Tuesday,09,June,2020,13:44:47:42724
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 20.4.1.0 (x64) HEX-NET : 0.4508.4
VIN: VSSZZZ6JZDR084932 License Plate:
Mileage: 114940km-71420mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR084932 Mileage: 114940km-71420miles
03- Brakes -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GR HW: 03F 907 309 AE
Component: SIMOS10.22AH10 4042
Revision: --H10--- Serial number:
Coding: 001100D6200400080000
Shop #: 06402 785 00200
Dataset: EV_ECM12TFS02103F906070GR 004006
ROD: EV_ECM12TFS02103F906070HB_SE25.rod
VCID: F8BC98ED43752F46B3-80AC
10478 - Charge Pressure Control Actuator
P334A 00 [096] - Electrical Malfunction
Mileage: 114943 km
Date: 2020.06.09
Time: 17:36:12
Engine speed: 0.00 /min
Coolant temperature: 21 °C
Intake air temperature: 23 °C
Voltage terminal 30: 13.507 V
Charge pressure actuator: specified value-PWM_BPA[0]: 0.000 %
POSN_DIF_BPA[0]: -0.00 %
Charge pressure actuator: adaptation for upper stop-VP_BPA_AD_TOL[0]: 0.8000 V
TQI_TCHA_PROT: 1023.96875 Nm
Readiness: 0110 0101
Address 03: Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: 04941 000 00000
VCID: 804CF00D17A567868B-80D4
Fault Frequency: 21
Reset counter: 12
Mileage: 114943 km
Date: 2014.10.30
Time: 00:03:44
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x14B5
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
03306 - Coding Not Valid
Reset counter: 51
Mileage: 114943 km
Date: 2014.10.30
Time: 00:20:24
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x1227
Hex Value: 0x149E
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Reset counter: 51
Mileage: 114943 km
Date: 2014.10.31
Time: 18:32:21
Hex Value: 0x0001
Hex Value: 0x0000
Hex Value: 0x1203
Hex Value: 0x16B2
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H06 0060
Serial number: 090465LGJ00152
Coding: 01
Shop #: 00000 000 00000
Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: FEB08EF561511176F9-80AA
136194 - Supply voltage
Reset counter: 44
Mileage: 114915 km
Date: 2020.05.24
Time: 00:00:33
Voltage terminal 15: 6.20 V
Voltage terminal 30: 6.30 V
Terminal 15 status: OFF
Entprellzeit: 90000 ms
332644 - Databus
Reset counter: 50
Mileage: 114943 km
Date: 2020.06.08
Time: 00:58:57
Voltage terminal 15: 11.40 V
Voltage terminal 30: 11.70 V
Terminal 15 status: On
Entprellzeit: 5000 ms
1140738 - Steering angle sensor
Reset counter: 0
Voltage terminal 15: 13.40 V
Voltage terminal 30: 17.75 V
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0330
Revision: 00 26 08 Serial number: 0000002541784-
VCID: A4049C9D677D9BA6CF-80F0
Reset counter: 47
Mileage: 114915 km
Date: 2014.10.23
Time: 07:05:22
Reset counter: 50
Mileage: 114943 km
Date: 2014.10.30
Time: 00:00:04
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 195124319
Coding: 7C882BE888610100002008F06E0B0CC80040422F608C0400200000000000
Shop #: 87864 120 23456
VCID: C5C221194C0782AEF8-8090
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3110
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3110
Coding: 020000
01758 - Bulbs for Brake Lamps
Fault Status: 00101011
Reset counter: 47
03431 - Activation of Left Parking Light
Reset counter: 47
03432 - Activation of Right Parking Light
Reset counter: 47
03302 - Response Closing Status of Passenger's Door
Reset counter: 47
Mileage: 114915 km
Date: 2014.10.23
Time: 20:44:09
Reset counter: 47
Mileage: 114915 km
Date: 2014.10.23
Time: 07:08:21
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA0A H10 0020
Revision: -------- Serial number: 003GX01AWX98
Coding: 003041
Shop #: 06401 785 00200
Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: CAD812256D196DD615-809E
Serial number: 3495RRB40084UHC4HI6Y
Serial number: 3505RRB401I4UJ4SHH6B
12670208 - Databus
[Kombi1-3 Time Out Error]
Reset counter: 50
Mileage: 114943 km
Date: 2020.06.08
Time: 00:58:57
12674816 - Databus
[VIN Time Out Error]
Reset counter: 50
Mileage: 114943 km
Date: 2020.06.08
Time: 00:58:57
Part No SW: 6J0 920 804 HW: 6J0 920 804
Component: KOMBI H04 0508
Coding: 110200
Shop #: 131071 1023 2097151
Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: E79ECB911ECBB0BE2A-80B2
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
[Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 022200
VCID: F0ACA0CD230577067B-80A4
01316 - Control Module
Reset counter: 48
Mileage: 114930 km
Date: 2014.10.29
Time: 23:34:53
Reset counter: 50
Reset counter: 47
Mileage: 114915 km
Date: 2014.10.22
Time: 02:55:50
Reset counter: 48
Mileage: 114930 km
Date: 2014.10.29
Time: 23:19:27
01304 - Radio
Reset counter: 47
Mileage: 114915 km
Date: 2014.10.15
Time: 00:00:05
Reset counter: 50
Component: IMMO H04 0508
Dataset: EV_Immo_UDS_VDD_RM09 A03009
VCID: EA98B2A50DD98DD635-80BE
10490880 - ROD - Unknown Error Code
- 00 [008]
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: 00788
VCID: AF2E63B16ABB28FE22-80FA
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: 77005 000 00000
VCID: F0ACA0CDE30577067B-80A4
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J1 035 153 H HW: 6J1 035 153 H
Component: Radio H15 0302
Revision: R0000000 Serial number: SEZAZ2M4760571
Coding: 0503020002
VCID: AA1872A5C5594DD6F5-80FE
00856 - Radio Antenna
Fault Status: 00111011
Reset counter: 47
Mileage: 96505 km
Date: 2017.06.09
Time: 00:00:30
Reset counter: 44
End----------(Elapsed Time: 01:01, VBatt start/end: 14.2V/14.3V)-----------
