Vw Caddy Van Re wire,
senna1
C?ID=231631
Hi
I have been working on a vw caddy van, 2008, Bit of a nightmare, where the wiring loom on the passenger side was cut through by a disc cutter, Some of the wires are colour coded, But some are x 2 such as two green and whites, two blue & black etc, i started to do one circuit at a time such as lights,, i then moved on to the central locking and had trouble getting the rear door motor to work, and the side sliding door will not lock only unlock, The Engine ECU is from a 2010 and it looks like the 17 instrument cluster is for this ecu, The owner had a few spare clusters & the one fitted on the scan looks like it matches as same vin and serial number, immob 25 also the same . The van has never been used with the 2010 ecu/cluster or key.
The van Is actually a 2008, with the 2010 ecu & cluster just fitted, and the steering ignition lock from the 2010.
He also had spare convenience system central control unit j393, which i think is for this vehicle as other spare controllers we tried we had nothing working,
I'm not sure if the j527 is the correct one for this van,
I noticed on the Autoscan that some of the dates where it shows faults found, freeze frame for example 09 central elect, 2005-09-13,, freeze frame i usually take as
the time when the fault happened, but how can this be when the vehicle is 2008,
My reason for posting this is some items should be working and they are not, just thought you guys maybe able to help regarding if any issues with the controllers on the scan if they could be causing a problem or will later,
Here is the Autoscan there is no engine or gearbox in the van, no radiator,
Tuesday,19,July,2016,16:05:20:46146
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ2KZAX106915   License Plate: 2010
Mileage: 223260km-138727mi   Repair Order: CADDY TEST 3
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZAX106915   Mileage: 223260km-138727miles
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BDJ.clb
   Part No SW: 03G 906 016 LF    HW: 03G 906 016 DR
   Component: R4 2,0L EDC 0000SG  2977
   Revision: 12345678    Serial number: VWX7Z0J23N702G
   Coding: 0003031
   Shop #: WSC 35110 377 00155
   VCID: 72EBF6F26D1B63AE78-8026
8 Faults Found:
16610 - Throttle Pedal Position Sensors (G79)/(G185)
            P0226 - 000 - Implausible Signal - Intermittent
                    RPM: 4473 /min
                    Torque: 7.3 Nm
                    Speed: 151.0 km/h
                    Load: 12.2 %
                    Voltage: 14.36 V
                    Bin. Bits: 11000000
17563 - Manifold Pressure Sensor (G71)
            P1155 - 000 - Short to Plus
                    RPM: 126 /min
                    Torque: 0.0 Nm
                    Speed: 3.0 km/h
                    Voltage: 12.92 V
                    Bin. Bits: 11000010
                    Absolute Pres.: 999.6 mbar
                    Absolute Pres.: 1785.0 mbar
19558 - Motor for Intake Manifold Flap (V157)
            P3102 - 000 - No Signal - Intermittent
                    Torque: 212.3 Nm
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 0.0 Nm
16611 - Throttle Pedal Position Sensor (G79)
            P0227 - 000 - Signal too Low - MIL ON
                    Torque: 212.3 Nm
                    Voltage: 12.31 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Bin. Bits:  0 01  0
18041 - Accelerator Position Sensor 2 (G185)
            P1633 - 000 - Signal too Low - MIL ON
                    Torque: 212.3 Nm
                    Voltage: 12.31 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Bin. Bits:  0 01  0
16567 - Fuel Temp. Sensor A (G81)
            P0183 - 000 - Open or Short to Plus
                    Torque: 212.3 Nm
                    Voltage: 12.31 V
                    Temperature: 133.2°C
                    Temperature: -6.3°C
                    Temperature: 38.7°C
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 000 - Signal too High
                    Torque: 212.3 Nm
                    Voltage: 12.31 V
                    Bin. Bits: 00000100
                    Temperature: -6.3°C
                    Temperature: 38.7°C
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - Intermittent
                    Torque: 212.3 Nm
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
Readiness: 1 4 0 0 0
   Part No: 1K0 907 379 P
   Coding: 0017106
   Shop #: WSC 35110 377 00156
   VCID: 3F8D6FC66EC9FEC647-806A
            013 - Check DTC Memory
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007988820
   Coding: 00884F030004100047000000000000000008FB075C000100000000000000
   Shop #: WSC 35110 377 08192
   VCID: 6FEDFF867E294E4697-803A
   Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 35110
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 108
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.05 V
                    Reset counter: 108
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.05 V
                    Reset counter: 108
                    Mileage: 216898 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.40 V
                    Reset counter: 108
                    Mileage: 208865 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.15 V
                    Reset counter: 108
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
                    Reset counter: 108
                    Mileage: 268927 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.45 V
                    Reset counter: 108
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 108
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 108
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Reset counter: 108
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
Address 15: Airbags
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0000002
   Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0J23N702G
   Coding: 0016401
   VCID: 2C57288A8FBF755EF2-8078
11 Faults Found:
                    Fault Frequency: 11
                    Reset counter: 210
                    Mileage: 223269 km
                    Time: 20:58:17
                    Reset counter: 121
                    Fault Status: 00101010
                    Reset counter: 148
                    Mileage: 223269 km
                    Time: 00:00:12
                    Reset counter: 121
00771 - Fuel Level Sensor (G)
                    Fault Frequency: 14
                    Reset counter: 148
                    Mileage: 223269 km
                    Time: 00:00:13
                    Fault Frequency: 15
                    Reset counter: 108
                    Mileage: 223269 km
                    Time: 00:19:05
                    Fault Frequency: 11
                    Reset counter: 121
                    Mileage: 223269 km
                    Time: 05:52:29
                    Fault Status: 01101101
                    Reset counter: 108
                    Mileage: 223269 km
                    Time: 00:18:59
01312 - Powertrain Data Bus
                    Reset counter: 121
                    Fault Frequency: 31
                    Reset counter: 108
                    Mileage: 223269 km
                    Time: 00:00:18
                    Reset counter: 148
                    Mileage: 223269 km
                    Time: 01:02:32
   Revision:   H07 01    Serial number: 120208F2001591
   Coding: 89801F020002027401
   VCID: 306F3CFAA39711BECE-8064
8 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 148
                    Mileage: 268927 km
                    Time: 00:00:13
                    Reset counter: 108
                    Mileage: 268927 km
                    Time: 00:00:13
                    Reset counter: 148
                    Reset counter: 148
                    Fault Frequency: 13
                    Reset counter: 148
                    Reset counter: 148
                    Reset counter: 108
                    Reset counter: 148
                    Mileage: 232123 km
                    Time: 00:13:14
   Component: IMMO            VDD 1222
02241 - Engine Control Module; Immobilizer Data not Adapted
            000 -  -  - Intermittent
                    Mileage: 223269 km
                    Time: 23:26:40
01176 - Key
                    Mileage: 223269 km
                    Time: 23:26:40
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   VCID: 76E3CAE201737F8E54-8022
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 008A0C087F2D84054858030000C0
   VCID: 000FAC3A53B7413E7E-8054
02483 - Module for Locking of Rear Lid (F327)
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75E1CDEE1C7574965D-8020
Address 56: Radio
End-------------------------(Elapsed Time: 01:17)--------------------------
senna1
C?ID=231631
UPDATE ,, The Vehicle is now all done,
