Steering wheel fault code?
pebjr
North Carolina, USA
C?ID=194904
I ran a scan on my 09 Jetta tdi after replacing a glow plug. I cleared the CEL and drove it with out any problems. Afterwards I rescan my car and this showed up. The CEL remained off and there was no problem with the performance of the car or handling of it.
Any suggestions of what this might be?
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 057 0101
Coding: 0012021
Shop #: WSC 00066 000 00000
VCID: 8429E99AC7C0AD3E3FF-80D1
Component: E0221 002 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
You will be asked to post a full Auto-Scan (inside [CODE ] your full scan [/CODE ] tags without the spaces) not just the faults found as there are more details shown. All the codes are in Ross-Tech Wiki apart from 00885.
VAG Error Code: 00885
Fault Location:
Ignition/Starter Switch D (Terminal 50) - Electrical Fault in Circuit - Intermittent
Possible Cause:
Operating problems.
Loose contact.
Corrosion at plug connections.
Switch defective.
Possible Solutions:
Test wiring.
Check connector(s).
Replace switch.
Keithuk
C?ID=122432
Sorry drpeter I searched for that error code and nothing showed else I wouldn't have posted that.
jakematic
NC USA
C?ID=129085
I think he means this notation on the wiki :)
Acknowledgments
Some content contributed by Keithuk
Keithuk
C?ID=122432
Yes I've just read that Jake, thanks drpeter.
Now it not a criticism but an observation there are a lot of code missing from Wiki as its a great site. I would have to email you my app so you could check them all 10,000 +.
