RVC issue, Solved and my bad
It was my bad completly! Thanks DV52 for helping me seeing what i did wrong!
(could also be that im the issue? but dont think so :P)
Hello
New to forum but not new with VCDS.
now i'm not sure if i messed upp or what happened trying to code some things to my new Golf R Mk7 Estate 2016 using the Beta 16.6 version.
Did a fresh install on Laptop with latest beta on site 2 days ago. 16.6, logs are fresh and only contains this car and what i have done to it
Attached autoscan togheter with Adaptation log and coding log.
And coded som small things as beep confirmation when locking unlocking, Auto Rainclosing(not sure if worked), offroad meny and also tried to enable Sport HMI meny (Didn't work). did try to code rear Brakelight so the inner lights would light up also when braking. (didnt work)
Somewhere with these a strange thing happened and the Rearview camera stopped working/Don’t open and only black window appears with the guiding lines lit up when putting "R" in gearbox, the Sensors does also work so only Camera that doesnt open orgets activated?
No errorcodes and haven’t touched those setting. (What im aware of)
Searched around and I found them in longcoding so tried to code away and then code back.
I resetted Car and also stereosystem by pressing on/off button 10sec+ betveen coding/adaptations, no help.
What can have affected this? I read on some other forum that on these new 2016+ cars it has been other changes done without knowing when coding with VCDS?
Is this true? Does someone know how to fix this issue?
AutoScan:
Adaptation Log:
Coding Log:
Hello
AutoScan:
Monday,18,July,2016,08:30:28:53327
VCDS Version: 16.6.0.2 (x64)
Data version: 20160602 DS251
VIN: WVWZZZAUZGP560046 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 55 5F
A9
VIN: WVWZZZAUZGP560046 Mileage: 2568km-1595miles
Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D0012246605033000
Shop #: WSC 00028 028 00207
ASAM Dataset: EV_ECM20TFS0205G0906259J 001002
ROD: EV_ECM20TFS0205G0906259F_VW37.rod
VCID: 3565717A949139EB3A-8060
Readiness: 0010 0001
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4913
Revision: 06253104 Serial number: TFK01509170039
Shop #: WSC 00028 028 00067
ROD: EV_TCMDQ250021.rod
VCID: 53A12FE23A2507DB34-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62805000000647
Coding: 04FA6BA15426296C0777070441C96920D62A94E0E08296F718425078C208
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7AFFA246FD0F169397-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0381190422
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: 3A7F6246BD8FD693D7-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 02020024200100011005000000101002
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 6ADF92068DAFA61367-803E
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86580510151643
Coding: 00511A46C24122F30BA44080B11C07281800000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: 0301DFA28AC5575BC4-8056
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150805 043 0551
Serial number: 150930043010
Component: RLHS 037 0059
Serial number: S5Y15M10D17H02M40S17
Coding: 90A8DD
Serial number: 000000000ZY1523618DQ
Serial number: 00000000000063701901
Sun Roof:
Subsystem 5 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST000K2C0Y00000
Coding: 191900
Roof Blind:
Subsystem 6 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST000K29E900000
Coding: 191900
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391528103152
Coding: 0071151011
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 43811FA2CA45975B84-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 22081503271870
Coding: 003C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR14P4BW
Shop #: WSC 00028 028 00064
VCID: 7F095352E62D33BBA0-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B09101571351
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B10101540287
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 110 15
Serial number: 35767000000E12BC861/
Subsystem 4 - Part No SW: ----------- HW: 480 000 110 15
Serial number: 35867000000EE0BC8619
Subsystem 5 - Part No SW: ----------- HW: 480 400 610 15
Serial number: 3516502BB1CCEA01127I
Subsystem 6 - Part No SW: ----------- HW: 480 400 610 15
Serial number: 3526502C11CF2D74714G
Subsystem 7 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3556502BB1CF2D71217N
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151008400276
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 73E18F62DA6567DBD4-8026
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 07AD10182F80000801886E011400000000000000
ROD: EV_DashBoardVDDMQBAB_VW37.rod
VCID: 2D55591A7CC1712B42-8078
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 06101510800887
Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
ROD: EV_GatewConti.rod
VCID: 75E5B17AD41179EBFA-8020
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N
Component: E221__MFL-DC1 H11 0040
Serial number: 29150001980050065407
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 5596328003
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Serial number: HA1-00028.08.15
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_VW36.rod
VCID: 4A9F3286ED6F461347-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000218721002
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_VW37.rod
VCID: 34634C7E9FEB20E30D-8060
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000169694623
Coding: 003F1220D000028000001000
VCID: 47990BB2FE7DBB7B58-8012
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000010558247
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ROD: EV_SteerAssisMQB_VW37.rod
VCID: 397D7D4AB889DD8BDE-806C
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA010C1K
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 6DD5991ABC41B12B02-8038
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000170123285
Coding: 003F1020DE00028000801000
VCID: 468706B6F977A273A3-8012
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000002354408
Coding: 090000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 06AA00000B010200
VCID: 408B10AEDB538C4399-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 B HW: 3G0 035 043
Component: MU-H-N-EU H42 0343
Serial number: A599J0FB021591
Coding: 027302010000000051110002000808001F0207F401200100DF
VCID: 1B3187C212758F9B2C-804E
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU303KDQ
Subsystem 2 - Part No SW: V03 959 800 QM HW: -----------
Component: ECE 2015/2016 --- 0123
Compact Disc Database:
Component: Gracenote2 --- 1011
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150909200436
VCID: 2F69431276CD033B70-807A
End-------------------------(Elapsed Time: 04:56)--------------------------
Adaptation Log:
Address 5F,3G0 035 043 B,channel (261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI,adapted from,not activated ,to,activated ,Sunday,17,July,2016,11:27:15:53327
Address 5F,3G0 035 043 B,channel (265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,adapted from,not activated ,to,activated ,Sunday,17,July,2016,11:27:31:53327
Address 5F,3G0 035 043 B,channel (262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,adapted from,not activated ,to,activated ,Sunday,17,July,2016,11:27:44:53327
Address 5F,3G0 035 043 B,channel (263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,adapted from,not activated ,to,activated ,Sunday,17,July,2016,11:27:57:53327
Address 5F,3G0 035 043 B,channel (264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,adapted from,not activated ,to,activated ,Sunday,17,July,2016,11:28:15:53327
Address 5F,3G0 035 043 B,channel (265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,adapted from,activated ,to,not activated ,Sunday,17,July,2016,11:28:55:53327
Address 5F,3G0 035 043 B,channel (263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,adapted from,activated ,to,not activated ,Sunday,17,July,2016,11:29:35:53327
Address 5F,3G0 035 043 B,channel (261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI,adapted from,activated ,to,not activated ,Sunday,17,July,2016,11:30:32:53327
Address 5F,3G0 035 043 B,channel (1)-Testmode_Video_speed_cutoff-speed_limit,adapted from,0 km/h,to,289 km/h,Sunday,17,July,2016,11:32:03:53327
Address 5F,3G0 035 043 B,channel (81)-Car_Function_Adaptations_Gen2-menu_display_compass,adapted from,not activated ,to,activated ,Sunday,17,July,2016,13:14:04:53327
Address 5F,3G0 035 043 B,channel (81)-Car_Function_Adaptations_Gen2-menu_display_compass,adapted from,not activated ,to,activated ,Sunday,17,July,2016,13:16:10:53327
Address 5F,3G0 035 043 B,channel (83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,adapted from,not activated ,to,activated ,Sunday,17,July,2016,13:16:40:53327
Address 5F,3G0 035 043 B,channel (265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,adapted from,activated ,to,not activated ,Sunday,17,July,2016,13:18:08:53327
Address 5F,3G0 035 043 B,channel (262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,adapted from,activated ,to,not activated ,Sunday,17,July,2016,13:18:28:53327
Address 5F,3G0 035 043 B,channel (263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,adapted from,activated ,to,not activated ,Sunday,17,July,2016,13:18:42:53327
Address 5F,3G0 035 043 B,channel (264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,adapted from,activated ,to,not activated ,Sunday,17,July,2016,13:18:56:53327
Address 09,5Q0 937 086 AK,channel (8)-Leuchte27NSL RC6-Lichtfunktion C 27,adapted from,nicht aktiv ,to,Bremslicht ,Sunday,17,July,2016,15:19:22:53327
Address 09,5Q0 937 086 AK,channel (10)-Leuchte27NSL RC6-Dimmwert CD 27,adapted from,0 ,to,100 ,Sunday,17,July,2016,15:19:59:53327
Address 09,5Q0 937 086 AK,channel (1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,adapted from,not active ,to,active ,Sunday,17,July,2016,15:24:34:53327
Address 09,5Q0 937 086 AK,channel (2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,adapted from,not active ,to,active ,Sunday,17,July,2016,15:24:57:53327
Address 09,5Q0 937 086 AK,channel (7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,adapted from,not active ,to,active ,Sunday,17,July,2016,15:27:34:53327
Address 09,5Q0 937 086 AK,channel (7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,adapted from,not active ,to,active ,Sunday,17,July,2016,15:35:21:53327
Address 03,3Q0 907 379 AB,channel Expanded electronic differential lock,adapted from,Standard ,to,Medium ,Sunday,17,July,2016,15:48:23:53327
Address 09,5Q0 937 086 AK,channel (9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,adapted from,not active ,to,active ,Sunday,17,July,2016,15:51:51:53327
Address 09,5Q0 937 086 AK,channel (9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,adapted from,not active ,to,active ,Sunday,17,July,2016,15:52:24:53327
Address 09,5Q0 937 086 AK,channel (7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,adapted from,not active ,to,active ,Monday,18,July,2016,08:37:46:53327
Address 09,5Q0 937 086 AK,channel (15)-Access control 2-Regenschliessen_ein_aus,adapted from,not active ,to,active ,Monday,18,July,2016,08:39:22:53327
Address 09,5Q0 937 086 AK,channel (16)-Access control 2-Regenschliessen_art,adapted from,once ,to,Permanent ,Monday,18,July,2016,08:39:54:53327
Address 09,5Q0 937 086 AK,channel (28)-Access control 2-Menuesteuerung Regenschliessen,adapted from,not active ,to,active ,Monday,18,July,2016,08:40:26:53327
Address 09,5Q0 937 086 AK,channel (2)-Access control 2-Comfort opening,adapted from,not active ,to,active ,Monday,18,July,2016,08:46:25:53327
Address 09,5Q0 937 086 AK,channel (5)-Leuchte27NSL RC6-Lichtfunktion B 27,adapted from,nicht aktiv ,to,Parklicht rechts ,Monday,18,July,2016,08:51:52:53327
Address 09,5Q0 937 086 AK,channel (5)-Leuchte27NSL RC6-Lichtfunktion B 27,adapted from,nicht aktiv ,to,Parklicht rechts ,Monday,18,July,2016,09:16:33:53327
Address 5F,3G0 035 043 B,channel (81)-Car_Function_Adaptations_Gen2-menu_display_compass,adapted from,not activated ,to,activated ,Monday,18,July,2016,09:21:26:53327
Address 5F,3G0 035 043 B,channel (83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,adapted from,not activated ,to,activated ,Monday,18,July,2016,09:21:59:53327
Address 5F,3G0 035 043 B,channel (41)-Car_Function_List_BAP_Gen2-compass_0x15,adapted from,not activated ,to,activated ,Monday,18,July,2016,09:22:26:53327
Address 5F,3G0 035 043 B,channel (265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,adapted from,activated ,to,not activated ,Monday,18,July,2016,09:24:44:53327
Address 5F,3G0 035 043 B,channel (262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,adapted from,activated ,to,not activated ,Monday,18,July,2016,09:24:59:53327
Address 5F,3G0 035 043 B,channel (263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,adapted from,activated ,to,not activated ,Monday,18,July,2016,09:25:17:53327
Address 5F,3G0 035 043 B,channel (264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,adapted from,activated ,to,not activated ,Monday,18,July,2016,09:26:42:53327
Address 5F,3G0 035 043 B,channel (264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,adapted from,activated ,to,not activated ,Monday,18,July,2016,09:28:43:53327
Address 5F,3G0 035 043 B,channel (263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,adapted from,not activated ,to,activated ,Monday,18,July,2016,09:28:59:53327
Address 5F,3G0 035 043 B,channel (1)-Testmode_Video_speed_cutoff-speed_limit,adapted from,0 km/h,to,200 km/h,Monday,18,July,2016,09:29:57:53327
Address 17,5G1 920 758 A,channel Ignition active message actuator,adapted from,Driver door ,to,No display ,Monday,18,July,2016,09:31:37:53327
Address 09,5Q0 937 086 AK,channel (6)-Leuchte28RFL LC11-Dimmwert AB 28,adapted from,100 ,to,145 ,Monday,18,July,2016,09:34:41:53327
Address 09,5Q0 937 086 AK,channel (6)-Leuchte29RFL RA64-Dimmwert AB 29,adapted from,100 ,to,145 ,Monday,18,July,2016,09:35:20:53327
Coding Log:
Address 5F,3G0 035 043 B,recoded (Long Coding),from,027302010000000051110002000808001F0207F401200100DF,to,028402010000000051111202008908001F0200F401200100FF,(00028/028/00067),Sunday,17,July,2016,13:04:51:53327
Address 5F,3G0 035 043 B,recoded (Long Coding),from,027302010000000051110002000808001F0207F401200100DF,to,027302010000000051111102000808001F0207F401200100DF,(00028/028/00067),Sunday,17,July,2016,13:22:18:53327
Address 5F,3G0 035 043 B,recoded (Long Coding),from,027302010000000051110002000808001F0207F401200100DF,to,027302010000000051110002000908001F0307F401200100DF,(00028/028/00067),Sunday,17,July,2016,13:22:56:53327
Address 17,5G1 920 758 A,recoded (Long Coding),from,07AD10182F80000801886A011400000000000000,to,07AD10182F80000801886E011400000000000000,(00028/028/00067),Sunday,17,July,2016,13:35:36:53327
Address 09,5Q0 937 086 AK,recoded (Long Coding),from,00511A46C24122F30BA44080B11C07281800000000000000000000000000,to,00511A46C27922F30BA44080B11C07281800000000000000000000000000,(00028/028/00067),Sunday,17,July,2016,15:32:51:53327
Address 01,5G0 906 259 J,recoded (Long Coding),from,091D00122466050B3000,to,091D0012246605033000,(00028/028/00207),Sunday,17,July,2016,15:40:00:53327
Address 08,5G0 907 044 BD,recoded (Long Coding),from,02020024200100011005000000101002,to,02020024200100091005000000101002,(00028/028/00067),Monday,18,July,2016,09:38:13:53327
Address 08,5G0 907 044 BD,recoded (Long Coding),from,02020024200100091005000000101002,to,02020024200100051005000000101002,(00028/028/00067),Monday,18,July,2016,09:39:13:53327
Address 08,5G0 907 044 BD,recoded (Long Coding),from,02020024200100051005000000101002,to,02020024200100011005000000101002,(00028/028/00067),Monday,18,July,2016,09:40:08:53327
Address 09-02,5Q0 955 547 A,recoded (Long Coding),from,90A8DD,to,94A8DD,(00028/028/00067),Monday,18,July,2016,19:35:51:53327
Address 09-02,5Q0 955 547 A,recoded (Long Coding),from,90A8DD,to,94A8DD,(00028/028/00067),Monday,18,July,2016,19:36:22:53327
Address 19,5Q0 907 530 AF,recoded (Installation List),from,01D43C1000000600400C9000,to,01D43C1000000700400C9000,,Monday,18,July,2016,19:41:31:53327
Address 19,5Q0 907 530 AF,recoded (Installation List),from,01D43C1000000700400C9000,to,01D43C1000000600400C9000,,Monday,18,July,2016,19:45:14:53327
