Passat B6 steering wheel upgrade to MK6
kamold
Australia
C?ID=241363
Hi,
I am a little confused about what components I'll need to upgrade a Passat B6 multifunction wheel to a Mk6 Golf GTI wheel and airbag module.
The car currently has a 5K0953569T SW control module which appears to be an all-in-one SWCM, slipring and indicator assembly...is this correct?
If that is the case I would assume that I then need a SWCM 3C0953549AH which supports LIN 1.3 and LIN 2.0, as well as a slipring 5K0 953 549 B and cruise/indicator stalks?
This looks like its different to my R36 which has a 3C0 953 549 AC SWCM and only needs to be upgraded to a AH version when installing the newer 12 button wheels..
Autoscan of the car in question:
Monday,25,July,2016,11:38:44:02396
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
VIN: WVWZZZ3CZA   License Plate:
Mileage: 184840km-114854mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 42 44 46 47 52 53
          55 56 62 65 69 72
VIN: WVWZZZ3CZA  Mileage: 184840km-114854miles
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 FS    HW: 03H 906 032 AB
   Component: CC3.6-FSI-EU5   G   4855
   Revision: 5GH07---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 00000
   VCID: 78F41A430BDA1783E1-802C
   Part No SW: 02E 300 012 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2102
   Revision:    51112    Serial number: 00001001090081
   VCID: 19323FC7D090EE8B3E-804C
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000104024329
   Coding: 0001443
   VCID: 62C0582BBD46ED53AF-8036
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 05311 115 00000
   VCID: 7EF80C5BE1FE29B3AB-802A
   Revision: 00H54000    Serial number: 00000003624609
   Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 336EED6F523C34DB14-8066
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 150110 022  0612
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     260110 054  0402
   Coding: 00209133
   Shop #: WSC 05124
                    Fault Status: 01101100
                    Reset counter: 114
                    Mileage: 161670 km
                    Voltage: 12.15 V
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08791001517523
   Coding: 110102
   Shop #: WSC 05314 000 00000
   VCID: 3260E86B6D263DD31F-8066
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__01C VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P1BTEFR
   Coding: 0012611
   VCID: 4280B8AB1D868D538F-8016
   Subsystem 1 - Serial number: 6332MTS615583179
   Subsystem 2 - Serial number: 6342MTS641960210
   Subsystem 3 - Serial number: 6351HTS61EC386KJ
   Subsystem 4 - Serial number: 6361HTS6J0U449KJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100122200638
   Coding: 8990270002
   ASAM Dataset: EV_VW360SteerWheelUDS A03002
   VCID: 6BDE350F828CAC1B1C-803E
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 872 J    HW: 3C0 920 872 J
   Component: KOMBI         H03 0305
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 2C5CF61347026B2355-8078
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P1012605FC
   Coding: FDA3FF47100212001003
   VCID: 2F66E11FBE14103B70-807A
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   VCID: 448CBEB307928363BD-8010
   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   VCID: 75EA13771CC86AEBFA-8020
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 00101110
                    Reset counter: 120
                    Mileage: 183560 km
                    Date: 2010.12.03
                    Time: 20:13:27
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667766015
   VCID: 2648043B51EE517383-8072
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0306
   Revision: 12101005    Serial number: 0000347098
   Coding: 0013B7
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 2648043B59EE517383-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0402
   Serial number: 00000001231544
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 143    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3162E767A82006CB66-8064
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 052 0412
   Coding: 00910A0001860E76300494157008DFCE105801
   Subsystem 1 - Part No: 1K8 951 605
   Component: LIN BACKUP HORN H09 9002
   Component: Neigungssensor  004 0611
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 137
                    Mileage: 184312 km
                    Date: 2010.12.10
                    Time: 19:15:02
Address 47: Sound System (R12)       Labels: None
   Part No HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198834515
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 55AA73F734080AEBDA-8000
   Part No SW: 3C0 959 702 A    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0306
   Revision: 14101005    Serial number: 0000278597
   Coding: 0013B6
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 2756093F5EE4487BB8-8072
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0402
   Serial number: 00000001250986
   Coding: 000290
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000142743
   Coding: 0000057
   VCID: 2C5CF6138F026B2355-8078
   Component: AFS-Steuergeraet    0142
   Coding: 2344385
   VCID: 346CEE73573233E30D-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3003905
   Coding: 0101000001
   VCID: 62C0582B7D46ED53AF-8036
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 150
                    Mileage: 184737 km
                    Date: 2010.12.15
                    Time: 20:59:08
   Component:    RDK              0453
   Coding: 0161211
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000124332086
   Coding: 4100000100000000
   VCID: 3064E263632A0FC369-8064
End-------------------------(Elapsed Time: 03:07)--------------------------
Eddie-NL
C?ID=41179
straight swop, no need to change steering module
kamold
Australia
C?ID=241363
I swapped in the steering wheel and airbag and none of the buttons or lights worked.
I was hoping that it was a straight swap from some other information I'd read...
I tried to code the controller to turn on LIN 2.0 but request was out of range.
kamold
Australia
C?ID=241363
If I also get a new slipring 1K0 959 653 C ,
a cruise stalk 1K0953513G,
as well as the swcm 3C0 953 549 AH,
can I then replace the 5K0953569T control unit?
golfi_vend
Tartu, Estonia
C?ID=195131
569T is better then 549AH.
Also you're mixing alot of not compatible part codes, like CCS stalk and swcm.
The autoscan you posted is able to handle lin2, but then you start to talk abou swcm ...549AC.
So which one is it?
kamold
Australia
C?ID=241363
I tried to enable LIN 2.0 on the 569T however I got request out of range error...does this module need security access first?
If I can use the existing 569T with the new steering wheel then this is the best outcome obviously.
Perhaps it is just a problem with the harness. I'll have a look at that next.
Thanks for the replies :)
kamold
Australia
C?ID=241363
Just wanted to add some information from Dana that should be the answer to my problem when I get to see the car again:
Byte 0, Bit 7 represents LIN 1.3 (the older 8 button / Mk5 wheel type). That bit is not documented in our coding helper because VW did not use it in production as far as we know due to the faze in period of LIN 2.0 in 2009.
In conclusion I believe the rejected coding is related to enabling LIN
1.3 and 2.0 at the same time but the installed steering wheel type may be an additional conflict.
kamold
Australia
C?ID=241363
Just an update to tidy this thread up:
The coding above from Dana was the key to getting this 569T controller to talk in LIN 2.0. Without changing bit 7 in byte 0 to 0 (turns off LIN 1.3), I couldn't enable LIN 2.0 in the documented long coding helper. Need to change these two values at the same time in order for the controller to accept the coding.
Thanks again Dana!!
Hi Julian,
We try to reply in forum so the answers become searchable but I wasn't aware you were a forum member when I replied to your email. I added your forum user name to our internal records so we can locate you easily in the future :-)
-- 8/12/2016 10:35 AM --
These modules do not require a Security Access code prior to Coding.
Without the VIN we can't determine any of the vehicle production
details.  Please let us know:
* Is this a retrofit or did someone change the factory condition of the
16 module coding?
* Did this car some with a factory MFSW?
* How many buttons are on the wheel that's currently installed?
The MFSW is communicating in the scan
>     Multifunction steering wheel control module:
.. but I suspect that's because Byte 0, Bit 7 represents LIN 1.3 (the
Regards,
I'm glad to hear my (crazy) LIN 1.3 conflict theory resolved this! It would be helpful if you could post a final scan or the clip from 16 after the coding was resolved.
I haven't had anyone with a UDS protocol (all-in-one SWCM with integrated slip ring) send a scan with Byte 0, Bit 7 enabled from the factory or during a retrofit .... but I added a note to the Part Number 5K0-953-569 section of our Wiki page.
golfi_vend
Tartu, Estonia
C?ID=195131
Please note that also SW 0136 also supports LIN1.3.
Can't paste autoscan where it is enabled, but i have tested this out specially after reading this thread.
The 5K0 953 569 T is retrofit in my car.
Thursday,25,August,2016,19:48:45:01666
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
Dealer/Shop Name: R36
Workshop Code: 232 23234 032332
VIN: WVWZZZ3CZ7E112639   License Plate: MINU PASSAT UUS ROOLIAJU
Mileage: 289800km-180073mi   Repair Order:
Scan: 01 03 08 09 10 15 16 17 19 22 25 36 37 42 44 46 52 53 55 56
          62 69 72 77
VIN: WVWZZZ3CZ7E112639   Mileage: 289800km-180073miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 NK    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  9972
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 21626 146 67472
   VCID: 75E113911CC7B4EA83-8020
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109     HW: 3C0 614 109
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0668122620
   Coding: 0029998
   Shop #: WSC 23234 232 32332
   VCID: 5BB565299A23029A95-800E
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 67DD49D9566B567A01-8032
Address 09: Cent. Elect.        Labels: User\3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000008732296
   Coding: EF0A8E87001E1A00DF0080000F000000803B5D535C000104004000000000
   VCID: 3365ED895233EADA6D-8066
   Subsystem 1 - Part No: 3C1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 251006 022  0601
   Coding: 00046997
   Shop #: WSC 23234
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     261006 014  1201
   Coding: 00217165
   Shop #: WSC 23234
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 28291107647326
   Coding: 118002
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 7CF706B5F7EDE5A2FC-8028
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 19 AIRBAG VW8R  031 2522
   Revision: 12031000    Serial number: 003B2PMWFJQQ
   Coding: 0012601
   VCID: 3169E781A82FD8CA1F-8064
   Subsystem 1 - Serial number: 6332MSME1319383FE
   Subsystem 2 - Serial number: 6342MSME134B640DE
   Subsystem 3 - Serial number: 6351HTS66HBC5L87A
   Subsystem 4 - Serial number: 6361HTS66HBGCHP6Y
   Component: LENKS.MODUL   009 0136
   Revision: FF010036    Serial number: 20100621200837
   Coding: 1182270002
   VCID: 6BD535E98283721A65-803E
   Subsystem 1 - Part No SW: 3C8 959 537 B    HW: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H4  0021
   Coding: E20000
   Part No SW: 3C0 920 872 G    HW: 3C0 920 872 G
   Coding: 161F00
   VCID: 29590FE148FFA00AD7-807C
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P076040751
   Coding: F9A3FF464006022002
   Shop #: WSC 05311 123 12345
   VCID: 23451DC9E2D37A5A9D-8076
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 H
   Component: Haldex 4Motion      1116
   Coding: 0000001
   VCID: 326BE88DAD29E3D266-8066
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 06402 785 00200
   VCID: 3979DFA1705F108AA7-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D51FBF1B417BC2A3B-8078
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 H
   Component: RNS-MID       H64 5238
   Revision: AB001001    Serial number: VWZ6Z7M7174093
   Coding: 02000400040000A20000
   Shop #: WSC 23454 324 56743
   VCID: 3B75C5A9BA63229AB5-806E
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V13  8350
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1123
   Revision: 31008001    Serial number: 00000534469101
   Coding: 0000503
   VCID: 3C77C6B57F6D25A2BC-8068
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   VCID: 3467EE95573DEDE274-8060
Address 46: Central Conv.        Labels: User\3C0-959-433-46.lbl
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051034E7630021F1FF000CF0E505900
   Component: LIN BACKUP HORN H07 8003
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1123
   Revision: 31008001    Serial number: 00000566169031
   Coding: 0000502
   VCID: 3D71CBB164772CAA8B-8068
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC005   013 0005
   Revision:   013
   Coding: 0000011
   VCID: 24471ED5E7DD7D62E4-8070
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2334721
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1114
   Revision: 11005001    Serial number: 00000000832501
   Coding: 0000208
   Revision: 3A001001    Serial number: 00000142570188
   Coding: 0100000100000000
   VCID: 306FE2856325D1C210-8064
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1114
   Revision: 11005001    Serial number: 00000000837204
   Coding: 0000208
   VCID: 3E73CCBD697137B292-806A
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105137557
   Coding: 020100010100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_VW32.rod
   VCID: 24471ED52FDD7D62E4-8070
End-------------------------(Elapsed Time: 02:50)--------------------------
Thanks! I don't have a spare steering wheel but I'm going to see if my factory installed 5K0 953 569 L controller will allow me to deactivate LIN 2.0 and enable (the incorrect) 1.3 version. 2012 Tiggy factory config:
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110614101144
Coding: 110A140000
Shop #: WSC 01324 020 00200
ROD: EV_VW360SteerWheelUDS_VW36.rod
VCID: 75EAE18DD4CACEB0023
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
If we can confirm this works on more than one part number controller I can add a LIN Version column to that chart.
Confirmed, I can disable the LIN 2.0 coding in Byte 1 and enable Byte 0, Bit 7
Tuesday,13,September,2016,19:44:58:08929
VCDS Version: 16.8.2.1 (x64)  HEX-NET CB: 0.4324.4
Data version: 20160902 DS260
VIN: WVGBV7AX1CW000438   License Plate: TIGGY HN 16.8.2.1
Mileage: 70540km-43831mi   Repair Order:
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
          4C 4F 52 53 55 56 62 72 77
VIN: WVGBV7AX1CW000438   Mileage: 70540km-43831miles
   Coding: 110A140000  < factory config
   VCID: F5ADE27154E357EA15-80A0
   Coding: 820000
.. but it did not result in that LIN 1.3 slave info like the OPs initial scan (with the coding of 8990270002).
   Coding: 9100140000
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 164
                    Mileage: 70541 km
                    Date: 2016.09.13
                    Time: 19:54:52
I suspect that may not mean the same thing based on Sebastian's description in the lbl for my module:
Attempting to paste 8990270002 into my module was refused.
golfi_vend
Tartu, Estonia
C?ID=195131
Please be noted that 5K0-953-569-T has TPI which updated the whole module to SW0140, so that should also support LIN1.3.
lemonfan
C?ID=129722
Could you tell me the TPI number for that update, please?
What topic is addressed with this TPI?
Thanks in advance!
golfi_vend
Tartu, Estonia
C?ID=195131
TPI 2024249/3
Customer statement / workshop findings
Failure of various comfort functions such as:
cruise control
multi-function steering wheel
multi-function display
rear screen wiper.
Technical background
Incorrect software in the steering column control unit.
And autoscan with retrofitted SWCM module to B6 with older LIN1.3 MFSW.
It also has fault with memory seats, but these are also retrofitted and another story. :)
Saturday,29,July,2017,04:09:33:36026
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 17.1.3.0 (x64)  HEX-NET CB: 0.4346.4
VIN: WVWZZZ3CZ8E   License Plate: SEAT-MEM-B7-KANGID
Mileage: 246430km-153124mi   Repair Order:
Scan: 01 03 08 09 10 15 16 17 18 19 25 36 37 42 44 46 52 53 55 56
          5D 62 72 77
VIN: WVWZZZ3CZ8E   Mileage: 246430km-153124miles
5D-Operations -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EM    HW: 03G 906 018 EM
   Component: R4 2.0l PPD1.2 G    4369
   Revision: --H52---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 27928 141 87345
   VCID: F4A4979C973715E17D-80A1
Readiness: N/A
   Part No SW: 3C0 698 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0017
   Revision: --020---    Serial number: 00000775527569
   Coding: 0002341
   Shop #: WSC 00046 000 00000
   VCID: AB164CE00A890A19EC-80FF
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 001C004802
   Shop #: WSC 00015 115 00000
   VCID: F8BCA3AC435F718151-80AD
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 216
                    Mileage: 246433 km
                    Date: 2017.07.29
                    Time: 01:48:09
   Revision: 00H54000    Serial number: 00000003838177
   Coding: EF0A8E0700281A005F0000000F000000801B3F4F5C000101002000000000
   Shop #: WSC 05124 123 12345
   VCID: B3265480D2B952D9A4-80E7
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 280108 003  0205
   Coding: 00049045
   Shop #: WSC 05124
   Component: RLS     260208 046  0204
   Coding: 00864333
   Shop #: WSC 05124
   Revision: --------    Serial number: 77631031607156
   Coding: 308002
   Shop #: WSC 99999 123 12345
   VCID: FCB4BFBC77675DA135-80A9
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP36XVHB
   Coding: 0012341
   VCID: BB367CA0FAE99A997C-80EF
   Subsystem 1 - Serial number: 6333FTS603550368
   Subsystem 2 - Serial number: 6343FTS646170118
   Subsystem 3 - Serial number: 6353ETS6VBRHSVNH
   Subsystem 4 - Serial number: 6363ETS61POHSVNH
   Revision: FF010041    Serial number: 20131206000056
   Coding: 9180270002
   Shop #: WSC 00079 790 12345
   VCID: EB968CE00209CA19AC-80BF
   Component: E221 - MFL  H02 0001
   Part No SW: 3C8 920 880 GX    HW: 3C8 920 880 GX
   Component: KOMBI         H03 0132
   Coding: 060F00
   VCID: 885CD36C33BF010121-80DD
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031012
   VCID: B5226A98DCCD4CE98A-80E1
   Revision:   H13       Serial number: 3690P118100464
   Coding: F9A1FF06402E02002002
   VCID: AF2E58F03E917639C0-80FB
   VCID: B93A66A8F0D5A8896E-80ED
   Part No SW: 3C0 959 760 D    HW: 3C0 959 760 D
   Component: Sitzverstellung     0101
   VCID: AE1045F4399B7F31CB-80FB
02330 - Rear Seat Height Adjustment Motor (V285)
01902 - Lumbar Support Fore / Aft Adjustment Motor (V230)
01915 - Lumbar Support Height Adjustment Sensor (G374)
            009 - Open or Short to Ground
   Component: RNS-MID       H60 5274
   Revision: AB001001    Serial number: VWZ6Z744249046
   Coding: 00000440040000A10011
   Shop #: WSC 05314 123 12345
   VCID: BB367CA03AE99A997C-80EF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Component: J386  TUER-SG FT    1131
   Revision: 31008001    Serial number: 00000100188211
   Coding: 0000247
   VCID: BC347FBCFFE79DA175-80E9
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Coding: 18900A00D1038E7E30021C1CF0008F0E507D40
   Shop #: WSC 66565 257 00032
   Component: LIN BACKUP HORN H08 9001
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Component: J387  TUER-SG BT    1131
   Revision: 31008001    Serial number: 00000626188203
   Coding: 0000246
   VCID: BD3272B8E4FD94A942-80E9
   Revision:   010       Serial number: 00000000053623
   Coding: 0000057
   Shop #: WSC 00829 223 74578
   VCID: AC144FFC0F870D21E5-80F9
   Part No SW: 5M0 907 357 B    HW: 5M0 907 357 B
   Component: AFS-Steuergeraet    X024
   Revision: 00H01000    Serial number:
   Coding: 2311169
   Coding: 00000035
   Coding: 00000035
Address 5D: Operations        Labels: 3C0-035-151.lbl
   Part No SW: 3C0 035 151 C    HW: 3C0 035 151 C
   Component: J738            011 0019
   Revision: 00011000
   VCID: 987C832CAB1F9181B1-80CD
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000233246
   Coding: 0000208
   VCID: F0AC9B8CE32F29C199-80A5
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000243464
   Coding: 0000208
   VCID: F1AA9E88E82520C996-80A5
   Revision: --------    Serial number: 35502105090747
   Coding: 020000000100000000000101
   ROD: EV_UHVPremi_002.rod
   VCID: A404A7DCAF57C5612D-80F1
End----------(Elapsed Time: 01:40, VBatt start/end: 13.8V/13.9V)-----------
filipkudlac
Slovakia
C?ID=388417
Hello everyone, i just wanted to bring some information to this topic !
From my experience, almost every 5K0 steering wheel ECU wich supports MFSW via LIN2.0 also supports LIN 1.3.
i have tried a few and every one worked properly.
Have to tick byte 0, bit 7 to turn on LIN1.3
I tried:
5K0 953 569 B with sw 122/136/140 - worked properly
5K0 953 569 AH with sw 140 - Worked properly
5K0 953 569 E with sw 140 - Worked properly
5K0 953 569 R with sw 136 - Worked properly
So it isnt just for 5K0 953 569 T, later i will try also steering ecu unit with higher 180 software :)
