Fuel pumps: FSI vs port injected (low pressure)
NZDubNurd
New Zealand
C?ID=230482
Hi Guys,
Anyone know if the FSI low pressure pumps (in tank) are basically the same as a standard port injected pump?
I want to run the FSI pump in the R32 Touran conversio on 12V straight, instead of the PWM signal they normally have. Are they still just a 12V motor in the pump? No the end of the world if it burns out (although going "BANG" may be bad...)
It will only be temporary, until I install the 4WD tank and correct pump.
(I realise I have to change the fuel filter/regulator to the port injected part, to get the max pressure down to where it should be)
Cheers !
Allan.
