09: Cent. Elect. long code help
scoby
C?ID=43746
Hi,
I am in Ireland and I have a customer with an American imported vw
Jetta. The problem is the turn signals are flashing red, instead of
amber, as per our regulations. We have new lamps if required, but I need
the coding for the central electrical unit. The long code helper has no
info that I can see. I have included a global scan for your review, any
help would be great.
Regards
Joe
 Log-05D83481-3VWWJ71K16M694989-110760km-68823mi.txt
> Wednesday,11,June,2014,13:44:00:33018
> VCDS -- Windows Based VAG/VAS Emulator
> VCDS Version: 12.12.2.0
> Data version: 20140212
> VIN: 3VWWJ71K16M694989   License Plate: 05D83481
> Mileage: 110760km-68823mi   Repair Order:
> Chassis Type: 1K (1K0)
> Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 72
> VIN: 3VWWJ71K16M694989   Mileage: 110760km/68823miles
> 00-Steering Angle Sensor -- Status: OK 0000
> 01-Engine -- Status: Malfunction 0010
> 03-ABS Brakes -- Status: OK 0000
> 08-Auto HVAC -- Status: Malfunction 0010
> 09-Cent. Elect. -- Status: Malfunction 0010
> 0F-Digital Radio -- Status: Malfunction 0010
> 15-Airbags -- Status: Malfunction 0010
> 16-Steering wheel -- Status: OK 0000
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 1C-Position Sensing -- Status: OK 0000
> 25-Immobilizer -- Status: OK 0000
> 42-Door Elect, Driver -- Status: Malfunction 0010
> 44-Steering Assist -- Status: OK 0000
> 46-Central Conv. -- Status: Malfunction 0010
> 52-Door Elect, Pass. -- Status: OK 0000
> 55-Xenon Range -- Status: OK 0000
> 56-Radio -- Status: OK 0000
> 62-Door, Rear Left -- Status: OK 0000
> 72-Door, Rear Right -- Status: OK 0000
> Address 01: Engine        Labels: 06F-907-115-AXX.lbl
>     Part No SW: 1K0 907 115 B    HW: 1K0 907 115 B
>     Component: 2.0l R4/4V TFSI     0040
>     Revision: --H10---    Serial number: VWZ7Z0E2428806
>     Coding: 0403010A18070160
>     Shop #: WSC 00140 941 55366
>     VCID: 2547813AEC61FC36C81-8070
> 6 Faults Found:
> 008200 - Intake Manifold Flap; Bank 1
>                 P2008 - 001 - Electrical Malfunction - MIL ON
>               Freeze Frame:
>                      Fault Status: 11100001
>                      Fault Priority: 0
>                      Fault Frequency: 19
>                      Reset counter: 255
>                      Mileage: 103619 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 17:42:21
>               Freeze Frame:
>                      RPM: 1179 /min
>                      Load: 18.0 %
>                      Speed: 18.0 km/h
>                      Temperature: 73.0°C
>                      Temperature: 24.0°C
>                      Absolute Pres.: 990.0 mbar
>                      Voltage: 14.351 V
> 012600 - Intake Manifold Runner Control
>                 P3138 - 008 - Regulation Deviation - MIL ON
>               Freeze Frame:
>                      Fault Status: 11101000
>                      Fault Priority: 0
>                      Fault Frequency: 10
>                      Reset counter: 255
>                      Mileage: 103619 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 17:42:21
>               Freeze Frame:
>                      RPM: 1179 /min
>                      Load: 16.9 %
>                      Speed: 18.0 km/h
>                      Temperature: 73.0°C
>                      Temperature: 24.0°C
>                      Voltage: 14.351 V
> 001090 - EVAP Emission Control Sys
>                 P0442 - 001 - Small Leak - MIL ON
>               Freeze Frame:
>                      Fault Priority: 0
>                      Fault Frequency: 1
>                      Reset counter: 255
>                      Mileage: 103850 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 07:41:36
>               Freeze Frame:
>                      RPM: 2148 /min
>                      Load: 19.2 %
>                      Speed: 58.0 km/h
>                      Temperature: 66.0°C
>                      Temperature: 9.0°C
>                      Voltage: 14.351 V
> 008577 - Performance Malfunction in Cooling System
>                 P2181 - 008 -  - Intermittent - MIL ON
>               Freeze Frame:
>                      Fault Status: 10101000
>                      Fault Priority: 0
>                      Fault Frequency: 6
>                      Reset counter: 255
>                      Mileage: 104082 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 11:09:41
>               Freeze Frame:
>                      RPM: 2222 /min
>                      Load: 46.6 %
>                      Speed: 91.0 km/h
>                      Temperature: 72.0°C
>                      Temperature: 16.0°C
>                      Absolute Pres.: 1010.0 mbar
>                      Voltage: 14.478 V
> 000665 - Boost Pressure Regulation
>                 P0299 - 002 - Control Range Not Reached - MIL ON
>               Freeze Frame:
>                      Fault Status: 11100010
>                      Fault Priority: 0
>                      Fault Frequency: 1
>                      Reset counter: 255
>                      Mileage: 107627 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 15:54:09
>               Freeze Frame:
>                      RPM: 2891 /min
>                      Load: 80.4 %
>                      Speed: 118.0 km/h
>                      Temperature: 69.0°C
>                      Temperature: 14.0°C
>                      Absolute Pres.: 980.0 mbar
>                      Voltage: 14.224 V
> 001109 - EVAP System
>                 P0455 - 001 - Large Leak Detected - MIL ON
>               Freeze Frame:
>                      Fault Priority: 0
>                      Fault Frequency: 1
>                      Reset counter: 255
>                      Mileage: 108003 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 11:25:55
>               Freeze Frame:
>                      RPM: 1444 /min
>                      Load: 34.1 %
>                      Speed: 29.0 km/h
>                      Temperature: 67.0°C
>                      Temperature: 16.0°C
>                      Absolute Pres.: 970.0 mbar
>                      Voltage: 14.478 V
> Readiness: 0000 0000
> Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
>     Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
>     Component: ESP FRONT MK60      0102
>     Revision: 00T12001
>     Coding: 0021122
>     Shop #: WSC 00066 000 00000
>     VCID: 408930AE1303391EDB7-8015
> No fault code found.
> Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
>     Part No: 1K0 820 047 DK
>     Component: Climatic PQ35   090 0505
>     Shop #: WSC 00000 000 00000
>     VCID: 70E9A06E6323E99E6B7-8025
> 1 Fault Found:
> 01271 - Positioning Motor for Temperature Flap (V68)
>              000 - -
> Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
>     Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
>     Component: Bordnetz-SG     H37 1002
>     Revision: 00H37000    Serial number: 00000000166776
>     Coding: 17070E234004180000140000001400000028770B5C
>     Shop #: WSC 80093 222 69422
>     VCID: 2B5377028A85CA461E5-807E
>     Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
>     Component: Wischer VW350  012  0402
>     Coding: 00065493
>     Shop #: WSC 80093
> 1 Fault Found:
> 00924 - Relay for Headlamp Cleaning System (J39)
>              009 - Open or Short to Ground
>               Freeze Frame:
>                      Fault Status: 01101001
>                      Fault Priority: 4
>                      Fault Frequency: 1
>                      Reset counter: 245
>                      Mileage: 110767 km
>                      Time Indication: 0
>               Freeze Frame:
>                          ON
>                      Voltage: 11.80 V
>                          ON
>                          ON
>                          OFF
>                          OFF
>                          OFF
> Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
>     Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
>     Component: SDAR XM         H03 0080
>     Revision: 00000000    Serial number: AUZ4Z7E3034586
> 3 Faults Found:
> 00003 - Control Module
>              014 - Defective
>               Freeze Frame:
>                      Fault Status: 01101110
>                      Fault Priority: 5
>                      Fault Frequency: 1
>                      Reset counter: 122
>                      Mileage: 2567 km
>                      Time Indication: 0
>                      Date: 2000.00.00
>                      Time: 17:29:53
> 02633 - Antenna for Satellite Tuner
>               Freeze Frame:
>                      Fault P
