Problems with Micro-CAN after update to VCDS 16.8.0.x
FrA1l3
Spain
C?ID=66925
Hello guys,
After opened the thread, I read this http://forums.ross-tech.com/showthread.php?7147-Updated-to-Release-16-8-and-Having-Trouble-Read-This-Thread but nothing works on my case.
My data:
Audi A3 8V 1.8TFSI 2016 - Chassis Type: 8V (5Q0)
Micro-CAN, with firmware updated
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
Laptop: Windows 10 (32b) in both autoscans, without modifications.
Since I updated the firmware of the cable to the latest version as requested by the VCDS, now I have many problems to work with it.
Before the upgrade, I accessed perfectly all switchboards of my car, now I'm going to copy the last log I've done for that seek.
In addition it takes much longer to scan each component and only in the list of switchboards autoscan takes 1 minute or more, when before came almost instantly.
I tryed to reinstall several times VCDS and deleted the usb drivers, but nothing changed.
If you need more info, please feel free to ask me, thanks in advance!
First, autoscan when I buyed the car in January 2016, perfect communication:
Friday,08,January,2016,13:33:47:65093
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WAUZZZ8V5GAxxxxxx   License Plate: xxxxxx
Mileage: 60km-37mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V5GAxxxxxx   Mileage: 60km-37miles
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1900122424010B2000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
   ROD: EV_ECM18TFS0208V0906264H_AU37.rod
   VCID: 41A78D1ED0778F363E-8014
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63205000001966
   Coding: 12F16AA234292A6E037F060541C82948562C54C0608294F5024100788408
   VCID: 79D725FEF82717F636-802C
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000798795
   Coding: 03000014000000011000000000001100
   VCID: 3245D2D265D124AEB7-8066
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061532900399
   Coding: 04140C42C24106FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 0937553EA8C7077626-805C
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151031  043 0580
   Serial number:         151114203816
   Coding: 0A47F7
   Slave 2:
   Serial number: 60984252
   Coding: 00006C
   Slave 3:
   Serial number: 02 09 2015  00001152
   Serial number: 000000000ZY15285372G
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000034048878
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000NG8CN00000
   Coding: 901E00
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R19FF8G
   Coding: 98CCC0000C0000005C5400CA004800000065
   VCID: 4BBBAF36E23B5566D4-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 357670000001CC19B71$
   Subsystem 2 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 358670000005CC19B711
   Subsystem 3 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3516502C51DCBE14A34Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3526502AD1DBD610E21M
   Subsystem 5 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3556502AB1D25F0552FO
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502A11D3F97211CE
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502AD1D3F973E10T
   Subsystem 8 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C11D73C637355
   Part No SW: 8V0 953 521 EH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 22111504400195
   Coding: A408
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0429440A8FE55A1E55-8050
   Part No SW: 8V0 920 871 R    HW: 8V0 920 871 R
   Component: KOMBI         H03 6423
   Coding: 07A409002B8000080500A8001000000000000000
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004211358
   Coding: 030100043F085A005B000248080B00000001010000000000000000000000
   ROD: EV_GatewLear.rod
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 13 11 2015  B0038624
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001511251892
   Serial number: 300915BIT20366
   Coding: 001C8A205C00040000001002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 43AB8716CA6B9D262C-8016
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 44A9840ACF659A1E15-8010
   Serial number: 081015BJ708753
   Coding: 001C82205E00040000001002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 42A58212D571942E27-8016
   Component: AFS-ECU       H01 0110
   Coding: 019A00002B200200
   VCID: 3FA38BE6A683F9C648-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7050
   Coding: E00100
   Part No SW: 8V0 035 864 C    HW: 8V0 035 864 B
   Component: MU-S-N-ER     042 0461
   Serial number: A3F01911150752
   Coding: 01730301FF00000021110001000A00032F0001040100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_AU37.rod
   VCID: 3B5BFFF6B29BE5E664-806E
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30EPHG
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000010091500040278
End-------------------------(Elapsed Time: 02:52)--------------------------
Now the last log from today, August 2016, incorrect communication:
Friday,19,August,2016,08:57:04:65093
Mileage: 15573km-9676mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V5GAxxxxxx   Mileage: 15573km-9676miles
Address 01: Engine
   VCID: 79D725FEF827178AE7-802C
   VCID: 3245D2D265D124D266-8066
   Serial number: 9688CAD7000000000001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 0937553EA8C7070AF7-805C
   Coding: 0A47F7
   Coding: 02006C
   Sun Roof:
   Coding: 901E00
Address 15: Airbags
   Coding: 07AD09002B8000080500AE041000000000000000
   VCID: 4BBBAF36E23B551A05-801E
   VCID: 43AB8716CA6B9D5AFD-8016
Address BB: Door Rear Drv
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 271015BJ80992A
   Coding: 000C82204000040000001002
   VCID: 45AF990EC45FA36AD3-8010
End-------------------------(Elapsed Time: 02:15)--------------------------
Same car, same Micro-CAN, same laptop (without any modification between autoscans)
Is my Micro-CAN damaged during update the firmware?
FrA1l3
Spain
C?ID=66925
What brand/model/speed/OS is your PC. Have you gone through this thread?
http://forums.ross-tech.com/showthr...ease-16-8-and-Having-Trouble-Read-This-Thread
Yes, I read this thread after publish here and I tryed all the solutions proposal in it.
Mi PC is Asus Eee PC 1008HA Seashell, Intel Atom N280@1.66Ghz, 2Gb of RAM. The actual OS is Windows 10 32 bits.
and I buyed and used the Micro-CAN since 2008, with the same laptop without any problem until now. I started with vagcom 805 and I know something about using the VAGCOM.
thank you in advance for your support
Andy
Sector 7G
HC424490
Do you have any other PCs you can try using even on a temporary basis? We have gotten at least one other report of an older, slower PC that technically meets our minimum specs, but runs into difficulty when it's forced to load thousands of adaptation channels in the newest cars, etc.
FrA1l3
Spain
C?ID=66925
Yes, I can try other laptop more newer than this. Thank you for your time, I will test it and post the results. :thumbs:
FrA1l3
Spain
C?ID=66925
Finally I tryed the same laptop but downgrade it to Windows7, and all the problems has gone.
I think there is any incompatibility between the hardware and Windows10.
thank you for your support, regards.
Between Micro-CAN and Windows 10? No, I don't think so.
But a 2009 (7 year old!) Atom CPU powered computer, Windows 10, and the current version of VCDS might simply not play nicely together.
FrA1l3
Spain
C?ID=66925
oh if forgiveness, when I said "hardware" I mean the laptop, not the cable :thumbs:
