Vw Touran ABS Long Coding help.
smokey08
C?ID=120732
Hello
I have a 2011 1.6tdi Touran which has had the ABS pump replaced. The old pump failed and is not available for me to recover the original long coding (original pump sent to repair company and they could not fix it and supplied another).
I have tried and failed to generate the coding with my AVDI.
Here is the autoscan;
Friday,29,July,2016,19:10:45:42467
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVGZZZ1TZBW025569   License Plate: xx60 xxx
Mileage: 97980km-60881mi   Repair Order:
Chassis Type: 1T (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 52 56 61 62 72
VIN: WVGZZZ1TZBW025569   Mileage: 97980km-60881miles
18-Aux. Heat -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AS    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 7003
   Revision: --------    Serial number: 00000000000000
   Coding: 00194034032501080000
   Shop #: WSC 01324 020 00200
   ASAM Dataset: EV_ECM16TDI02103L906023AS 003002
   ROD: EV_ECM16TDI02103L906023AS.rod
   VCID: 77F86653CE68A7864F-8022
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [032] - Signal too High
6086 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:18
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Fault Frequency: 13
                    Mileage: 97979 km
                    Date: 2016.07.29
                    Time: 00:36:24
   Revision: 00H31001
   Shop #: WSC 33361 790 00999
   VCID: 76E66B57C162DE8E54-8022
03842 - RPM Sensor Rear Right: Incorrect Signal
            000 -  -  - Intermittent
                    Reset counter: 23
                    Mileage: 97980 km
                    Date: 2010.12.20
                    Time: 02:31:48
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 87
                    Count: 52480
                    Count: 65280
                    Count: 65280
            000 -  -
                    Reset counter: 23
                    Mileage: 97980 km
                    Date: 2010.12.20
                    Time: 02:35:53
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 48896
                    Count: 65280
                    Count: 65024
                    Fault Status: 01100101
                    Reset counter: 23
                    Mileage: 97980 km
                    Date: 2010.12.20
                    Time: 02:31:48
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 279
                    Count: 52224
                    Count: 65280
                    Reset counter: 23
                    Mileage: 97980 km
                    Date: 2010.12.20
                    Time: 02:31:48
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 52224
                    Count: 65280
                    Reset counter: 23
                    Mileage: 97980 km
                    Date: 2010.12.20
                    Time: 02:31:48
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 52224
                    Count: 65280
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426     HW: 7N0 907 426
   Component: AC Manuell    H15 0101
   Revision: 00010001
   Coding: 0000000003
   VCID: 71EC584BA00CF9B681-8024
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:24
   Part No SW: 5K0 937 084 D    HW: 5K0 937 084 D
   Component: BCM PQ35 B    011 0035
   Revision: BA011001
   Coding: 48180A389025F1E040080080140000E441518E08426DA1606480C7000041
   VCID: 3360924392908BA6B3-8066
   Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 01091  26  0512
   Coding: 009795
   Component: RLS 110910 05  54  0403
   Coding: 0330ED
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
                    Reset counter: 41
                    Mileage: 97007 km
                    Date: 2010.11.28
                    Time: 19:15:17
                    Voltage: 10.95 V
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2010.12.11
                    Time: 00:05:20
                    Voltage: 10.30 V
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431024901519
   Coding: 109201
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 3C72B97FB7CE44DE62-8068
11 Faults Found:
12656928 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:23
12656929 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:22
12656930 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:22
12656931 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:22
12656932 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:22
12656933 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:23
13637395 - Databus
                    Reset counter: 23
                    Mileage: 97979 km
                    Date: 2016.07.29
                    Time: 00:36:26
13637396 - Databus
                    Reset counter: 36
                    Mileage: 95738 km
                    Date: 2016.06.19
                    Time: 17:27:12
13637397 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.29
                    Time: 01:46:55
12656934 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:23
12656935 - Databus
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:22
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D00PHEA
   Coding: 0012338
   VCID: 3778A65346E867868F-8062
   Subsystem 1 - Serial number: 6332QSME295D3E0CX
   Subsystem 2 - Serial number: 6342QSME295D4D12P
   Subsystem 3 - Serial number: 6352QSME7D6B0138Q
   Subsystem 4 - Serial number: 6362QSME5D6C420EY
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JI6000T2
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 72EE5747A50AC2AE78-8026
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0118967
   Coding: 820000
   Part No SW: 1T0 920 971 D    HW: 1T0 920 971 D
   Component: KOMBI         H05 0404
   Coding: 481B00
   VCID: 3564AC5B94E495969D-8060
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2016.07.20
                    Time: 00:05:23
   Part No: 5K0 963 271 C
   Component: Zuheizer        051 2606
   Revision: 00051000    Serial number: 09021535000000
   Coding: 0000031
   VCID: 2F689E33BEB8AF46D7-807A
00664 - Fuel gauge
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 64
                    Mileage: 89200 km
                    Date: 2016.03.22
                    Time: 07:44:29
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 160910F2000932
   Coding: E9A07F06000A1204008003
   VCID: 2E568337B9B2A64EDC-807A
                    Fault Status: 00110100
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2010.12.11
                    Time: 00:05:19
                    Fault Frequency: 139
                    Reset counter: 59
                    Mileage: 69990 km
                    Date: 2015.06.25
                    Time: 19:11:46
   Component: IMMO          H05 0404
   VCID: 6ADE4F278DDA0A6EC0-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 48220 km
                    Date: 2014.02.21
                    Time: 18:16:15
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668616266
   VCID: 275876135648F7061F-8072
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2112
   Coding: 0131765
   VCID: 489AD5AF3B16187EF6-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 01324 785 00200
   VCID: 316C984BA88CB9B6C1-8064
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 51
                    Reset counter: 23
                    Mileage: 97981 km
                    Date: 2010.12.20
                    Time: 03:25:51
                    Voltage: 12.25 V
                        DD
                    Temperature: 29.0\B0C
                    Reset counter: 63
                    Mileage: 97979 km
                    Date: 2010.12.11
                    Time: 00:05:23
                    Voltage: 12.38 V
                        DU
                    Temperature: 30.0\B0C
                    RPM: 890 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0131765
   VCID: 4798D69336081706FF-8012
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: RCD310 EU     H13 5042
   Revision: -----05S    Serial number: VWZ4Z2K1335712
   Coding: 0100040004
   VCID: 65C43C1B6CC42516ED-8030
   Component: Batt.regelung H25 5603
   Coding: 030B185A
   VCID: 71EC584BA80CF9B681-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2104
   Coding: 0131216
   Shop #: WSC 01324 020 1012552
   VCID: 326E9747AD8A82AEB8-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0131216
   VCID: 3360924352908BA6B3-8066
End-------------------------(Elapsed Time: 02:42)--------------------------
Brake discs are: Front 288mm and rear 253mm and car is UK spec RHD.
Coding which I tried is: 333B401609240EFFCC1002EA90220082300040
Here is the label if it helps
Any help generating the coding will be appreciated. Thank you.
Arek_VI
Poland
C?ID=275247
Try this coding:
323B0016092400FF4C1000EA90220081000400
smokey08
C?ID=120732
After a lot of wildcard* searching I think I may have worked it out to be:
333B4016092406FFCC1002EA90226081310150
I will update post again tomorrow once I have tested.
Gone But Not Forgotten
Revision: 00H31001
WVGZZZ1TZBW025569
1K0 907 379 BE
03L 906 023 AS 1.6
CAYC
AREK: 323B0016092400FF4C1000EA90220081000400
Smoke: 333B4016092406FFCC1002EA90226081310150
Scans of the net trolling:
Coding: 323B401609260EFD4C0C02EC901A7041310000 Close match
BASE : 323B0016092400FF4C1000EA90220000000000 VIN Decode.
Decode:323B401609260EFD4C0C02EC901A7041310000
323BX016092X0XFX4CXX0XEX90XXXXXXXXXXX
xxxx4xxxxxxx6xxxxxxxxxx2xxxxx 7041310000 <<<<<
Smoke: 333B4016092406FFCC1002EA90226081310150 <<<<< Cross check Smokey
Coding :323B4016092400FF4C1002EA90227041310000 Try this.............
6FF4C1002EA90227041310000 Try this.............
smokey08
C?ID=120732
I have completed this job today.
Correct coding should be 333B4016092406FFCC1002EA902260B1310150
During the fault diagnosis an old generation wheel speed sensor to the rear left so I had to set the code to 333B4016092406FFCC1002EA902260B1310140 to clear the fault and have advised customer to fit a new genuine sensor and get me back to correct the coding.
I did try all the codings posted and only mine was accepted but it gave "control module incorrectly coded fault code" and stop start error on dashboard. A bit more searching of autoscans on the internet and I managed to work it out.
Many thanks for your help.
Nice post Smokey because scans are the answer in many cases so ask for full scans when in forums elsewhere because it helps everyone.
