Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
47 4F 52 55 56 61 62 67 69 6C 6D 6F 72 76 77
VIN: WA1AV94L47D009991 Mileage: 165670km/102942miles
62-Door,Rear Left -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0060
Revision: --H16--- Serial number:
Coding: 01210009190F0D60
Shop #: WSC 08166 444 102996
16 Faults Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - MIL ON
Fault Status: 11100100
Mileage: 157481 km
Date: 2015.12.24
Time: 09:22:06
RPM: 774 /min
Load: 15.7 %
Temperature: 99.0°C
Temperature: 42.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
008585 - Bank 2; System too Lean at Idle
P2189 - 004 - No Signal/Communication - MIL ON
Mileage: 157481 km
Date: 2015.12.24
Time: 09:22:10
RPM: 778 /min
Load: 15.7 %
Temperature: 99.0°C
Temperature: 42.0°C
Voltage: 13.970 V
000135 - Fuel Rail/System Pressure: Too Low
P0087 - 008 - Implausible Signal - Intermittent
Fault Frequency: 29
Mileage: 165100 km
Date: 2016.03.18
Time: 16:50:07
RPM: 2084 /min
Load: 69.0 %
Speed: 55.0 km/h
Temperature: 91.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
P0087 - 002 - Lower Limit Exceeded - MIL ON
Fault Status: 11100010
Mileage: 165109 km
Date: 2016.03.19
Time: 08:41:52
RPM: 3155 /min
Load: 11.8 %
Speed: 88.0 km/h
Temperature: 92.0°C
Temperature: 15.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
001112 - Evap System Purge Control Valve (N80): Short to Ground
P0458 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165644 km
RPM: 1406 /min
Load: 36.5 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 12.446 V
005173 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165644 km
RPM: 1406 /min
Load: 36.5 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 13.462 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276): Open Circuit
P129B - 004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10100100
Mileage: 165644 km
RPM: 466 /min
Load: 97.6 %
Temperature: 32.0°C
Temperature: 33.0°C
Voltage: 11.303 V
000258 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165644 km
RPM: 1071 /min
Load: 20.8 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 12.192 V
000268 - Mass Air Flow Sensor (G246): Signal too Low
P010C - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165644 km
RPM: 1071 /min
Load: 20.8 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 12.192 V
009217 - EVAP Leak Detection Pump Control Circuit: Short to GND
P2401 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165644 km
Date: 2016.03.27
Time: 09:25:58
RPM: 1126 /min
Load: 38.4 %
Speed: 4.0 km/h
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 14.351 V
P0300 - 001 - Upper Limit Exceeded - MIL ON
Fault Status: 11100001
Mileage: 165645 km
Date: 2016.03.27
Time: 09:26:51
RPM: 3015 /min
Load: 51.0 %
Speed: 38.0 km/h
Temperature: 54.0°C
Temperature: 30.0°C
Voltage: 14.224 V
000771 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - MIL ON
Mileage: 165645 km
Date: 2016.03.27
Time: 09:26:51
RPM: 3015 /min
Load: 51.0 %
Speed: 38.0 km/h
Temperature: 54.0°C
Temperature: 30.0°C
Voltage: 14.224 V
000770 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - MIL ON
Mileage: 165645 km
Date: 2016.03.27
Time: 09:26:51
RPM: 3015 /min
Load: 51.0 %
Speed: 38.0 km/h
Temperature: 54.0°C
Temperature: 30.0°C
Voltage: 14.224 V
008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
P2294 - 004 - No Signal/Communication - Intermittent - MIL ON
Mileage: 165647 km
Date: 2016.03.27
Time: 10:50:44
RPM: 1720 /min
Load: 14.9 %
Speed: 63.0 km/h
Temperature: 64.0°C
Temperature: 35.0°C
Voltage: 14.351 V
000769 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - MIL ON
Mileage: 165652 km
Date: 2016.03.28
Time: 05:34:50
RPM: 770 /min
Load: 34.5 %
Speed: 5.0 km/h
Temperature: 25.0°C
Temperature: 24.0°C
Voltage: 14.097 V
000773 - Cylinder 5: Misfire Detected
P0305 - 008 - Implausible Signal - MIL ON
Fault Status: 11101000
Mileage: 165652 km
Date: 2016.03.28
Time: 05:35:33
RPM: 1905 /min
Load: 37.2 %
Speed: 35.0 km/h
Temperature: 32.0°C
Temperature: 25.0°C
Voltage: 14.351 V
Readiness: 0000 1001
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 BR HW: 09D 927 750 BR
Component: AL 750 6A 0915
Revision: 00H49000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
013 - Check DTC Memory
Reset counter: 0
Date: 2005.09.20
Time: 12:00:00
Address 03: ABS Brakes Labels: 4L0-910-517.lbl
Part No SW: 4L0 910 517 E HW: 4L0 614 517 E
Component: ESP ALLRAD MK25E1 0140
Revision: 00H45001
Coding: 0021553
Fault Status: 01101101
Reset counter: 167
Mileage: 165644 km
Date: 2016.03.27
Time: 09:25:48
Count: 64
Count: 13569
Count: 8196
Count: 43264
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 729 R HW: 4E0 035 729 A
Component: Interfacebox H43 1600
Revision: 00000000 Serial number: 354CL067501339
Coding: 0000003
Part No: 4L0 910 609
Component: E0380 BedienteilH01 0050
Reset counter: 227
Mileage: 157473 km
Date: 2015.12.24
Time: 05:25:29
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 211
Mileage: 165673 km
Date: 2016.03.28
Time: 17:53:33
Reset counter: 202
Mileage: 165339 km
Date: 2016.03.23
Time: 18:01:58
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D0631280D7
Coding: F7F3FE7F347A02
Reset counter: 227
Mileage: 157473 km
Date: 2015.12.24
Time: 05:03:56
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Component: KLIMABETAETIGUNGH05 0040
Revision: 00---006 Serial number: 00000000014930
Coding: 0000006
00003 - Control Module
Fault Status: 00100011
Fault Frequency: 11
Mileage: 124044 km
Date: 2013.12.13
Time: 21:56:17
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 A HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7470
Revision: --H03001 Serial number: 15.1528-0082.2
Coding: 0015520
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Reset counter: 207
Mileage: 163368 km
Date: 2016.03.05
Time: 14:05:24
Error Code: 68
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H45 1100
Revision: 00000000 Serial number: 306C9067500421
02927 - DVD Read Error
Fault Frequency: 9
Reset counter: 185
Mileage: 162578 km
Date: 2016.03.04
Time: 17:33:00
Hex Value: 0x56ED
Hex Value: 0x0FC5
Hex Value: 0x0401
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
Fault Status: 01101000
Reset counter: 165
Mileage: 155790 km
Date: 2015.10.08
Time: 22:20:20
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 A HW: 4L0 035 223 A
Component: DSP-High AU716 H02 0090
Revision: PROD_01 Serial number: 00000000205110
Coding: 0000026
Fault Status: 00111011
Reset counter: 209
Mileage: 165638 km
Date: 2016.03.26
Time: 18:52:32
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000007731
Shop #: WSC 08166 444 00177
Part No: 4F0 915 105 D
Component: von VA0 2603131260
Coding: 344630393135313035442056413032363033313331323630
Fault Frequency: 85
Mileage: 124562 km
Date: 2013.12.26
Time: 16:04:40
Address 62: Door,Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Reset counter: 228
Mileage: 128378 km
Date: 2014.04.04
Time: 15:03:53
Address 69: Trailer (J345) Labels: None
Part No SW: 4E0 907 383 H HW: 4E0 907 383 G
Component: Anhaenger H08 0080
Revision: 2A002002 Serial number: 00000116067289
Coding: 0200000000000000
Shop #: WSC 08166 444 09063
02579 - Trailer; Left Brake Lamps (M65)
Fault Status: 11101010
Reset counter: 121
Mileage: 164761 km
Date: 2016.03.08
Time: 11:54:48
02580 - Trailer; Right Brake Lamps (M66)
Reset counter: 121
Mileage: 164761 km
Date: 2016.03.08
Time: 11:54:48
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 4L0 910 441 HW: 4L0 907 441
Component: J772__Rearview 0020
Revision: --H10--- Serial number: 525PA8-J631307
Coding: 1010001
03006 - Back-up Camera System not calibrated
Reset counter: 138
Invalid
Invalid
Invalid
