Mk6 golf steering wheel into mk5 issues.
The Red Warrior
New Zealand
C?ID=277311
Hi all from New Zealand.
I'm having a few issues with my retrofit of a MFSW from a mk6 Golf GTI into my mk5 Golf GTI.
Just a little info in case it makes a difference: my car is a 2005 manual and didn't have a MFSW as standard.
It's also running APR stage 2+ software.
So, after buyiing the steering wheel and airbag along with the other parts I needed due to researching this site and various others such as mk5golfgti.co.uk I ended up with the different wiring loom, CH version steering wheel control module and a G version cruise control stalk.
The install of all parts was easy enough, but it took several attempts to clear the steering wheel symbol from the dash and the associated codes by doing the reset and basic procedures steps.
However, I still have these errors:
Engine
005784 P1698 - 001
Steering wheel
00895 014 - Defective
Gateway
00003 014 - Defective
They all seem to relate to the cruise control stalk. Also the tyre pressure warning light is flashing on the dash. Pressing the button to reset it just makes it light up solid and then when you release the button it starts flashing again.
I've taken apart the cruise control stalk as per a link in the vcds wiki pages I've found and checked for corrosion but it's all good as you would expect being new.
Strangely I can clear the fault code in the steering wheel option on vcds and it stays cleared. However when I re- check it after going into the can gateway option it will have reappeared.
I didn't take an auto scan of my car beforehand unfortunately.
I've tried selecting different versions (4 or 6 position) of the cruise control stalk under the steering wheel options but this hasn't helped.
When checking outputs with vcds it shows when I have the cruise control switch on or off (although it he cruise control icon doesn't show up on the dash) and indicator and high beam all work as they should. I can't find anywhere that shows the output test for the set and resume buttons though.
When coding after the install the steering wheel module already had a code and after selecting the multi function steering wheel with push to talk ( I guess this is correct as that is referring to the microphone symbol?) vcds said this was an uncoded module and did I want to use default codes of 12345 etc. I selected no to leave in the code that was in there. I've since tried 12345 as well without luck.
Should I have written down my coding from my original steering wheel module and used that?
I'll pull it all apart and reinstall that to get the code off it if need be, but don't want to go down that route if I don't need to
Anything anyone can think of that I've done wrong or aren't doing?
Thanks in advance for any help.
Ps I've searched the forums for this and although I find similar problems they never have the resolution posted.
The Red Warrior
New Zealand
C?ID=277311
Please post a complete Auto-Scan so people can see these issues in full context.
Sunday,14,August,2016,17:03:08:48248
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WVWZZZ1KZ5U026982   License Plate:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: WVWZZZ1KZ5U026982   Mileage: 143070km-88899miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E1874300
   Coding: 0403000318070160
   Shop #: WSC 00080 824 179521
   VCID: 63C5DAF2A2E9C05ADD-8036
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -
                    Fault Status: 01100001
                    Fault Frequency: 15
                    Mileage: 142846 km
                    Time: 11:28:46
                    RPM: 759 /min
                    Load: 15.7 %
                    Temperature: 83.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
Readiness: 0000 0001
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 00046 412 00000
   VCID: 3A7B479675E3E192AE-806E
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 6DD1BCCABC2D862A7B-8038
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [009] - Actuator stuck
                    Fault Frequency: 131
                    Reset counter: 243
                    Mileage: 142834 km
                    Time: 08:46:48
9472882 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 240
                    Mileage: 142834 km
                    Time: 19:41:36
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H37 0803
   Revision: 00H37000    Serial number: 00000001736947
   Coding: E78F0B060004180000140000140000000009FE055C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 3J AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD024YEB
   Coding: 0013130
   VCID: 2E537BC6B9AB3D3202-807A
   Subsystem 1 - Serial number: 6332MSME094F0742C
   Subsystem 2 - Serial number: 6342MSME093E1D05H
   Subsystem 3 - Serial number: 6351HSME0676472ED
   Subsystem 4 - Serial number: 6361HSME06604341Z
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0000734
   Shop #: WSC 131071 102 209715
   VCID: 7AFB879635632192EE-802E
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No: 1K6 920 860 E
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0005703
   Shop #: WSC 33895 000 104857
   VCID: 306F65BEA39F2BC210-8064
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 200113F1001586
   Coding: 350003
   Shop #: WSC 00079 790 12345
   VCID: 3F8D3682AEC1C4BA99-806A
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Date: 2000.14.00
                    Time: 00:00:23
   Component: IMMO            VDD 0812
   Shop #: WSC 00080 824 89442
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0148
   Coding: 0000070
   VCID: 326B6FB6AD9319D266-8066
00120 - Outside Warning Light/Door exit Light Driver Side
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.0       1502
   VCID: 316960BAA89522CA1F-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AM
   Coding: 08C802087F2D8405485F01E010CC
   VCID: 7BF582923A59189AF5-802E
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000070
   VCID: 33656AB2528910DA6D-8066
00121 - Outside Warning Light/Door exit Light Passenger Side
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   VCID: 74E7A9AE170757E2B4-8020
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  053 0213
   Revision: 00000001    Serial number: VWZ1Z3P3158648
   Coding: 0100040004000C
   VCID: 23459AF22269805A9D-8076
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007665888803
   Coding: 0A10000000010101
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3C77418EB7D7DFA2BC-8068
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 240
                    Mileage: 142834 km
                    Time: 19:41:36
End-------------------------(Elapsed Time: 02:10)--------------------------
I've found this too which looks like it relates to my car and this retrofit:
http://wiki.ross-tech.com/wiki/index.php/Cruise_Control_Retrofitting_(1K)
Specifically this bit:
Add the Wiring from Steering Column Control Module to the Engine Control Module. This step used to be necessary before MY 2006/2007 but as of MY 2010 several Users have reported missing Wiring when the Vehicle was not Factory equipped with Cruise Control. Check the proper Wiring Diagrams for the Vehicle in question.
For Steering Wheel Control Module P/N 1K0-953-549-* check Connector/Pin T20/13.
For Steering Wheel Control Module P/N 5K0-953-549-* and 5K0-953-569-* check Connector/Pin T16/5.
Just not sure what this means. Do i have to re-pin some plugs or add additional wires or something else altogether?
Ta, Mike.
golfi_vend
Tartu, Estonia
C?ID=195131
Hi
Your new cruise stalk is defective. Is it s real "G" stalk? From ebay? Some have bad contact in slider, open the stalk and you should be able to fix this.
Or if this is not real G modification to wiring is needed, sameway any old stalk could be modified to work wiyh newer swcm.
Engine fault is related to this, can gw you will need new if you want to get rid of the fault.
The Red Warrior
New Zealand
C?ID=277311
Hi
Cheers for the quick reply.
I can't say for sure if it's a real "G" stalk although the sticker with the part number has G as does the bag that it came in. I realise that's no guarantee though. Or are you saying it may be an older version of a genuine stalk that has the newer markings like a "G" version but isn't wired as a "G" one?
Now that you mention it, my old CC stalk was the "A" version with the sliding switch on top only having "OFF" and "ON". The new one has "CANCEL" as well between "OFF" and "ON", but there is no definitive detent there. It just sort of sits in 'no mans land'.
It is from ebay. It came as a kit including the CH steering wheel control module and the wiring loom for the steering wheel. I read about some having bad contacts and saw the 'how to' on how to pull it apart and clean the contacts of the sliding mechanism. VCDS showed that this switch was working beforehand anyway, but none the less I pulled it apart and clean it just to be sure.
I don't have a problem with modifying my old cruise control stalk. (Wish I'd seen this mod slightly sooner as I could have saved myself buying the new CC stalk).
Not sure I understand what you mean by I'll need a new CAN gateway to get rid of the engine fault though.
Ta, Mike.
golfi_vend
Tartu, Estonia
C?ID=195131
Sorry for confusion. For getting rid of can-gw fault, you'll need need gw.
For ccs mod ill post later.
golfi_vend
Tartu, Estonia
C?ID=195131
Everything for mod can be seen on this pic:
attachment.php
The Red Warrior
New Zealand
C?ID=277311
Well well well. Guess what? My "G" revision CC stalk is not a "G" revision at all! I've taken it out and the yellow wires go into pins 5 & 10 just like an "A" revision.
So I'll just modify my old stalk like in your photo and put that back in and see what happens.
I'll give you an update to let you know how it goes.
I'll be emailing the seller of the CC stalk. Grrr!
The Red Warrior
New Zealand
C?ID=277311
So after doing the wiring mod to the CC and installing it all back together I took car for a tiny drive to go and to do the steering angle sensor and the Steering Limit Stop Adaptation. But after going just afew meters the steering wheel light, ESP and ABS lights all went and and steering felt normal. At this point i checked for fault codes and Engine, ABS, Steering Wheel, Steering Assist and CAN gateway were all clear.
However, I still had the tyre pressure symbol flashing on the instrument cluster and pressing the button to reset it didn't work.
I thought maybe it will go away if I redo the steering angle sensor and the Steering Limit Stop Adaptation. Alas, it didn't and I now also have the fault back in the CAN gateway and it wont clear.
Cruise control is now working and the faults relating to it are gone. I'll have to do some more investigating about these issues unless anyone has some ideas.
Looks like your first post golfi_vend was close to spot on. Cheers.
Here's my auto scan as it stands now:
Monday,15,August,2016,20:17:44:48248
VIN: WVWZZZ1KZ5U026982   Mileage: 143100km-88918miles
   Coding: 0004738
   Revision: 00003001
   Coding: 0000000000
          B108B 71 [008] - Actuator stuck
                    Fault Frequency: 187
                    Reset counter: 30
                    Mileage: 142834 km
                    Time: 08:46:48
                    Reset counter: 240
                    Mileage: 142834 km
                    Time: 19:41:36
   Coding: 00049109
   Coding: 00218142
   Coding: 0013130
   Coding: 0000734
   Coding: 00000130
   Coding: 0005703
   Coding: 350003
            014 - Defective
                    Date: 2000.14.00
                    Time: 00:00:23
   Coding: 0000070
   Coding: 0000070
   Coding: 0000003
   Coding: 0000016
   Coding: 0000016
   ROD: EV_UHVNA.rod
                    Reset counter: 240
                    Mileage: 142834 km
                    Time: 19:41:36
End-------------------------(Elapsed Time: 02:09)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
Use / before code on last code. Eg. [/Code]
The Red Warrior
New Zealand
C?ID=277311
Found this in a reasonably recent post on mk5golfgti.co.uk forum and it was exactly what I needed:
Copied from rosstech:
Pressure Monitoring System Reset
This procedure will NOT apply unless the vehicle has ABS based Tire Pressure Monitoring (PR-7K1/7K6) installed!
Prerequisites:
Ignition ON
[Select]
[03 - Brake Electronics]
[Basic Settings - 04]
Group 042
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
[Done, Go Back]
The Tire Pressure Monitoring Lamp (K220) should blink.
Now check the Tire Pressure and correct it if necessary.
Press and Hold the Tire Pressure Monitoring Button (E492) AND the ASR/ESP Button (E256) for 2 Seconds.
A short Tone should sound after pressing/holding these buttons for 2 Seconds and the blinking should change to a permanent lit Tire Pressure Monitoring Lamp (K220).
The Reset is now done and as soon as you let the buttons go the Tire Pressure Monitoring Lamp (K220) should go OFF.
Did this a warning light on instrument cluster is gone. :D
I still have the fault in the CAN gateway but I've no idea what it's referring to. It doesn't seem to be affecting anything.
I've got 8 out of the 12 buttons on the steering wheel working, but possibly cant get them all to work as I only have a midline MFD.
So, happy days. Thanks all.
Joren
Belgium
C?ID=359640
I also dit a golf 6 gti steering wheel retrofit in a golf 5 GTI
My cruise control doesnt work
Can you tell how to make it work?
NitrousOxide
Jamaica
C?ID=269481
Correction: all 12 buttons now work for me
NitrousOxide
Jamaica
C?ID=269481
You need to post an Auto Scan for the team to assist you
Cruise control needs to be enabled in the engine control module as well as address 16.
Joren
Belgium
C?ID=359640
I had cruise control before, when i place the old steering colum module the cruise control Works.
I think i also need to reconnect the yellow wires.
My wiring is now from left to right under blue white green red yellow
Above nothing white green red yellow
Joren
Belgium
C?ID=359640
Friday,04,December,2020,17:02:46:17260
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ6P014777   License Plate:
Mileage: 232010km-144164mi   Repair Order:
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76
VIN: WVWZZZ1KZ6P014777   Mileage: 232010km-144164miles
37-Navigation -- Status: Not registered 0011
   Part No SW: 1K0 907 115 T    HW: 1K0 907 115 A
   Revision: --H01---    Serial number: VWZ7Z0E2482609
   Coding: 040300031C070160
   Shop #: WSC 00191 264 15243
   VCID: 373E29BC460EE8F754-8062
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
                    Fault Status: 01100010
                    Mileage: 221949 km
                    Time: 00:17:17
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.430 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus
                    Mileage: 221949 km
                    Time: 00:17:17
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Voltage: 11.557 V
               P1602 - 002 - Voltage too Low
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Voltage: 11.303 V
Readiness: 0110 0101
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000701090864
   Shop #: WSC 44551 111 44551
   VCID: 1464BE303738E3EF11-8040
01208 - Data Records in Control Unit Altered
                    Fault Frequency: 255
                    Reset counter: 0
                    Mileage: 221949 km
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 00028 028 00001
   VCID: 40CC426013C0AF4FE5-8014
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   VCID: 679EB9FC562EB87704-8032
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000002112403
   Coding: E78F8F27000418320014000014000000001B00005C
   VCID: 2B1605CC8A465C1720-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 00028
                    Fault Status: 00101100
                    Fault Frequency: 49
                    Reset counter: 212
                    Mileage: 228036 km
                    Voltage: 13.80 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Fault Status: 01101001
                    Reset counter: 172
                    Mileage: 222527 km
                    Voltage: 13.95 V
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2E AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0K749Z
   Coding: 0012869
   Subsystem 1 - Serial number: 6332MSME0B023507%
   Subsystem 2 - Serial number: 6342MSME0B0463567
   Subsystem 3 - Serial number: 6351HSME08170B734
   Subsystem 4 - Serial number: 6361HSME081916700
   Coding: 0001534
   VCID: 7AB8F088359C359FEB-802E
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
            014 - Defective
   Part No: 1K6 920 872
   Coding: 0005103
   Shop #: WSC 00046 000 00000
   VCID: 6E90CCD879D4693F47-803A
   Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1634
   Revision:   H51       Serial number: 18081300F10603
   Coding: 350000
   VCID: 78BCEA80CB90278F9D-802C
                    Fault Status: 00101110
                    Mileage: 222470 km
                    Time: 21:26:39
                    Mileage: 228677 km
                    Time: 20:33:04
                    Reset counter: 209
                    Mileage: 231931 km
                    Time: 22:47:06
   Component: IMMO            VDD 1212
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H04 2680
   Revision: AB001001    Serial number: VWZ6Z7K4029009
   Coding: 040004020400008000
   Shop #: WSC 05314 000 00000
   VCID: 2E100CD87954293F07-807A
00856 - Radio Antenna
                    Reset counter: 172
                    Mileage: 228672 km
                    Time: 20:33:23
01523 - Microphone for Telephone (R38)
                    Reset counter: 172
                    Mileage: 228677 km
                    Time: 20:33:17
                    Reset counter: 209
                    Mileage: 231931 km
                    Time: 22:47:04
                    Reset counter: 209
                    Mileage: 231931 km
                    Time: 22:46:14
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2467
   Coding: 0000182
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 322818A8AD6C0DDF63-8066
02546 - Steering Limit Stop
                    Mileage: 2000 km
                    Temperature: 8.0°C
                    Voltage: 11.40 V
                    Voltage: 11.30 V
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 809002085103087F2D048F0F60084F01E0A040
   Shop #: WSC 45209 124 52223
   VCID: 004C826053406F4FA5-8054
                    Fault Frequency: 229
                    Reset counter: 209
                    Mileage: 231267 km
                    Time: 13:32:11
                    Reset counter: 182
                    Mileage: 231267 km
                    Time: 13:32:11
                    Fault Status: 00110010
                    Reset counter: 209
                    Mileage: 231931 km
                    Time: 22:46:18
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0000182
   VCID: 383C2A804B10E78F5D-806C
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
   Coding: 0000003
   VCID: 74A4DEB017F843EFB1-8020
00070 - Starting Battery Voltage
00497 - Sensor for Vehicle Leveling; Rear
            010 - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 228672 km
                    Time: 20:33:23
                    Reset counter: 172
                    Mileage: 228677 km
                    Time: 20:33:17
                    Reset counter: 209
                    Mileage: 231931 km
                    Time: 22:47:04
                    Reset counter: 209
                    Mileage: 231931 km
                    Time: 22:46:14
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
   VCID: 33261DAC527604D768-8066
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 34241EB0577803EF71-8060
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 01 Einparkhilfe     0101
   VCID: 2D120BD4B45252273E-8078
End----------(Elapsed Time: 01:21, VBatt start/end: 14.3V/14.4V)-----------
Sunday,06,December,2020,10:46:41:17260
                    Mileage: 221949 km
                    Time: 00:17:17
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Voltage: 11.430 V
                    Mileage: 221949 km
                    Time: 00:17:17
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Voltage: 11.557 V
                    Voltage: 0.000 V
               P1643 - 001 -
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Voltage: 11.303 V
                    Reset counter: 0
                    Mileage: 232013 km
   Revision: 00T12001
   Coding: 0004738
   Coding: 00063445
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
                    Reset counter: 172
                    Mileage: 232013 km
                    Voltage: 14.20 V
   Coding: 0012869
   Coding: 0001831
   Coding: 00000131
            014 - Defective
   Coding: 0005103
   Coding: 350000
                    Fault Frequency: 13
                    Mileage: 232013 km
                    Time: 00:07:47
                    Fault Frequency: 9
                    Reset counter: 172
                    Mileage: 232008 km
                    Time: 00:07:55
                    Reset counter: 172
                    Mileage: 232013 km
                    Time: 00:07:53
   Coding: 0000182
                    Mileage: 2000 km
                    Temperature: 12.0°C
                    Voltage: 14.20 V
                    Voltage: 14.00 V
   Coding: 0000182
   Coding: 0000003
                    Fault Frequency: 9
                    Reset counter: 172
                    Mileage: 232008 km
                    Time: 00:07:55
                    Reset counter: 172
                    Mileage: 232013 km
                    Time: 00:07:53
   Coding: 0000144
   Coding: 0000144
End----(Elapsed Time: 01:14, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
this is my log file
Mari
C?ID=150535
Lots of faultcodes... start with sorting out what is the reason and fix them... Is possible that one of the existing faultcodes is the reason why CC is not working at this moment!
Joren
Belgium
C?ID=359640
I am still working on the car, the battery died multiple times.
The cruise control works fine with the old module.
But not with the new module. In the measuring blocks i can see that the main switch Works fine.
