Gen4 Auto mirror folding
kamold
Australia
C?ID=241363
Hi folks,
I am trying to enable auto mirror folding in some Gen4 door controllers according to these instructions:
http://forums.vwvortex.com/showthre...de-mirrors-DIY-tutorial-(nice-coding-feature)
When I try to change the adaptation channel for System parameter 0, byte 8 from 90 to 95, I get an error from VCDS:
'Must enter 16 decimal bytes, separated by space'
So I read all bytes 0-15 for this 'system parameter 0' channels and then changed only byte 8, then try and modify byte 0 but get the same error (I've entered all 16 bytes separated by a space between each one).
Has anyone done this and knows the trick to modifying these bytes in the door controller? In the post above people seem to be able to just modify one hex byte at a time
This is the vehicle in question:
Monday,25,July,2016,11:38:44:02396
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
VIN: WVWZZZ3CZA   License Plate:
Mileage: 184840km-114854mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 42 44 46 47 52 53
          55 56 62 65 69 72
VIN: WVWZZZ3CZA  Mileage: 184840km-114854miles
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 FS    HW: 03H 906 032 AB
   Component: CC3.6-FSI-EU5   G   4855
   Revision: 5GH07---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 00000
   VCID: 78F41A430BDA1783E1-802C
   Part No SW: 02E 300 012 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2102
   Revision:    51112    Serial number: 00001001090081
   VCID: 19323FC7D090EE8B3E-804C
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000104024329
   Coding: 0001443
   VCID: 62C0582BBD46ED53AF-8036
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 05311 115 00000
   VCID: 7EF80C5BE1FE29B3AB-802A
   Revision: 00H54000    Serial number: 00000003624609
   Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 336EED6F523C34DB14-8066
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 150110 022  0612
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     260110 054  0402
   Coding: 00209133
   Shop #: WSC 05124
                    Fault Status: 01101100
                    Reset counter: 114
                    Mileage: 161670 km
                    Voltage: 12.15 V
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08791001517523
   Coding: 110102
   Shop #: WSC 05314 000 00000
   VCID: 3260E86B6D263DD31F-8066
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__01C VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P1BTEFR
   Coding: 0012611
   VCID: 4280B8AB1D868D538F-8016
   Subsystem 1 - Serial number: 6332MTS615583179
   Subsystem 2 - Serial number: 6342MTS641960210
   Subsystem 3 - Serial number: 6351HTS61EC386KJ
   Subsystem 4 - Serial number: 6361HTS6J0U449KJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100122200638
   Coding: 8990270002
   ASAM Dataset: EV_VW360SteerWheelUDS A03002
   VCID: 6BDE350F828CAC1B1C-803E
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 872 J    HW: 3C0 920 872 J
   Component: KOMBI         H03 0305
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 2C5CF61347026B2355-8078
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P1012605FC
   Coding: FDA3FF47100212001003
   VCID: 2F66E11FBE14103B70-807A
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   VCID: 448CBEB307928363BD-8010
   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   VCID: 75EA13771CC86AEBFA-8020
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 00101110
                    Reset counter: 120
                    Mileage: 183560 km
                    Date: 2010.12.03
                    Time: 20:13:27
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667766015
   VCID: 2648043B51EE517383-8072
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0306
   Revision: 12101005    Serial number: 0000347098
   Coding: 0013B7
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 2648043B59EE517383-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0402
   Serial number: 00000001231544
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 143    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3162E767A82006CB66-8064
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 052 0412
   Coding: 00910A0001860E76300494157008DFCE105801
   Subsystem 1 - Part No: 1K8 951 605
   Component: LIN BACKUP HORN H09 9002
   Component: Neigungssensor  004 0611
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 137
                    Mileage: 184312 km
                    Date: 2010.12.10
                    Time: 19:15:02
Address 47: Sound System (R12)       Labels: None
   Part No HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198834515
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 55AA73F734080AEBDA-8000
   Part No SW: 3C0 959 702 A    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0306
   Revision: 14101005    Serial number: 0000278597
   Coding: 0013B6
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 2756093F5EE4487BB8-8072
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0402
   Serial number: 00000001250986
   Coding: 000290
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000142743
   Coding: 0000057
   VCID: 2C5CF6138F026B2355-8078
   Component: AFS-Steuergeraet    0142
   Coding: 2344385
   VCID: 346CEE73573233E30D-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3003905
   Coding: 0101000001
   VCID: 62C0582B7D46ED53AF-8036
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 150
                    Mileage: 184737 km
                    Date: 2010.12.15
                    Time: 20:59:08
   Component:    RDK              0453
   Coding: 0161211
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000124332086
   Coding: 4100000100000000
   VCID: 3064E263632A0FC369-8064
End-------------------------(Elapsed Time: 03:07)--------------------------
kamold
Australia
C?ID=241363
Ok I've found that the reason for the error message whilst trying to modify that adaptation value was just a trailing space in the value...thought I'd checked that before...
Anyway, I've now tried the auto fold trick on a B7 with Gen4 controllers with the same non-result.
My feeling is that this is due to us driving on the correct side of the road ;)
I checked through the adaptation map for the passenger door controller and changed the two channels that I found with values of 90 to 95 one at a time, but still no fob folding joy.
Autoscan is below.
I have the full adaptation channel maps from passenger and driver door controllers also if anyone might be able to make any sense of them..
I suppose I could also just try setting both door controllers to LHD and then see if it makes any difference...anyone know what outcome or behavior this would have on the vehicle?
Monday,12,September,2016,14:54:46:02396
VCDS Version: 16.8.1.1
Data version: 20160902 DS256
Workshop Code: 123 12345 000000
VIN: WVWZZZ3CZFE068048   License Plate: JAY_B7
Mileage: 12830km-7972mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 2E 36 37 3C 42 44 46
          4C 4F 52 53 55 56 61 62 6C 6D 72 77 A5
VIN: WVWZZZ3CZFE068048   Mileage: 12830km-7972miles
Address 01: Engine (J623-CFGC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RF    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 4779
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 001D0032046701080000
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_ECM20TDI01103L906018RF 003003
   ROD: EV_ECM20TDI01103L906018RE.rod
   VCID: 7F06F15FE6F420BAD1-802A
   Part No SW: 02E 300 016 H    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4012
   Revision: 05653104    Serial number: 00001409122578
   Shop #: WSC 05311 000 00001
   VCID: 19323FC7D090EE8A4F-804C
   Part No SW: 3AA 614 109 BS    HW: 3AA 614 109 BS
   Component: J104   C2 450M VE7B 0061
   Revision: --H07---    Serial number: 00000008457472
   Coding: 0909073
   VCID: 7F06F15F2EF420BAD1-802A
   Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
   Component: Climatronic   H05 0607
   Revision: 00001K02
   Coding: 061401A003
   VCID: 000472A39B0A5F42A8-8054
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0475
   Revision: BD422001
   Coding: 0008000000000000049800805400297423D54B88626D8560E480C7240041
   VCID: 4992AF87E0B05E0A3F-801C
   Subsystem 1 - Part No: 3AC 955 119
   Component: Wischer 14071  26  0612
   Coding: 00B795
   Component: RLS 250914 05  54  0403
   Coding: 0230ED
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56231413502614
   Coding: 34930E
   ASAM Dataset: EV_EPHVA2C000000000 002014
   ROD: EV_EPHVA2C000000000_VW36.rod
   VCID: 4B9E958FE2CC4C1A0D-801E
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000643111
   Coding: 0010000
   VCID: 3874DA434B5AD78250-806C
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__105 VW10 HI   2418
   Revision: 29020000    Serial number: 003N5PJCCT98
   Coding: 0012341
   VCID: 000472A3530A5F42A8-8054
   Subsystem 1 - Serial number: 6332MTS621282344
   Subsystem 2 - Serial number: 6342MTS621012344
   Subsystem 3 - Serial number: 6351HTS6UAA36DKJ
   Subsystem 4 - Serial number: 6361HTS61U0V5DKJ
   Part No SW: 3C9 953 501 CT    HW: 5K0 953 569 AS
   Revision: FF010042    Serial number: 20140910201654
   Coding: 399AA50000
   VCID: 7DFA0B57ECF832AAC3-8028
   Component: E221__MFL-TK6  H07 0023
   Coding: E30000
   Part No SW: 3AA 920 871 D    HW: 3AA 920 871 D
   Component: KOMBI         H03 0905
   Coding: 151F01
   Shop #: WSC 05314 115 00001
   VCID: 346CEE739F3233E27C-8060
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1653
   Revision:   H56       Serial number: 210914F1002936
   Coding: 462007
   Shop #: WSC 05314 000 00001
   VCID: 010277A79800564AA7-8054
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 4688A4BB31AEB172D2-8012
   Part No SW: 3AA 959 433 E    HW: 3AA 959 433 E
   Component:    IMMO         048 0407
   Revision: 00048000    Serial number: VWZCZ000000000
   VCID: 3B7EC54F7A6CFC9ABD-806E
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3101
   Revision: 00H05000
   Coding: 000039
   Shop #: WSC 40022 666 40022
   VCID: 3776D97F8644D8FA59-8062
   Part No SW: 1T0 035 680 T    HW: 1T0 035 680 T
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7P7270003
   Coding: 04000402040000A00011
   VCID: 3F86B15FAE74E0BA91-806A
   Subsystem 1 - Part No: 7L6 919 859 G
   Component: AUNZ V7  8035
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0030
   Revision: 00H03000    Serial number: 6PZ 010 316-09
   Coding: 0001173
   VCID: 3A70C04B7556C592A6-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J0770_SWA_Slave_H03 0030
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F03.09.1400H03000AMS15538ÿ
   Subsystem 4 - Serial number: S15538ÿ
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0009018487
   Coding: 0217B7
   Shop #: WSC 05311 115 00001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356AD37794482AEA4B-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  005 0503
   Serial number: 00000004144437
   Coding: 010690
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 197    3501
   Revision: 00H22000
   VCID: 3972DF477050CE8AAF-806C
   Component:    KSG PQ47 ELV 048 0700
   Coding: 02900A80D2830E76340494157C08DF0B005800
   Shop #: WSC 12345 123 00000
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1653
   Coding: 00000008
   VCID: 6FE6211FBE94503A41-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0008998101
   Coding: 0217B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3668D47B894E21F242-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  005 0503
   Serial number: 00000004146934
   Coding: 010690
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000285818
   Coding: 0022167
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 029E00000B000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 3776D97F8E44D8FA59-8062
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 230000
   Component: Batt.regelung H56 1653
   Coding: 330F1859
   VCID: 71E22767A8A046CA57-8024
   Component: J367-BDM  H07 0180
   Serial number: 41268F29351491849220
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525PA8-J481885
   Coding: 0020007
   VCID: 68D44A035B7A870200-803C
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 3AF 827 383 A    HW: 3AF 827 383 A
   Component: J605  HECKDECKEL    0860
   Revision: 00H52001
   Subsystem 1 - Part No: 3AF 827 384 A
   Component: J756  HECKDECKEL    0860
   Subsystem 2 - Serial number: 1400H52001001C0183ÿ
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 D    HW: 5N0 035 729 D
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666674608
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
   VCID: 3162E767602006CA17-8064
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0195832390
   Coding: 010000000102020D0200000000010100
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 3972DF47B850CE8AAF-806C
End-------------------------(Elapsed Time: 03:55)--------------------------
Driver's door adaptation map:
;SW:3AA-959-701-A   HW:3C0-959-793-C ---  Door Elect, Driver
;Component:TUER-SG FT    002 0534, Coding:0217B7
;EV_TSGFPQ35BRFVW46X,A04001,EV_TSGFPQ35BRFVW46X.rod
;Monday,12,September,2016,14:59:46:02396
;VCDS Version: Release 16.8.1  Data version: 20160902 DS256
;VCID: 356AD37794482AEA4B-8060
ENG106031-ENG103506-ECU ID2 PartNumber HW SW-Byte 1,3
ENG106031-ENG99970-ECU ID2 PartNumber HW SW-Byte 10,
ENG106031-ENG103845-ECU ID2 PartNumber HW SW-Byte 11,
ENG106031-ENG103008-ECU ID2 PartNumber HW SW-Byte 12,
ENG106031-ENG100040-ECU ID2 PartNumber HW SW-Byte 13,
ENG106031-ENG101630-ECU ID2 PartNumber HW SW-Byte 14,
ENG106031-ENG99906-ECU ID2 PartNumber HW SW-Byte 15,
ENG106031-ENG99415-ECU ID2 PartNumber HW SW-Byte 16,1
ENG106031-ENG101004-ECU ID2 PartNumber HW SW-Byte 17,6
ENG106031-ENG100194-ECU ID2 PartNumber HW SW-Byte 18,2
ENG106031-ENG102302-ECU ID2 PartNumber HW SW-Byte 19,
ENG106031-ENG100432-ECU ID2 PartNumber HW SW-Byte 2,A
ENG106031-ENG102337-ECU ID2 PartNumber HW SW-Byte 20,
ENG106031-ENG100802-ECU ID2 PartNumber HW SW-Byte 21,
ENG106031-ENG101604-ECU ID2 PartNumber HW SW-Byte 22,
ENG106031-ENG103171-ECU ID2 PartNumber HW SW-Byte 3,A
ENG106031-ENG99780-ECU ID2 PartNumber HW SW-Byte 4,9
ENG106031-ENG101635-ECU ID2 PartNumber HW SW-Byte 5,5
ENG106031-ENG100290-ECU ID2 PartNumber HW SW-Byte 6,9
ENG106031-ENG101242-ECU ID2 PartNumber HW SW-Byte 7,7
ENG106031-ENG101974-ECU ID2 PartNumber HW SW-Byte 8,9
ENG106031-ENG100834-ECU ID2 PartNumber HW SW-Byte 9,4
ENG106032-ENG103506-ECU ID2 PartNumber VW SW ID-Byte 1,3
ENG106032-ENG99970-ECU ID2 PartNumber VW SW ID-Byte 10,A
ENG106032-ENG103845-ECU ID2 PartNumber VW SW ID-Byte 11,
ENG106032-ENG103008-ECU ID2 PartNumber VW SW ID-Byte 12,R
ENG106032-ENG100040-ECU ID2 PartNumber VW SW ID-Byte 13,1
ENG106032-ENG101630-ECU ID2 PartNumber VW SW ID-Byte 14,6
ENG106032-ENG99906-ECU ID2 PartNumber VW SW ID-Byte 15,1
ENG106032-ENG99415-ECU ID2 PartNumber VW SW ID-Byte 16,°
ENG106032-ENG101004-ECU ID2 PartNumber VW SW ID-Byte 17,5
ENG106032-ENG100194-ECU ID2 PartNumber VW SW ID-Byte 18,0
ENG106032-ENG102302-ECU ID2 PartNumber VW SW ID-Byte 19,3
ENG106032-ENG100432-ECU ID2 PartNumber VW SW ID-Byte 2,A
ENG106032-ENG102337-ECU ID2 PartNumber VW SW ID-Byte 20,9
ENG106032-ENG103171-ECU ID2 PartNumber VW SW ID-Byte 3,A
ENG106032-ENG99780-ECU ID2 PartNumber VW SW ID-Byte 4,9
ENG106032-ENG101635-ECU ID2 PartNumber VW SW ID-Byte 5,5
ENG106032-ENG100290-ECU ID2 PartNumber VW SW ID-Byte 6,9
ENG106032-ENG101242-ECU ID2 PartNumber VW SW ID-Byte 7,7
ENG106032-ENG101974-ECU ID2 PartNumber VW SW ID-Byte 8,0
ENG106032-ENG100834-ECU ID2 PartNumber VW SW ID-Byte 9,4
ENG106033-ENG103506-ECU ID3 HW ID VW-Byte 1,0
ENG106033-ENG100432-ECU ID3 HW ID VW-Byte 2,0
ENG106033-ENG103171-ECU ID3 HW ID VW-Byte 3,5
ENG106034-ENG103506-ECU ID4 VW Tester ID-Byte 1,20
ENG106034-ENG99970-ECU ID4 VW Tester ID-Byte 10,20
ENG106034-ENG100432-ECU ID4 VW Tester ID-Byte 2,20
ENG106034-ENG103171-ECU ID4 VW Tester ID-Byte 3,20
ENG106034-ENG99780-ECU ID4 VW Tester ID-Byte 4,20
ENG106034-ENG101635-ECU ID4 VW Tester ID-Byte 5,20
ENG106034-ENG100290-ECU ID4 VW Tester ID-Byte 6,20
ENG106034-ENG101242-ECU ID4 VW Tester ID-Byte 7,20
ENG106034-ENG101974-ECU ID4 VW Tester ID-Byte 8,20
ENG106034-ENG100834-ECU ID4 VW Tester ID-Byte 9,20
ENG108997-ENG103506-Software Version Number-Byte 1,°
ENG108997-ENG100432-Software Version Number-Byte 2,5
ENG108997-ENG103171-Software Version Number-Byte 3,0
ENG108997-ENG99780-Software Version Number-Byte 4,3
ENG108998-ENG103506-Software Version Number(Front)-Byte 1,0
ENG108998-ENG100432-Software Version Number(Front)-Byte 2,5
ENG108998-ENG103171-Software Version Number(Front)-Byte 3,3
ENG108998-ENG99780-Software Version Number(Front)-Byte 4,4
ENG109228-ENG103506-System Data Part 1 (rear)-Byte 1,00
ENG109228-ENG100432-System Data Part 1 (rear)-Byte 2,04
ENG109228-ENG103171-System Data Part 1 (rear)-Byte 3,01
ENG109228-ENG99780-System Data Part 1 (rear)-Byte 4,9D
ENG109228-ENG101635-System Data Part 1 (rear)-Byte 5,AB
ENG109228-ENG100290-System Data Part 1 (rear)-Byte 6,00
ENG109230-ENG99970-System Data Part 10 (rear)-Byte 10,38
ENG109230-ENG103845-System Data Part 10 (rear)-Byte 11,39
ENG109230-ENG100834-System Data Part 10 (rear)-Byte 9,31
ENG109230-ENG100703-System Data Part 10 (rear)-Bytes 1-8,31 30 31 30 30 30 31 31
ENG109232-System Data Part 11 (rear),00
ENG109234-System Data Part 12 (rear),3F
ENG109236-ENG103506-System Data Part 13 (rear)-Byte 1,28
ENG109236-ENG100432-System Data Part 13 (rear)-Byte 2,00
ENG109236-ENG103171-System Data Part 13 (rear)-Byte 3,00
ENG111562-System Data Part 14 (rear),56
ENG109238-ENG103506-System Data Part 2 (rear)-Byte 1,00
ENG109238-ENG100432-System Data Part 2 (rear)-Byte 2,00
ENG109238-ENG103171-System Data Part 2 (rear)-Byte 3,00
ENG109238-ENG99780-System Data Part 2 (rear)-Byte 4,0C
ENG109238-ENG101635-System Data Part 2 (rear)-Byte 5,01
ENG109238-ENG100290-System Data Part 2 (rear)-Byte 6,21
ENG109238-ENG101242-System Data Part 2 (rear)-Byte 7,00
ENG109238-ENG101974-System Data Part 2 (rear)-Byte 8,00
ENG109240-ENG100802-System Data Part 3 (rear)-Byte 21,00
ENG109240-ENG101604-System Data Part 3 (rear)-Byte 22,00
ENG109240-ENG99579-System Data Part 3 (rear)-Byte 23,00
ENG109240-ENG103695-System Data Part 3 (rear)-Byte 24,00
ENG109240-ENG100496-System Data Part 3 (rear)-Bytes 1-20,00 00 02 00 00 00 00 02 00 00 02 00 07 00 00 01 00 00 00 00
ENG109242-ENG100802-System Data Part 4 (rear)-Byte 21,00
ENG109242-ENG101604-System Data Part 4 (rear)-Byte 22,00
ENG109242-ENG99579-System Data Part 4 (rear)-Byte 23,02
ENG109242-ENG103695-System Data Part 4 (rear)-Byte 24,00
ENG109242-ENG100496-System Data Part 4 (rear)-Bytes 1-20,00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 07 00 00 01 00
ENG109244-ENG103506-System Data Part 5 (rear)-Byte 1,00
ENG109244-ENG99970-System Data Part 5 (rear)-Byte 10,1F
ENG109244-ENG103845-System Data Part 5 (rear)-Byte 11,25
ENG109244-ENG103008-System Data Part 5 (rear)-Byte 12,28
ENG109244-ENG100040-System Data Part 5 (rear)-Byte 13,00
ENG109244-ENG101630-System Data Part 5 (rear)-Byte 14,00
ENG109244-ENG100432-System Data Part 5 (rear)-Byte 2,00
ENG109244-ENG103171-System Data Part 5 (rear)-Byte 3,00
ENG109244-ENG99780-System Data Part 5 (rear)-Byte 4,01
ENG109244-ENG101635-System Data Part 5 (rear)-Byte 5,00
ENG109244-ENG100290-System Data Part 5 (rear)-Byte 6,02
ENG109244-ENG101242-System Data Part 5 (rear)-Byte 7,76
ENG109244-ENG101974-System Data Part 5 (rear)-Byte 8,00
ENG109244-ENG100834-System Data Part 5 (rear)-Byte 9,00
ENG109246-ENG103506-System Data Part 6 (rear)-Byte 1,1C
ENG109246-ENG100432-System Data Part 6 (rear)-Byte 2,10
ENG109246-ENG103171-System Data Part 6 (rear)-Byte 3,29
ENG109246-ENG99780-System Data Part 6 (rear)-Byte 4,C1
ENG109248-ENG100703-System Data Part 7 (rear)-Bytes 1-8,14 09 23 11 89 C1 29 36
ENG109248-ENG103836-System Data Part 7 (rear)-Bytes 9-16,01 01 FE 00 00 00 00 00
ENG109250-ENG100703-System Data Part 8 (rear)-Bytes 1-8,05 4E 45 61 93 64 05 25
ENG109250-ENG103836-System Data Part 8 (rear)-Bytes 9-16,80 01 03 00 00 00 00 00
ENG109252-ENG99489-System Data Part 9 (rear)-Byte 25,31
ENG109252-ENG102774-System Data Part 9 (rear)-Byte 26,34
ENG109252-ENG99230-System Data Part 9 (rear)-Byte 27,34
ENG109252-ENG100061-System Data Part 9 (rear)-Byte 28,31
ENG109252-ENG99769-System Data Part 9 (rear)-Bytes 1-24,30 30 30 30 30 30 30 34 31 34 34 34 33 37 42 52 46 30 30 31 32 33 30 39
ENG109253-ENG104208-System Data Part1-Byte 41,00
ENG109253-ENG103472-System Data Part1-Byte 42,00
ENG109253-ENG100442-System Data Part1-Byte 43,00
ENG109253-ENG100609-System Data Part1-Byte 44,00
ENG109253-ENG100195-System Data Part1-Byte 45,00
ENG109253-ENG99626-System Data Part1-Byte 46,00
ENG109253-ENG99965-System Data Part1-Byte 47,8E
ENG109253-ENG101803-System Data Part1-Byte 48,12
ENG109253-ENG103888-System Data Part1-Byte 49,12
ENG109253-ENG99281-System Data Part1-Byte 50,12
ENG109253-ENG102742-System Data Part1-Byte 51,00
ENG109253-ENG103526-System Data Part1-Byte 52,01
ENG109253-ENG99116-System Data Part1-Byte 53,01
ENG109253-ENG100829-System Data Part1-Byte 54,00
ENG109253-ENG101474-System Data Part1-Byte 55,00
ENG109253-ENG99580-System Data Part1-Byte 56,00
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,00
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,0C
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,06
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,14
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,01
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,03
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,09
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,27
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,20
ENG109253-ENG100544-System Data Part1-Data Bytes 1-20,DD
ENG109253-ENG100974-System Data Part1-Data Bytes 21-40,01
ENG109253-ENG100974-System Data Part1-Data Bytes 21-40,00
ENG109253-ENG100974-System Data Part1-Data Bytes 21-40,04
ENG109254-ENG100528-System Data Part2-Byte 201,20
ENG109254-ENG100921-System Data Part2-Byte 202,20
ENG109254-ENG99578-System Data Part2-Byte 203,20
ENG109254-ENG101532-System Data Part2-Byte 204,20
ENG109254-ENG103350-System Data Part2-Byte 205,20
ENG109254-ENG100576-System Data Part2-Byte 206,20
ENG109254-ENG99377-System Data Part2-Byte 207,20
ENG109254-ENG101439-System Data Part2-Byte 208,20
ENG109254-ENG100902-System Data Part2-Byte 209,20
ENG109254-ENG102196-System Data Part2-Byte 210,20
ENG109254-ENG99194-System Data Part2-Byte 211,20
ENG109254-ENG99588-System Data Part2-Byte 212,20
ENG109254-ENG100830-System Data Part2-Byte 213,20
ENG109254-ENG100170-System Data Part2-Byte 214,20
ENG109254-ENG102656-System Data Part2-Byte 215,20
ENG109254-ENG99386-System Data Part2-Byte 216,00
ENG109254-ENG101799-System Data Part2-Param to DOP,8F
ENG109254-ENG101799-System Data Part2-Param to DOP,77
ENG109254-ENG101799-System Data Part2-Param to DOP,8E
ENG109254-ENG101799-System Data Part2-Param to DOP,00
ENG109254-ENG101799-System Data Part2-Param to DOP,86
ENG109254-ENG101799-System Data Part2-Param to DOP,6E
ENG109254-ENG102681-System Data Part2-Param to DOP (1),30
ENG109254-ENG102681-System Data Part2-Param to DOP (1),34
ENG109254-ENG102681-System Data Part2-Param to DOP (1),31
ENG109254-ENG102681-System Data Part2-Param to DOP (1),33
ENG109254-ENG102681-System Data Part2-Param to DOP (1),37
ENG109254-ENG102681-System Data Part2-Param to DOP (1),00
ENG109254-ENG102681-System Data Part2-Param to DOP (1),07
ENG109254-ENG101119-System Data Part2-Param to DOP (2),07
ENG109254-ENG101119-System Data Part2-Param to DOP (2),00
ENG109254-ENG101119-System Data Part2-Param to DOP (2),01
ENG109254-ENG101119-System Data Part2-Param to DOP (2),05
ENG109254-ENG101119-System Data Part2-Param to DOP (2),04
ENG109254-ENG101119-System Data Part2-Param to DOP (2),02
ENG109254-ENG99432-System Data Part2-Param to DOP (3),07
ENG109254-ENG99432-System Data Part2-Param to DOP (3),04
ENG109254-ENG99432-System Data Part2-Param to DOP (3),01
ENG109254-ENG99432-System Data Part2-Param to DOP (3),05
ENG109254-ENG99432-System Data Part2-Param to DOP (3),00
ENG109254-ENG99432-System Data Part2-Param to DOP (3),06
ENG109254-ENG99432-System Data Part2-Param to DOP (3),03
ENG109254-ENG102423-System Data Part2-Param to DOP (4),00
ENG109254-ENG102423-System Data Part2-Param to DOP (4),07
ENG109254-ENG102423-System Data Part2-Param to DOP (4),03
ENG109254-ENG102423-System Data Part2-Param to DOP (4),02
ENG109254-ENG102423-System Data Part2-Param to DOP (4),06
ENG109254-ENG102423-System Data Part2-Param to DOP (4),01
ENG109254-ENG102423-System Data Part2-Param to DOP (4),05
ENG109254-ENG102423-System Data Part2-Param to DOP (4),20
ENG109254-ENG101060-System Data Part2-Param to DOP (5),07
ENG109254-ENG101060-System Data Part2-Param to DOP (5),00
ENG109254-ENG101060-System Data Part2-Param to DOP (5),03
ENG109254-ENG101060-System Data Part2-Param to DOP (5),02
ENG109254-ENG101060-System Data Part2-Param to DOP (5),04
ENG109254-ENG101060-System Data Part2-Param to DOP (5),06
ENG109254-ENG101060-System Data Part2-Param to DOP (5),01
ENG109254-ENG101060-System Data Part2-Param to DOP (5),05
ENG109254-ENG102712-System Data Part2-Param to DOP (6),00
ENG109255-ENG103495-System Data Part3-Byte 151,FF
ENG109255-ENG102438-System Data Part3-Byte 152,FF
ENG109255-ENG102077-System Data Part3-Byte 153,FF
ENG109255-ENG99587-System Data Part3-Byte 154,FF
ENG109255-ENG102965-System Data Part3-Byte 155,FF
ENG109255-ENG100933-System Data Part3-Byte 156,FF
ENG109255-ENG99799-System Data Part3-Byte 157,02
ENG109255-ENG103197-System Data Part3-Byte 158,02
ENG109255-ENG103117-System Data Part3-Byte 159,C0
ENG109255-ENG103963-System Data Part3-Byte 160,04
ENG109255-ENG100244-System Data Part3-Byte 161,8C
ENG109255-ENG99107-System Data Part3-Byte 162,02
ENG109255-ENG101597-System Data Part3-Byte 163,E0
ENG109255-ENG102734-System Data Part3-Byte 164,FF
ENG109255-ENG101010-System Data Part3-Byte 165,00
ENG109255-ENG104065-System Data Part3-Byte 166,00
ENG109255-ENG103283-System Data Part3-Byte 167,00
ENG109255-ENG101239-System Data Part3-Byte 168,00
ENG109255-ENG101152-System Data Part3-Byte 169,00
ENG109255-ENG103867-System Data Part3-Byte 170,00
ENG109255-ENG100945-System Data Part3-Byte 171,00
ENG109255-ENG99877-System Data Part3-Byte 172,00
ENG109255-ENG99528-System Data Part3-Byte 173,A5
ENG109255-ENG102115-System Data Part3-Byte 174,FF
ENG109255-ENG101799-System Data Part3-Param to DOP,FF
ENG109255-ENG101799-System Data Part3-Param to DOP,08
ENG109255-ENG101799-System Data Part3-Param to DOP,28
ENG109255-ENG101799-System Data Part3-Param to DOP,01
ENG109255-ENG101799-System Data Part3-Param to DOP,00
ENG109255-ENG101799-System Data Part3-Param to DOP,03
ENG109255-ENG101799-System Data Part3-Param to DOP,80
ENG109255-ENG101799-System Data Part3-Param to DOP,20
ENG109255-ENG101799-System Data Part3-Param to DOP,79
ENG109255-ENG102681-System Data Part3-Param to DOP (1),00
ENG109255-ENG102681-System Data Part3-Param to DOP (1),03
ENG109255-ENG102681-System Data Part3-Param to DOP (1),80
ENG109255-ENG102681-System Data Part3-Param to DOP (1),20
ENG109255-ENG102681-System Data Part3-Param to DOP (1),79
ENG109255-ENG102681-System Data Part3-Param to DOP (1),FF
ENG109255-ENG102681-System Data Part3-Param to DOP (1),08
ENG109255-ENG102681-System Data Part3-Param to DOP (1),28
ENG109255-ENG102681-System Data Part3-Param to DOP (1),01
ENG109255-ENG101119-System Data Part3-Param to DOP (2),FF
ENG109255-ENG101119-System Data Part3-Param to DOP (2),08
ENG109255-ENG101119-System Data Part3-Param to DOP (2),28
ENG109255-ENG101119-System Data Part3-Param to DOP (2),01
ENG109255-ENG101119-System Data Part3-Param to DOP (2),00
ENG109255-ENG101119-System Data Part3-Param to DOP (2),03
ENG109255-ENG101119-System Data Part3-Param to DOP (2),80
ENG109255-ENG101119-System Data Part3-Param to DOP (2),20
ENG109255-ENG101119-System Data Part3-Param to DOP (2),79
ENG109255-ENG99432-System Data Part3-Param to DOP (3),FF
ENG109255-ENG102423-System Data Part3-Param to DOP (4),FF
ENG109255-ENG101060-System Data Part3-Param to DOP (5),FF
ENG109256-ENG101453-System Data Part4-Byte 61,30
ENG109256-ENG99549-System Data Part4-Byte 62,39
ENG109256-ENG102677-System Data Part4-Byte 63,30
ENG109256-ENG102277-System Data Part4-Byte 64,31
ENG109256-ENG102731-System Data Part4-Byte 65,38
ENG109256-ENG103512-System Data Part4-Byte 66,34
ENG109256-ENG101977-System Data Part4-Byte 67,38
ENG109256-ENG102320-System Data Part4-Byte 68,37
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,31
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,30
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,39
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,54
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,55
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,45
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,52
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,2D
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,53
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,47
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,20
ENG109256-ENG103513-System Data Part4-Copy (2) of Param to DOP,46
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,31
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,32
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,39
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,2E
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,30
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,38
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,34
ENG109256-ENG102415-System Data Part4-Copy of Param to DOP,36
ENG109256-ENG101799-System Data Part4-Param to DOP,14
ENG109256-ENG101799-System Data Part4-Param to DOP,08
ENG109256-ENG101799-System Data Part4-Param to DOP,29
ENG109256-ENG101799-System Data Part4-Param to DOP,10
ENG109256-ENG101799-System Data Part4-Param to DOP,69
ENG109256-ENG101799-System Data Part4-Param to DOP,91
ENG109256-ENG101799-System Data Part4-Param to DOP,84
ENG109256-ENG101799-System Data Part4-Param to DOP,32
ENG109256-ENG101799-System Data Part4-Param to DOP,01
ENG109256-ENG101799-System Data Part4-Param to DOP,00
ENG109256-ENG101799-System Data Part4-Param to DOP,42
ENG109256-ENG101799-System Data Part4-Param to DOP,52
ENG109256-ENG101799-System Data Part4-Param to DOP,46
ENG109256-ENG101799-System Data Part4-Param to DOP,2D
ENG109256-ENG101799-System Data Part4-Param to DOP,30
ENG109257-ENG101799-System Data Part5-Param to DOP,05
ENG109257-ENG101799-System Data Part5-Param to DOP,33
ENG109257-ENG101799-System Data Part5-Param to DOP,45
ENG109257-ENG101799-System Data Part5-Param to DOP,07
ENG109257-ENG101799-System Data Part5-Param to DOP,93
ENG109257-ENG101799-System Data Part5-Param to DOP,68
ENG109257-ENG101799-System Data Part5-Param to DOP,74
ENG109257-ENG101799-System Data Part5-Param to DOP,00
ENG109257-ENG101799-System Data Part5-Param to DOP,01
ENG109257-ENG101799-System Data Part5-Param to DOP,10
ENG109257-ENG101799-System Data Part5-Param to DOP,30
ENG109257-ENG101799-System Data Part5-Param to DOP,31
ENG109258-ENG100802-System Data Part6-Byte 21,FF
ENG109258-ENG101604-System Data Part6-Byte 22,FF
ENG109258-ENG99579-System Data Part6-Byte 23,FF
ENG109258-ENG103695-System Data Part6-Byte 24,FF
ENG109258-ENG99489-System Data Part6-Byte 25,FF
ENG109258-ENG102774-System Data Part6-Byte 26,FF
ENG109258-ENG99230-System Data Part6-Byte 27,FF
ENG109258-ENG100061-System Data Part6-Byte 28,FF
ENG109258-ENG100604-System Data Part6-Byte 29,FF
ENG109258-ENG103842-System Data Part6-Byte 30,FF
ENG109258-ENG99768-System Data Part6-Byte 31,FF
ENG109258-ENG100571-System Data Part6-Byte 32,FF
ENG109258-ENG101401-System Data Part6-Byte 33,00
ENG109258-ENG102991-System Data Part6-Byte 34,00
ENG109258-ENG100859-System Data Part6-Byte 35,00
ENG109258-ENG101880-System Data Part6-Byte 36,00
ENG109258-ENG103588-System Data Part6-Byte 37,00
ENG109258-ENG101128-System Data Part6-Byte 38,00
ENG109258-ENG101799-System Data Part6-Param to DOP,FF
ENG109258-ENG101799-System Data Part6-Param to DOP,FE
ENG109258-ENG101799-System Data Part6-Param to DOP,00
ENG109258-ENG101799-System Data Part6-Param to DOP,01
ENG109259-System Data Part7,00
ENG109260-System Data Part8,3F
ENG109263-ENG103506-System Parameter Part16-Byte 1,B7
ENG109263-ENG99970-System Parameter Part16-Byte 10,00
ENG109263-ENG103845-System Parameter Part16-Byte 11,00
ENG109263-ENG103008-System Parameter Part16-Byte 12,00
ENG109263-ENG100040-System Parameter Part16-Byte 13,00
ENG109263-ENG101630-System Parameter Part16-Byte 14,00
ENG109263-ENG100432-System Parameter Part16-Byte 2,17
ENG109263-ENG103171-System Parameter Part16-Byte 3,02
ENG109263-ENG99780-System Parameter Part16-Byte 4,00
ENG109263-ENG101635-System Parameter Part16-Byte 5,00
ENG109263-ENG100290-System Parameter Part16-Byte 6,08
ENG109263-ENG101242-System Parameter Part16-Byte 7,E6
ENG109263-ENG101974-System Parameter Part16-Byte 8,14
ENG109263-ENG100834-System Parameter Part16-Byte 9,BF
ENG109264-ENG101453-System Parameter Part-17-Byte 61,00
ENG109264-ENG99549-System Parameter Part-17-Byte 62,00
ENG109264-ENG102677-System Parameter Part-17-Byte 63,00
ENG109264-ENG102277-System Parameter Part-17-Byte 64,00
ENG109264-ENG102731-System Parameter Part-17-Byte 65,00
ENG109264-ENG103512-System Parameter Part-17-Byte 66,00
ENG109264-ENG101977-System Parameter Part-17-Byte 67,00
ENG109264-ENG102320-System Parameter Part-17-Byte 68,00
ENG109264-ENG100683-System Parameter Part-17-Byte 69,00
ENG109264-ENG102178-System Parameter Part-17-Byte 70,00
ENG109264-ENG103513-System Parameter Part-17-Copy (2) of Param to DOP,00
ENG109264-ENG102415-System Parameter Part-17-Copy of Param to DOP,00
ENG109264-ENG101799-System Parameter Part-17-Param to DOP,00
ENG109265-ENG103506-System Parameters Part 1 (rear)-Byte 1,7F
ENG109265-ENG100432-System Parameters Part 1 (rear)-Byte 2,BE
ENG109265-ENG103171-System Parameters Part 1 (rear)-Byte 3,0F
ENG109265-ENG99780-System Parameters Part 1 (rear)-Byte 4,34
ENG109265-ENG101635-System Parameters Part 1 (rear)-Byte 5,00
ENG109265-ENG100290-System Parameters Part 1 (rear)-Byte 6,0D
ENG109265-ENG101242-System Parameters Part 1 (rear)-Byte 7,C3
ENG109265-ENG101974-System Parameters Part 1 (rear)-Byte 8,11
ENG109266-System Parameters Part 10 (rear),00
ENG109267-ENG100802-System Parameters Part 2 (rear)-Byte 21,01
ENG109267-ENG101604-System Parameters Part 2 (rear)-Byte 22,80
ENG109267-ENG99579-System Parameters Part 2 (rear)-Byte 23,29
ENG109267-ENG103695-System Parameters Part 2 (rear)-Byte 24,44
ENG109267-ENG100496-System Parameters Part 2 (rear)-Bytes 1-20,0C 7A 0E 56 64 73 00 00 06 08 10 20 50 C8 3F 55 9B 00 5A 3F
ENG109268-ENG100802-System Parameters Part 3 (rear)-Byte 21,00
ENG109268-ENG101604-System Parameters Part 3 (rear)-Byte 22,43
ENG109268-ENG99579-System Parameters Part 3 (rear)-Byte 23,28
ENG109268-ENG103695-System Parameters Part 3 (rear)-Byte 24,19
ENG109268-ENG100496-System Parameters Part 3 (rear)-Bytes 1-20,56 3C 7C 5E 56 56 56 56 8A 92 B2 99 87 07 07 87 FB F4 65 34
ENG109269-ENG100703-System Parameters Part 4 (rear)-Bytes 1-8,07 B6 82 C1 73 23 08 27
ENG109269-ENG103836-System Parameters Part 4 (rear)-Bytes 9-16,3C 85 25 3B 0D 20 08 0C
ENG109270-ENG100703-System Parameters Part 5 (rear)-Bytes 1-8,87 51 12 1B 37 83 A4 7D
ENG109270-ENG103836-System Parameters Part 5 (rear)-Bytes 9-16,60 3F B4 48 B4 22 19 0F
ENG109271-ENG100802-System Parameters Part 6 (rear)-Byte 21,00
ENG109271-ENG101604-System Parameters Part 6 (rear)-Byte 22,00
ENG109271-ENG99579-System Parameters Part 6 (rear)-Byte 23,E6
ENG109271-ENG103695-System Parameters Part 6 (rear)-Byte 24,77
ENG109271-ENG99489-System Parameters Part 6 (rear)-Byte 25,6B
ENG109271-ENG102774-System Parameters Part 6 (rear)-Byte 26,5E
ENG109271-ENG99230-System Parameters Part 6 (rear)-Byte 27,C6
ENG109271-ENG100061-System Parameters Part 6 (rear)-Byte 28,1E
ENG109271-ENG100604-System Parameters Part 6 (rear)-Byte 29,03
ENG109271-ENG103842-System Parameters Part 6 (rear)-Byte 30,64
ENG109271-ENG99768-System Parameters Part 6 (rear)-Byte 31,83
ENG109271-ENG100571-System Parameters Part 6 (rear)-Byte 32,02
ENG109271-ENG101401-System Parameters Part 6 (rear)-Byte 33,51
ENG109271-ENG102991-System Parameters Part 6 (rear)-Byte 34,00
ENG109271-ENG100859-System Parameters Part 6 (rear)-Byte 35,1F
ENG109271-ENG101880-System Parameters Part 6 (rear)-Byte 36,7F
ENG109271-ENG103588-System Parameters Part 6 (rear)-Byte 37,FD
ENG109271-ENG101128-System Parameters Part 6 (rear)-Byte 38,00
ENG109271-ENG100496-System Parameters Part 6 (rear)-Bytes 1-20,17 1A 3D 43 71 78 BB BD 5A 83 CA D7 2C 33 6C B8 85 88 E6 F3
ENG109272-ENG101004-System Parameters Part 7 (rear)-Byte 17,05
ENG109272-ENG100194-System Parameters Part 7 (rear)-Byte 18,86
ENG109272-ENG101808-System Parameters Part 7 (rear)-Bytes 1-16,0E 46 20 20 20 0D 03 02 02 0D 0D 5A 34 32 03 22
ENG109273-ENG103506-System Parameters Part 8 (rear)-Byte 1,03
ENG109273-ENG100432-System Parameters Part 8 (rear)-Byte 2,01
ENG109273-ENG103171-System Parameters Part 8 (rear)-Byte 3,06
ENG109273-ENG99780-System Parameters Part 8 (rear)-Byte 4,90
ENG109274-ENG100496-System Parameters Part 9 (rear)-Bytes 1-20,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG109274-ENG100087-System Parameters Part 9 (rear)-Bytes 21-40,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG109279-ENG103387-System_Parameter_0-System Parameter Byte 10,07
ENG109279-ENG101332-System_Parameter_0-System Parameter Byte 11,E4
ENG109279-ENG99890-System_Parameter_0-System Parameter Byte 12,E4
ENG109279-ENG99354-System_Parameter_0-System Parameter Byte 13,62
ENG109279-ENG101672-System_Parameter_0-System Parameter Byte 14,00
ENG109279-ENG99567-System_Parameter_0-System Parameter Byte 15,28
ENG109279-ENG103987-System_Parameter_0-System Parameter Byte0,7F
ENG109279-ENG99921-System_Parameter_0-System Parameter Byte1,BE
ENG109279-ENG103298-System_Parameter_0-System Parameter Byte2,0F
ENG109279-ENG100424-System_Parameter_0-System Parameter Byte3,34
ENG109279-ENG99548-System_Parameter_0-System Parameter Byte4,00
ENG109279-ENG103950-System_Parameter_0-System Parameter Byte5,0D
ENG109279-ENG101580-System_Parameter_0-System Parameter Byte6,C3
ENG109279-ENG102804-System_Parameter_0-System Parameter Byte7,11
ENG109279-ENG99426-System_Parameter_0-System Parameter Byte8,95
ENG109279-ENG101522-System_Parameter_0-System Parameter Byte9,F2
ENG109280-ENG103387-System_Parameter_1-System Parameter Byte 10,00
ENG109280-ENG101332-System_Parameter_1-System Parameter Byte 11,00
ENG109280-ENG99890-System_Parameter_1-System Parameter Byte 12,05
ENG109280-ENG99354-System_Parameter_1-System Parameter Byte 13,08
ENG109280-ENG101672-System_Parameter_1-System Parameter Byte 14,0C
ENG109280-ENG99567-System_Parameter_1-System Parameter Byte 15,10
ENG109280-ENG103987-System_Parameter_1-System Parameter Byte0,E4
ENG109280-ENG99921-System_Parameter_1-System Parameter Byte1,00
ENG109280-ENG103298-System_Parameter_1-System Parameter Byte2,4C
ENG109280-ENG100424-System_Parameter_1-System Parameter Byte3,00
ENG109280-ENG99548-System_Parameter_1-System Parameter Byte4,0C
ENG109280-ENG103950-System_Parameter_1-System Parameter Byte5,7A
ENG109280-ENG101580-System_Parameter_1-System Parameter Byte6,0F
ENG109280-ENG102804-System_Parameter_1-System Parameter Byte7,87
ENG109280-ENG99426-System_Parameter_1-System Parameter Byte8,69
ENG109280-ENG101522-System_Parameter_1-System Parameter Byte9,9E
ENG109281-ENG103387-System_Parameter_10-System Parameter Byte 10,0E
ENG109281-ENG101332-System_Parameter_10-System Parameter Byte 11,0F
ENG109281-ENG99890-System_Parameter_10-System Parameter Byte 12,28
ENG109281-ENG99354-System_Parameter_10-System Parameter Byte 13,1E
ENG109281-ENG101672-System_Parameter_10-System Parameter Byte 14,0A
ENG109281-ENG99567-System_Parameter_10-System Parameter Byte 15,75
ENG109281-ENG103987-System_Parameter_10-System Parameter Byte0,1E
ENG109281-ENG99921-System_Parameter_10-System Parameter Byte1,28
ENG109281-ENG103298-System_Parameter_10-System Parameter Byte2,37
ENG109281-ENG100424-System_Parameter_10-System Parameter Byte3,46
ENG109281-ENG99548-System_Parameter_10-System Parameter Byte4,5A
ENG109281-ENG103950-System_Parameter_10-System Parameter Byte5,64
ENG109281-ENG101580-System_Parameter_10-System Parameter Byte6,00
ENG109281-ENG102804-System_Parameter_10-System Parameter Byte7,03
ENG109281-ENG99426-System_Parameter_10-System Parameter Byte8,07
ENG109281-ENG101522-System_Parameter_10-System Parameter Byte9,0A
ENG109282-ENG103387-System_Parameter_11-System Parameter Byte 10,28
ENG109282-ENG101332-System_Parameter_11-System Parameter Byte 11,14
ENG109282-ENG99890-System_Parameter_11-System Parameter Byte 12,00
ENG109282-ENG99354-System_Parameter_11-System Parameter Byte 13,64
ENG109282-ENG101672-System_Parameter_11-System Parameter Byte 14,02
ENG109282-ENG99567-System_Parameter_11-System Parameter Byte 15,00
ENG109282-ENG103987-System_Parameter_11-System Parameter Byte0,75
ENG109282-ENG99921-System_Parameter_11-System Parameter Byte1,DF
ENG109282-ENG103298-System_Parameter_11-System Parameter Byte2,72
ENG109282-ENG100424-System_Parameter_11-System Parameter Byte3,5B
ENG109282-ENG99548-System_Parameter_11-System Parameter Byte4,DF
ENG109282-ENG103950-System_Parameter_11-System Parameter Byte5,72
ENG109282-ENG101580-System_Parameter_11-System Parameter Byte6,5B
ENG109282-ENG102804-System_Parameter_11-System Parameter Byte7,07
ENG109282-ENG99426-System_Parameter_11-System Parameter Byte8,03
ENG109282-ENG101522-System_Parameter_11-System Parameter Byte9,00
ENG109283-ENG103387-System_Parameter_12-System Parameter Byte 10,00
ENG109283-ENG101332-System_Parameter_12-System Parameter Byte 11,00
ENG109283-ENG99890-System_Parameter_12-System Parameter Byte 12,00
ENG109283-ENG99354-System_Parameter_12-System Parameter Byte 13,00
ENG109283-ENG101672-System_Parameter_12-System Parameter Byte 14,00
ENG109283-ENG99567-System_Parameter_12-System Parameter Byte 15,00
ENG109283-ENG103987-System_Parameter_12-System Parameter Byte0,00
ENG109283-ENG99921-System_Parameter_12-System Parameter Byte1,00
ENG109283-ENG103298-System_Parameter_12-System Parameter Byte2,26
ENG109283-ENG100424-System_Parameter_12-System Parameter Byte3,18
ENG109283-ENG99548-System_Parameter_12-System Parameter Byte4,32
ENG109283-ENG103950-System_Parameter_12-System Parameter Byte5,14
ENG109283-ENG101580-System_Parameter_12-System Parameter Byte6,14
ENG109283-ENG102804-System_Parameter_12-System Parameter Byte7,EA
ENG109283-ENG99426-System_Parameter_12-System Parameter Byte8,00
ENG109283-ENG101522-System_Parameter_12-System Parameter Byte9,00
ENG109284-ENG103387-System_Parameter_13-System Parameter Byte 10,FF
ENG109284-ENG101332-System_Parameter_13-System Parameter Byte 11,FF
ENG109284-ENG99890-System_Parameter_13-System Parameter Byte 12,FF
ENG109284-ENG99354-System_Parameter_13-System Parameter Byte 13,FF
ENG109284-ENG101672-System_Parameter_13-System Parameter Byte 14,FF
ENG109284-ENG99567-System_Parameter_13-System Parameter Byte 15,0F
ENG109284-ENG103987-System_Parameter_13-System Parameter Byte0,00
ENG109284-ENG99921-System_Parameter_13-System Parameter Byte1,00
ENG109284-ENG103298-System_Parameter_13-System Parameter Byte2,00
ENG109284-ENG100424-System_Parameter_13-System Parameter Byte3,00
ENG109284-ENG99548-System_Parameter_13-System Parameter Byte4,00
ENG109284-ENG103950-System_Parameter_13-System Parameter Byte5,00
ENG109284-ENG101580-System_Parameter_13-System Parameter Byte6,00
ENG109284-ENG102804-System_Parameter_13-System Parameter Byte7,00
ENG109284-ENG99426-System_Parameter_13-System Parameter Byte8,FF
ENG109284-ENG101522-System_Parameter_13-System Parameter Byte9,FF
ENG109285-ENG103387-System_Parameter_14-System Parameter Byte 10,00
ENG109285-ENG101332-System_Parameter_14-System Parameter Byte 11,00
ENG109285-ENG99890-System_Parameter_14-System Parameter Byte 12,00
ENG109285-ENG99354-System_Parameter_14-System Parameter Byte 13,00
ENG109285-ENG101672-System_Parameter_14-System Parameter Byte 14,00
ENG109285-ENG99567-System_Parameter_14-System Parameter Byte 15,00
ENG109285-ENG103987-System_Parameter_14-System Parameter Byte0,74
ENG109285-ENG99921-System_Parameter_14-System Parameter Byte1,E0
ENG109285-ENG103298-System_Parameter_14-System Parameter Byte2,1E
ENG109285-ENG100424-System_Parameter_14-System Parameter Byte3,E4
ENG109285-ENG99548-System_Parameter_14-System Parameter Byte4,00
ENG109285-ENG103950-System_Parameter_14-System Parameter Byte5,00
ENG109285-ENG101580-System_Parameter_14-System Parameter Byte6,00
ENG109285-ENG102804-System_Parameter_14-System Parameter Byte7,00
ENG109285-ENG99426-System_Parameter_14-System Parameter Byte8,00
ENG109285-ENG101522-System_Parameter_14-System Parameter Byte9,00
ENG109286-ENG103987-System_Parameter_15-System Parameter Byte0,00
ENG109286-ENG99921-System_Parameter_15-System Parameter Byte1,00
ENG109287-ENG103387-System_Parameter_2-System Parameter Byte 10,29
ENG109287-ENG101332-System_Parameter_2-System Parameter Byte 11,44
ENG109287-ENG99890-System_Parameter_2-System Parameter Byte 12,78
ENG109287-ENG99354-System_Parameter_2-System Parameter Byte 13,3C
ENG109287-ENG101672-System_Parameter_2-System Parameter Byte 14,64
ENG109287-ENG99567-System_Parameter_2-System Parameter Byte 15,55
ENG109287-ENG103987-System_Parameter_2-System Parameter Byte0,18
ENG109287-ENG99921-System_Parameter_2-System Parameter Byte1,44
ENG109287-ENG103298-System_Parameter_2-System Parameter Byte2,3F
ENG109287-ENG100424-System_Parameter_2-System Parameter Byte3,62
ENG109287-ENG99548-System_Parameter_2-System Parameter Byte4,9E
ENG109287-ENG103950-System_Parameter_2-System Parameter Byte5,00
ENG109287-ENG101580-System_Parameter_2-System Parameter Byte6,6E
ENG109287-ENG102804-System_Parameter_2-System Parameter Byte7,3F
ENG109287-ENG99426-System_Parameter_2-System Parameter Byte8,01
ENG109287-ENG101522-System_Parameter_2-System Parameter Byte9,60
ENG109288-ENG103387-System_Parameter_3-System Parameter Byte 10,07
ENG109288-ENG101332-System_Parameter_3-System Parameter Byte 11,8A
ENG109288-ENG99890-System_Parameter_3-System Parameter Byte 12,FD
ENG109288-ENG99354-System_Parameter_3-System Parameter Byte 13,72
ENG109288-ENG101672-System_Parameter_3-System Parameter Byte 14,B5
ENG109288-ENG99567-System_Parameter_3-System Parameter Byte 15,34
ENG109288-ENG103987-System_Parameter_3-System Parameter Byte0,46
ENG109288-ENG99921-System_Parameter_3-System Parameter Byte1,46
ENG109288-ENG103298-System_Parameter_3-System Parameter Byte2,4B
ENG109288-ENG100424-System_Parameter_3-System Parameter Byte3,46
ENG109288-ENG99548-System_Parameter_3-System Parameter Byte4,8A
ENG109288-ENG103950-System_Parameter_3-System Parameter Byte5,88
ENG109288-ENG101580-System_Parameter_3-System Parameter Byte6,9E
ENG109288-ENG102804-System_Parameter_3-System Parameter Byte7,96
ENG109288-ENG99426-System_Parameter_3-System Parameter Byte8,91
ENG109288-ENG101522-System_Parameter_3-System Parameter Byte9,8C
ENG109289-ENG103387-System_Parameter_4-System Parameter Byte 10,08
ENG109289-ENG101332-System_Parameter_4-System Parameter Byte 11,27
ENG109289-ENG99890-System_Parameter_4-System Parameter Byte 12,3C
ENG109289-ENG99354-System_Parameter_4-System Parameter Byte 13,86
ENG109289-ENG101672-System_Parameter_4-System Parameter Byte 14,14
ENG109289-ENG99567-System_Parameter_4-System Parameter Byte 15,28
ENG109289-ENG103987-System_Parameter_4-System Parameter Byte0,00
ENG109289-ENG99921-System_Parameter_4-System Parameter Byte1,53
ENG109289-ENG103298-System_Parameter_4-System Parameter Byte2,50
ENG109289-ENG100424-System_Parameter_4-System Parameter Byte3,19
ENG109289-ENG99548-System_Parameter_4-System Parameter Byte4,07
ENG109289-ENG103950-System_Parameter_4-System Parameter Byte5,B3
ENG109289-ENG101580-System_Parameter_4-System Parameter Byte6,9B
ENG109289-ENG102804-System_Parameter_4-System Parameter Byte7,61
ENG109289-ENG99426-System_Parameter_4-System Parameter Byte8,73
ENG109289-ENG101522-System_Parameter_4-System Parameter Byte9,2D
ENG109290-ENG103387-System_Parameter_5-System Parameter Byte 10,B6
ENG109290-ENG101332-System_Parameter_5-System Parameter Byte 11,7D
ENG109290-ENG99890-System_Parameter_5-System Parameter Byte 12,A0
ENG109290-ENG99354-System_Parameter_5-System Parameter Byte 13,3F
ENG109290-ENG101672-System_Parameter_5-System Parameter Byte 14,AA
ENG109290-ENG99567-System_Parameter_5-System Parameter Byte 15,47
ENG109290-ENG103987-System_Parameter_5-System Parameter Byte0,0A
ENG109290-ENG99921-System_Parameter_5-System Parameter Byte1,1D
ENG109290-ENG103298-System_Parameter_5-System Parameter Byte2,14
ENG109290-ENG100424-System_Parameter_5-System Parameter Byte3,0A
ENG109290-ENG99548-System_Parameter_5-System Parameter Byte4,87
ENG109290-ENG103950-System_Parameter_5-System Parameter Byte5,51
ENG109290-ENG101580-System_Parameter_5-System Parameter Byte6,12
ENG109290-ENG102804-System_Parameter_5-System Parameter Byte7,20
ENG109290-ENG99426-System_Parameter_5-System Parameter Byte8,37
ENG109290-ENG101522-System_Parameter_5-System Parameter Byte9,A0
ENG109291-ENG103387-System_Parameter_6-System Parameter Byte 10,08
ENG109291-ENG101332-System_Parameter_6-System Parameter Byte 11,8C
ENG109291-ENG99890-System_Parameter_6-System Parameter Byte 12,FF
ENG109291-ENG99354-System_Parameter_6-System Parameter Byte 13,2B
ENG109291-ENG101672-System_Parameter_6-System Parameter Byte 14,0E
ENG109291-ENG99567-System_Parameter_6-System Parameter Byte 15,80
ENG109291-ENG103987-System_Parameter_6-System Parameter Byte0,D9
ENG109291-ENG99921-System_Parameter_6-System Parameter Byte1,22
ENG109291-ENG103298-System_Parameter_6-System Parameter Byte2,19
ENG109291-ENG100424-System_Parameter_6-System Parameter Byte3,0D
ENG109291-ENG99548-System_Parameter_6-System Parameter Byte4,75
ENG109291-ENG103950-System_Parameter_6-System Parameter Byte5,FF
ENG109291-ENG101580-System_Parameter_6-System Parameter Byte6,32
ENG109291-ENG102804-System_Parameter_6-System Parameter Byte7,75
ENG109291-ENG99426-System_Parameter_6-System Parameter Byte8,C8
ENG109291-ENG101522-System_Parameter_6-System Parameter Byte9,00
ENG109292-ENG103387-System_Parameter_7-System Parameter Byte 10,0F
ENG109292-ENG101332-System_Parameter_7-System Parameter Byte 11,32
ENG109292-ENG99890-System_Parameter_7-System Parameter Byte 12,0A
ENG109292-ENG99354-System_Parameter_7-System Parameter Byte 13,0A
ENG109292-ENG101672-System_Parameter_7-System Parameter Byte 14,03
ENG109292-ENG99567-System_Parameter_7-System Parameter Byte 15,32
ENG109292-ENG103987-System_Parameter_7-System Parameter Byte0,10
ENG109292-ENG99921-System_Parameter_7-System Parameter Byte1,04
ENG109292-ENG103298-System_Parameter_7-System Parameter Byte2,9C
ENG109292-ENG100424-System_Parameter_7-System Parameter Byte3,00
ENG109292-ENG99548-System_Parameter_7-System Parameter Byte4,02
ENG109292-ENG103950-System_Parameter_7-System Parameter Byte5,0D
ENG109292-ENG101580-System_Parameter_7-System Parameter Byte6,F2
ENG109292-ENG102804-System_Parameter_7-System Parameter Byte7,0D
ENG109292-ENG99426-System_Parameter_7-System Parameter Byte8,32
ENG109292-ENG101522-System_Parameter_7-System Parameter Byte9,0C
ENG109293-ENG103387-System_Parameter_8-System Parameter Byte 10,0D
ENG109293-ENG101332-System_Parameter_8-System Parameter Byte 11,00
ENG109293-ENG99890-System_Parameter_8-System Parameter Byte 12,00
ENG109293-ENG99354-System_Parameter_8-System Parameter Byte 13,32
ENG109293-ENG101672-System_Parameter_8-System Parameter Byte 14,00
ENG109293-ENG99567-System_Parameter_8-System Parameter Byte 15,00
ENG109293-ENG103987-System_Parameter_8-System Parameter Byte0,0A
ENG109293-ENG99921-System_Parameter_8-System Parameter Byte1,03
ENG109293-ENG103298-System_Parameter_8-System Parameter Byte2,20
ENG109293-ENG100424-System_Parameter_8-System Parameter Byte3,20
ENG109293-ENG99548-System_Parameter_8-System Parameter Byte4,20
ENG109293-ENG103950-System_Parameter_8-System Parameter Byte5,0D
ENG109293-ENG101580-System_Parameter_8-System Parameter Byte6,03
ENG109293-ENG102804-System_Parameter_8-System Parameter Byte7,02
ENG109293-ENG99426-System_Parameter_8-System Parameter Byte8,02
ENG109293-ENG101522-System_Parameter_8-System Parameter Byte9,0D
ENG109294-ENG103387-System_Parameter_9-System Parameter Byte 10,2A
ENG109294-ENG101332-System_Parameter_9-System Parameter Byte 11,9B
ENG109294-ENG99890-System_Parameter_9-System Parameter Byte 12,00
ENG109294-ENG99354-System_Parameter_9-System Parameter Byte 13,00
ENG109294-ENG101672-System_Parameter_9-System Parameter Byte 14,00
ENG109294-ENG99567-System_Parameter_9-System Parameter Byte 15,00
ENG109294-ENG103987-System_Parameter_9-System Parameter Byte0,00
ENG109294-ENG99921-System_Parameter_9-System Parameter Byte1,00
ENG109294-ENG103298-System_Parameter_9-System Parameter Byte2,00
ENG109294-ENG100424-System_Parameter_9-System Parameter Byte3,00
ENG109294-ENG99548-System_Parameter_9-System Parameter Byte4,00
ENG109294-ENG103950-System_Parameter_9-System Parameter Byte5,00
ENG109294-ENG101580-System_Parameter_9-System Parameter Byte6,14
ENG109294-ENG102804-System_Parameter_9-System Parameter Byte7,00
ENG109294-ENG99426-System_Parameter_9-System Parameter Byte8,00
ENG109294-ENG101522-System_Parameter_9-System Parameter Byte9,03
ENG109297-ENG103364-System-Parameter Block-Byte 241,00
ENG109297-ENG102453-System-Parameter Block-Byte 242,00
ENG109297-ENG103666-System-Parameter Block-Bytes 101-150,75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00
ENG109297-ENG100496-System-Parameter Block-Bytes 1-20,7F BE 0F 34 00 0D C3 11 95 F2 07 E4 E4 62 00 28 E4 00 4C 00
ENG109297-ENG100448-System-Parameter Block-Bytes 151-200,14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA
ENG109297-ENG100071-System-Parameter Block-Bytes 201-220,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF
ENG109297-ENG100087-System-Parameter Block-Bytes 21-40,0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F
ENG109297-ENG101191-System-Parameter Block-Bytes 221-240,FF FF FF 0F 74 E0 1E E4 00 00 00 00 00 00 00 00 00 00 00 00
ENG109297-ENG99900-System-Parameter Block-Bytes 41-60,01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A
ENG109297-ENG102407-System-Parameter Block-Bytes 61-80,FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28
ENG109297-ENG102513-System-Parameter Block-Bytes 81-100,0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D
ENG110034-ENG103364-VW-Identification-Byte 241,00
ENG110034-ENG102453-VW-Identification-Byte 242,00
ENG110034-ENG103666-VW-Identification-Bytes 101-150,00 00 30 35 33 34 45 56 5F 54 53 47 46 50 51 33 35 42 52 46 56 57 34 36 58 00 00 00 00 00 00 00 41 30 34 30 30 31 01 81 C8 F6 30 39 16 09 12 00 00 00
ENG110034-ENG100496-VW-Identification-Bytes 1-20,30 30 31 33 30 35 30 30 00 00 00 00 00 00 00 00 00 00 00 00
ENG110034-ENG100448-VW-Identification-Bytes 151-200,00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG110034-ENG100071-VW-Identification-Bytes 201-220,00 00 00 00 00 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
ENG110034-ENG100087-VW-Identification-Bytes 21-40,00 00 00 00 00 00 00 00 00 00 00 33 41 41 39 35 39 37 30 31
ENG110034-ENG101191-VW-Identification-Bytes 221-240,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG110034-ENG99900-VW-Identification-Bytes 41-60,41 20 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 39 33 43
ENG110034-ENG102407-VW-Identification-Bytes 61-80,20 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 4A 33 38
ENG110034-ENG102513-VW-Identification-Bytes 81-100,36 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG110126-MAS00478-Window_Lifter_Position-Reserved,50
ENG110126-ENG102781-Window_Lifter_Position-Data 1,1.50
ENG110126-ENG102143-Window_Lifter_Position-Data 2,7253.5
ENG110126-ENG103757-Window_Lifter_Position-Data 3,00
ENG110126-ENG101787-Window_Lifter_Position-Data 4,00
Elapsed Time: 00:54
kamold
Australia
C?ID=241363
RHD Gen4 auto mirror folding *SOLVED!*
I have been provided with the necessary adaptation change by the wise and kind user welshkaiboy from the mytiguan forums.
They would prefer the information not be made public domain which I respect, so if anyone is interested please PM me.
Bwant
C?ID=130834
Kamold you have pm.
chillout1983
C?ID=162783
Tried it but it doesn't work on my car unfortunately
kamold
Australia
C?ID=241363
What is the part number and software version of your driver's door controller for future reference?
chillout1983
C?ID=162783
This is the details of my module any help would be great as I am keen to get this working
Revision: 12110009 Serial number: 0008808303
Coding: 0212B7
VCID: 356B114294524BEA43-8060
Slave Driver:
Serial number: 00000004061119
Coding: 010290
kamold
Australia
C?ID=241363
Coding: 0212B7
Slave Driver:
Coding: 010290
That's exactly the same part and sw version that I have had success with enabling.
Have you checked in the convenience menu in the MFD?
Did the adaptation value change correctly when you entered the new value?
chillout1983
C?ID=162783
The value did change to either however I don't have mirrors listed in the convenience menu on the mfd
Cheers
Bwant
C?ID=130834
Just for info the change worked on this door controller-2010 Passat CC
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0308
Revision: 12101005 Serial number: 0000746448
Coding: 0012FF
Shop #: WSC 00124 012 00001
VCID: 7CFDCA9DF7451EA2F4-8028
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001407098
Coding: 0000D8
chillout1983
C?ID=162783
Sorted now thank you next on the list is to gt the power trunk to close remotely that's another frustration as I see Octavia's doing it
kamold
Australia
C?ID=241363
What was the issue?
chillout1983
C?ID=162783
I think I either didn't hold the lock button long enough or it didn't accept the changes properly.
I couldn't help but notice you have the electric tailgate on you r36 does it close via the remote and if it does how did yo do it ?
Cheers
kamold
Australia
C?ID=241363
No, doesn't close via remote.
And with kids I'll not be pursuing a method to do so.
Have enabled it on an MQB Octavia. Can close either from the cabin button or the remote.
Not sure it's possible on the PQ platform cars though.
Claudiu
C?ID=221613
Can u PM the info regarding the folding please. I have changed Byte 8 to 95 and 99 and nothing happens.
Thank u
Claudiu
C?ID=221613
can someone help me with the coding for folding mirrors please. see scan below
Tuesday,14,May,2019,19:04:01:22001
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WVWZZZ3CZEE505544   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 36 37 42 44 46 4C 4F
          52 53 55 56 61 62 72
VIN: WVWZZZ3CZEE505544   Mileage: 92300km-57352miles
Address 01: Engine (J623-CFGC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 TM    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9979
   Coding: 001D0012042501080000
   Shop #: WSC 00445 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018TM 003003
   VCID: 085C7445B366CA0A95-805C
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
                    Mileage: 91777 km
                    Date: 2019.05.01
                    Time: 18:56:46
                    Engine speed: 853.00 /min
                    Normed load value: 18.0 %
                    Coolant temperature: 57 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 11.940 V
                    Unlearning counter according OBD: 21
                    Immobilizer snapshot A-Sia Error Snap A: 9B 1B 4D
                    Immobilizer snapshot B-Sia Error Snap B: 0A 00 00
   Part No SW: 02E 300 062 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4006
   Revision: 05652104    Serial number: 00001306051671
   Shop #: WSC 05311 000 00000
   VCID: 200C0CE5F396124AFD-8074
   Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
   Component: J104   C2 450M VD09 0030
   Revision: --H07---    Serial number: 00000007130476
   Coding: 0008124
   VCID: 7CB418953FBE96AA81-8028
   Part No SW: 3AA 907 044 BE    HW: 3AA 907 044 BE
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 071400C849
   Shop #: WSC 00015 115 00000
   VCID: 74A430B5DFEEDEEAC9-8020
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 0008000000000000008C0080940009642355040864200720E484C72400C1
   Shop #: WSC 05311 000 08193
   VCID: 49DAB141E0ECF3024A-801C
   Subsystem 1 - Part No SW: 3C8 955 119 G    HW: 3C8 955 119 G  Labels: 1KX-955-119.CLB
   Component: WWS464 300113  010 0604
   Serial number: 300113
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M06D11H09M52S38S1
   Coding: 0228DD
                    Reset counter: 45
                    Mileage: 92255 km
                    Date: 2013.10.02
                    Time: 10:29:17
                    Voltage: 14.60 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28261315500063
   Coding: 108104
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3FCEAF99A6284DB2E4-806A
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 27051306590001
   Coding: 010180
   Shop #: WSC 05314 000 00000
   VCID: 271E17F956B8E572BC-8072
   Component: J234__70J VW10 HI   2118
   Revision: 26019000    Serial number: 003L7PBUS1ZW
   Coding: 0012362
   Subsystem 1 - Serial number: 6332MTS622641443
   Subsystem 2 - Serial number: 6342MTS648081443
   Subsystem 3 - Serial number: 6351HTS66N741CKJ
   Subsystem 4 - Serial number: 6361HTS6H9VL0CKR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010042    Serial number: 20130610200604
   Coding: 0982270001
   VCID: 6B962BC982D0011218-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3C8 920 981 D    HW: 3C8 920 981 D
   Component: KOMBI         H04 0611
   Coding: 440F01
   Shop #: WSC 05314 115 00000
   VCID: 2F2EFFD97648BD3274-807A
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 310513F1003219
   Coding: 469007
   VCID: 7CB41895FFBE96AA81-8028
   Part No SW: 3AA 959 799 C    HW: 3AA 959 799 C
   Component:    IMMO         090 0407
   Revision: 00090000    Serial number: VWZCZ000000000
   VCID: 48DCB4453BE60A0A55-801C
   Revision: A1001003    Serial number: 7664904371
   Coding: 020100
   VCID: 2B16EBC94A50C11258-807E
   Part No SW: 3C8 959 760 C    HW: 3C8 959 760 C
   Component: Sitzmemory    H05 2901
   Revision: 00H05000
   Coding: 000039
   VCID: 3522CDB19C1487E23E-8060
02340 - Seat Fore/Aft Adjustment Motor (V288)
                    Fault Status: 00101011
                    Reset counter: 188
                    Mileage: 87055 km
                    Date: 2019.01.04
                    Time: 15:52:24
02330 - Rear Seat Height Adjustment Motor (V285)
                    Reset counter: 206
                    Mileage: 89604 km
                    Date: 2013.06.22
                    Time: 13:01:39
   Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
   Component: RNS315-EU   H70 0407
   Serial number: VWZAZ2N0341391
   Coding: 0400040104000F0000019002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 3522CDB1941487E23E-8060
   Component: EUR_W_V9  0069
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0556
   Revision: 12110009    Serial number: 0007089874
   Coding: 0213B7
   Shop #: WSC 05311 115 00000
   VCID: 6D9225D1BCC40F2206-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003524791
   Coding: 010090
   Component: EPS_ZFLS Kl. 209    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 393AC181700C6382DA-806C
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 09 KESSY PQ47   090 0367
   Coding: 01910A0001C60E76360494157200DFCE10580003242498
   Component: Neigungssensor  004 0611
   Subsystem 4 - Component:       ViP n.mounted
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FAE3FD9BEC8FD3234-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0556
   Revision: 14110009    Serial number: 0007094104
   Coding: 0213B6
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 6E9022DDB1C2F43A3F-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003512183
   Coding: 010090
   Revision:   H19       Serial number: 00000001116200
   Coding: 0022167
   VCID: 3620CABD41128CFA37-8062
   Coding: 07B600000B000200
   VCID: 373EC7B98E1875F22C-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
   Component: Batt.regelung H56 1642
   Coding: 030F1859
   VCID: 71AA39A1A8FCEBC222-8024
   Serial number: 40157B21021490419937
End----------(Elapsed Time: 01:42, VBatt start/end: 12.3V/12.0V)-----------
Fredrick Awuor
Kenya
C?ID=309834
kindly check PM
Tiptop
C?ID=127746
Would you please PM me the information please
Thank you 🙏
swenak
Czech Republic
C?ID=236893
I change adaptation and coding, but auto mirror folding not work. I still must hold lock on keyfob to fold mirros. Here is my adaptation map and coding. Can someone check it?
Thanks.
   Component: TUER-SG FT    002 0530
   Revision: 12110009    Serial number: 0008938590
   Coding: 301136
   VCID: 353C49B055CFB8132C9-8060
;SW:3AA-959-701-A   HW:3C0-959-793-C ---  Door Elect, Driver --- SA: 04354
;Component:TUER-SG FT    002 0530, Coding:301136
;EV_TSGFPQ35BRFVW46X,A04001,EV_TSGFPQ35BRFVW46X_VW36.rod
;Tuesday,24,May,2022,17:29:54:60651
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
;VCID: 353C49B055CFB8132C9-8060
ENG108998-ENG103506-Software Version Number(Front)-Byte 1,0 ,4
ENG108998-ENG100432-Software Version Number(Front)-Byte 2,5 ,4
ENG108998-ENG103171-Software Version Number(Front)-Byte 3,3 ,4
ENG108998-ENG99780-Software Version Number(Front)-Byte 4,0 ,4
ENG109253-System Data Part1,00 00 01 0C 04 06 00 00 00 00 00 09 00 17 8B 00 00 A8 76 00 01 01 04 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8F 12 12 12 01 02 01 00 00 00 ,56
ENG109254-System Data Part2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 30 30 30 30 34 31 31 39 34 38 31 00 00 07 07 07 07 07 07 07 07 07 07 07 00 00 00 01 00 00 00 07 07 07 07 07 07 07 07 07 07 07 07 07 07 07 07 07 07 04 07 07 05 06 07 05 07 03 00 07 07 06 07 07 07 07 07 07 07 07 07 07 03 04 00 01 06 01 00 04 01 00 02 00 01 00 00 00 06 00 07 06 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 01 02 00 01 00 00 00 00 00 00 00 02 00 00 00 00 01 00 01 02 02 00 00 03 00 00 00 00 00 00 00 00 07 01 01 00 00 00 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 ,216
ENG109255-System Data Part3,FF FF 08 E0 01 02 01 7A 01 E3 B4 F3 AB FF FF 09 AE 01 01 FD 80 01 E3 A6 C7 8C FF FF 09 AB 01 01 F9 E1 01 E3 9E D4 4A FF FF 09 00 01 00 00 00 00 03 80 15 2A FF FF 09 00 01 00 00 00 00 03 80 00 AC FF FF 09 00 01 00 00 00 00 03 80 00 AC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0A 02 C4 84 8C EE FF FF 00 00 00 00 00 00 00 00 A5 FF ,174
ENG109256-System Data Part4,14 07 31 16 30 91 84 32 01 10 00 00 00 00 42 52 46 2D 30 30 31 33 31 2E 30 37 2E 31 34 30 30 30 31 31 36 33 30 31 32 31 31 30 30 30 39 54 55 45 52 2D 53 47 20 46 54 20 20 20 30 30 30 38 39 33 38 35 39 30 ,68
ENG109257-System Data Part5,05 22 45 3E 93 68 72 00 01 10 00 00 00 00 00 00 30 30 31 31 ,20
ENG109258-System Data Part6,FF FE 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 01 00 01 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 ,38
ENG109259-System Data Part7,00 ,1
ENG109260-System Data Part8,3F ,1
ENG109263-System Parameter Part16,36 11 30 00 00 08 E6 14 BF 22 05 23 00 00 ,14
ENG109264-System Parameter Part-17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
ENG109279-System_Parameter_0,7F BE 0F 34 00 0D C3 51 99 F2 07 E4 E4 62 00 28 ,16
ENG109280-System_Parameter_1,E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 ,16
ENG109281-System_Parameter_10,1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 ,16
ENG109282-System_Parameter_11,75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 ,16
ENG109283-System_Parameter_12,00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 ,16
ENG109284-System_Parameter_13,00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F ,16
ENG109285-System_Parameter_14,74 E9 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 ,16
ENG109286-System_Parameter_15,00 00 ,2
ENG109287-System_Parameter_2,18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 ,16
ENG109288-System_Parameter_3,46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 ,16
ENG109289-System_Parameter_4,00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 ,16
ENG109290-System_Parameter_5,0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 ,16
ENG109291-System_Parameter_6,D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 ,16
ENG109292-System_Parameter_7,10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 ,16
ENG109293-System_Parameter_8,0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 ,16
ENG109294-System_Parameter_9,00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 ,16
ENG109297-System-Parameter Block,7F BE 0F 34 00 0D C3 51 99 F2 07 E4 E4 62 00 28 E4 00 4C 00 0C 7A 0F 87 69 9E 00 00 05 08 0C 10 18 44 3F 62 9E 00 6E 3F 01 60 29 44 78 3C 64 55 46 46 4B 46 8A 88 9E 96 91 8C 07 8A FD 72 B5 34 00 53 50 19 07 B3 9B 61 73 2D 08 27 3C 86 14 28 0A 1D 14 0A 87 51 12 20 37 A0 B6 7D A0 3F AA 47 D9 22 19 0D 75 FF 32 75 C8 00 08 8C FF 2B 0E 80 10 04 9C 00 02 0D F2 0D 32 0C 0F 32 0A 0A 03 32 0A 03 20 20 20 0D 03 02 02 0D 0D 00 00 32 00 00 00 00 00 00 00 00 14 00 00 03 2A 9B 00 00 00 00 1E 28 37 46 5A 64 00 03 07 0A 0E 0F 28 1E 0A 75 75 DF 72 5B DF 72 5B 07 03 00 28 14 00 64 02 00 00 00 26 18 32 14 14 EA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 0F 74 E9 1E E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110034-VW-Identification,30 30 31 33 30 35 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 41 41 39 35 39 37 30 31 41 20 00 00 00 00 00 00 00 00 33 43 30 39 35 39 37 39 33 43 20 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 32 4A 33 38 36 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 35 33 30 45 56 5F 54 53 47 46 50 51 33 35 42 52 46 56 57 34 36 58 00 00 00 00 00 00 00 41 30 34 30 30 31 00 00 08 E6 14 BF 22 05 24 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,242
ENG110126-MAS00478-Window_Lifter_Position-Reserved,00 ,8
ENG110126-ENG102781-Window_Lifter_Position-Data 1,178.75 ,8
ENG110126-ENG102143-Window_Lifter_Position-Data 2,9937.5 ,8
ENG110126-ENG103757-Window_Lifter_Position-Data 3,00 ,8
ENG110126-ENG101787-Window_Lifter_Position-Data 4,01 ,8
