polo esp 8.0 coding
Shafo
South Africa
C?ID=163752
hello dear friends
I have a funny one today
polo 9n 1.9tdi
customer brought in complaining about abs and tc light on dash
first scan revealed low voltage to abs pump and I thought its a simple blown fuse ..get to the front and indeed abs main fuse is blown...I replace and clear faults...
abs lights reappears and this is what I find
vehicle is manual btw
so I assume somebody incorrectly coded this abs module or perhaps ecu has been remapped?
will appreciate any advice
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Wednesday,13,July,2016,12:07:45:48700
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: AAVZZZ9NZ6U013546   Mileage: 350500km-217790miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 PJ
   Component: 1,9l R4 EDC G000SG  2631
   Coding: 00002
   Shop #: WSC 31414
   VCID: 6ED5763F2A29394E9C-4AE6
   AAVZZZ9NZ6U013546     VWZ7Z0E2203971
18263 - Powertrain Data Bus
            P1855 - 35-10 - Software Version Monitoring - Intermittent
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.lbl
   Part No SW: 6Q0 907 379 AH    HW: 6Q0 907 379 AH
   Component: ESP 8.0 front   H03 0001
   Coding: 0000386
   Shop #: WSC 00011 000 00000
   VCID: 0303378B41AB242663-5120
                    Reset counter: 36
                    Mileage: 350507 km
            000 -  -
                    Reset counter: 36
                    Mileage: 350507 km
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 36
                    Mileage: 350507 km
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6ADD7A2F16C1D56EC0-5120
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00AF BN-SG.         1S34
   Coding: 09358
   Shop #: WSC 31414
   VCID: 3C718C772CD59BDE62-5120
01598 - Drive Battery Voltage
   Part No: 6Q0 909 601 F
   Component: 05 AIRBAG VW5       0010
   Coding: 12341
   Shop #: WSC 31414
   VCID: 36659E5F12F9418E94-5120
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 822 M
   Coding: 01148
   VCID: 3B738F6B29DB9CE66B-5120
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70E96847301D2FBE8E-5120
   Part No: 6R0 423 156 B
   Coding: 10110
   VCID: 2F6BAB3BEDA37046D7-5120
Address 45: Inter. Monitor        Labels: 6Q0-951-171.lbl
   Part No: 6Q0 951 171 C
   Component: Innenraumueberw.    0020
   VCID: 326DA24FFE915DAEB8-5120
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 66 Komfortgerát     0002
   Coding: 00016
   Shop #: WSC 31414
   VCID: 3D77817337CF92D655-4B00
Address 56: Radio        Labels: 1J0-035-15x-56.lbl
   Part No: 6Q0 035 186 A
   Component:  Radio FF6         0001
   Coding: 00403
   Shop #: WSC 31414
   VCID: 2F6BAB3BEDA37046D7-51B2
End-------------------------(Elapsed Time: 02:51)--------------------------
also I thought id try to do the coding on the abs but there is no coding helper so that's not happening
Shafo
South Africa
C?ID=163752
Help please :(
vagtuning
VCDS Super-User
C?ID=57100
Try recoding gatewy with same value, cycle Ignition and look if changed
Or try coding 443 for ABS
