Release 16.8 discussion thread (what's new, etc.)
   #21
VAG-Dave
Scotland
HC806344
Can you post a screen-shot? What Window Size do you have set on the Options screen? I'm thinking perhaps that control isn't scaling properly?
Had a look at the scaling option etc & that makes the whole VCDS "window" bigger, I am talking about the actual text size of the channels in the Screen. Before they were almost the same size as the "fixed" text in the screen.
I'll load a pic later
   #22
Andy
Sector 7G
HC424490
You're talking about the font size of the Channel pulldown menu, right?
In that example, there's plenty of room, but some Adaptation channels have very long names, and combined with the IDE stuff, the font size needs to be small to fit it all in there.
   #23
VAG-Dave
Scotland
HC806344
Had to activate an old photobucket account as most forums I use have direct photo loading.
[/URL][/IMG]
The wordng for the channel is smaller in size/height than the wording in green of "not active" before it was about the same size & bigger than it currently is!
   #25
VAG-Dave
Scotland
HC806344
Yep, only so much real estate available. You can always adjust the screen size in Options:
http://www.ross-tech.com/vcds/tour/option_screen.html
I mentioned above that I have tried that but that just makes the whole VCDS screen bigger, & to get the text which is now smaller in this release to the same size it was before, means the rest of the screen can be read from the other side of the garage!
   #26
^^^ Related to VAG-Dave's point, but on a slightly different aspect (don't want to hijack Dave's issue): I'm aware that ver 16.8 has just wrought a significant change to the way that adaptation channels are reported, but has there been any further thought about displaying these channels as relational database items (i.e. in their Parent/child relationships)?
Not sure about others, but in my humble opinion, such an arrangement would be more intuitive. In the current GUI - where an adaptation channel group has many children, the drop down list can get fairly congested! Of course the down-side of my suggestion is that finding an adaptation channel would be a two-step process, but as control modules become more sophisticated in the future, I suspect that the benefit of not using a "flat" structure for adaptation channel nomenclature will become more evident (IMO)!
   #29
MatrixG
Italy
C?ID=243861
Hi all! I am wondering if the infotainment ECU of my Audi A1 model year 2011 will have a coding info option soon. Last year I was waiting for it. In particular i'm waiting for the MMI 3G+ (also for RMC), for the Bose Sound System and for the radio unit. Do you know if there will any update?
Greetings
Alex
   #30
Andy
Sector 7G
HC424490
Got a fresh AutoScan using 16.8.0.3? I take it this unit from one of your earlier threads?
Part No SW: 8X0 035 666 K HW: 8X0 035 666
Did you send us channel maps?
MatrixG
Italy
C?ID=243861
Perfect. Here is my Auto-Scan with debug level -> 2
LINK ZIP File
Here is my new Autoscan
Tuesday,16,August,2016,17:26:09:55074
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN:   License Plate:
Mileage: 96110km-59719mi   Repair Order:
Chassis Type: 8X (8X0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 55 56 5F
VIN: Mileage: 96110km-59719miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 KM    HW: 03L 906 023 KM
   Component: 1,6l R4 CR td H53 8859
   Revision: --H53---    Serial number:
   Coding: 00114034032401080000
   Shop #: WSC 49452 001 104857
   ASAM Dataset: EV_ECM16TDI02103L906023KM 003009
   ROD: EV_ECM16TDI02103L906023KM.rod
   VCID: 7BF26186F232429AF5-802E
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AH    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0004
   Revision: --------
   Coding: 310448E9437300B98C2812E2C2D200520F00
   VCID: 04001A7A83CC3D6284-8050
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030003701954
   Shop #: WSC 00046 000 00000
   VCID: 34608ABA57EC4DE274-8060
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 D
   Component: BCM PQ35  M   108 0653
   Revision: 00108 AB
   Coding: 06000A2CA805F300A01841E02100094C53FF720A21EF5122E40887870041
   VCID: 4088D66AD354E142E0-8014
   Subsystem 1 - Part No SW: 8K0 955 559     HW: 8K0 955 559
   Component: RLS  H04 0003
   Serial number: 10684353
   Coding: 020A2D
   Subsystem 2 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
   Part No SW: 8X0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H06 0011
   Revision: 11001001    Serial number: --------------
   Coding: 100201
   Shop #: WSC 06385 790 00000
   ASAM Dataset: EV_AU210ParkAssis8K 002007
   ROD: EV_AU210ParkAssis8K.rod
   VCID: 4480DA7ACF4CFD62C4-8010
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ000XZYE
   Coding: 30314539303330303036554A304C38583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 4898CE4AF364D90228-801C
   Serial number: 3554VRB4059060GKGO5J
   Serial number: 3575HRB405R0BI7UF93W
   Serial number: 3585HRB404P0ATOC5PHG
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB405L0891I70VJ
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110625200001
   Coding: 5184204000
   Shop #: WSC 00046 790 00000
   VCID: 3B72A186B2B2829AB5-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8X0 920 930 A    HW: 8X0 920 930 A
   Component: KOMBI         H07 0124
   Coding: 11DE00
   Shop #: WSC 00046 790 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
   VCID: 3878BE8A8384A98258-806C
   Part No SW: 8X0 907 468 A    HW: 8X0 907 468 A
   Component: GAT 4CAN 1L M H04 0083
   Revision: 1C060023    Serial number: 2341C1112681C9
   Coding: FBCF005A000100010053
   VCID: 4382D966C242FA5AFD-8016
   Subsystem 1 - Part No SW: 8K0 915 181 G    HW: 8K0 915 181 G
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370467434
   Serial number: 11034000644021200181
   Component: IMMO          H07 0124
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011E12205C00000100
   Shop #: WSC 27995 123 104857
   VCID: 52ACEC220D3863D246-8006
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F6A85D6EACA6E3A09-807A
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 8X0 035 223 C    HW: 8X0 035 223 B
   Component: BOSE G3 A1Q3  H04 0130
   Revision: CK004200    Serial number: 00000000005265
   Coding: 030000
   VCID: 326C8CA26DF843D266-8066
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   Coding: 011E12201E00000100
   Shop #: WSC 00046 123 12345
   VCID: 51AEE32E083E18CA7F-8004
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357     HW: 8X0 907 357
   Component: ****LWR12**** H02 0040
   Serial number: 110119-0004-066
   Coding: 1131941010020500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 7F0A9596E62A5EBAD9-802A
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109C.0F8024676
   Coding: 010105010000000002
   VCID: 28586ECA5B243902C8-807C
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 138
                    Mileage: 96113 km
                    Date: 2016.08.16
                    Time: 17:17:31
                    Voltage: 12.10 V
                    Bin. Bits: 00000000 00000001
   Component: H-BN-EU       H46 0792
   Revision: --------    Serial number: 436DQ0AB000409
   Coding: 0C0101020008C1E90100033600000001E40000000000000000
   Shop #: WSC 06443 128 28888
   VCID: 4586C77ECC76C46AD3-8010
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Subsystem 2 - Part No SW: 8X0 919 604     HW: 8X0 919 604
   Component: DU6 High  H42 0084
   Serial number: 9463AR0C2500973
   Subsystem 3 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
End-------------------------(Elapsed Time: 02:46)--------------------------
Thursday,18,August,2016,17:29:12:55074
VIN: WAUZZZ8X7BB067301   License Plate:
VIN: WAUZZZ8X7BB067301   Mileage: 96110km-59719miles
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37X-ESP82.CLB
   Revision: --------
Address 08: Auto HVAC        Labels: NONE
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.CLB
   Revision: 00108 AB
   Coding: 020A2D
   Coding: 100201
   Coding: 5184204000
   Coding: 11DE00
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.CLB
   Coding: 000002
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.CLB
Address 44: Steering Assist        Labels: 6Q0-423-156.CLB
   Coding: 11251
   Shop #: WSC 00046
Address 47: Sound System (J525)       Labels: REDIR FAIL!
   Coding: 030000
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.CLB
Address 56: Radio (R)       Labels: REDIR FAIL!
            000 -  -
                    Reset counter: 138
                    Mileage: 96113 km
                    Date: 2016.08.18
                    Time: 16:38:04
                    Voltage: 12.00 V
   Component: H-BN-EU       H46 H-BN-EU       H46 07920792
End---------------------(Elapsed Time: 22:37, Deb=2)-----------------------
Hope this could help ME and YOU :D
Until now I have retrofitted
Front - Rear park assist
Cruise Control
MMI 3G+
Bose Sound System
Multifunc. Sterr. Wheel with new ECU
Folding Mirrors
Rain-Light sensor
LED lights interior
Now I'm trying to coding correctly radio and Information Electronic. Also I've coded TPMS. It works but the reset button doesn't do anything. It's correctly connected to pin 4 of my ESP ECU
lala30
Croatia
C?ID=71949
dont see coding BCM and few adapted chanal :
but is base same
Thursday,21,July,2016,09:04:59:14216
VCDS Version: 16.6.0.2 (x64)
Data version: 20160602 DS251
Workshop Code: 016 06385 000790
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001615600542
Shop #: WSC 06385 790 00016
ROD: EV_BCMBOSCH_VW37.rod
VCID: 7EF32078E1C0FDB3AB-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160528 043 0585
Serial number: 160608052321
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61914725
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Serial number: 30 03 2016 00002094
MatrixG
Italy
C?ID=243861
I'm trying to understand the content of PLA and PLB files. It seems that PLB comes from Measuring Block Function and PLA from Adaptation Channel. Is it correct?
My aim is try to remove that last error that remain on 56 - Radio. As saysyYour web page
Sound System Data Set incorrect or doesn't match Vehicle Equipment
it seems an Adaptation problem. I've compared the coding string with other Audi A1 scan from the web with similiar equipment (3G+,Bose, DAB) and I think that this last one is correct.
I would understand the difference between a coding and an adaptation. Coding seems like a motherboard BIOS setting which is loaded at start. Instead Adaptation seems like when you have a program running and you want to modify some environment settings. But my feeling is that in some ECU, adaptations seem like a coding operation because involves some hardware enabling (like num of speaker channel choosing).
   #34
Yes.
I don't think so. This is usually indicative of an incorrect set of data that has to be "flashed" into the module.
Yes, they are two different functions, but at times (and depending on the module in question), there does seem to be overlap in what they do. Both can be thought of as means of configuring a module. Early on, coding started out as just 7 bits, expanded to 15, then to 23, and then to 'long coding', where it's a long string of bytes that can be changed. Adaptation was originally a maximum of 99 8-bit channels, which grew to 99 16-bit channels, got expanded to 255 channels, then long adaptation started accepting text strings in some modules, and now with UDS, it can (in principle) support 64k channels of arbitrary data types.
Andy
Sector 7G
HC424490
I'm putting this here for now, Helen's A3 Adp map of 09. So far all three MQBs I tried, displayed these channels correctly (although I assume "look" should be "lock"?):
Monday,22,August,2016,17:47:13:58389
VCDS Version: 16.8.0.3 (x64)  HEX-NET CB: 0.4323.4
VIN: WAU3FLFF2F1131312   License Plate: HN-16-8-0-3
UDS Adaptation Channel: IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen
Stored value 3
UDS Adaptation Channel: IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus
Stored value by look command via remote control key
kuebk
Poland
C?ID=139835
Last time I got my hands on VW Passat B8, this was my first car with UDS and so far I'm unable to do proper ECU logging. I'm doing following:
- 01 Engine
- Advanced Measuring Blocks
- type in filter, lets say I type "inj"
- checked deviation for all for cylinders
- have proper live readings
- change filter to other
- all live values disappear
When live values disapper the only solution to bring them back is to disconnect from ECU and connect back again. Is this known issue?
Sunday,11,September,2016,14:22:48:35018
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WVWZZZ3CZGE229809   License Plate:
Mileage: 2124km-1319mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 A5
VIN: WVWZZZ3CZGE229809   Mileage: 2124km-1319miles
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H22 1989
   Revision: B5H22---
   Coding: 0119001204341D083000
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026ES.rod
   VCID: 7F07F74FE675B6BAD1-802A
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61076000000875
   Coding: 0FEC6A8F34220B75077F060041CC49F0562CD0E0608292F11060F078C002
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_VW48.rod
   VCID: 79F31957F851988AEF-802C
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0400711518
   Coding: 0F00000E03
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 3A71C65BBDD75392A6-806E
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020104202100011115500000101802
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 6DDB3D07BC19342A73-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 865821041600XN
   Coding: 00030E46C2C102FF0BA44084B11C07081880000000000000000000000000
   VCID: 030F7BBF8A9DD25AB5-8056
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160319  042 0607
   Serial number:         160331135718
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 90062778
   Coding: 00006E
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 30 01 2016  10001669
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY160322FUP
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065508776
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331610402883
   Coding: 0071051101
   Shop #: WSC 05311 115 00060
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 448DB8A3CF131562CC-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 2A00604951FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346DE8639FB3A5E27C-8060
0836 - Databus
                    Fault Frequency: 137
                    Reset counter: 59
                    Mileage: 69 km
                    Date: 2016.09.02
                    Time: 15:56:39
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 12.3 V
                    Status_ACC_System: ACC_Init
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSP7RMAL%
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EF90A4BE17FBFB2DA-802A
   Belt Pretensioner left:
   Serial number: 3G1857705G0116Q00489
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G1857706G0109Q00603
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 000 704 16
   Serial number: 3576U000000F72502A17
   Subsystem 4 - Part No SW: -----------    HW: 454 000 704 16
   Serial number: 3586U0000003D73C4A1J
   Subsystem 5 - Part No SW: -----------    HW: 454 802 703 16
   Serial number: 3516R89A0780A0000008
   Subsystem 6 - Part No SW: -----------    HW: 454 802 703 16
   Serial number: 3526REA37650A000000C
   Subsystem 7 - Part No SW: -----------    HW: 454 801 903 16
   Serial number: 3556VB8F84A0A000000U
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160322500255
   Coding: 0400
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BFF035FF26DAA9AFD-802E
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Component: KOMBI         301 6430
   Coding: 07A409102B84000801886B011000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 234F1B3F2A5D325A95-8076
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 14041610800743
   Coding: 030300345F087300FB00024E080F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160000684620036151
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001604022918
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
                    Reset counter: 53
                    Mileage: 846 km
                    Date: 2016.09.04
                    Time: 17:39:40
                    Supply voltage: Terminal 30: 12.7 V
                    Terminal 15: OFF
   Serial number: 16000073566008
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E32177A021D0CA57-8024
   Serial number: 150316ECE0660A
   Coding: 00351A208000028000001000
   VCID: 438FBBBFCA1D125AF5-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E
   Serial number: 00000000000003499791
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000743749
   Coding: 01000010005000
   Shop #: WSC 00015 115 00311
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_VW37.rod
   VCID: 3D7BCD47ACF964AA83-8068
   Serial number: 120416EDC00817
   Coding: 003510208000028000001000
   VCID: 4281BEBBD5071B52FE-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E
   Serial number: 00000000000003495278
   Coding: 090000
   Component: AFS-ECU       H01 0120
   Coding: 039A00004F200200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3F87B74FA6F576BA91-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0624
   Coding: 02840201FF00000051110001000808001F010084012001008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6ED93A0BB11FCF324A-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU00WKH
   Subsystem 2 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0400576168
   Coding: 0100000202000000
   VCID: 3B7FC35FB2ED6A9ABD-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 14041611K11660
   Coding: 0004080200000401002213458040A10010000E300040
   ROD: EV_MFKBoschMQBB.rod
   VCID: 3777DF6F8EC54EFA59-8062
End-------------------------(Elapsed Time: 04:30)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We have a new version in the works which addresses a similar issue (for adaptation channels) that is likely to be related to your observations here, please contact us via support@ross-tech.com with a reference to this topic and we should be able to send you something for testing.
   #38
- 01 Engine
Please download a fresh copy of VCDS (which should get you to 16.8.1.3). I believe that will fix the problem you are experiencing. Confirmation would be appreciated.
Viking
C?ID=151455
Just had a small issue with updating VCDS. I was on 16.8.0, and it flagged up an update available so I clicked yes. It downloaded okay (apparently) but didn't volunteer to update the program. I rebooted the laptop and checked the build number in the program and it was still at 16.8.0. Manually checked updates and there was nothing new, despite there being a previous notice to upgrade.
I downloaded a fresh install from the website and installed it, and all is now updated okay.
   #40
kuebk
Poland
C?ID=139835
Where can I find longer version number? Mine VCDS doesn't show the fourth element of version string.
