Misfire after aborted scan, ECU comm problems, 2005 S4 Cabriolet b6 8H BHF 4.2 V8
   #21
ivagp
C?ID=95551
have u checked cam correlation. u can find that measuring blocks 90s somethings. that is a very hard job. it has chains in front and back.
ivagp
C?ID=95551
i believe you have 4 camshafts and two cam sensors, even if you dont have correlation codes you can still have timing off. if you have missfire codes or fuel trim codes you must check correlation.
   #24
RichS
C?ID=222890
Jack, Ivagp, I do recall the dealer mentioning some kind of code that would assess timing chain health. I hope I can figure out where / if that dtc is, and how to use it. Or do the dimples in the pistons already tell me everything I need to know? I do plan on a leakdown test or a compression test to tell me if I need to do heads / valves, or just the chain.
   #25
NostraJackAss
What what WHAT!......please explain or are these the recesses for the valves?
Do you have a compression issue?
Pictures?
   #26
NostraJackAss
Oh I saw pictures now, that were not able to be seen before.
That looks like carbon and the valve relief machined area of piston.
What is compression?
   #27
RichS
C?ID=222890
I would value insight as to what to try next.
I did some more tests - Jack, in answer to your question, compression taken while the engine was cold (I didn't want to risk further damage) was:
#1-150 psi, 2-165, 3-147, 4-150, 5-150, 6-150, 7-150, 8-160.
I switched coil packs about the center point of the engine for example, #1 was moved to #8 cylinder, #4 was moved to #5.
I installed new plugs. I cleared the DTC codes from the engine to try running with a fresh start - fresh map. (Was that wise?).
The engine ran more smoothly than before, at 1000 rpm there were no misfires, but at idle after warming up it was still rough. Misfires started again at #1 and then started in at #2 and #3.
My next step is likely to pull injectors and attempt to clean them, check the spray pattern, check for leaks, and install new injector o-rings. Or maybe just swap then side to side. Does anyone know of a good injector test stand setup for sale, i need to buy something to pressurize each injector and test for leaks.
I took some logs at measuring blocks 15, 16, 17 31,32,33, and 91-94 as well - yes, there are camshaft codes, but I am not sure how to interpret them yet.
Here are the logs:
Friday,19,August,2016,19:13:02:29481
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Mileage:    Repair Order: runnuing 8-19-2016
                Address 01: Engine  (8H0 910 560 L)
19:12:38 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  0  Misfire Counter Cylinder 1
  0  Misfire Counter Cylinder 2
  0  Misfire Counter Cylinder 3
  Enabled  Misfire Recognition
19:12:38 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
  0  Misfire Counter Cylinder 4
  0  Misfire Counter Cylinder 5
  0  Misfire Counter Cylinder 6
19:12:38 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
  0  Misfire Counter Cylinder 7
  0  Misfire Counter Cylinder 8
19:14:54 Group 032: Lambda Control (Mixture Adaptation)
  0.0 %  Adaptation (Idle) Bank 1 Sensor 1
  0.0 %  Adaptation (Partial) Bank 1 Sensor 1
  0.0 %  Adaptation (Idle) Bank 2 Sensor 1
  0.0 %  Adaptation (Partial) Bank 2 Sensor 1
19:14:54 Group 033: Lambda Control
  -19.5 %  Lambda Control Bank 1 Sensor 1
  1.500 V  Sensor Voltage Bank 1 Sensor 1
  2.3 %  Lambda Control Bank 2 Sensor 1
  1.560 V  Sensor Voltage Bank 2 Sensor 1
19:14:54 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
  2520 /min  Engine Speed (G28)
  490.0°C  Catalytic Converter Bank 1 Temp.
  0.290  Dynamic Factor Bank 1 Sensor 1
  Test OFF  Result Lambda Aging
19:15:33 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
19:15:33 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
19:15:33 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
19:17:38 Group 091: Camshaft Adjustment (Bank 1 Intake)
  2320 /min  Engine Speed (G28)
  5.1 %  Cam. Adjustment Intake Bank 1
  0.0°KW  Cam. Adjustment Intake B1 (spec.)
  -8.5°KW  Cam. Adjustment Intake B1 (act.)
19:17:38 Group 092: Camshaft Adjustment (Bank 2 Intake)
  0.0°KW  Cam. Adjustment Intake B2 (spec.)
  -6.0°KW  Cam. Adjustment Intake B2 (act.)
19:17:38 Group 093: Camshaft Adjustment Adaptation
     Phase Position Bank 1 Intake
     Phase Position Bank 2 Intake
19:17:54 Group 094: Camshaft Adjustment (Intake)
  -7.5°KW  Cam. Adjustment Intake B1 (act.)
  -7.0°KW  Cam. Adjustment Intake B2 (act.)
  Test OFF  Cam. Adj. Test Bank 1 Intake
  Test OFF  Cam. Adj. Test Bank 2 Intake
19:17:54 Group 095: Intake Manifold Change-Over
  2720 /min  Engine Speed (G28)
  16.5 %  Engine Load
  91.0°C  Coolant Temperature (G62)
  IMC-V OFF  Intake Manifold Change-Over
19:17:54 Group 096
19:18:54 Group 094: Camshaft Adjustment (Intake)
  -6.5°KW  Cam. Adjustment Intake B2 (act.)
19:18:54 Group 095: Intake Manifold Change-Over
  2440 /min  Engine Speed (G28)
  16.5 %  Engine Load
  93.0°C  Coolant Temperature (G62)
19:18:54 Group 096
19:20:56 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.000  Lambda Control Bank 1 (actual)
  1.000  Lambda Control Bank 1 (specified)
  1.008  Lambda Control Bank 2 (actual)
  1.000  Lambda Control Bank 2 (specified)
19:20:56 Group 032: Lambda Control (Mixture Adaptation)
  -18.0 %  Adaptation (Partial) Bank 1 Sensor 1
  0.8 %  Adaptation (Partial) Bank 2 Sensor 1
19:20:56 Group 033: Lambda Control
  1.6 %  Lambda Control Bank 1 Sensor 1
  1.560 V  Sensor Voltage Bank 1 Sensor 1
  -3.1 %  Lambda Control Bank 2 Sensor 1
  1.500 V  Sensor Voltage Bank 2 Sensor 1
19:21:04 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.008  Lambda Control Bank 1 (actual)
19:21:04 Group 032: Lambda Control (Mixture Adaptation)
19:21:04 Group 033: Lambda Control
  2.3 %  Lambda Control Bank 1 Sensor 1
  -0.8 %  Lambda Control Bank 2 Sensor 1
  1.520 V  Sensor Voltage Bank 2 Sensor 1
19:21:21 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
  2400 /min  Engine Speed (G28)
  540.0°C  Catalytic Converter Bank 1 Temp.
19:21:21 Group 035: Lambda Control (Aging Check: Bank 2 Sensor 1)
  540.0°C  Catalytic Converter Bank 2 Temp.
  0.290  Dynamic Factor Bank 2 Sensor 1
19:21:21 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
  0.680 V  Sensor Voltage Bank 1 Sensor 2
  B1-S2 OK  Result Lambda Availability
  0.625 V  Sensor Voltage Bank 2 Sensor 2
  B2-S2 OK  Result Lambda Availability
19:23:42 Group 001: General
  2000 /min  Engine Speed (G28)
  102.0°C  Coolant Temperature (G62)
  -7.8 %  Lambda Control Bank 1
  -3.9 %  Lambda Control Bank 2
19:23:42 Group 002: General
  2040 /min  Engine Speed (G28)
  15.0 %  Engine Load
  2.05 ms  Injection Timing
  13.33 g/s  Mass Air Flow Sensor (G70)
19:23:42 Group 003: General
  12.89 g/s  Mass Air Flow Sensor (G70)
  5.9 %  Throttle Valve Angle
  31.5 °BTDC  Ignition Timing Angle
19:24:49 Group 031: Lambda Control (Lambda Sensor Voltages)
  0.992  Lambda Control Bank 1 (actual)
  0.992  Lambda Control Bank 2 (actual)
19:24:49 Group 032: Lambda Control (Mixture Adaptation)
19:24:49 Group 033: Lambda Control
  -3.9 %  Lambda Control Bank 1 Sensor 1
  -9.4 %  Lambda Control Bank 2 Sensor 1
19:24:51 Group 031: Lambda Control (Lambda Sensor Voltages)
19:24:51 Group 032: Lambda Control (Mixture Adaptation)
19:24:51 Group 033: Lambda Control
  -2.3 %  Lambda Control Bank 1 Sensor 1
  1.540 V  Sensor Voltage Bank 1 Sensor 1
  1.6 %  Lambda Control Bank 2 Sensor 1
  1.580 V  Sensor Voltage Bank 2 Sensor 1
19:25:19 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
  2680 /min  Engine Speed (G28)
  535.0°C  Catalytic Converter Bank 1 Temp.
19:25:19 Group 035: Lambda Control (Aging Check: Bank 2 Sensor 1)
  535.0°C  Catalytic Converter Bank 2 Temp.
19:25:19 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
  0.640 V  Sensor Voltage Bank 1 Sensor 2
  0.600 V  Sensor Voltage Bank 2 Sensor 2
19:25:35 Group 037: Lambda Control (Delta Lambda Bank 1)
  15.0 %  Engine Load
  0.000  Delta Lambda Bank 1 Sensor 2Specification: -0.03...+0.03
  B1-S1 OK  Result Delta Lambda B1
19:25:35 Group 038: Lambda Control (Delta Lambda Bank 2)
  15.0 %  Engine Load
  0.590 V  Sensor Voltage Bank 2 Sensor 2
  0.000  Delta Lambda Bank 2 Sensor 2
  B2-S1 OK  Result Delta Lambda B2
19:25:35 Group 039: Lambda Control (Sensor Exchange)
  16.06 g/s  Mass Air Flow Sensor (G70)
  0.665 V  Sensor Voltage Bank 1 Sensor 2
  0.575 V  Sensor Voltage Bank 2 Sensor 2
  System OK  Result Sensor Exchange
19:26:41 Group 091: Camshaft Adjustment (Bank 1 Intake)
  2600 /min  Engine Speed (G28)
  -5.5°KW  Cam. Adjustment Intake B1 (act.)
19:26:41 Group 092: Camshaft Adjustment (Bank 2 Intake)
  2560 /min  Engine Speed (G28)
  -4.5°KW  Cam. Adjustment Intake B2 (act.)
19:26:41 Group 093: Camshaft Adjustment Adaptation
19:26:51 Group 094: Camshaft Adjustment (Intake)
  -6.0°KW  Cam. Adjustment Intake B1 (act.)
  -3.0°KW  Cam. Adjustment Intake B2 (act.)
19:26:51 Group 095: Intake Manifold Change-Over
  2640 /min  Engine Speed (G28)
  15.0 %  Engine Load
  106.0°C  Coolant Temperature (G62)
19:26:51 Group 096
19:29:04 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
19:29:04 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
19:29:04 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  61  Misfire Counter Cylinder 1
  11  Misfire Counter Cylinder 2
  29  Misfire Counter Cylinder 3
19:31:08 Group 032: Lambda Control (Mixture Adaptation)
19:31:08 Group 033: Lambda Control
  -3.1 %  Lambda Control Bank 1 Sensor 1
  1.620 V  Sensor Voltage Bank 1 Sensor 1
  7.8 %  Lambda Control Bank 2 Sensor 1
19:31:08 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
  760 /min  Engine Speed (G28)
  505.0°C  Catalytic Converter Bank 1 Temp.
19:31:35 Group 030: Lambda Control (Sensor Status)
     00110  Bank 1 Sensor 1
      0110  Bank 1 Sensor 2
     00110  Bank 2 Sensor 1
      0110  Bank 2 Sensor 2
19:31:35 Group 031: Lambda Control (Lambda Sensor Voltages)
  0.977  Lambda Control Bank 1 (actual)
  1.039  Lambda Control Bank 2 (actual)
19:31:35 Group 032: Lambda Control (Mixture Adaptation)
19:32:12 Group 030: Lambda Control (Sensor Status)
19:32:12 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.070  Lambda Control Bank 2 (actual)
19:32:12 Group 032: Lambda Control (Mixture Adaptation)
19:32:22 Group 033: Lambda Control
  0.0 %  Lambda Control Bank 1 Sensor 1
  1.880 V  Sensor Voltage Bank 1 Sensor 1
  0.0 %  Lambda Control Bank 2 Sensor 1
  1.760 V  Sensor Voltage Bank 2 Sensor 1
19:32:22 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
  485.0°C  Catalytic Converter Bank 1 Temp.
19:32:22 Group 035: Lambda Control (Aging Check: Bank 2 Sensor 1)
  485.0°C  Catalytic Converter Bank 2 Temp.
And here is the scan on completion of run, showing an error for mixture too rich - bank one.
Friday,19,August,2016,19:55:22:29481
VIN: WUARL48H95Kxxxxxx   License Plate:
Mileage: 170390km-105875mi   Repair Order: post run post DTC clear 8-19-2016
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WUARL48H95Kxxxxxx   Mileage: 170390km-105875miles
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8H0 910 560 L    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: 00000000    Serial number: AUX6Z0D0436780
   Coding: 0007774
   Shop #: WSC 00672 785 00200
   VCID: 316933DDAB5A73B6E2-5140
17535 - Fuel Trim; Bank 1 (Mult)
            P1127 - 002 - System too Rich
16556 - Fuel Trim; Bank 1
            P0172 - 002 - System Too Rich
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 001 -
16685 - Cylinder 1
            P0301 - 001 - Misfire Detected
16687 - Cylinder 3
            P0303 - 001 - Misfire Detected
Readiness: 0010 1101
   Part No SW: 8E0 910 156 R    HW: 09L 927 156
   Component: AG6 09L 4.2L5V USA  0060
   Revision: --H01---    Serial number:        0098085
   Coding: 0001002
   VCID: 356107CD5F325F96BE-515E
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 Q
   Component: ABS/ESP allrad      4533
   Coding: 04597
   Shop #: WSC 00672
   VCID: 366300C11234548EB7-5122
   Part No: 8E0 820 043 AM
   Component:   A4 Klimaautomat   2831
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6CD7E2A91CF8DE5E91-517C
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   Shop #: WSC 00672
   VCID: 356107CD0F325F96BE-4B1A
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW:
   Component: SDAR XM
   Revision:             Serial number: AUZ4Z7D2021424
   VCID: 2B5521B589761966D8-5198
02633 - Antenna for Satellite Tuner
            009 - Open or Short to Ground
            000 -  -
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 D
   Component: Airbag 8.4EC        0015
   Coding: 0010105
   VCID: 3B7511F5791689E648-515E
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01141
   Shop #: WSC 00672
   VCID: 3E7318E13A049CCE6F-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No SW: 8H0 920 980 S    HW: 8H0 920 980 S
   Component: KOMBI+WFS 3     H12 0020
   Revision: 0020        Serial number: AUX6Z0D0436780
   Coding: 0001231
   Shop #: WSC 19346 002 1048576
   VCID: 3F8D65E56D0E95C664-5140
Address 25: Immobilizer        Labels: 8E0-920-9xx-8E2.lbl
   Coding: 0001231
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255
   Component:  VSG  B6 CABRIO     6389
   VCID: 73E5F9D511C601A650-5140
   Part No: 8H0 959 760
   Component: Sitzmemory EE H06   0010
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74E7FAC944C8069E49-4B00
02011 - Right Entry Assistance Control Module (J573)
            49-00 - No Communications
02010 - Left Entry Assistance Control Module (J572)
            79-00 - Please Check Fault Codes
Address 37: Navigation        Labels: None
   Part No SW: 8H0 035 192 B    HW: 8H0 035 192 B
   Component: RNS-E US3       H53 0110
   Revision:      03S    Serial number: AUZBZ7E1700297
   Coding: 0419133
   Shop #: WSC 03751 444 57240
   VCID: 2643D0819294240E07-517C
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 81
                    Date: 2004.06.24
                    Time: 02:13:43
                    Mileage: 655350 km
                    Count: 2206
                    Clock: 20:30
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8H0 959 433 E
   Component: Komfortgerát T7B    3320
   Coding: 11788
   Shop #: WSC 00672
   VCID: 366300C11234548EB7-4B1A
   Subsystem 1 - Part No: 8H1959801B
   Component: Tõrsteuer.FS BRM 3020
   Subsystem 2 - Part No: 8H1959802B
   Component: Tõrsteuer.BF BRM 3020
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
01560 - Passenger Door
            59-10 - Can't Unlock - Intermittent
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00070
   Shop #: WSC 00672
   VCID: 0407AA091468361E79-4B32
Address 56: Radio        Labels: None
   Coding: 0419133
                    Reset counter: 81
                    Date: 2004.06.24
                    Time: 02:13:43
                    Mileage: 655350 km
                    Count: 2206
                    Clock: 20:30
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H13   0010
   Coding: 00006
   Shop #: WSC 00065
   VCID: 356107CD0F325F96BE-4B00
End-------------------------(Elapsed Time: 06:00)--------------------------
   #28
NostraJackAss
I think this car could really benefit from a decarburization by using chemicals in gas and intake misted........
   #29
ivagp
C?ID=95551
your engine has vvt that relies on oil pressure. when the engine is cold typically you have good oil pressure, so you have good idle when cold. after warm up when engine drops back to idle you need to check 91 and 92. on both banks check .3 and .4 when cold and when hot,at idle and 2500rpm. they need to mirror each other. you also mentioned u cleared the cam codes was it something like p0011 p0012. if you have trouble after warm you need to check oil pressure.
   #30
NostraJackAss
The same can be said when engine cold....... it is a rich mixture for warm-up loop.....and when hot that carbon soaks fuel like a sponge, or if air leaks are present for false air you get the same result.
You could try a thicker oil to see if it improves warm up idle........ like IVAGP stated about oil PSI......to further test.
   #31
RichS
C?ID=222890
Jack, I think that's a good idea, I am about one more attempt away from a trip to the dealer.
Ivagp, I logged some MB's up in the 90's. I am open to interpretation, I have not yet checked oil pressure - thank you. It is close to the end of it's oil change cycle, I use the recommended oil - Mobil1 0W40
Lots of work and lots of internal photos in the past few days.
I did an intake flapper valve test, and found that my intake valve flapper is stuck mechanically - the actuator tries to open it at 5000 rpm but cannot. I cannot turn it by hand.
I put a camera inside the injector bore, and the valves appeared shiny. I cannot tell if the manifold surfaces have carbon deposits.
I removed the injector rail assembly, ran the fuel pump with VAG-COM, and measured the injector output. I also noticed that 6 of eight injectors (#'s 2 through 7) were missing pintles; some of the o-rings stayed in the injector bores. The injector bores are without landings in this 40V engine, and the pintle is all that holds it in place against suction. That means the o-rings can be sucked past the injector tip, creating a vacuum leak. Someone had attempted a seal with mysterious brown goo that may or may not have worked. I installed new pintles from O'Reilly (BWD #274081), but they are obviously wrong - the hole obstructed the spray pattern. I modified them to work (see photo) but whether they melt off is anyone's guess.
Before cleaning, the injectors (079133551B) all flowed nearly within Audi / Bentley spec (spec is 105-125 mL in 30 seconds). The injectors flowed 87-92 grams, or 124-131 mL. My measuring method was probably less accurate than that range. After ultrasonic cleaning, and an improved measurement method (my wife helped me time the injector cycle) the flows were unchanged, but the spray patterns looked more consistent. I see five holes in this injector (or are they all really holes?), but I only see two major sprays, does that sound correct? (see photos and videos).
After clearing DTY's and reassembly, the car ran more smoothly, but still had a miss at idle. The MIL light came on after a few minutes. The miss started on #1.
I would really like to figure out the root cause of this - why it came on so suddenly.
The engine seems extremely hot under the hood. The paint on the valve covers is flaking and peeling. I did log catalytic converter temperatures.
Here are photos:
And logs, quite big, I still am not sure what to look for. Most were done at 1000 rpm and idle.
Sunday,21,August,2016,12:02:40:29481
Mileage:    Repair Order: post injectior clean pintle addition 8-21-2016 warm
Control Module Part Number: 8H0 910 560 L    HW: 8E0 907 560
  Component and/or Version: 4.2L V8/5V      G   0010
           Software Coding: 0007774
            Work Shop Code: WSC 00672 785 00200
            P0300 - 001 -
16685 - Cylinder 1
17538 - Fuel Trim; Bank 2 (Mult)
            P1130 - 001 - System too Lean
16558 - Fuel Trim; Bank 2
            P0174 - 001 - System Too Lean
12:05:28 Group 001: General
  1080 /min  Engine Speed (G28)
  97.0°C  Coolant Temperature (G62)
  5.5 %  Lambda Control Bank 1
  -4.7 %  Lambda Control Bank 2
12:05:28 Group 002: General
  1120 /min  Engine Speed (G28)
  16.5 %  Engine Load
  2.46 ms  Injection Timing
  7.97 g/s  Mass Air Flow Sensor (G70)
12:05:28 Group 003: General
  8.03 g/s  Mass Air Flow Sensor (G70)
  3.5 %  Throttle Valve Angle
  15.8 °BTDC  Ignition Timing Angle
12:05:45 Group 001: General
  1920 /min  Engine Speed (G28)
  98.0°C  Coolant Temperature (G62)
  0.8 %  Lambda Control Bank 1
  -7.0 %  Lambda Control Bank 2
12:05:45 Group 002: General
  1960 /min  Engine Speed (G28)
  15.0 %  Engine Load
  13.11 g/s  Mass Air Flow Sensor (G70)
12:05:45 Group 003: General
  13.22 g/s  Mass Air Flow Sensor (G70)
  5.1 %  Throttle Valve Angle
  30.8 °BTDC  Ignition Timing Angle
12:06:25 Group 001: General
  2800 /min  Engine Speed (G28)
  7.0 %  Lambda Control Bank 1
12:06:25 Group 002: General
  2840 /min  Engine Speed (G28)
  15.8 %  Engine Load
  19.56 g/s  Mass Air Flow Sensor (G70)
12:06:25 Group 003: General
  18.97 g/s  Mass Air Flow Sensor (G70)
  7.5 %  Throttle Valve Angle
  39.8 °BTDC  Ignition Timing Angle
12:09:05 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  39  Misfire Counter Cylinder 1
12:09:05 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
12:09:08 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  40  Misfire Counter Cylinder 1
12:09:08 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
12:10:41 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  76  Misfire Counter Cylinder 1
12:10:41 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
12:10:41 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
12:10:52 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  137  Misfire Counter Cylinder 1
  8  Misfire Counter Cylinder 2
  17  Misfire Counter Cylinder 3
12:10:52 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
  6  Misfire Counter Cylinder 4
12:10:52 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
12:10:56 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  161  Misfire Counter Cylinder 1
  21  Misfire Counter Cylinder 3
12:10:56 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
  7  Misfire Counter Cylinder 4
12:10:56 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
12:11:02 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  199  Misfire Counter Cylinder 1
  19  Misfire Counter Cylinder 2
  34  Misfire Counter Cylinder 3
12:11:02 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
12:11:02 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
12:12:54 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  22  Misfire Counter Cylinder 1
12:12:54 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
12:12:54 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
12:13:36 Group 018: Ignition (Misfire Recognition - RPM/Load Barriers)
  880 /min  Lower RPM Barrier
  1640 /min  Upper RPM Barrier
  20.0 %  Lower Load Barrier
  20.0 %  Upper Load Barrier
12:13:36 Group 020: Ignition (Timing Retardation Cylinder 1-4)
  0.0°KW  Timing Retardation Cylinder 1
  0.0°KW  Timing Retardation Cylinder 2
  0.0°KW  Timing Retardation Cylinder 3
  0.0°KW  Timing Retardation Cylinder 4
12:13:36 Group 021: Ignition (Timing Retardation Cylinder 5-8)
  0.0°KW  Timing Retardation Cylinder 5
  0.0°KW  Timing Retardation Cylinder 6
  0.0°KW  Timing Retardation Cylinder 7
  0.0°KW  Timing Retardation Cylinder 8
12:14:09 Group 022: Ignition (Timing Retardation Cylinder 1 && 2)
  1160 /min  Engine Speed (G28)
  15.8 %  Engine Load
12:14:09 Group 023: Ignition (Timing Retardation Cylinder 3 && 4)
  15.8 %  Engine Load
12:14:09 Group 024: Ignition (Timing Retardation Cylinder 5 && 6)
  15.8 %  Engine Load
12:14:44 Group 025: Ignition (Timing Retardation Cylinder 7 && 8)
  15.8 %  Engine Load
12:14:44 Group 026: Ignition (Knock Control Cylinder 1-4)
  1.287 V  Knock Sensor Voltage Cylinder 1
  1.053 V  Knock Sensor Voltage Cylinder 2
  1.638 V  Knock Sensor Voltage Cylinder 3
  1.521 V  Knock Sensor Voltage Cylinder 4
12:14:44 Group 027: Ignition (Knock Control Cylinder 5-8)
  0.936 V  Knock Sensor Voltage Cylinder 5
  0.936 V  Knock Sensor Voltage Cylinder 6
  1.053 V  Knock Sensor Voltage Cylinder 7
  1.521 V  Knock Sensor Voltage Cylinder 8
12:15:33 Group 028: Ignition (Knock Sensor Test)
  16.5 %  Engine Load
  Test OFF  Knock Sensor Test Result
12:15:33 Group 029
12:15:33 Group 030: Lambda Control (Sensor Status)
     00111  Bank 1 Sensor 1
     00111  Bank 2 Sensor 1
12:15:38 Group 028: Ignition (Knock Sensor Test)
  1040 /min  Engine Speed (G28)
  15.8 %  Engine Load
12:15:38 Group 029
12:15:38 Group 030: Lambda Control (Sensor Status)
     00011  Bank 1 Sensor 1
     00011  Bank 2 Sensor 1
12:16:24 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.000  Lambda Control Bank 2 (actual)
12:16:24 Group 032: Lambda Control (Mixture Adaptation)
  -0.2 %  Adaptation (Idle) Bank 1 Sensor 1
  -21.1 %  Adaptation (Partial) Bank 1 Sensor 1
  20.3 %  Adaptation (Partial) Bank 2 Sensor 1
12:16:24 Group 033: Lambda Control
  -1.6 %  Lambda Control Bank 1 Sensor 1
  1.520 V  Sensor Voltage Bank 1 Sensor 1
  1.540 V  Sensor Voltage Bank 2 Sensor 1
12:16:55 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
  470.0°C  Catalytic Converter Bank 1 Temp.
12:16:55 Group 035: Lambda Control (Aging Check: Bank 2 Sensor 1)
  470.0°C  Catalytic Converter Bank 2 Temp.
12:16:55 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
  0.805 V  Sensor Voltage Bank 1 Sensor 2
  0.140 V  Sensor Voltage Bank 2 Sensor 2
12:17:26 Group 037: Lambda Control (Delta Lambda Bank 1)
  15.8 %  Engine Load
  0.820 V  Sensor Voltage Bank 1 Sensor 2
  Test OFF  Result Delta Lambda B1
12:17:26 Group 038: Lambda Control (Delta Lambda Bank 2)
  15.8 %  Engine Load
  0.145 V  Sensor Voltage Bank 2 Sensor 2
  Test OFF  Result Delta Lambda B2
12:17:26 Group 039: Lambda Control (Sensor Exchange)
  6.72 g/s  Mass Air Flow Sensor (G70)
  0.150 V  Sensor Voltage Bank 2 Sensor 2
  Test OFF  Result Sensor Exchange
12:18:33 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
  78 ohms  Resistance Bank 1 Sensor 1
  Htg. S1 OFF  Heater Condition
  0.10 kOhm  Resistance Bank 1 Sensor 2
  Htg. S2 ON  Heater Condition
12:18:33 Group 042: Lambda Control (Lambda Sensor Heating Bank 2)
  78 ohms  Resistance Bank 2 Sensor 1
  Htg. S1 ON  Heater Condition
  0.00 kOhm  Resistance Bank 2 Sensor 2
12:18:33 Group 043: Lambda Control (Aging Check: Bank 1 Sensor 2)
  410.0°C  Catalytic Converter Bank 1 Temp.
  0.810 V  Lambda Voltage Bank 1 Sensor 1
  Test OFF  Lambda Sensor Aging Test B1S2
12:19:08 Group 043: Lambda Control (Aging Check: Bank 1 Sensor 2)
  0.815 V  Lambda Voltage Bank 1 Sensor 1
12:19:08 Group 044: Lambda Control (Aging Check: Bank 2 Sensor 2)
  410.0°C  Catalytic Converter Bank 2 Temp.
  0.165 V  Lambda Voltage Bank 2 Sensor 1
  B2-S2 OK  Lambda Sensor Aging Test B2S2
12:19:08 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
  560.0°C  Catalytic Converter Bank 1 Temp.
  0.30  Catalytic Conversion Bank 1
  Test OFF  Cat. Conversion Test Bank 1
12:19:31 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
  1000 /min  Engine Speed (G28)
12:19:31 Group 047: Lambda Control (Catalytic Conversion Test Bank 2)
  560.0°C  Catalytic Converter Bank 2 Temp.
  0.30  Catalytic Conversion Bank 2
  Test OFF  Cat. Conversion Test Bank 2
12:19:31 Group 050: Idle Speed Stabilization
  990 /min  Engine Speed (actual)
  860 /min  Engine Speed (specified)
  A/C-Low  A/C Readiness
  Compr.OFF  A/C Compressor
12:19:34 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
12:19:34 Group 047: Lambda Control (Catalytic Conversion Test Bank 2)
12:19:34 Group 050: Idle Speed Stabilization
  970 /min  Engine Speed (actual)
  850 /min  Engine Speed (specified)
12:21:23 Group 060: Electronic Throttle (Throttle Body Alignment)
  12.5 %  Throttle Valve Sensor 1 (G187)
  86.7 %  Throttle Valve Sensor 2 (G188)
  0  Throttle Valve Steps Counter
  ADP. O.K.  Throttle Body Alignment Status
12:21:23 Group 064: Electronic Throttle (Sensor Adaption Values)
  0.520 V  Lower Adaptation Sensor 1 (G187)
  4.560 V  Lower Adaptation Sensor 2 (G188)
  0.700 V  Emergency Air Gap Sensor 1 (G187)
  4.380 V  Emergency Air Gap Sensor 2 (G188)
12:21:23 Group 066: Electronic Throttle (Cruise Control System)
  0.0 km/h  Vehicle Speed (current)
  00001000  Switch Positions I
  0.0 km/h  Vehicle Speed (specified)
  10000001  Switch Positions II
12:22:14 Group 070: Emission Reduction (EVAP Valve Test)
  42.0 %  Evap. Emissions Sol. Valve (Open)
  0.0 %  Evap. Emissions Sol. Valve (Flow)
  Test OFF  EVAP Valve Test
12:22:14 Group 077: Emission Reduction (Secondary Air Injection: Bank 1)
  6.81 g/s  Mass Air Flow Sensor (G70)
  -100.0 %  Air Mass from Sec. Air Inj. Bank 1
  Abort  Secondary Air Injection Test B1
12:22:14 Group 078: Emission Reduction (Secondary Air Injection: Bank 2)
  6.69 g/s  Mass Air Flow Sensor (G70)
  -68.0 %  Air Mass from Sec. Air Inj. Bank 2
  Abort  Secondary Air Injection Test B2
12:23:04 Group 080: Advanced Control Module Identification I
     <>   15.02.05    <>     <>  0395  Advanced Identification I
12:23:04 Group 086: Readiness Code I
  00101101  Readiness Bits
  00001111  Cycle Flags I
  01111100  Cycle Flags II (Part 1)
  00010100  Cycle Flags II (Part 2)
12:23:04 Group 087: Readiness and Error Bits
  00000000  Error Flags I
  00000000  Error Flags II (Part 1)
  00000000  Error Flags II (Part 2)
12:23:32 Group 088: Cycle Flags
  11110000  Cycle Flags I
  00101101  Cycle Flags II
  00001000  Cycle Flags III
12:23:32 Group 089: On-Board-Diagnostics (OBD)
     Distance Driven with MIL on
  OK  Tank Condition
12:23:32 Group 091: Camshaft Adjustment (Bank 1 Intake)
  48.2 %  Cam. Adjustment Intake Bank 1
  12.0°KW  Cam. Adjustment Intake B1 (spec.)
  10.5°KW  Cam. Adjustment Intake B1 (act.)
12:23:59 Group 091: Camshaft Adjustment (Bank 1 Intake)
  46.3 %  Cam. Adjustment Intake Bank 1
  11.5°KW  Cam. Adjustment Intake B1 (act.)
12:23:59 Group 092: Camshaft Adjustment (Bank 2 Intake)
  43.1 %  Cam. Adjustment Intake Bank 1
  12.0°KW  Cam. Adjustment Intake B2 (spec.)
  13.0°KW  Cam. Adjustment Intake B2 (act.)
12:23:59 Group 093: Camshaft Adjustment Adaptation
  -6.0°KW  Phase Position Bank 1 Intake
  -6.0°KW  Phase Position Bank 2 Intake
12:24:03 Group 091: Camshaft Adjustment (Bank 1 Intake)
  47.8 %  Cam. Adjustment Intake Bank 1
  12.5°KW  Cam. Adjustment Intake B1 (spec.)
12:24:03 Group 092: Camshaft Adjustment (Bank 2 Intake)
  46.7 %  Cam. Adjustment Intake Bank 1
  12.5°KW  Cam. Adjustment Intake B2 (spec.)
  12.0°KW  Cam. Adjustment Intake B2 (act.)
12:24:03 Group 093: Camshaft Adjustment Adaptation
12:24:15 Group 091: Camshaft Adjustment (Bank 1 Intake)
  2120 /min  Engine Speed (G28)
  42.7 %  Cam. Adjustment Intake Bank 1
  27.5°KW  Cam. Adjustment Intake B1 (spec.)
  28.0°KW  Cam. Adjustment Intake B1 (act.)
12:24:15 Group 092: Camshaft Adjustment (Bank 2 Intake)
  2080 /min  Engine Speed (G28)
  42.4 %  Cam. Adjustment Intake Bank 1
  27.5°KW  Cam. Adjustment Intake B2 (spec.)
  29.0°KW  Cam. Adjustment Intake B2 (act.)
12:24:15 Group 093: Camshaft Adjustment Adaptation
12:25:11 Group 091: Camshaft Adjustment (Bank 1 Intake)
  3120 /min  Engine Speed (G28)
  39.5°KW  Cam. Adjustment Intake B1 (spec.)
  39.0°KW  Cam. Adjustment Intake B1 (act.)
12:25:11 Group 092: Camshaft Adjustment (Bank 2 Intake)
  45.1 %  Cam. Adjustment Intake Bank 1
  39.5°KW  Cam. Adjustment Intake B2 (spec.)
  39.5°KW  Cam. Adjustment Intake B2 (act.)
12:25:11 Group 093: Camshaft Adjustment Adaptation
12:25:36 Group 091: Camshaft Adjustment (Bank 1 Intake)
  40.4 %  Cam. Adjustment Intake Bank 1
  14.5°KW  Cam. Adjustment Intake B1 (act.)
12:25:36 Group 092: Camshaft Adjustment (Bank 2 Intake)
12:25:36 Group 093: Camshaft Adjustment Adaptation
12:27:07 Group 093: Camshaft Adjustment Adaptation
12:27:07 Group 094: Camshaft Adjustment (Intake)
  12.5°KW  Cam. Adjustment Intake B1 (act.)
  12.5°KW  Cam. Adjustment Intake B2 (act.)
  System OK  Cam. Adj. Test Bank 1 Intake
  System OK  Cam. Adj. Test Bank 2 Intake
12:27:07 Group 095: Intake Manifold Change-Over
  17.3 %  Engine Load
  104.0°C  Coolant Temperature (G62)
12:27:35 Group 093: Camshaft Adjustment Adaptation
12:27:35 Group 094: Camshaft Adjustment (Intake)
12:27:35 Group 095: Intake Manifold Change-Over
  16.5 %  Engine Load
12:28:12 Group 093: Camshaft Adjustment Adaptation
12:28:12 Group 094: Camshaft Adjustment (Intake)
  27.0°KW  Cam. Adjustment Intake B1 (act.)
  23.0°KW  Cam. Adjustment Intake B2 (act.)
12:28:12 Group 095: Intake Manifold Change-Over
  14.3 %  Engine Load
12:28:23 Group 093: Camshaft Adjustment Adaptation
12:28:23 Group 094: Camshaft Adjustment (Intake)
  41.5°KW  Cam. Adjustment Intake B1 (act.)
  41.5°KW  Cam. Adjustment Intake B2 (act.)
12:28:23 Group 095: Intake Manifold Change-Over
  3320 /min  Engine Speed (G28)
  16.5 %  Engine Load
                      VCID: 316933DDAB5A73B6E2-515E
7 Faults Found:
            P0300 - 001 -
16685 - Cylinder 1
16687 - Cylinder 3
            P0303 - 002 - Misfire Detected
12:31:52 Group 014: Ignition (Misfire Recognition - Total)
  18.0 %  Engine Load
  139  Misfire Counter
12:31:52 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
  124  Misfire Counter Cylinder 1
  3  Misfire Counter Cylinder 3
12:31:52 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
  3  Misfire Counter Cylinder 4
NostraJackAss
I would take those air shrouds off and toss in the garbage.
I wonder if your miss is injector related still, by moving to do isolation test or if the ground to the coil is insufficient.
Swap coil, plug, injector, and overlay the two grounds, trigger and power just to be sure.
Isolate!
I like your post, however, testing this way........... is negating the PSI drop across the entire threshold of volume or PSI when multiple injectors are open.
Additionally alligator clips to arc is a no no!
   #33
nathan
C?ID=167279
hi rich
i had an s4 for 9 years and know a fair bit about how to repair these cars
the engine in this car is actually the bbk unit ... not the bhf unit which was in the audi a8
there is a technical service bulletin regarding swapping the coil packs as an "upgrade" audi wont admit that the coils packs can and actually do cause fires (mine tried it whilst i was filling it with petrol in a filling station with my 8 year old daughter in the back
of the car )
so id speak to audi and see if there is any outstanding work to be completed on the car specifically the coil packs
right on the front of the engine between the front scuttle and the front of the block there is a small actuator which when revved above 5000rpm should turn 90 degrees
if it doesnt then this is one of the faults which needs curing
if the car is still on the original exhaust check if it has "ex ups" on the back box
these open up above 3500 rpm to give the beast a little bit of a roar and work off the vaccum pipes which go under the back bumper and then into the car (not all cars had these )
again check the vac lines as they are prone for damage
if you need any more help or info my email is dualmono21@hotmail.com
nath
   #34
NostraJackAss
Almost all coil packs from back then fell into the major coil pack campaign or service action.
The coils fail due to insufficient grounds or spring tension of the coil pack connectors.
RichS
C?ID=222890
Jack, a question for you – what plastic shroud should I pitch? I am having a little trouble finding the coil ground location, any ideas on where to look? Finding that ground is the next focus. Spring tension of the connector…Good thought, I’ll look there also. Thanks.
Nathan, thank you for the insight, glad your car didn’t go up in flames especially with an 8 year old. The coil packs appear to have been replaced, the Audi website says so anyway, although I am not sure when. I swapped coils, injectors, replaced plugs, and the misfire remained in cylinder #1. The #1 plug, as removed, looked very black…see the first posts. The rotary flapper valve is stuck, I can see the actuator trying to move it but it cannot. Nor can it be moved by hand. I think I may pull the manifold to see if the missing pintles melted onto something and made the flapper stick.
Rich
   #36
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I have used this guy's parts and I'm happy with them:
http://www.mrinjectorparts.com/store/c9/Top_Feed_Kits.html
Jason
   #38
nathan
C?ID=167279
richs
if you do decide to take the manifold off and you cant manage to unstick the actuator im lead to believe there is now a repair kit available to fix
there didnt use to be one available but im told there now is
   #39
RichS
C?ID=222890
Run each set of grounds to each coil to battery ground.
2 for each coil as per WD.
Jack, what is WD? Is there a set of interim connectors that I can place between the coil and the and the ignition harness to take a ground from?
I have photos of what I think are the grounds, as near as I can tell...two brown wires that emerge from the ignition harness to the center of the firewall, directly between engine and firewall. I have yet to find the ground location described in the Bentley manual in a way I understand.
Thank you for the help so far.
Rich
   #40
RichS
C?ID=222890
Good to know - There are a few procedures for unsticking the actuator that involve moving the lock carrier (bumper & grille) to the forward position; is it easier to remove the manifold to work on it?
Thank you for the insight!
Rich
