2013 Audi Q5 HVAC diag procedures
tmoe
C?ID=109772
my '13 q5 3.0 hvac blower has recently developed a very odd problem. The AC will start working, blowing cold air through the vents but over time the amount of air coming out of any of the vents slowly is reduced to almost nothing. You can hear the blower working, the compressor is working as the air coming out of vent is still cold but very little. Its not icing of the coils because if you stop the Q5 and restart the engine the blower starts working properly only to slowing lose air coming out of the vent. There are not any error codes.
Are there any diag and adaptation procedures that can be run to verify the hvac modules/compressor are operating correctly?
Here's a recent autoscan
Thursday,07,July,2016,18:19:06:46081
VCDS Version: 16.6.0.2 (x64)
Data version: 20160602 DS251
VIN: WA1DGAFP9DA055175   License Plate:
Mileage: 30800km-19138mi   Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          6C 6D 72
VIN: WA1DGAFP9DA055175   Mileage: 30800km-19138miles
Address 01: Engine (J623-CTUC)       Labels: 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0001
   Revision: --H07---
   Coding: 2A2A0034052601060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218R0907551A 001002
   ROD: EV_ECM30TFS0218R0907551A.rod
   VCID: 3668398E89F37CF333-8062
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 AM    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 08148776B3873A0391-805C
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8R0 907 379 AL    HW: 8R0 907 379 AL
   Component: ESP8 quattro  H09 0040
   Coding: 191D1C03
   Shop #: WSC 06335 123 12345
   VCID: 0A10BD7EA58B481387-805E
            000 -  -
                    Fault Frequency: 18
                    Reset counter: 106
                    Mileage: 30788 km
                    Date: 2016.07.01
                    Time: 12:26:24
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0015
                    Hex Value: 0x1099
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H12 0633
   Coding: 0DA54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 040C934687AF1E63FD-8050
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01090120131044
   Coding: 6621228000
   VCID: 397232B2B0ED938BDE-806C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000041307401
   Coding: 26000095813CAFE00201480300003D0D4F9C4708A6090321000008004000030100000034000000
   VCID: 78F4F7B6CB674A83E1-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 121210  H11 0050
   Coding: 01DD13
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD914GJK
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4796444AFE19F57B58-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R120000BKTB
   Serial number: 6334MSME7435280AC
   Serial number: 6344MSME754412726
   Serial number: 6352QSME52281F4AO
   Serial number: 6362QSME76281566J
   Serial number: 63732SME5F2557566
   Serial number: 63832SME5F25426C8
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372LLL000R5
   Coding: 000037
   VCID: 438E505AC221D95B84-8016
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 T    HW: 8R0 920 980 T
   Component: KOMBIINSTR.   H35 0556
   Revision: 00000000    Serial number: UWH23461E
   Coding: 83FF22000301D705020201
   VCID: 4A907D7EE50B081347-801E
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y12C2102AD
   Coding: 80CF03FF00
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000047771961
   Coding: 01581B00000000000000
   VCID: 4280555EDD3BD0538F-8016
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000047920322
   Coding: 011D13205E00440004
   VCID: 4FA66C6A1E692D3B10-801A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0006119582
   Coding: 000000010001
   Shop #: WSC 42520 123 104857
   ROD: EV_RCEPSAU48X.rod
   VCID: 3B7E28BAB2D1A19BCC-806E
   Revision: 00002001    Serial number: 0300043943
   Coding: 01260E3A30FA709787B0053602040007
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H05 0220
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813009257302
   VCID: 2D5A16E274A53F2B42-8078
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000047286961
   VCID: 4E98716E196324331B-801A
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001231545
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 387437B683E78A8321-806C
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156L%0C7678101
   Coding: 020007010000000001
   VCID: 2240F5DE3D7BF053EF-8076
   Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 0624
   Revision: --------    Serial number: 204AV0D7550774
   Coding: 1C0200060105E1EF47029B5C00000403140000000000000002
   VCID: 3776348A86F985FB28-8062
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  4949
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000048182296
   Coding: 010C13204000240004
   VCID: 4688494EF113EC73A3-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J2YA23J
   Coding: 1020010
   VCID: 346C0386578F6EE30D-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7E28BABAD1A19BCC-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000048182297
End-------------------------(Elapsed Time: 03:53)--------------------------
Is this in "Auto" mode? I'm not familiar with the HVAC controls in the Q5, but all the ones I've seen in other models give one the ability to set fan speed manually. What happens if you manually turn up the fan speed?
tmoe
C?ID=109772
Yes it has an auto mode but I can change manually and the sound of the blower changes as you would expect but there is not any increase in air coming from the vent. I've also changed the location the air is supposed to blow, windshield, center vents and floor and this doesn't change where the air blows. What's odd is that when I restart the Q5 all works fine for a bit of time ( the amount of time is all over the board, sometime very quickly in under an hour it goes crazy; yesterday on a long trip it was 8 hours into a trip where the vents acted up, got off interstate worked fine for about an hour then all of a sudden it stops blowing even though the blower is running. Seems like a flap that controls where the air flows goes crazy after a period of time. Older VW/Audi's had a diag procedure to adapt the flap and I was wondering if this version of Q5 has something similar.
PPP
Sketchy
Cambodia
C?ID=242293
Hi,
It is worth trying to do a hard reset for the system. Let try it.
tmoe
C?ID=109772
I did clear codes, I don't see a way to do a hard(soft) reset as there isn't a label file for the module so there isn't any information for long coding or adaptation. the older vw and audi's had a diag procedure and I was hoping that was the case.
