Can not find an option a to recalibrate G450 sensor
axnels2
C?ID=217346
I replaced 076-906-051a pressure sensors and having a hard time finding a way to recalibrate them. Can someone please help? More specifically I can not find menu options to let me do that on VCDS. I guess these sensors are called G450 and G451.
axnels2
C?ID=217346
No one recalibrated the exhaust sensors on TDI? Odd. Where can I find a complete list of VCDS features and functions?
Santos
Procedures will vary based on the control module. This post would be better in the vehicle repair section. I will move the post but ask that you also post an autoscan so we have more specific vehicle details.
axnels2
C?ID=217346
Santos, thanks for helping me post to correct forums. this is 2009 jsw MKV 2.0 tdi with DSG... Here is a recent autoscan.
VIN: 3VWPL71K59M323465 License Plate:
Mileage: 93610km-58166mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWPL71K59M323465 Mileage: 93610km/58166miles
0F-Digital Radio -- Status: Cannot be reached 1100
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: 12H01--- Serial number: VWX7Z0I124C0GP
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3FA3AAE56EB2B7E6A2D-806A
001146 - Exhaust Pressure Sensor 2
P047A - 000 - Open Circuit - Intermittent
Mileage: 93566 km
Time: 12:18:55
Temperature: 25.2∞C
Temperature: 67.5∞C
Temperature: 54.0∞C
Pressure: 0 mbar
Pressure: 0 mbar
001674 - ECM Power Relay Load Circuit: (J271)
P068A - 000 - De-Energized Performance Too Early - Intermittent
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0∞C
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1953
Revision: 04844002 Serial number: 00000811130854
Shop #: WSC 00028 000 00000
VCID: D1871C5D4826B196C49-8084
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B600D492400FD880F06EA921E0042B100
VCID: 75CF08CDDC0E3DB6B81-8020
Part No SW: 1K0 820 047 JJ HW: 1K0 820 047 JJ
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 75CF08CD1C0E3DB6B81-8020
01296 - Sensor for Vent Temperature; Center (G191)
007 - Short to Ground
00229 - Refrigerant Pressure
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009298417
Coding: 04898F2340041500070000001C000000000873075C00012000 0000000000
VCID: 3245F3D1ADE06A8E5D3-8067
Component: Wischer 050209 021 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 0K AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08L391
Coding: 0012363
VCID: 6DFF20AD745EF576401-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME41052F143
Subsystem 3 - Serial number: 6342MSME4330563EA
Subsystem 4 - Serial number: 6351HSME1B452579B
Subsystem 5 - Serial number: 6361HSME1B2E0871C
Subsystem 6 - Serial number: 63727SME1B600D5B7
Subsystem 7 - Serial number: 63827SME1B60146D3
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001034
VCID: 8225E311DDC09A0E0D3-80D7
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I124C0GP
Coding: 0007203
Shop #: WSC 20129 444 64522
VCID: 3957C4FD709699D69C9-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 101208F2000424
Coding: ED807F07001302002002
VCID: 3753C2C546828FA66AD-8062
01304 - Radio
Reset counter: 184
Mileage: 71553 km
Time: 08:06:50
02649 - Digital Radio Tuner
Reset counter: 209
Mileage: 72038 km
Time: 18:25:19
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2EGJ03
VCID: FDDF90EDA43EE5F6701-80A8
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000515189128
Coding: 0001205
VCID: 6FC33AA57E52076672D-803A
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C79EDA98FC43C7E17F-8079
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 11.2 V
PD
Temperature: 17.0∞C
Count: 2
Steering Angle: 0.00∞
SteerAng n.Init
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Revision: 00052000 Serial number: 00000000000000
Coding: 1390078852830C3E29040585B0880F0488DC00
VCID: 72C533D16D602A8E9D3-8027
00332 - Control Circuit for Tank Flap
Fault Status: 00110111
Reset counter: 118
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08121601350503
Coding: 0001204
VCID: 70C139D9636C189E6B7-8025
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003721937
Coding: 0001168
VCID: 76CD0FC1010836AEB1B-8023
Component: RDK 0453
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003761699
Coding: 0001168
VCID: 77D302C506024FA6AAD-8022
End ---------------------------------------------------------------------
For some reason we get a lot of calls about incorrect replacement sensors sold to repair shops from the VW dealer so please make sure that BOTH sensors were NOT the same 076-906-051-A part number.
1K0-131-552-B is control line with pressure difference sender per PartsLink24 by VIN
03G-906-051-A is pressure difference sender per PartsLink24 and supersedes to 076-906-051-A as far as I can tell.
Based on the parts illustrations alone (I did not dig through the repair manual yet) it looks like the 1K0 sensor is the front/upstream G450 and the 076 sensor is the rear/downstream sensor which should be named G451. If you aren't sure please check the part numbers located on the old sensors and post the numbers here for review.
Exhaust Gas Differential Pressure Sensor (G450) Adaptation is performed as follows:
* Key ON, Engine OFF
* [Coding-2] or [Login-II] button
* Enter 30605 [Do It!]
* Switch Ignition OFF for 30 seconds
After the key is cycled back on the adaptation should be completed. If it is not completed, proceed with the next steps:
These steps must be repeated 5 times.
* Ignition ON
* Wait 5 seconds
* Ignition OFF
* Wait 40 seconds
* Repeat 4 more times
axnels2
C?ID=217346
Dana, thank you for your reply. My sensors were 076-906-051-A sensor1 and 03G-906-051-A (exhaust Pressure Sensor 2 ). Sensor 2 have been replaced with 076-906-051-A as I was told it is more current part. So now both of my sensors are 076-906-051-A. Car appears to be working fine and I don't see any trouble codes... Car already went through a regen and I did not observe any abnormalities.
Thanks for posting the part numbers! If you encounter any further issues or fault codes in the exhaust system (DPF, EGR or similar) please update this thread.
-Dana
