK48.rod
VCID: 7F07FB6EE6E166BAD9-802A
UK MY16 Škoda Superb L&K 190 TDI DSG (Gizmo's car)
Serial number: 01061528007986
Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
Shop #: WSC 33361 790 00063
VCID: 095A5466A856D974F8-805C
You will see the coding for my car shows all zero's, is this normal ?
Ross Tech has been informed and a debug file supplied together with an Autoscan.
