Jetta MK6 ABS Fault - Any advice/ thoughts?
fflip
C?ID=218364
hi Folks,
I am a new owner of a Jetta and VCDS (no, they don't come bundled together)
While doing my first scan I am concerned about 2 ABS faults, scan is listed below.
Recently I had a flat tire where I thing the ABS/TPMS failed to detect in due time, so the tire was a total loss. I am unsure if this is related but not to my errors.
I do not understand the date format for the events either - one says: Date: 2016.14.31 ?!?
Any advice is appreciated!
Thanks in Advance!
Don't worry about radio fault code;
Tuesday,10,June,2014,18:05:24:53937
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: 3VWLL7[B]AJ[/B]XXXXXXXXXX   License Plate: MYCAR
Chassis Type: AJ (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 47 56 77
   Part No SW: 03L 906 019 HD    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000AG  4818
   Revision: 12H15---    Serial number:
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 74C935DB17699EBE8FF-8021
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3524
   Revision: 05551213    Serial number: 00001208290375
   VCID: 2469059BE7094E3EDFF-8071
   Revision: 00H31001
   Coding: B14B400C492700FC8D0D02EC921E0042A71000
   VCID: 7DDF10FFE423DFF6F01-8028
02846 - Switch fro Tire Pressure Monitoring Display (E492)
                    Reset counter: 98
                    Mileage: 27179 km
                    Date: 2016.14.31
                    Time: 21:17:32
                    Count: 16391
                    Count: 32780
                    Count: 157
                    Count: 45056
                    Count: 768
02214 - Tire Pressure Warning
                    Reset counter: 113
                    Mileage: 19693 km
                    Date: 2013.14.07
                    Time: 14:23:35
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 50945
                    Count: 254
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001306129
   VCID: 60E1498BB391121EFB7-8035
The flux capacitor in your car is obviously defective. VW should replace it under warranty. ;)
Seriously, does your car know the date? The date data that's stored in fault codes' freezeframes has been a source of some frustration to us; in cars which aren't date-aware, it's not a real date, it's some kind of goofy offset from the build date, and although we thought we finally had that nailed down in the latest Beta version, I think there's something not quite right with that.
fflip
C?ID=218364
What is the Flux capacitor if I may ask ? (I've seen similar threads where this was a joke)
It is a joke :-) http://en.wikipedia.org/wiki/DeLorean_time_machine
.. but all joking aside "02846 - Switch fro Tire Pressure Monitoring Display (E492)" looks like we have a typo! I'm not sure if that was addressed to I'm mention it to the guys.
It isn't entirely uncommon to have Tire Pressure Warning - Lower Limit Exceeded faults when a tire was low but the switch fault is not normal. I suspect the E492 switch itself is malfunctioning but Implausible Signal can also mean sticking. Is that in the center console or glove box and either way, is something pressing on it at times (owner's manual or glove box treasures) or did coffee spill into a console mounted switch? Do you have children that like to press buttons?
fflip
C?ID=218364
Thank you
So the switch is the one in the glovebox... nothing there which can tickle it
I think I'll let the error codes there and I will ask the dealer to scan the car.
Do you know if dealers bother if we scan our cars with VCDS, or should I better say nothing about VCDS?
FFLIP
Is it still under warranty? You blanked out so much of the VIN that we can't see what model year it is.
Depends on the dealer. Some buy VCDS for their techs. Others think it's an act of sacrilege to scan with anything other than their "authorized" tools.
fflip
C?ID=218364
went to the dealer who scanned the car and said there were no errors. A reason to "trust" them even more
They most likely cleared the faults, so they probably weren't lying about the condition of the car when they gave it back to you.
