Adaptive Cruise Control error after Towbar electrics fitted
   #21
golfi_vend
Tartu, Estonia
C?ID=195131
Please add this foto, i really like to see it :)
   #22
stut4
C?ID=278823
http://imgur.com/MgRJs86
i forgot to add, they had to do a suspension alignment at the same time as the setup has to be perfect - this was included in the cost.
i'll get the scan uploaded later.
stut4
C?ID=278823
Wednesday,17,August,2016,20:49:56:57968
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: TMBKJ7NP5G7010402   License Plate:
Chassis Type: NP (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 36 42 44 52 55 5F 69 6D BB
          BC
VIN: TMBKJ7NP5G7010402   Mileage: 11229km-6977miles
Address 01: Engine (J623-DFCA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2,0L EDC   H22 1195
   Revision: B4H22---
   Coding: 011D0012047501082000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
   ROD: EV_ECM20TDI01104L906026FN.rod
   VCID: 7BF23395F207109AF5-802F
17156 - Databus
                    Mileage: 11150 km
                    Date: 2016.08.16
                    Time: 10:49:31
                    Engine speed: 0.00 /min
                    Coolant temperature: 35 ∞C
                    Intake air temperature: 35 ∞C
                    Voltage terminal 30: 11.820 V
                    Drivetrain coordinator: ACC fault status-Bit 0: 0
                    Drivetrain coordinator: ACC fault status-Bit 8: 0
                    Drivetrain coordinator: brake fault status-Bit 0: 0
                    Drivetrain coordinator: brake function status-Bit 0: 0
                    Drivetrain coordinator: brake function status-Bit 8: 0
                    Acceleration: 0.000 m/s≤
   Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4803
   Revision: 06253104    Serial number: TFK01506011806
   ROD: EV_TCMDQ250021.rod
   VCID: 173A0F25EE6FD4FA71-8043
   Revision: 00000000    Serial number: 61755000000539
   Coding: 1E07929C34210B6C077B060041C54978492CD0E0608292F51861F078C209
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AFC3691FD3D2992EE-802F
Address 08: Auto HVAC (E87)       Labels: 3V0-907-044.clb
   Part No SW: 3V0 907 044 AR    HW: 3V0 907 044 AR
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00007777
   Coding: 12110104000100011005000000101000
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 040048698FF96F6284-8051
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061516208770
   Coding: 0F021A46C2C722FB17844086B10C57281000000000000000000000000000
   ROD: EV_BCMBOSCH_SK48.rod
   VCID: 091E595DA8DB320AF7-805D
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 150122  032 0121
   Serial number: 00000001501200606046
   Coding: 165DDD
   Component: RLHS  037 0059
   Serial number: S4Y15M06D23H10M57S30
   Coding: 00084D
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151271JN3
   Serial number: 00000000000031808593
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39291513909292
   Coding: 0001050111
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3D76FD8DAC93DEAA8B-8069
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 3200678951FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3460D8A99FD91FE274-8061
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R0W5DH%
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   Subsystem 1 - Part No SW: -----------    HW: 480 001 306 15
   Serial number: 35700000000FAA31641M
   Subsystem 2 - Part No SW: -----------    HW: 480 001 606 15
   Serial number: 35800000000F839CD41
   Subsystem 3 - Part No SW: -----------    HW: 480 400 806 15
   Serial number: 3510002C31B41480420I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 806 15
   Serial number: 3520002BF1B41484B1B8
   Subsystem 5 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3550002AF1B4148463A6
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 GB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150624401220
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 78F82C99C3313B8298-802D
   Part No SW: 3V0 920 941     HW: 3V0 920 941
   Component: KOMBI         212 6421
   Coding: 27A5090A2F80AE0001887A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 72EC1EB1A54D51D2A6-8027
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 18061510801230
   Coding: 030100344F087300FB00025A1C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00063
   ROD: EV_GatewConti.rod
   VCID: 75E625ADD42346EA83-8021
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C0015120615
   Serial number: 6026037003
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OF311220
   Coding: 001400000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B72F395B287D09AB5-806F
   Serial number: 110515BEA08468
   Coding: 001D0820DE01040000001100
   VCID: 43828B75CA77A85AFD-8017
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   ROD: EV_SteerAssisMQB_VW37.rod
   Serial number: 010515BDT15501
   Coding: 001D0220DE01040000001100
   VCID: 428C8E71D56DA152F6-8017
   Coding: 06DE00003F010000
   VCID: 40888479DB61B342E0-8015
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 A    HW: 3V0 035 020
   Component: MU-H-ND-EU    H41 0318
   Serial number: A435D0FB000210
   Coding: 03840201FF00000011111201008808002F0000C601200100DE
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 244028E92F398F62E4-8071
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H44 1028
   Serial number: SKZ8Z9RAM003GV
   Subsystem 2 - Part No SW: V03 959 801 JJ    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Compact Disc Database:
   Component: Gracenote2  --- 1011
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0397704831
   Coding: 0110000000000000
   VCID: 3E74FA81A195C5B292-806B
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30086671600000
   Coding: 0D80
   Shop #: WSC 61468 001 104857
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
   VCID: 3C70F089B789D7A2BC-8069
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 210415BDK07391
   Coding: 001800208001040000001100
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 300515BEU0524B
End-------------------------(Elapsed Time: 05:05)--------------------------
only error left is an engine module error, but its not causing me any issues, and i wonder if its related to the towbar wiring loom.
Zenerdiode
Newcastle, England
C?ID=24330
This is very intriguing - but also a little but confusing. :confused:
If your last 'fiddle' with the coding values was around your scan of the 10/08/2016 (or 08-10-2016 for the Americans :)) and you haven't touched it since Dealer coding when you acquired your Auto-Scan earlier today; I have the following observations:
Coding changed in the following modules:
Old - 011D0012037501082000
New - 011D00120[B][COLOR="#FF0000"]4[/COLOR][/B]7501082000
09
Old - 0F021A46C2C722FB17844086B10C57280000000000000000000000000000
New - 0F021A46C2C722FB17844086B10C5728[B][COLOR="#FF0000"]1[/COLOR][/B]000000000000000000000000000
13
Old - 3200678951FFC428949C804C
New - 3200678951FFC428949C804[B][COLOR="#FF0000"]D[/COLOR][/B]
17
Old - 27A5090A2F80AE00018864011000000000000000
New - 27A5090A2F80AE000188[B][COLOR="#FF0000"]7A[/COLOR][/B]011000000000000000
19
Old - 030100344F087300EB00025A1C0F00010001070000000000000000000000
New - 030100344F087300[B][COLOR="#FF0000"]F[/COLOR][/B]B00025A1C0F00010001070000000000000000000000
69
Old - 0100000000000000
New - 01[B][COLOR="#FF0000"]1[/COLOR][/B]0000000000000
However, the WSC have behaved peculiarly:
01
Old - 33361 790 00063
New - 33361 790 00063
09
Old - 12345 123 12345
New - 33361 790 00063 <<<< Expected
13
17
19
Old - 73430 790 00063
New - 73430 790 00063
69
New - 12345 123 12345 <<<< Unexplained! The Dealer system (ODIS) should have placed its 'signature' here too; as in 0x09 and 0x13. :confused:
